is it possible to program the arduino due while using the Native USB port (not programing), and to set one of the pins to logical "HIGH"/"LOW"?
or the arduino is read only while on the native USB port is being used?
Huh? Yes, it is possible to program the Due through the native USB port and you do not need the IDE to do this. Bossac is a command line program you can use to program the Due. If you want official tools there is also SAM-BA. Or, you can use JTAG but that's not through the native USB port. But, I don't know what you mean by setting one of the pins to logical high/low. What does that have to do with programming the Due? You mean you want to upload a sketch that does that? Without the Arduino core files?
I successfully managed to programm my DUE via Atmel Studio 7 following along this guide for Atmel Studio 6 http://codetron.net/arduino-due-in-atmel-studio-using-c-led-blinking/
Programming port though.
Perhaps OP means drive the pins directly, in real-time, without programming - using the native USB port as a direct command port?
If that is so, one could, of course, write code to read data from the native USB port and set output pins accordingly..
I dunno, just a wild guess.
