Arduino DUE TFT screen compatibility
hi guys this is my first post so i will introduce myself i´m an electronic engineering student, from Guatemala.
I´m planning to buy this:
http://www.amazon.com/gp/product/B00EQ1UP9K/ref=oh_details_o03_s00_i00?ie=UTF8&psc=1
I was wondering if this works with the DUE and if it doesn´t which screen would you recommend me to buy.
thanks for the help.
i borrowed one from my friend and found out this module works with arduino DUE, well at least a basic example i´ll run further tests
First of all, I recommend using this shield that is compatible with the DUE.
"http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=121057447668".
It is compatible with both Standard 40 pin And 32 pin Displays. Make sure you check the pin out before you purchase.
It eliminates most of the compatibility problems that arise along with all the jumper wires that would be needed.
There is also a list of compatible boards that is in that Size and price range In the listing. Most of these boards are UTFT Library compatible.
Check with "Electronics - Henning Karlsen" For compatibility list.
Hope this helps.
Joe.
