i'm building a simple piano using a due. what i have so far is an sd shield with a wav file, and a button that is supposed to play the file every time it is pressed. whenever i reset the board, the first press works great, but any next one comes out buffered and messed up. i believe it has something to do with the buffer not resetting after playing the file, but i don't understand how to do it.
#include <SD.h>
#include <SPI.h>
#include <Audio.h>
struct Key
int keyPin;
int ledPin;
File noteAudio;
Key key;
bool key_released;
int volume;
const int S=1024; // Number of samples to read in block
short buffer[S];
key.keyPin = 36;
pinMode(key.keyPin,INPUT_PULLUP);
// debug output at 9600 baud
pinMode(53, OUTPUT);
// setup SD-card
Serial.print("Initializing SD card...");
if (!SD.begin(53))
Serial.println(" failed!");
return;
Serial.println(" done.");
// hi-speed SPI transfers
SPI.setClockDivider(53);
// 44100Khz stereo => 88200 sample rate
// 100 mSec of prebuffering.
Audio.begin(88200, 100);
key.noteAudio = SD.open("test.wav");
// until the file is not finished
//Serial.println(digitalRead(key.keyPin));
if (digitalRead(key.keyPin)==LOW && key_released)
{ key_released=false;
while (key.noteAudio.available() ) {
//Serial.println("Playing file...");
// read from the file into buffer
key.noteAudio.read(buffer, sizeof(buffer));
// Prepare samples
volume = 1024;
Audio.prepare(buffer, S, volume);
// Feed samples to audio
Audio.write(buffer, S);
// memset(buffer,0,S);
key.noteAudio.close();
if (digitalRead(key.keyPin)==HIGH) key_released=true;
