arduino frezes when stuff is conected to 3.3v
(im using spi but the problem occurs with simple electronics as well)
for some reason my arduino nano hates 3.3v and whenever I use it it freaks out, the arduino disconnects from the computer and wont revive new sketches and wont send data back to the pc along with that the entire arduino sketch freezes, I have a youtube link to what happens here odd arduino spi problems - YouTube
the wireing is is done according to this video
here is my sketch
#include <SD.h>
#include <SPI.h>
int CS_PIN = 10;
File file;
  initializeSD();
  createFile("test.txt");
  writeToFile("This is sample text!");
  closeFile();
  openFile("prefs.txt");
  Serial.println(readLine());
  closeFile();
void initializeSD()
  Serial.println("Initializing SD card...");
  pinMode(CS_PIN, OUTPUT);
  if (SD.begin())
    Serial.println("SD card is ready to use.");
  } else
    Serial.println("SD card initialization failed");
    return;
int createFile(char filename[])
  file = SD.open(filename, FILE_WRITE);
  if (file)
    Serial.println("File created successfully.");
    return 1;
  } else
    Serial.println("Error while creating file.");
    return 0;
int writeToFile(char text[])
  if (file)
    file.println(text);
    Serial.println("Writing to file: ");
    Serial.println(text);
    return 1;
  } else
    Serial.println("Couldn't write to file");
    return 0;
void closeFile()
  if (file)
    file.close();
    Serial.println("File closed");
int openFile(char filename[])
  file = SD.open(filename);
  if (file)
    Serial.println("File opened with success!");
    return 1;
  } else
    Serial.println("Error opening file...");
    return 0;
String readLine()
  String received = "";
  char ch;
  while (file.available())
    ch = file.read();
    if (ch == '\n')
      return String(received);
      received += ch;
  return "";
When you give links to other sites, or anywhere, please use the link button so your URLs are clickable. Schematic of your project will probably be necessary, along with data sheets and links to the products you are using (sensors, boards, etc.)
Nano has 16 MHz resonator, which require 3.78V min to run fully compliant.
