Hi, for an unknown reason yesterday my output works as program. today, after some little modification, ALL my output start active. the little code added is to activate 4 more ouuput on my 40's output in my sketch !!
i use the "input pullup" code everywhere
// code pour controler un aiguillage de train avec DEL témon selo la position.
// Luc Champagne avec la precieuse contribution de Guillaume Dorczynski. merci
// 2 février 2026
//sur appel le DEL allume et demeure allumé et la sortie relais est activé pour la durée de (temporisation_durée)
//sur appel de la position opposé, les DEL change d'état et le relay associé s'active pendant la (temporisation_durée)
//mcp1 configurer en entrée (16)
//mcp2 configurer en sortie (16)
#include <Adafruit_MCP23X17.h>
#include <Arduino.h>
//#include <ESP8266WiFi.h>
Adafruit_MCP23X17 mcp1;
Adafruit_MCP23X17 mcp2;
const uint8_t pin_bouton1a = 2;
const uint8_t pin_bouton1b = 3;
const uint8_t pin_bouton2a = 4;
const uint8_t pin_bouton2b = 5;
const uint8_t pin_bouton3a = 6;
const uint8_t pin_bouton3b = 7;
const uint8_t pin_bouton4a = 8;
const uint8_t pin_bouton4b = 9;
const uint8_t pin_bouton5a = 10;
const uint8_t pin_bouton5b = 11;
const uint8_t pin_bouton6a = 12;
const uint8_t pin_bouton6b = 13;
const uint8_t pin_led1a = 22;
const uint8_t pin_led1b = 24;
const uint8_t pin_led2a = 26;
const uint8_t pin_led2b = 28;
const uint8_t pin_led3a = 30;
const uint8_t pin_led3b = 32;
const uint8_t pin_led4a = 34;
const uint8_t pin_led4b = 36;
const uint8_t pin_led5a = 38;
const uint8_t pin_led5b = 40;
const uint8_t pin_led6a = 42;
const uint8_t pin_led6b = 44;
const uint8_t relay_pin1a =23;
const uint8_t relay_pin1b = 25;
const uint8_t relay_pin2a = 27;
const uint8_t relay_pin2b = 29;
const uint8_t relay_pin3a = 31;
const uint8_t relay_pin3b = 33;
const uint8_t relay_pin4a = 35;
const uint8_t relay_pin4b = 37;
const uint8_t relay_pin5a = 39;
const uint8_t relay_pin5b = 41;
const uint8_t relay_pin6a = 43;
const uint8_t relay_pin6b = 45;
const uint8_t pin_bouton7a = 0; // input A1 mcp1
const uint8_t pin_bouton7b = 1; // input A2 mcp1
const uint8_t pin_bouton8a = 2; // input A3 mcp1
const uint8_t pin_bouton8b = 3; // inpit A4 mcp1
const uint8_t pin_bouton9a = 4; // input A5 mcp1
const uint8_t pin_bouton9b = 5; // input A6 mcp1
const uint8_t pin_bouton10a = 6; // input A7 mcp1
const uint8_t pin_bouton10b = 7; // input A8 mcp1
const uint8_t pin_led7a = 0; // output A1 mcp2
const uint8_t pin_led7b = 1; // output A2 mcp2
const uint8_t pin_led8a = 2; // output A3 mcp2
const uint8_t pin_led8b = 3; // output A4 mcp2
const uint8_t pin_led9a = 4; // output A5 mcp2
const uint8_t pin_led9b = 5; // output A6 mcp2
const uint8_t pin_led10a =6; // output A7 mcp2
const uint8_t pin_led10b = 7; // output A8 mcp2
