Arduino getting stuck randomly - 4 program timer
Hello, I'm trying to write a program for my device.
Usually during the timer phase, it can happen once a day, twice a day or even once a week, the program gets stuck and sometimes the relay stays open. Sometimes the program gets stuck when it is not in the timer phase and does not accept any input until it is reset.
It has 4 different programs with different prices and different timers to count. Once the user inserts coin via the coin selector, as a certain balance is reached and the related button is pressed, a timer starts and opens up a relay for that time period.
I'm using an arduino nano, fed by a small 700mA smps, the relay circuit even though it has an opto-isolated scheme, the gnd and 5V pins are from the same source as the arduino.
I think the problem lies in the code because I have used similar hardware setup before but still not so sure, I'm mostly suspicious of the rs485 commands and the progTimer function.
//Parameters of the program
unsigned long previousMillis  = 0;   //Old time point
unsigned long buttonMillis1   = 0;   //Old button point
unsigned long buttonMillisFast1 = 0;
uint8_t  buttonHang1          = 0;  // A hanger for button pressed
uint16_t buttonValue1         = 0;  // Button Analog reader
uint8_t  buttonReading1       = 0;  // Button Digital State
uint8_t  buttonState1         = 0;
uint8_t  lastButtonState1     = 0;
unsigned long buttonMillis2   = 0;  //Old button point
uint8_t  buttonHang2          = 0;  // A hanger for button pressed
uint16_t buttonValue2         = 0;  // Button Analog reader
uint8_t  buttonReading2       = 0;  // Button Digital State
uint8_t  buttonState2         = 0;
uint8_t  lastButtonState2     = 0;
unsigned long setMillis       = 0;      //Old button point
uint8_t  setHang              = 0;      // A hanger for button pressed
uint16_t setValue             = 0;      // Button Analog reader
uint8_t  setReading           = 0;      // Button Digital State
uint8_t  setState             = 0;
uint8_t  lastSetState         = 0;
uint8_t  setCount             = 0;
uint16_t setOnceState    = 0;             // The State variable of coin for Edge Detection
uint8_t setOnceLastState = 0;
uint8_t setOnceInState   = 0;          // The State variable of coin for Edge Detection
uint8_t setInLastState1 = 0;
uint8_t setInLastState2 = 0;
uint8_t setInLastState3 = 0;
uint8_t setInLastState4 = 0;
uint8_t setStateInput   = 0;
uint8_t setStateOutput  = 0;
uint8_t outPinSelect    = 0;
int16_t progTimeMain     = 0;
unsigned long timerMillis = 0;
char myStr[9];
uint8_t stateToLed = 0;
uint8_t balance       = 0;                // Money Balance
uint16_t coinState    = 0;                // The State variable of coin for Edge Detection
uint8_t coinLastState = 0;
uint8_t coinInState   = 0;                // The State variable of coin for Edge Detection
unsigned long panelMillis    = 0;
unsigned long panelMillis1   = 0;
uint8_t but_state_set = 0;
uint8_t but_state_up = 0;
uint8_t but_state_down = 0;
const uint16_t intervalSn     = 1000;
const uint8_t debounceDelay = 40; // Debounce for analog buttons and such
const uint16_t pressedTime = 300; // Debounce for analog buttons and such
const uint8_t dispMillis = 20;           // the refresh ms for the 7 segment displays
const uint8_t dispSelectMillis = 180; // the refresh ms for the 7 segment displays, in select mode
// Inputs - Outputs
uint8_t button_set  = A6;
uint8_t button_up   = A5;
uint8_t button_down = A7;
const uint8_t coinPin     = A4;
const uint8_t input0      = A3;
const uint8_t input1      = A2;
const uint8_t input2      = A1;
const uint8_t input3      = A0;
const uint8_t output1     = 7;
const uint8_t output2     = 5;
const uint8_t output3     = 3;
const uint8_t rs485En     = 2;
The ones given above are the parameters and variables,
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include "HC595AnodeMultiDig.h"
#include "PanelParameters.h"
#include "PanelVariables.h",
#include <EEPROM.h>
#include <SoftwareSerial.h>
#include <avr/wdt.h>
uint16_t dataArray [21] = {0, 0, 0, 0, 0, 0, 0, 102, 202, 87, 47, 4, 8, 8, 8, 0, 0, 0, 0, 0,0};
uint16_t dataStored [21] = {};
uint16_t dataValueLast = 0;
uint16_t baudRate = 9600;
uint8_t i = 0;  // Menu Numbering
uint8_t j = 0;  // Set Enabler
uint8_t rs485ControlState = 0;
