Arduino Due interface with Arduino Ethernet Shield 2 Board : Need help
Hi Sir,
I am Planning to work Arduino Due to interface with Ethernet Shield 2 board (With Wiznet Controller W5500) (SPI Port). Kindly let us know the Ethernet Shield library will support for Arduino Due to interface with Ethernet Shield 2 board? Kindly help on this.
yes and I think you asked this already
Yes Sir. I asked the compatibility of hardware in other thread. I have to know that the Ethernet shield library will support for Due board also.
the Ethernet shield is compatible with Due and Uno R4
the shield works with any board with matching pinout and the Ethernet library works with any platform with proper Arduino SPI library
Hi sir,
I have the Following boards:
Arduino Due:
Arduino Ethernet Shield 2 Board:
Can i connect Directly the Arduino Due + Ethernet Shield 2 board to test the Ethernet shield library as I did in Arduino Mega + Ethernet Shield 2 board? Kindly let us know.
Image attached for Interfacing the Mega + Ethernet Shield 2 board for your reference.
Screenshot from 2023-08-12 17-05-30
In the Same way, the Due + Ethernet Shield 2 board can be connected?
yes
