Arduino Driver Install "A service installation section in this INF is invalid."
Just wanted to say that I was able to reproduce the error using Win 10 and having the Uno in DFU mode which then wanted drivers for the Atmega16u2 chip.
I am guessing your board probably doesn’t have the usb firmware loaded.
It is too bad you have run into this problem so early in your journey and it will be much easier to just return the board.
But, if you want some more fun, I would try one of the examples I will point you to.
I have used this one a few times and I like it because it uploads both the DFU program and the USB-firmware at the same time. You would have to turn your other Arduino into an "Arduino as ISP" or get a ISP programmer like a USBasp.
If your Arduino has the DFU program loaded, and I think yours does, it would also be doable using Flip.
I just used this today and it worked great for uploading the USB-firmware. You don't have to solder anything on the newer Arduinos.
Doesn't the Uno have a different VID/PID than 2A03/0043 when it's in DFU mode? On my Uno with the .org firmware installed on the ATmega16U2, the VID/PID when in DFU mode is 03EB/2FEF. krasnejv reported their VID/PID was detected as 2A03/0043. No word from ingineer_74.
I agree, the VID/PID 2A03/0043 changes when you go to the DFU mode and I also loaded the .org firmware. At the first of the thread they were both trying to get drivers for the Atmega16u2 and the only time you should even see the 16u2 is when you are in DFU mode as far as I know.
Anyway, this has been driving me crazy as I have followed the thread and I tried to come up with something else to check.
Hello kprims and thanks for the suggestions. I mean what's the worst that I can do--break a broken board?
I would like to try the procedure using FLIP first, however the link that he gives for the FLIP app is not valid. When I click on http://www.atmel.com/tools/FLIP.aspx it takes me to https://www.microchip.com/.
I've tried searching the web and can't seem to find it. Can someone point me to FLIP?
The procedure from instructables uses point to point wiring and I don't have the female to female wires to make those connections.
So if I can find the FLIP app, I could try that. If someone could point to where I could get it I would appreciate it. Thanks.
John
krasnejv:
Here it is:
Microchip broke all the old URLs after they bought Atmel.
krasnejv:
You can use male to female wires as well. You just need to make the right connections to the female headers on your Uno. There is a table on this page that shows the Arduino pins that correspond to each of the pins on the 2x3 ICSP header under the "Connections" section of this page:
I very much recommend buying a selection of the male to male, male to female, and female to female jumper wires. They come in very handy for playing with Arduino.
Hi all:
ingineer_74 here...
I haven't been on this thread since Friday evening...looks like there has been a lot of activity/progress since then.
I was also able to get my board to sort of work and open up the COM port and get Windows to "see" the Arduino board. However, when I get into the IDE and try to upload the Blink Sketch, it hangs and attempts to load the Sketch 10 times with no success. (see attached verbose text file that was saved and Device Manager and Hardware IDs)
Any ideas? I think my board has been damaged...what is interesting is the Green and L Yellow/Amber LED stay lit when plugging in the USB cable and also when I hit the Reset button.
I'll look at some of the previous posts here to see if there may be something there that may help with my issue.
ArduinoIDE_Compilation and Upload verbose info.txt (29.6 KB)
Hi pert.
Thanks. I only have the bare-wire-end male to male that came with the kit. I'll have to get some of the others.
John
ingineer_74:
Well, I don't know that you can call it progress, but activity for sure.
ingineer_74's Hardware_IDs.PNG:
So your board does not have the arduino.org VID/PID like krasnejv's board. In addition to my test with installing the drivers after installing the .org firmware on my Uno's ATmega16U2, that makes me think the .org VID/PID has nothing to do with the "A service installation section in this INF is invalid." error you both encountered.
ingineer_74's upload error:
Arduino: 1.8.9 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b115200 -D -Uflash:w:C:\Users\tjend\AppData\Local\Temp\arduino_build_428674/Blink.ino.hex:i
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM6
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x7f
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x7f
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x7f
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x7f
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x7f
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x7f
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x7f
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x7f
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x7f
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x7f
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
ingineer_74's Windows_Device_Manager_Info.PNG:
So you do have the correct board and COM port selected (potential causes of this error).