uint8_t rsReceiveControl = 0;
uint8_t setActiveControl = 0;
const byte numChars = 10;
uint8_t rs485OutState = 0;
unsigned long constRs485Send = 0;
unsigned long constRs485Send1 = 0;
uint16_t turnoverNon = 0;
uint16_t turnoverT = 0;
const uint8_t rxPin = 6;
const uint8_t txPin = 4;
const char bal[] = "BA";
const char tim[] = "TI";
const char tO[] = "SO";
const char tU[] = "ST";
const char tK[] = "SK";
const char tC[] = "SC";
SoftwareSerial rs485(rxPin, txPin);
//HardwareSerial & rs485 = Serial;
void firstUpdate()
  for (int k = 3; k < 11; k++)
    dataArray[k] = (256*(EEPROM.read(k+20)) + EEPROM.read(k));
  for (int k = 16; k < 20; k++)
  // Writing with only byte values
  for (int k = 11; k < 15; k++){
    dataArray[k] = EEPROM.read(k);
  // To verify the change in variables
  for (int k = 3; k < 20; k++)
    dataStored[k] = dataArray[k];
  rs485.begin(baudRate);
  //Serial.begin(baudRate);
  pinMode(ds_pin, OUTPUT);
  pinMode(stcp_pin, OUTPUT);
  pinMode(shcp_pin, OUTPUT);
  pinMode(rxPin, INPUT_PULLUP);
  pinMode(button_set, INPUT);
  pinMode(button_up, INPUT);
  pinMode(button_down, INPUT);
  pinMode(input0, INPUT);
  pinMode(input1, INPUT);
  pinMode(input2, INPUT);
  pinMode(input3, INPUT);
  pinMode(output1, OUTPUT);
  pinMode(output2, OUTPUT);
  pinMode(output3, OUTPUT);
  pinMode(rs485En, OUTPUT);
  //wdt_disable();
  delay(2000);
  firstUpdate();            // To read the EEPROM values
  //wdt_enable(WDTO_2S);
  // wdt_reset();
  // The Coin reading functions, for it to be displayed, dataarray =
  coinRead(coinPin);
  if (dataArray[0] != balance)
    dataArray[0] = balance;
    rs485Write(bal, balance);
  // send the balance data constantly, within the given interval
  if (millis() - constRs485Send > 2000)
    constRs485Send = millis();
  // send the program data constantly, within the given interval
  if (millis() - constRs485Send1 > 3000)
    rs485Write(tim, setStateOutput);
    constRs485Send1 = millis();
  // The input checker, will reveal the state of the object
  setInputs(input0, input1, input2, input3,
              dataArray[11], dataArray[12], dataArray[13], dataArray[14]);
  progTimer(dataArray[7], dataArray[8], dataArray[9], dataArray[10],
              output1, output1, output2, output3);
  // Menu is only working while the Program is not ON
  if (setStateOutput == 0) {dispMenu();}
  else {
    if (millis() - panelMillis1 > dispMillis)
        stateToLed = num7Convert(setStateOutput);
        dig2Display (0, 49);  dig2Display (1, stateToLed); // P and state
        num7Display (progTimeMain); // Display remaining time
        clearCache();
        panelMillis1 = millis();
      // if set button is pressed, program forcefully terminates
      if (setOnce(button_set))
        setStateOutput = 0;
void updateEEprom_8bit(uint8_t regNo){
  // Scan the arrays for the 8 bit values, compare and update if necessary
  if (dataStored[regNo] != dataArray[regNo])
    dataStored[regNo] = dataArray[regNo];
    EEPROM.update(regNo,(dataStored[regNo]));
void updateEEprom_16bit(uint8_t regNo){
    EEPROM.update(regNo, ((dataStored[regNo])%256));
    EEPROM.update((regNo+20), ((dataStored[regNo])/256));
void rs485Write (char *regText, uint16_t dataValue)
    if (dataValueLast != dataValue)
      dataValueLast = dataValue;
      itoa(dataValueLast, myStr,10);  // The value which will be given for the function
    digitalWrite(rs485En, HIGH); // To allow sending data via RS485
    delay(3);
    rs485.write('<');           // Start the send parameter
    rs485.write(regText);       // Write the fun no first
    rs485.write(myStr);         // Write the data value second
    rs485.write('>');           // End the send parameters
    rs485.flush();              // Wait until sending is finished
    digitalWrite(rs485En, LOW); // Enable receive mode
void rs485DataEqualize()
  if (i == 7)  rs485Write(tO, dataArray[7]);
  if (i == 8)  rs485Write(tU, dataArray[8]);
  if (i == 9)  rs485Write(tK, dataArray[9]);
  if (i == 10) rs485Write(tC, dataArray[10]);
void dispMenu ()
  // Menu limiting
  if (i>15 && i<35) i = 0;
  if (i>250) i = 15;
  // Showing the Balance
  if (i == 0)
    if (millis() - panelMillis > dispMillis)
      menu7Display(i);
      num7Display(dataArray[i]);
      clearCache();
      panelMillis = millis();
    j = 0;  // To prevent j from not being 0 when cleared
