Arduino Grbl has not finished uploading. Getting error
Arduino: 1.8.15 (Windows 10), Board: "Arduino Uno"
In file included from C:\Users\Protech\Documents\Arduino\libraries\MIGRBL/grbl.h:43:0,
             from C:\Users\Protech\Documents\Arduino\libraries\MIGRBL\examples\grblUpload\grblUpload.ino:27:
C:\Users\Protech\Documents\Arduino\libraries\MIGRBL/nuts_bolts.h:51:0: warning: "max" redefined
#define max(a,b) (((a) > (b)) ? (a) : (b))
In file included from sketch\grblUpload.ino.cpp:1:0:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:93:0: note: this is the location of the previous definition
#define max(a,b) ((a)>(b)?(a):(b))
C:\Users\Protech\Documents\Arduino\libraries\MIGRBL/nuts_bolts.h:52:0: warning: "min" redefined
#define min(a,b) (((a) < (b)) ? (a) : (b))
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:92:0: note: this is the location of the previous definition
#define min(a,b) ((a)<(b)?(a):(b))
C:\Users\Protech\Documents\Arduino\libraries\MIGRBL/nuts_bolts.h:55:0: warning: "bit" redefined
#define bit(n) (1 << n)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:124:0: note: this is the location of the previous definition
#define bit(b) (1UL << (b))
Sketch uses 29462 bytes (91%) of program storage space. Maximum is 32256 bytes.
Global variables use 1484 bytes (72%) of dynamic memory, leaving 564 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xd3
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xd3
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xd3
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xd3
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xd3
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xd3
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xd3
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xd3
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xd3
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xd3
option enabled in File -> Preferences.
Correct COM port selected in the IDE?
Correct board selected in the IDE?
@saqibpaf
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Read the forum guidelines to see how to properly post error messages.