const uint8_t relay_pin7a = 8; // output B1 mcp2
const uint8_t relay_pin7b = 9; // output B2 mcp2
const uint8_t relay_pin8a = 10; // output B3 mcp2
const uint8_t relay_pin8b = 11; // output B4 mcp2
const uint8_t relay_pin9a = 12; // output B5 mcp2
const uint8_t relay_pin9b = 13; // output B6 mcp2
const uint8_t relay_pin10a = 14; // output B7 mcp2
const uint8_t relay_pin10b = 15; // output B8 mcp2
Serial.println("MCP23xxx Blink Test!");
if (!mcp1.begin_I2C(0x20)) {
Serial.println("Error.");
while (1);
//for (int i = 0; i < 16; i++)
// mcp1.pinMode(i, INPUT_PULLUP);
if (!mcp2.begin_I2C(0x21)) {
while (1);
// mcp2.pinMode(i, OUTPUT);
//Serial.println("Looping...");
pinMode( pin_bouton1a, INPUT_PULLUP);
pinMode( pin_bouton1b, INPUT_PULLUP);
pinMode( pin_bouton2a, INPUT_PULLUP);
pinMode( pin_bouton2b, INPUT_PULLUP);
pinMode( pin_bouton3a, INPUT_PULLUP);
pinMode( pin_bouton3b, INPUT_PULLUP);
pinMode( pin_bouton4a, INPUT_PULLUP);
pinMode( pin_bouton4b, INPUT_PULLUP);
pinMode( pin_bouton5a, INPUT_PULLUP);
pinMode( pin_bouton5b, INPUT_PULLUP);
pinMode( pin_bouton6a, INPUT_PULLUP);
pinMode( pin_bouton6b, INPUT_PULLUP);
pinMode( pin_led1a, OUTPUT);
pinMode( pin_led1b, OUTPUT);
pinMode( pin_led2a, OUTPUT);
pinMode( pin_led2b, OUTPUT);
pinMode( pin_led3a, OUTPUT);
pinMode( pin_led3b, OUTPUT);
pinMode( pin_led4a, OUTPUT);
pinMode( pin_led4b, OUTPUT);
pinMode( pin_led5a, OUTPUT);
pinMode( pin_led5b, OUTPUT);
pinMode( pin_led6a, OUTPUT);
pinMode( pin_led6b, OUTPUT);
pinMode( relay_pin1a, OUTPUT);
pinMode( relay_pin1b, OUTPUT);
pinMode( relay_pin2a, OUTPUT);
pinMode( relay_pin2b, OUTPUT);
pinMode( relay_pin3a, OUTPUT);
pinMode( relay_pin3b, OUTPUT);
pinMode( relay_pin4a, OUTPUT);
pinMode( relay_pin4b, OUTPUT);
pinMode( relay_pin5a, OUTPUT);
pinMode( relay_pin5b, OUTPUT);
pinMode( relay_pin6a, OUTPUT);
pinMode( relay_pin6b, OUTPUT);
mcp1.begin_I2C(0x20);
mcp1.pinMode(pin_bouton7a, INPUT_PULLUP);
mcp1.pinMode(pin_bouton7b, INPUT_PULLUP);
mcp1.pinMode(pin_bouton8a, INPUT_PULLUP);
mcp1.pinMode(pin_bouton8b, INPUT_PULLUP);
mcp1.pinMode(pin_bouton9a, INPUT_PULLUP);
mcp1.pinMode(pin_bouton9b, INPUT_PULLUP);
mcp1.pinMode(pin_bouton10a, INPUT_PULLUP);
mcp1.pinMode(pin_bouton10b, INPUT_PULLUP);
mcp2.begin_I2C(0x21);
mcp2.pinMode(pin_led7a, OUTPUT);
mcp2.pinMode(pin_led7b, OUTPUT);
mcp2.pinMode(pin_led8a, OUTPUT);
mcp2.pinMode(pin_led8b, OUTPUT);
mcp2.pinMode(pin_led9a, OUTPUT);
mcp2.pinMode(pin_led9b, OUTPUT);
mcp2.pinMode(pin_led10a, OUTPUT);
mcp2.pinMode(pin_led10b, OUTPUT);
mcp2.pinMode(relay_pin7a, OUTPUT);
mcp2.pinMode(relay_pin7b, OUTPUT);
mcp2.pinMode(relay_pin8a, OUTPUT);
mcp2.pinMode(relay_pin8b, OUTPUT);
mcp2.pinMode(relay_pin9a, OUTPUT);
mcp2.pinMode(relay_pin9b, OUTPUT);
mcp2.pinMode(relay_pin10a, OUTPUT);