  // menu is changeable while j = 0
  if (j == 0) {i = buttonCountDir(button_up,button_down,i);}
  // Display the Turnover Non Clearable
  if (i == 1)
    turnoverNon = dataArray[16] * dataArray[11] + dataArray[17] * dataArray[12] + dataArray[18] * dataArray[13] + dataArray[19] * dataArray[14];
    if (turnoverNon > 9999)
      dataArray[16] = 0; dataArray[17] = 0; dataArray[18] = 0; dataArray[19] = 0;
      menu7Display(i);
      num7Display(turnoverNon);
      clearCache();
  // Display the Turnover Clearable
  if (i == 2)
    turnoverT = dataArray[3] * dataArray[11] + dataArray[4] * dataArray[12] + dataArray[5] * dataArray[13] + dataArray[6] * dataArray[14];
    if (turnoverT > 9999)
      dataArray[3] = 0; dataArray[4] = 0; dataArray[5] = 0; dataArray[6] = 0;
      menu7Display(i);
      num7Display(turnoverT);
      clearCache();
  // The value of the programs
  if (i > 2 && i < 7)
        menu7Display(i);
        clearCache();
  // The functions that can be changed
  if (i > 6 && i < 15)
    j = setCountDir(button_set,j);
    // Menu Set only active in the changeable situation
    if (j == 0) // When Set is not selected
      if (setActiveControl == 1)
        if (i >= 11 && i <= 14) {updateEEprom_8bit(i);}
        if (i >= 7 && i <= 10) {updateEEprom_16bit(i);}
        rs485DataEqualize();
     // Menu variable inside value to be
        menu7Display(i);
        clearCache();
    else if (j == 1) // When Set is selected
      setActiveControl = 1;
      // Inside set value, making the values changeable
      dataArray[i] = buttonCountDir(button_up,button_down,dataArray[i]);
      //The general display for the menu part
        menu7Display(i);
        clearCache();
      // While the value is changeable, LED will flicker
      if (millis() - panelMillis1 > dispSelectMillis)
        clearCache();
  // For the situation where the clear method is
  if (i == 15)
    // Display is changed for the clear menu
      menu7Display(i); // Menu Number will be displayed as usual
      dig4Display(1, 99);  // C symbol
      dig4Display(2, 243); // l symbol
      dig4Display(3, 244); // r symbol with dot
      clearCache();
    // If the set button is pressed, the values related to money will be cleared
      balance = 0; dataArray[3] = 0; dataArray[4] = 0; dataArray[5] = 0; dataArray[6] = 0;
      // Balance,OnYikG,TamYikG,KopG,CilaG
      i = 0;
// Function to only set one variable once,and then return to 0 position
uint8_t setOnce(uint8_t setPin){
  uint8_t setOnceActive = 0;
  setOnceState = analogRead(setPin);
  if (setOnceState < 100){
    setOnceInState = 1;
  } else setOnceInState = 0;
  // compare the coinState to its previous state
  if (setOnceInState != setOnceLastState) {
    // if  the state has changed, increment the counter
    if (setOnceInState == 1) {
        setOnceActive = 1;
  setOnceLastState = setOnceInState;
  return setOnceActive;
uint8_t setCountDir (uint8_t button3, uint8_t setValue)
  setValue = analogRead(button3);
  if (setValue < 100)
    {setReading = 1;} else {setReading = 0; setState = 0;}
  // Check if the state of the pin has changed
  if(setReading != lastSetState)
    setMillis = millis();
  // If the debounce time has passed, Let the button hang
  if (setReading == 1 && (millis() - setMillis > debounceDelay))
    setHang = 1;
    setState = 1;
  // When the button is unpressed, then it will count one time, release the hang
  if (setState != setHang)
    setHang = 0;
    setCount++;
  lastSetState = setReading;
  if (setCount > 1) {setCount = 0;}
  return setCount;
uint16_t buttonCountDir (uint8_t button1, uint8_t button2, uint16_t countValue1)
  //Count Up
  buttonValue1 = analogRead(button1);
  if (buttonValue1 < 100)
    {buttonReading1 = 1;} else {buttonReading1 = 0; buttonState1 = 0;}
  if(buttonReading1 != lastButtonState1)
    buttonMillis1 = millis();
  if (buttonReading1 == 1 && (millis() - buttonMillis1 > debounceDelay))
    buttonHang1 = 1;
    buttonState1 = 1;
  if (buttonState1 != buttonHang1)
    buttonHang1 = 0;
    countValue1++;
  lastButtonState1 = buttonReading1;
  // Count Down
  buttonValue2 = analogRead(button2);
  if (buttonValue2 < 100)
    {buttonReading2 = 1;} else {buttonReading2 = 0; buttonState2 = 0;}
  if(buttonReading2 != lastButtonState2)
    buttonMillis2 = millis();
