Hello
I am trying to do the EVSE project in the link below.
Project made with Atmega328P. I am using Atmega. But I am having problem with ADC signals.
The analog value that should be at 12V is 245-327 . The value I got is meaningless ( ex 0-145)
Can you help on the subject?
ISR(ADC_vect)
unsigned char adcl = ADCL;
unsigned char adch = ADCH;
switch(ADC_Channel) {
case 0:
GFCI_ADC = (adch << 8) | adcl;
case 1:
Pilot_Low_ADC = (adch << 8) | adcl;
case 2:
Pilot_High_ADC = (adch << 8) | adcl;
Full Code
/* EV Charger software
* James Fotherby 20th April 2022
* At Power On:
* 1) Ensure relays are open, configure PWM and ADC for running in the background
* 2) Perform GFCI test
* 3) Enter State_A
* Status A: (No vehicle present) CP: DC +12v -
* Status B: When a vehicle is plugged in, a diode and resistor pull the DC +12v down to about +9v. We then start our 1khz PWM signal
* Status C: When a vehicle is ready and wants to charge it'll pull the positive side of the PWM down further to 6v (or 3v). This prompts us to close the relays after another GFCI test
* We use timer 1 to output generate our PWM/DC voltage
* We synchronise our ADC readings to using Timer1 interrupts to read the low and high PWM regions and we continuously read the GFCI ADC
* These are the list of faults that we detect:
* 1) STARTUP GFCI TEST FAIL
* 2) GFCI DETECT
* 3) DIODE FAULT
* 4) VOLTAGE CLASS FAULT
* 5) START CHARGE GFCI TEST FAIL
* Changes:
* - 4/5/2022 - Added 4 second WDT reset
* - 22/5/2022 - Fixed bug in Timer interrupt which alternates the ADC channels
* - changed required successive faults from 100 to 10
// Pin definitions
#define Relay_1_Pin 7
#define Relay_2_Pin 8
#define Pilot_PWM_Pin 10
#define GFCI_Test_Pin 11
#define Indicator_LED 13
#define GFCI_ADC_Pin A0
#define Pilot_ReadADC_Pin A1
// State and fault definitions
#define STATE_A 1 // No EV connected
#define STATE_B 2 // EV Connected but not charging
#define STATE_C 3 // Charging
#define CHARGE_PWM_DUTY 350 // Seems to result in 7.4 kW charging rate for me. (Lower numbers = higher duty cycle and charge rates)
#define _12_VOLTS 12
#define _9_VOLTS 9
#define _6_VOLTS 6
#define _3_VOLTS 3
#define _DIODE_FAULT 1
#define _FAULT 0
#define FAIL 0
#define PASS 1
#define STARTUP_GFCI_TEST_FAIL 2
#define GFCI_DETECT 3
#define DIODE_FAULT 4
#define VOLTAGE_CLASS_FAULT 5
#define START_CHARGE_GFCI_TEST_FAIL 6
// ADC ranges for classifying voltage levels (923 = 12v and 285 = -12v)
#define POS_12V_MAX 923 // 12.5V
#define POS_12V_MIN 895 // 11.5V
#define POS_9V_MAX 868 // 10V
#define POS_9V_MIN 815 // 8V
#define POS_6V_MAX 789 // 7V
#define POS_6V_MIN 735 // 5V
#define POS_3V_MAX 708 // 4V
#define POS_3V_MIN 656 // 2V
#define NEG_12V_MAX 327
#define NEG_12V_MIN 245
#define GFCI_FAULT_THRESHOLD 250 // This is the ADC value that beyond which trips our GFCI detection system
#define GFCI_FAULT_ABORT_THRESHOLD 500 // If it's taking longer than this to test our GFCI it's clearly failing to work
#define FAULT_COUNT_THRESHOLD 10 // We have to have 10 successive trivial faults to trip out.