mcp2.pinMode(relay_pin10b, OUTPUT);
uint8_t etat_bouton_actuel1a = digitalRead( pin_bouton1a );
uint8_t etat_bouton_actuel1b = digitalRead( pin_bouton1b );
uint8_t etat_bouton_actuel2a = digitalRead( pin_bouton2a );
uint8_t etat_bouton_actuel2b = digitalRead( pin_bouton2b );
uint8_t etat_bouton_actuel3a = digitalRead( pin_bouton3a );
uint8_t etat_bouton_actuel3b = digitalRead( pin_bouton3b );
uint8_t etat_bouton_actuel4a = digitalRead( pin_bouton4a );
uint8_t etat_bouton_actuel4b = digitalRead( pin_bouton4b );
uint8_t etat_bouton_actuel5a = digitalRead( pin_bouton5a );
uint8_t etat_bouton_actuel5b = digitalRead( pin_bouton5b );
uint8_t etat_bouton_actuel6a = digitalRead( pin_bouton6a );
uint8_t etat_bouton_actuel6b = digitalRead( pin_bouton6b );
uint8_t etat_bouton_actuel7a = mcp1.digitalRead( pin_bouton7a );
uint8_t etat_bouton_actuel7b = mcp1.digitalRead( pin_bouton7b );
uint8_t etat_bouton_actuel8a = mcp1.digitalRead( pin_bouton8a );
uint8_t etat_bouton_actuel8b = mcp1.digitalRead( pin_bouton8b );
uint8_t etat_bouton_actuel9a = mcp1.digitalRead( pin_bouton9a );
uint8_t etat_bouton_actuel9b = mcp1.digitalRead( pin_bouton9b );
uint8_t etat_bouton_actuel10a = mcp1.digitalRead( pin_bouton10a );
uint8_t etat_bouton_actuel10b = mcp1.digitalRead( pin_bouton10b );
static uint8_t etat_bouton_precedent1a = etat_bouton_actuel1a;
static uint8_t etat_bouton_precedent1b = etat_bouton_actuel1b;
static uint8_t etat_bouton_precedent2a = etat_bouton_actuel2a;
static uint8_t etat_bouton_precedent2b = etat_bouton_actuel2b;
static uint8_t etat_bouton_precedent3a = etat_bouton_actuel3a;
static uint8_t etat_bouton_precedent3b = etat_bouton_actuel3b;
static uint8_t etat_bouton_precedent4a = etat_bouton_actuel4a;
static uint8_t etat_bouton_precedent4b = etat_bouton_actuel4b;
static uint8_t etat_bouton_precedent5a = etat_bouton_actuel5a;
static uint8_t etat_bouton_precedent5b = etat_bouton_actuel5b;
static uint8_t etat_bouton_precedent6a = etat_bouton_actuel6a;
static uint8_t etat_bouton_precedent6b = etat_bouton_actuel6b;
static uint8_t etat_bouton_precedent7a = etat_bouton_actuel7a;
static uint8_t etat_bouton_precedent7b = etat_bouton_actuel7b;
static uint8_t etat_bouton_precedent8a = etat_bouton_actuel8a;
static uint8_t etat_bouton_precedent8b = etat_bouton_actuel8b;
static uint8_t etat_bouton_precedent9a = etat_bouton_actuel9a;
static uint8_t etat_bouton_precedent9b = etat_bouton_actuel9b;
static uint8_t etat_bouton_precedent10a = etat_bouton_actuel10a;
static uint8_t etat_bouton_precedent10b = etat_bouton_actuel10b;
static bool temporisation_active = false;
static uint16_t temporisation_millis = 0;
const uint16_t temporisation_duree = 500;
//boucle pour aiguillage 1
if ( etat_bouton_precedent1a != etat_bouton_actuel1a )