  if (buttonReading2 == 1 && (millis() - buttonMillis2 > debounceDelay))
    buttonHang2 = 1;
    buttonState2 = 1;
  if (buttonState2 != buttonHang2)
    buttonHang2 = 0;
    countValue1--;
  lastButtonState2 = buttonReading2;
  return countValue1;
void coinRead(uint8_t coinPinout){
  coinState = analogRead(coinPinout);
  if (coinState < 100){
    coinInState = 1;
  } else coinInState = 0;
  if (coinInState != coinLastState) {
    if (coinInState == 1) {
        balance++;
        // P10 Panel print program which only works when the balance changes
        // P10.BALANCE(balanceF);
  coinLastState = coinInState;
// The function to read the inputs, deduct price and give the state command
void setInputs(uint8_t setInPin1, uint8_t setInPin2,
                uint8_t setInPin3, uint8_t setInPin4,
                uint8_t price1, uint8_t price2,
                uint8_t price3, uint8_t price4)
  uint16_t setInValue1 = analogRead(setInPin1);
  uint16_t setInValue2 = analogRead(setInPin2);
  uint16_t setInValue3 = analogRead(setInPin3);
  uint16_t setInValue4 = analogRead(setInPin4);
  uint8_t setInState1 = 0;
  uint8_t setInState2 = 0;
  uint8_t setInState3 = 0;
  uint8_t setInState4 = 0;
  // if the Out state has been activated, do not read the pins
    if (setInValue1 < 100){setInState1 = 1;} else setInState1 = 0;
    if (setInState1 != setInLastState1)
      if (setInState1 == 1 && balance >= price1)
      {setStateInput = 1; balance = balance - price1;}
    setInLastState1 = setInState1;
    if (setInValue2 < 100){setInState2 = 1;} else setInState2 = 0;
    if (setInState2 != setInLastState2)
      if (setInState2 == 1 && balance >= price2)
      {setStateInput = 2; balance = balance - price2;}
    setInLastState2 = setInState2;
    if (setInValue3 < 100){setInState3 = 1;} else setInState3 = 0;
    if (setInState3 != setInLastState3)
      if (setInState3 == 1 && balance >= price3)
      {setStateInput = 3; balance = balance - price3;}
    setInLastState3 = setInState3;
    if (setInValue4 < 100){setInState4 = 1;} else setInState4 = 0;
    if (setInState4 != setInLastState4)
      if (setInState4 == 1 && balance >= price4)
      {setStateInput = 4; balance = balance - price4;}
    setInLastState4 = setInState4;
// Timer usage
void progTimer(uint16_t time1, uint16_t time2, uint16_t time3,
                uint16_t time4, uint8_t outPin1, uint8_t outPin2,
                uint8_t outPin3, uint8_t outPin4)
  // Caution for the relays to forcefully close when this
    digitalWrite(output1, LOW);
    digitalWrite(output2, LOW);
    digitalWrite(output3, LOW);
    progTimeMain = 0;
  if (setStateInput != 0)
    setStateOutput = setStateInput;
    setStateInput = 0;              // Reset the input State
    //rs485Millis = millis();
  // Main Timer notation and process start, Only One time operation
  if (setStateOutput != 0 && progTimeMain == 0)
    switch(setStateOutput)
        case 1: progTimeMain = time1;  outPinSelect = outPin1;
                dataArray[3]++; dataArray[16]++; rs485OutState = 1; break;
        case 2: progTimeMain = time2;  outPinSelect = outPin2;
                dataArray[4]++; dataArray[17]++; rs485OutState = 2; break;
        case 3: progTimeMain = time3;  outPinSelect = outPin3;
                dataArray[5]++; dataArray[18]++; rs485OutState = 3; break;
        case 4: progTimeMain = time4;  outPinSelect = outPin4;
                dataArray[6]++; dataArray[19]++; rs485OutState = 4; break;
    updateEEprom_16bit(rs485OutState + 2);
    updateEEprom_16bit(rs485OutState + 15);
    rs485Write(tim, rs485OutState);
    digitalWrite(outPinSelect, HIGH);
  // While the program state is high and the progTimeMain function is not 0
  // start counting
  if (setStateOutput != 0 && progTimeMain != 0)
    // Every second decrease counter by 1
    if (millis() - timerMillis >= 1000)
      timerMillis = millis();
      progTimeMain--;
    // If counter reaches 0, shut down the timer output, with relay
    if (progTimeMain <= 0 || setStateOutput == 0)
      setStateOutput = 0;
      rs485OutState = 0;
      digitalWrite(outPinSelect, LOW);
      timerMillis = 0;
Need a circuit diagram as this is often a power issue .
That’s a big sketch with lots of arrays - you might be running out of memory or are using more positions in one than you have declared ( I’m not looking )
