Problem with coding multi command
Greetings to coding masters
I created the arduino code below and haven't found a solution.
Maybe someone is kind and can help me.
The problem that is unfinished and cannot be solved is in the last condition, namely the AFTER_LS1 condition. Where the command for "No action should occur if PB_forward is pressed" is not implemented so that when in this condition we press the PB_forward button the result remains active.
The scheme, components and process are as herebelow:
Description: An Arduino UNO connected to four push buttons (PB_stop, PB_reverse, PB_forward, PB_LS1) and two relays (relay_reverse, relay_forward). The initial state has all relays off.
Conditions:
REVERSE Condition:
If relay_forward is inactive,
When PB_reverse is pressed, activate relay_reverse.
No action should occur if PB_forward is pressed.
FORWARD Condition:
If relay_reverse is inactive,
When PB_forward is pressed, activate relay_forward.
No action should occur if PB_reverse is pressed.
STOP_ALL Condition:
When PB_stop is pressed, turn off both relay_reverse and relay_forward.
LS1 Condition:
If relay_forward is active,
When PB_LS1 is pressed, turn off relay_forward
AFTER_LS1 Condition:
If LS1 Condition was occured,
// Pin Definitions
#define PB_reverse 2
#define PB_forward 3
#define PB_stop 4
#define PB_LS1 5
#define relay_reverse 6
#define relay_forward 7
// Variable Definitions
bool relay_reverse_active = false;
bool relay_forward_active = false;
bool LS1_condition_occurred = false;
  // Initialize Serial Communication
  // Set Pin Modes
  pinMode(PB_stop, INPUT);
  pinMode(PB_reverse, INPUT);
  pinMode(PB_forward, INPUT);
  pinMode(PB_LS1, INPUT);
  pinMode(relay_reverse, OUTPUT);
  pinMode(relay_forward, OUTPUT);
  // Check for PB_reverse Press
  if (digitalRead(PB_reverse) == HIGH && !relay_forward_active) {
    digitalWrite(relay_reverse, HIGH);
    relay_reverse_active = true;
  // Check for PB_forward Press
  if (digitalRead(PB_forward) == HIGH && !relay_reverse_active) {
    digitalWrite(relay_forward, HIGH);
    relay_forward_active = true;
  // Check for PB_stop Press
  if (digitalRead(PB_stop) == HIGH) {
    digitalWrite(relay_reverse, LOW);
    digitalWrite(relay_forward, LOW);
  // Check for PB_LS1 Press
  if (digitalRead(PB_LS1) == HIGH && relay_forward_active) {
    LS1_condition_occurred = true;
  // Check for PB_forward Press after LS1 Condition
  if (digitalRead(PB_forward) == HIGH && LS1_condition_occurred) {
    // No action should occur
Hello harkelumum
One solution could be to design a ButtonManager that executes a function when the corresponding button becomes pressed.
such button wiring is dangerous, shortcut possible.
Relay switching should be designed to break-before-make (open-before-close) to avoid this.
two relays should better be switching and be connected as H-bridge
Hello harkelumum
Take a view here to gain the knowlege about button and LED wiring.
Please say you're not driving the relays directly with the UNO outputs. No kickback diodes across the relay coils visible.
so this just turns off both relays, but enters an AfterLS1 state
and in this AfterLS1 state, the forward button is ignored but not the reverse and stop buttons.
but how is the AfterLS1 state exited?