delay( 30 );
if ( etat_bouton_actuel1a == LOW )
if ( temporisation_active == true )
Serial.println( "La temporisation est déjà active!" );
Serial.println( "Début de la temporisation." );
temporisation_active = true;
temporisation_millis = millis();
digitalWrite( relay_pin1a, HIGH );
digitalWrite( relay_pin3a, HIGH); //a valider si 3A ou 3B
digitalWrite( pin_led1a, HIGH);
digitalWrite( pin_led1b, LOW);
digitalWrite( pin_led3a, HIGH); //a valider
digitalWrite( pin_led3b, LOW); //a valider
if ( etat_bouton_precedent1b != etat_bouton_actuel1b )
delay( 30 );
if ( etat_bouton_actuel1b == LOW )
digitalWrite( relay_pin1b, HIGH );
digitalWrite( pin_led1b, HIGH);
digitalWrite( pin_led1a, LOW);
//boucle pour aiguillage 2
if ( etat_bouton_precedent2a != etat_bouton_actuel2a )
delay( 30 );
if ( etat_bouton_actuel2a == LOW )
digitalWrite( relay_pin2a, HIGH );
digitalWrite( relay_pin4a, HIGH);
digitalWrite( pin_led2a, HIGH);
digitalWrite( pin_led2b, LOW);
digitalWrite( pin_led4a, HIGH);
digitalWrite( pin_led4b, LOW);
if ( etat_bouton_precedent2b != etat_bouton_actuel2b )
delay( 30 );
if ( etat_bouton_actuel2b == LOW )
digitalWrite( relay_pin2b, HIGH );
digitalWrite( relay_pin3b, HIGH);
digitalWrite( pin_led2b, HIGH);
digitalWrite( pin_led2a, LOW);
digitalWrite( pin_led3b, HIGH);
digitalWrite( pin_led3a, LOW);
// boucle pour aiguillage 3
if ( etat_bouton_precedent3a != etat_bouton_actuel3a )
delay( 30 );
if ( etat_bouton_actuel3a == LOW )
digitalWrite( relay_pin3a, HIGH );
if ( etat_bouton_precedent3b != etat_bouton_actuel3b )
delay( 30 );
if ( etat_bouton_actuel3b == LOW )
digitalWrite( relay_pin3b, HIGH );
// boucle aiguillage 4
if ( etat_bouton_precedent4a != etat_bouton_actuel4a )
delay( 30 );
if ( etat_bouton_actuel4a == LOW )
digitalWrite( relay_pin4a, HIGH );
if ( etat_bouton_precedent4b != etat_bouton_actuel4b )
delay( 30 );
if ( etat_bouton_actuel4b == LOW )
digitalWrite( relay_pin4b, HIGH );
digitalWrite( pin_led4b, HIGH);
digitalWrite( pin_led4a, LOW);
// boucle aiguillge 5
if ( etat_bouton_precedent5a != etat_bouton_actuel5a )
delay( 30 );
if ( etat_bouton_actuel5a == LOW )
digitalWrite( relay_pin5a, HIGH );
digitalWrite( relay_pin6b, HIGH );
digitalWrite( pin_led5a, HIGH);
digitalWrite( pin_led5b, LOW);
digitalWrite( pin_led6b, HIGH);
digitalWrite( pin_led6a, LOW);
if ( etat_bouton_precedent5b != etat_bouton_actuel5b )
delay( 30 );
if ( etat_bouton_actuel5b == LOW )
digitalWrite( relay_pin5b, HIGH );
digitalWrite( pin_led5b, HIGH);
digitalWrite( pin_led5a, LOW);
// boucle aiguillge 6
if ( etat_bouton_precedent6a != etat_bouton_actuel6a )
delay( 30 );
if ( etat_bouton_actuel6a == LOW )
digitalWrite( relay_pin6a, HIGH );
digitalWrite( pin_led6a, HIGH);
digitalWrite( pin_led6b, LOW);