Do a bit of bug finding to check
Posting the report after downloading the code tells how much memory is used. It might contain interesting information.
This is the relay circuit, I'm also using 74HC595 to drive 4 digit 7 segment display, have 3 buttons with 10k pull-ups, my smps is 700 ma output, according to the datasheet the relay works with 40mA and because the frequency of the display refresh is low (the display seems dim too) I don't think that draws much current either. I'll measure how much amp the circuit consumes and post the values.
This is the info it gives when I compile, after seeing that I thought I have lots of room to play with
The circuit diagram is only partial and doesn’t give much info; in the diagram where does the 5v come from ? If from the Arduino , then that is an issue. the 5v pin is not a power supply . How is the display wired ?? Overheating regulators can cause random shutdown .
You may also get noise from the load ( not shown)
If you declare an array and then use parts of it out side the declared range ( in error) , it can be an issue. - need to check that .
Copy the text and post it in code tags. That screenshot makes nobody happy.
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\WiseMech\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\WiseMech\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\WiseMech\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\WiseMech\AppData\Local\Temp\arduino_build_848301 -warnings=none -build-cache C:\Users\WiseMech\AppData\Local\Temp\arduino_cache_29787 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\WiseMech\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\WiseMech\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\WiseMech\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\WiseMech\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\WiseMech\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\WiseMech\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\WiseMech\Desktop\PanelTypeArdNano_programWashLoop_rs485_Eeprom_cirosuz\PanelTypeArdNano_programWashLoop_rs485_Eeprom_cirosuz.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\WiseMech\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\WiseMech\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\WiseMech\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\WiseMech\AppData\Local\Temp\arduino_build_848301 -warnings=none -build-cache C:\Users\WiseMech\AppData\Local\Temp\arduino_cache_29787 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\WiseMech\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\WiseMech\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\WiseMech\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\WiseMech\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\WiseMech\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\WiseMech\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\WiseMech\Desktop\PanelTypeArdNano_programWashLoop_rs485_Eeprom_cirosuz\PanelTypeArdNano_programWashLoop_rs485_Eeprom_cirosuz.ino
Using board 'nano' from platform in folder: C:\Users\WiseMech\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\WiseMech\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
"C:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\WiseMech\\AppData\\Local\\Temp\\arduino_build_848301\\sketch\\PanelTypeArdNano_programWashLoop_rs485_Eeprom_cirosuz.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for EEPROM.h: [EEPROM@2.0]
ResolveLibrary(EEPROM.h)
  -> candidates: [EEPROM@2.0]
"C:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "C:\\Users\\WiseMech\\AppData\\Local\\Temp\\arduino_build_848301\\sketch\\PanelTypeArdNano_programWashLoop_rs485_Eeprom_cirosuz.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for SoftwareSerial.h: [SoftwareSerial@1.0]
ResolveLibrary(SoftwareSerial.h)
  -> candidates: [SoftwareSerial@1.0]
"C:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "C:\\Users\\WiseMech\\AppData\\Local\\Temp\\arduino_build_848301\\sketch\\PanelTypeArdNano_programWashLoop_rs485_Eeprom_cirosuz.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Using cached library dependencies for file: C:\Users\WiseMech\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SoftwareSerial\src\SoftwareSerial.cpp
Generating function prototypes...