// Librarys
#include <avr/wdt.h>
// Global variable definitions (Globals are bad - I know!)
volatile int Pilot_Low_ADC;
volatile int Pilot_High_ADC;
volatile int GFCI_ADC;
volatile byte ADC_Channel = 0;
void Close_Relays();
void Open_Relays();
byte Read_Pilot_Voltage();
byte GFCI_Test();
void Fault_Handler(byte Fault_type);
noInterrupts();
Serial1.begin(115200);
Serial1.println("starting up...");
pinMode(Indicator_LED, OUTPUT);
// Configure Relay outputs
Open_Relays();
// Configue Pin 10 for PWM output 1kHz.
pinMode(Pilot_PWM_Pin, OUTPUT);
ICR1 = 1000; // A 16MHz XO with a 1/8 prescaler and 1/1000 up/down (phase correct) count leads to a 1kHz PWM wave.
TCCR1A = 0b00100010;
TCCR1B = 0b00010010; // Timer 1 configured for PWM Phase correct with OC1B enabled non inverting and a 1/8 prescaler
TIMSK1 = 0b00100001; // Enable Interrupts when timer counter at top and bottom (ie. middle of the PWM high and low sections)
OCR1B = 0; // Output +12v DC on the pilot
// Configure ADC Module
ADMUX = B01000000; // Set V_Ref to be AVcc, Set channel to A0
ADCSRA = B10001111; // Enable ADC, Enable conversion complete interrupt, set 128 Prescaler -> ADC Clk = 125KHz
// Enable Watch Dog
wdt_enable(WDTO_4S);
wdt_reset();
interrupts();
// Perform GFCI test
if(GFCI_Test() != PASS) {
Fault_Handler(STARTUP_GFCI_TEST_FAIL);
// OCR1B = CHARGE_PWM_DUTY;
// while(1) {
// delay(100);
// Serial.print(Pilot_Low_ADC); Serial.print(", "); Serial.print(Pilot_High_ADC); Serial.print(", "); Serial.println(GFCI_ADC);
// Ready to start main loop
Serial1.println("Starting in State A");
static byte Current_State = STATE_A;
static byte PVC;
wdt_reset();
PVC = Read_Pilot_Voltage();
Serial1.println(""); // PVC = Pilot Voltage Classification
Serial1.print("PVC = ");
Serial1.print(PVC);
Serial1.print("Pilot_Low_ADC = ");
Serial1.println(Pilot_Low_ADC);
Serial1.print("Pilot_High_ADC = ");
Serial1.println(Pilot_High_ADC);
Serial1.println("#########");
// ---- Fault detection --------------------------------------------------------------------------------
/* if(GFCI_ADC > GFCI_FAULT_THRESHOLD)
Fault_Handler(GFCI_DETECT);
if(PVC == _DIODE_FAULT)
Fault_Handler(DIODE_FAULT);
/*if(PVC == _FAULT)
Fault_Handler(VOLTAGE_CLASS_FAULT);*/
//Serial.println(Pilot_Low_ADC);
// ---- Main State machine logic -----------------------------------------------------------------------
switch (Current_State) {
case STATE_A:
if(PVC == _9_VOLTS or PVC == _6_VOLTS or PVC == _3_VOLTS) {
digitalWrite(Indicator_LED, HIGH);
Serial1.println("State B");
Open_Relays();
Current_State = STATE_B;
case STATE_B:
if(PVC == _12_VOLTS) {
OCR1B = 0;
Serial1.println("State A");
Open_Relays();
else if(PVC == _6_VOLTS or PVC == _3_VOLTS) {
Fault_Handler(START_CHARGE_GFCI_TEST_FAIL);
else {
Serial1.println("State C");
Close_Relays();
Current_State = STATE_C;
case STATE_C:
if(PVC == _12_VOLTS or PVC == _9_VOLTS) {
Open_Relays();
static int Fault_Count = 0;
static int Previous_Value = _12_VOLTS;