Do you have any shield or wiring connected to your board? If so, disconnect it and try uploading to just the Uno alone.
If your Uno doesn't have one of those nifty plastic bases, make sure it's not sitting on any conductive object that could short out the contacts on the bottom of the board.
ingineer_74:
Does the LED marked "L" blink after you do that?
Hi Pert...yes agreed a lot of activity for sure.
Anyway, I’m not using anything connected to the board such as shields or any wiring...just the board as stand-alone as pulled right out of the starter kit box. I place it directly on top of its little box to ensure it’s not sitting on anything conductive.
As for the L LED, it never blinks when hitting the Reset button(or plugging in usb cable). Stays solid yellow.
Hi pert,
OK, I FLIPed the bad board and now it is COM4 with a hardware ID of:
USB\VID_2341&PID_0043&REV_001
However, when I try to load the Blink example sketch, it never finishes the upload and gives the results in the attached text file. So I guess I'm at the same place that ingineer_74 is. The board is stand-alone on the plastic mount. Could it be that the microprocessor needs to be flashed also?
John
Problem Uploading.txt (8.44 KB)
The L LED should blink rapidly after releasing the Reset button. If it doesn't, you probably need to re-burn the boot-loader for the m328p chip.
It sucks to get your first gear this screwed up. I have mostly Chinese Clones, but have never received anything that didn't have the right firmware.
The LED stays on all the time. How do you re-burn the boot-loader for the m328p chip?
This one requires another Arduino set up as "Arduino as ISP"
https://www.arduino.cc/en/tutorial/arduinoISP
When I started out, this one helped me to get going. I still use the cable set up for "Arduino as ISP".
Now days I usually use a USBasp with Alpha firmware for burning bootloaders.
https://forum.arduino.cc/index.php?topic=363772.0
There are also several U-tube videos out there.
Help will be available if you run into problems.
kprims,
Thanks for the information. I'm sorry that I put you through the extra work. I realized after I posted that I should have looked it up myself (Google it, dummy!!!). Anyway, thanks again for the links.
John
No problem. There is a lot of outdated information out there and for the most part, these sections worked for me.
I tried installing the bootloader with no success. I carefully checked the wiring as given in the Arduino Web page. I was able to load the ISP sketch to the programmer board, but when I burn bootloader it stops with an error.
One thing--the chip on my good board is an ATmega328P-PU and the chip on the target board is an ATmega328P U. I see from another source on YouTube Burn a Bootloader onto Arduino Uno - YouTube that there is a file called avrdude.conf where a HEX number might need to be changed. If I am reading his table correctly, a "0x0F" needs to be changed to "0x14" in the file. I tried changing that value, but then the Arduino as ISP sketch gave an error while uploading.
I don't know what to do next.
It would help to see the error.
I should mention the Arduino as ISP now requires a 10uF capacitor between Reset and Gnd, the stripe toward Gnd.
You should get to the point where you are told the chip signature is wrong
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: Expected signature for ATmega328 is 1E 95 14
         Double check chip,
You are going to have a great Arduino background before you ever run one of your own sketches. :slight_smile:
I tried again. This time I was able to upload ArduinoISP and burn bootloader without any errors.
However, when I disconnect everything and try to upload Blink, I get an error as shown in the attached text file. The Uno is recognized and is COM4.
The guy in the Youtube video says that you don't need the 10uF cap after Arduino 1.0.5. I hope that's true, because I don't have a 10uF cap.
Error.txt (8.44 KB)
If you got the bootloader burned, the L Led should be working correctly.
Most Arduinos need the 10uF capacitor again. Seems what goes around comes around. They changed to using -c arduino a couple of IDE issues ago and this resets the "Arduino as ISP" if we are missing the capacitor.
I tried the bootloader 4 times and it still doesn't work. I'll try to locate the capacitor, but it may take some time.