if ( etat_bouton_precedent6b != etat_bouton_actuel6b )
delay( 30 );
if ( etat_bouton_actuel6b == LOW )
// boucle aiguillge 7
if ( etat_bouton_precedent7a != etat_bouton_actuel7a )
delay( 30 );
if ( etat_bouton_actuel7a == LOW )
mcp2.digitalWrite( relay_pin7a, HIGH );
mcp2.digitalWrite( pin_led7a, HIGH);
mcp2.digitalWrite( pin_led7b, LOW);
if ( etat_bouton_precedent7b != etat_bouton_actuel7b )
delay( 30 );
if ( etat_bouton_actuel7b == LOW )
mcp2.digitalWrite( relay_pin7b, HIGH );
mcp2.digitalWrite( pin_led7b, HIGH);
mcp2.digitalWrite( pin_led7a, LOW);
// boucle aiguillge 8
if ( etat_bouton_precedent8a != etat_bouton_actuel8a )
delay( 30 );
if ( etat_bouton_actuel8a == LOW )
mcp2.digitalWrite( relay_pin8a, HIGH );
mcp2.digitalWrite( pin_led8a, HIGH);
mcp2.digitalWrite( pin_led8b, LOW);
if ( etat_bouton_precedent8b != etat_bouton_actuel8b )
delay( 30 );
if ( etat_bouton_actuel8b == LOW )
mcp2.digitalWrite( relay_pin8b, HIGH );
mcp2.digitalWrite( pin_led8b, HIGH);
mcp2.digitalWrite( pin_led8a, LOW);
// boucle aiguillge 9
if ( etat_bouton_precedent9a != etat_bouton_actuel9a )
delay( 30 );
if ( etat_bouton_actuel9a == LOW )
mcp2.digitalWrite( relay_pin9a, HIGH );
mcp2.digitalWrite( pin_led9a, HIGH);
mcp2.digitalWrite( pin_led9b, LOW);
if ( etat_bouton_precedent9b != etat_bouton_actuel9b )
delay( 30 );
if ( etat_bouton_actuel9b == LOW )
mcp2.digitalWrite( relay_pin9b, HIGH );
mcp2.digitalWrite( pin_led9b, HIGH);
mcp2.digitalWrite( pin_led9a, LOW);
// boucle aiguillge 10
if ( etat_bouton_precedent10a != etat_bouton_actuel10a )
delay( 30 );
if ( etat_bouton_actuel10a == LOW )
mcp2.digitalWrite( relay_pin10a, HIGH );
mcp2.digitalWrite( pin_led10a, HIGH);
mcp2.digitalWrite( pin_led10b, LOW);
if ( etat_bouton_precedent10b != etat_bouton_actuel10b )
delay( 30 );
if ( etat_bouton_actuel10b == LOW )
mcp2.digitalWrite( relay_pin10b, HIGH );
mcp2.digitalWrite( pin_led10b, HIGH);
mcp2.digitalWrite( pin_led10a, LOW);
if ( temporisation_active == true && millis() - temporisation_millis >= temporisation_duree )
Serial.println( "Fin de la temporisation." );
digitalWrite( relay_pin1a, LOW);
digitalWrite( relay_pin1b, LOW);
digitalWrite( relay_pin2a, LOW);
digitalWrite( relay_pin2b, LOW);
digitalWrite( relay_pin3a, LOW);
digitalWrite( relay_pin3b, LOW);
digitalWrite( relay_pin4a, LOW);
digitalWrite( relay_pin4b, LOW);
digitalWrite( relay_pin5a, LOW);
digitalWrite( relay_pin5b, LOW);
digitalWrite( relay_pin6a, LOW);
digitalWrite( relay_pin6b, LOW);
mcp2.digitalWrite(relay_pin7a, LOW);
mcp2.digitalWrite(relay_pin7b, LOW);
mcp2.digitalWrite(relay_pin8a, LOW);
mcp2.digitalWrite(relay_pin8b, LOW);
mcp2.digitalWrite(relay_pin9a, LOW);
mcp2.digitalWrite(relay_pin9b, LOW);
mcp2.digitalWrite(relay_pin10a, LOW);
mcp2.digitalWrite(relay_pin10b, LOW);