// Here we take the Pilot voltages and classfy them into states
if((Pilot_Low_ADC > NEG_12V_MIN and Pilot_Low_ADC < NEG_12V_MAX) or OCR1B == 0) {
if(Pilot_High_ADC > POS_12V_MIN and Pilot_High_ADC < POS_12V_MAX) {
Previous_Value = _12_VOLTS; Fault_Count = 0;
return(_12_VOLTS);
else if(Pilot_High_ADC > POS_9V_MIN and Pilot_High_ADC < POS_9V_MAX) {
Previous_Value = _9_VOLTS; Fault_Count = 0;
return(_9_VOLTS);
else if(Pilot_High_ADC > POS_6V_MIN and Pilot_High_ADC < POS_6V_MAX) {
Previous_Value = _6_VOLTS; Fault_Count = 0;
return(_6_VOLTS);
else if(Pilot_High_ADC > POS_3V_MIN and Pilot_High_ADC < POS_3V_MAX) {
Previous_Value = _3_VOLTS; Fault_Count = 0;
return(_3_VOLTS);
else {
// The measured voltage is out of any expected range. We call this a fault condition
Fault_Count++;
if(Fault_Count > FAULT_COUNT_THRESHOLD)
return(_FAULT);
return(Previous_Value);
else {
// Diode fault - the negative PWM should always be -12v, if it's not we have a diode missing fault!
Fault_Count++;
return(_DIODE_FAULT);
byte GFCI_Test() // This routine energises the test coil on the current transformer using a 50Hz square wave
pinMode(GFCI_Test_Pin, OUTPUT);
delay(100);
unsigned long GFCI_TimeDiff, GFCI_Timestamp = millis();
while(1) {
digitalWrite(GFCI_Test_Pin, HIGH); delay(10);
digitalWrite(GFCI_Test_Pin, LOW); delay(10);
GFCI_TimeDiff = millis() - GFCI_Timestamp;
if(GFCI_ADC > GFCI_FAULT_THRESHOLD or GFCI_TimeDiff > GFCI_FAULT_ABORT_THRESHOLD)
pinMode(GFCI_Test_Pin, INPUT);
Serial.print("Ground fault detection time: "); Serial.print(GFCI_TimeDiff); Serial.println(" ms");
delay(500); // Allows time for the GFCI circuitary to decay to zero
if(GFCI_TimeDiff < 100) {
Serial.println("GFCI Test Successful");
return(PASS);
else {
Serial.println("GFCI Test Unsuccessful");
return(FAIL);
Serial1.println("GFCI Test Successful");
return(PASS);
Open_Relays();
OCR1B = 0;
//Serial.println("FAULT: "); Serial.print(Fault_type);
while(1) {
delay(100);
delay(100);
digitalWrite(Indicator_LED, LOW);
wdt_reset();
void Close_Relays()
pinMode(7, OUTPUT); pinMode(8, OUTPUT);
digitalWrite(7, HIGH); digitalWrite(8, HIGH);
void Open_Relays()
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
digitalWrite(7, LOW);
digitalWrite(8, LOW);
// This code runs when the PWM signal is in the middle of its low period
ISR(TIMER1_OVF_vect)
static byte selector = 0;
if(ADCSRA & 0b01000000) // If the ADC is still performing a conversion (it shouldn't be) then return
return;
if(selector) {
ADMUX = B01000000;
ADCSRA |= B01000000;
ADC_Channel = 0;
selector = 0;
else {
ADMUX = B01000001;
ADC_Channel = 1;
selector = 1;
// This code runs when the PWM signal is in the middle of its high period
ISR(TIMER1_CAPT_vect)
return;
if(selector) {
ADMUX = B01000000;
ADC_Channel = 0;
selector = 0;
else {
ADMUX = B01000001;
ADC_Channel = 2;
selector = 1;
// Interrupt service routine for ADC conversion complete
ISR(ADC_vect)
case 0:
case 1:
case 2:
