I'm testing the Edge control board and I discovered that sometimes the Function that controls the on-board solid-state relay fails: When I send the commands the device doesn't recognize them, so the control program is not sure about the state of the device. I'm working in the following conditions:
I'm using the Edge control Library
I'm using the SSRs with a common voltage of 24Vdc ( f= 0Hz)
Hello, do yourself a favour and please read How to get the best out of this forum and modify your post accordingly (including code with code tags and necessary documentation (links to parts, drawing of your circuit, power supplies etc ) for your ask).
