Arduino Error "Sketch uses 966 bytes (2%) or program storage space. Maximum is 32256 bytes. Global variables use 9 bytes (0%) of dynamic memory,
I have begun Arduino recently and just started coding. When I was trying to do a simple LED code it gave me this error on my screen. I have tried the old bootloader option but still didn't work. I was hoping that someone here knew the solution to this.
Make sure you have the correct board and port selected.
Pictures are not acceptable.
  • In the Arduino IDE, use Ctrl T or CMD T to format your code then copy the complete sketch.
  • Use the < CODE / > icon from the ‘posting menu’ to attach the copied sketch.
  • Paste the error report.
As @LarryD tells, please post information according to How to get the best out of this forum - Using Arduino / Project Guidance - Arduino Forum
Screen shots are seldomly a good alternative.
Regarding code many helpers load it into the IDE, compile and check things. For that, screen shots are useless.
New games, new bets. Come on!
I have checked it is on the right port.
Please remove the screen shot and post the error messages as text, using code tags.
Copy your "output" and paste it here... (use the < CODE > button and "type or paste code here..."
Sketch uses 966 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
Hopefully the Op will read the guidelines after so many hints.