"C:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "C:\\Users\\WiseMech\\AppData\\Local\\Temp\\arduino_build_848301\\sketch\\PanelTypeArdNano_programWashLoop_rs485_Eeprom_cirosuz.ino.cpp" -o "C:\\Users\\WiseMech\\AppData\\Local\\Temp\\arduino_build_848301\\preproc\\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\WiseMech\\AppData\\Local\\Temp\\arduino_build_848301\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "C:\\Users\\WiseMech\\AppData\\Local\\Temp\\arduino_build_848301\\sketch\\PanelTypeArdNano_programWashLoop_rs485_Eeprom_cirosuz.ino.cpp" -o "C:\\Users\\WiseMech\\AppData\\Local\\Temp\\arduino_build_848301\\sketch\\PanelTypeArdNano_programWashLoop_rs485_Eeprom_cirosuz.ino.cpp.o"
Compiling libraries...
Compiling library "EEPROM"
Compiling library "SoftwareSerial"
Using previously compiled file: C:\Users\WiseMech\AppData\Local\Temp\arduino_build_848301\libraries\SoftwareSerial\SoftwareSerial.cpp.o
Compiling core...
Using precompiled core: C:\Users\WiseMech\AppData\Local\Temp\arduino_cache_29787\core\core_arduino_avr_nano_cpu_atmega328_fa6b0ba11f3dde5ceb43cce0924df67b.a
Linking everything together...
"C:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\WiseMech\\AppData\\Local\\Temp\\arduino_build_848301/PanelTypeArdNano_programWashLoop_rs485_Eeprom_cirosuz.ino.elf" "C:\\Users\\WiseMech\\AppData\\Local\\Temp\\arduino_build_848301\\sketch\\PanelTypeArdNano_programWashLoop_rs485_Eeprom_cirosuz.ino.cpp.o" "C:\\Users\\WiseMech\\AppData\\Local\\Temp\\arduino_build_848301\\libraries\\SoftwareSerial\\SoftwareSerial.cpp.o" "C:\\Users\\WiseMech\\AppData\\Local\\Temp\\arduino_build_848301/..\\arduino_cache_29787\\core\\core_arduino_avr_nano_cpu_atmega328_fa6b0ba11f3dde5ceb43cce0924df67b.a" "-LC:\\Users\\WiseMech\\AppData\\Local\\Temp\\arduino_build_848301" -lm
"C:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\WiseMech\\AppData\\Local\\Temp\\arduino_build_848301/PanelTypeArdNano_programWashLoop_rs485_Eeprom_cirosuz.ino.elf" "C:\\Users\\WiseMech\\AppData\\Local\\Temp\\arduino_build_848301/PanelTypeArdNano_programWashLoop_rs485_Eeprom_cirosuz.ino.eep"
"C:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\WiseMech\\AppData\\Local\\Temp\\arduino_build_848301/PanelTypeArdNano_programWashLoop_rs485_Eeprom_cirosuz.ino.elf" "C:\\Users\\WiseMech\\AppData\\Local\\Temp\\arduino_build_848301/PanelTypeArdNano_programWashLoop_rs485_Eeprom_cirosuz.ino.hex"
Using library EEPROM at version 2.0 in folder: C:\Users\WiseMech\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\EEPROM
Using library SoftwareSerial at version 1.0 in folder: C:\Users\WiseMech\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SoftwareSerial
"C:\\Users\\WiseMech\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\WiseMech\\AppData\\Local\\Temp\\arduino_build_848301/PanelTypeArdNano_programWashLoop_rs485_Eeprom_cirosuz.ino.elf"
Sketch uses 8510 bytes (27%) of program storage space. Maximum is 30720 bytes.
Global variables use 317 bytes (15%) of dynamic memory, leaving 1731 bytes for local variables. Maximum is 2048 bytes.
C:\Users\WiseMech\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\WiseMech\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM7 -b115200 -D -Uflash:w:C:\Users\WiseMech\AppData\Local\Temp\arduino_build_848301/PanelTypeArdNano_programWashLoop_rs485_Eeprom_cirosuz.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\WiseMech\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM7
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\WiseMech\AppData\Local\Temp\arduino_build_848301/PanelTypeArdNano_programWashLoop_rs485_Eeprom_cirosuz.ino.hex"
avrdude: writing flash (8510 bytes):
Writing | ################################################## | 100% 1.21s
avrdude: 8510 bytes of flash written
avrdude: verifying flash memory against C:\Users\WiseMech\AppData\Local\Temp\arduino_build_848301/PanelTypeArdNano_programWashLoop_rs485_Eeprom_cirosuz.ino.hex:
avrdude: load data flash data from input file C:\Users\WiseMech\AppData\Local\Temp\arduino_build_848301/PanelTypeArdNano_programWashLoop_rs485_Eeprom_cirosuz.ino.hex:
avrdude: input file C:\Users\WiseMech\AppData\Local\Temp\arduino_build_848301/PanelTypeArdNano_programWashLoop_rs485_Eeprom_cirosuz.ino.hex contains 8510 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 1.06s
avrdude: verifying ...
avrdude: 8510 bytes of flash verified
avrdude done.  Thank you.
Couldn't show you the full schematic because my friend was the one who came up with it but I couldn't reach him, once he sends me I'll display it, I can say this however:
  • 5V 700 mA SMPS is power source for Arduino Nano, 7 segment display and Relays.
  • 7 segment display works with 2 shift registers 74HC595, because the refresh rate is low I assumed it wouldn't waste the pin current limits of that device, the reason I've set refresh rate low is also because there wasn't any transistor on the Digit Power pins, I think the 74HC595 has an output pin continuous current max as 35 mA. I haven't noticed any heating while operating them as well.
  • The relays open a Solenoid Valve (18 Watt - 220V) and a another high rating contactor which drives a 380 Volt Pump
I haven't seen any problems with the array definitions, I've defined them as size 21 and the max. array definition occurs with dataArray[19], I don't know if I'm not seeing it.
I've realized that in progTimer function the digitalWrite is abused when setStateOutput = 0, which is most of the time, don't know whether that will cause a problem:
    progTimeMain = 0;
And in the rs485 function definition I've used delay(3), it seemed to me that it would not matter much since there wasn't much time critical operation in my code.
    delay(3);
There's no obvious problem with memory used.
Do You have a DMM? Measure the 5 volt. Does it drop and then the execution hangs?
I didn't know you could.
If by abuse you mean it gets done thousands of times and most of the time the pin was already where digitalWrite() was going to take it, it matters not.
It might take a bit less time to decide you don't need to do a digitalWrite than to just do it no matter what, but an insignificant time, why clutter up the code with getting around that?
a7
What is connected to the relay that "stays open"?
In every relay I have either a Solenoid Valve (18 watt -220 Volt) or a 220V contactor, the contactor is used to operate 380V tri phase motor, and in one relay I have both the solenoid and contactor.
As I understand it, if it freezes during the progTimer function phase, the relay stays open, and so does the contactor and valve. If it freezes while doing nothing the relays stay closed still, but the Arduino does not receive any input
By the way, I've taken measurements and it shows that when the card is powered up it consumes 25 mA, the max. Occurs when the relay is open and 4 digits are active, then I've seen 85 mA. Which is hardly anywhere close to my 700 mA SMPS output.
If it is an EMI related issue would it be better to use a transformer and linear voltage regulator as a power supply.
