Arduino-IDE 2.3.2 Do not read any installed library
I recently bought a laptop with windows 11 so I downloaded the latest version and everything works fine except that every library I install won't work whether was installed from the library manager or manually I always get the same error: "No such file or directory"
PS C:\Users\rimms\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 2552
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/rimms/.arduinoIDE'
Configuring to accept webviews on '^.+.webview..+$' hostname.
2024-05-06T13:14:23.171Z root INFO Backend Object.initialize: 2.6 ms [Finished 0.279 s after backend start]
2024-05-06T13:14:23.172Z root INFO Backend Object.configure: 2.2 ms [Finished 0.279 s after backend start]
2024-05-06T13:14:23.172Z root INFO Backend s.onStart: 0.9 ms [Finished 0.279 s after backend start]
2024-05-06T13:14:23.172Z root INFO Backend s.configure: 0.2 ms [Finished 0.291 s after backend start]
2024-05-06T13:14:23.172Z root INFO Backend d.onStart: 0.1 ms [Finished 0.291 s after backend start]
2024-05-06T13:14:23.173Z root INFO Backend d.configure: 0.1 ms [Finished 0.291 s after backend start]
2024-05-06T13:14:23.173Z root INFO Backend d.initialize: 12.1 ms [Finished 0.291 s after backend start]
2024-05-06T13:14:23.173Z root INFO Backend c.onStart: 0.1 ms [Finished 0.291 s after backend start]
2024-05-06T13:14:23.173Z root INFO Backend a.configure: 0.6 ms [Finished 0.292 s after backend start]
2024-05-06T13:14:23.174Z config INFO >>> Initializing CLI configuration...
2024-05-06T13:14:23.174Z root INFO Backend c.initialize: 0.3 ms [Finished 0.292 s after backend start]
2024-05-06T13:14:23.174Z root INFO Backend R.onStart: 0.3 ms [Finished 0.292 s after backend start]
2024-05-06T13:14:23.175Z config INFO Loading CLI configuration from c:\Users\rimms.arduinoIDE\arduino-cli.yaml...
2024-05-06T13:14:23.175Z daemon INFO Starting daemon from C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-06T13:14:23.175Z root INFO Backend a.initialize: 0.2 ms [Finished 0.292 s after backend start]
2024-05-06T13:14:23.175Z root INFO Backend w.onStart: 0.5 ms [Finished 0.293 s after backend start]
2024-05-06T13:14:23.175Z root INFO Backend r.configure: 0.8 ms [Finished 0.293 s after backend start]
2024-05-06T13:14:23.175Z discovery-log INFO start
2024-05-06T13:14:23.175Z discovery-log INFO start new deferred
2024-05-06T13:14:23.175Z root INFO Backend d.initialize: 0.2 ms [Finished 0.293 s after backend start]
2024-05-06T13:14:23.175Z root INFO Backend y.onStart: 1.1 ms [Finished 0.294 s after backend start]
2024-05-06T13:14:23.175Z root INFO Backend r.configure: 0.9 ms [Finished 0.294 s after backend start]
2024-05-06T13:14:23.175Z root INFO Backend a.onStart: 0.2 ms [Finished 0.295 s after backend start]
2024-05-06T13:14:23.175Z root INFO Backend h.configure: 0.2 ms [Finished 0.295 s after backend start]
2024-05-06T13:14:23.175Z root INFO Backend s.configure: 0.1 ms [Finished 0.295 s after backend start]
2024-05-06T13:14:23.175Z root INFO Backend l.configure: 0.0 ms [Finished 0.295 s after backend start]
2024-05-06T13:14:23.176Z root INFO Theia app listening on http://127.0.0.1:58061.
2024-05-06T13:14:23.176Z root INFO Finished starting backend application: 1.4 ms [Finished 0.296 s after backend start]
2024-05-06T13:14:23.177Z root WARN The local plugin referenced by local-dir:/c%3A/Users/rimms/.arduinoIDE/plugins does not exist.
2024-05-06T13:14:23.177Z root WARN The local plugin referenced by local-dir:/c%3A/Users/rimms/.arduinoIDE/extensions does not exist.
2024-05-06T13:14:23.177Z root WARN The local plugin referenced by local-dir:C:\Users\rimms.arduinoIDE\plugins does notexist.
2024-05-06T13:14:23.179Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"builtin":{"libraries":"C:\Users\rimms\AppData\Local\Arduino15\libraries"},"data":"c:\Users\rimms\AppData\Local\Arduino15","downloads":"C:\Users\rimms\AppData\Local\Arduino15\staging","user":"c:\Users\rimms\OneDrive\المستندات\Arduino"},"library":{"enable_unsafe_install":false},"locale":"en","logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-05-06T13:14:23.179Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-05-06T13:14:23.179Z config INFO Loaded the CLI configuration.
2024-05-06T13:14:23.188Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/rimms/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/rimms/OneDrive/%D8%A7%D9%84%D9%85%D8%B3%D8%AA%D9%86%D8%AF%D8%A7%D8%AA/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-05-06T13:14:23.188Z config INFO Validating the CLI configuration...
2024-05-06T13:14:23.188Z config INFO The CLI config is valid.
2024-05-06T13:14:23.189Z config INFO <<< Initialized the CLI configuration.
Restoring workspace roots: c:\Users\rimms\Downloads\Car_Parking_System
isTempSketch: false. Input was c:\Users\rimms\Downloads\Car_Parking_System\Car_Parking_System.ino
2024-05-06T13:14:23.198Z root INFO Resolve plugins list: 23.6 ms [Finished 0.318 s after backend start]
2024-05-06T13:14:23.240Z daemon INFO time="2024-05-06T16:14:23+03:00" level=info msg="Using config file: c:\Users\rimms\.arduinoIDE\arduino-cli.yaml"
time="2024-05-06T16:14:23+03:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-05-06T16:14:23+03:00" level=info msg="Executing arduino-cli daemon"
Daemon is now listening on 127.0.0.1:58062
{"IP":"127.0.0.1","Port":"58062"}
2024-05-06T13:14:23.240Z daemon INFO Daemon is running.
2024-05-06T13:14:23.281Z daemon INFO time="2024-05-06T16:14:23+03:00" level=info msg="Checking signature" index="c:\Users\rimms\AppData\Local\Arduino15\package_index.json" signatureFile="c:\Users\rimms\AppData\Local\Arduino15\package_index.json.sig" trusted=true
time="2024-05-06T16:14:23+03:00" level=info msg="Loading hardware from: c:\Users\rimms\AppData\Local\Arduino15\packages"
time="2024-05-06T16:14:23+03:00" level=info msg="Loading package arduino from: C:\Users\rimms\AppData\Local\Arduino15\packages\arduino\hardware"
time="2024-05-06T16:14:23+03:00" level=info msg="Missing signature file" index="C:\Users\rimms\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\installed.json"
time="2024-05-06T16:14:23+03:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-05-06T16:14:23+03:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2024-05-06T16:14:23+03:00" level=info msg="Missing signature file" index="C:\Users\rimms\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13\installed.json"
time="2024-05-06T16:14:23+03:00" level=info msg="Loaded platform" platform="arduino:esp32@2.0.13"
time="2024-05-06T16:14:23+03:00" level=info msg="Missing signature file" index="C:\Users\rimms\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.1.0\installed.json"
time="2024-05-06T16:14:23+03:00" level=info msg="Loaded platform" platform="arduino:renesas_uno@1.1.0"
time="2024-05-06T16:14:23+03:00" level=info msg="Checking existence of 'tools' path: C:\Users\rimms\AppData\Local\Arduino15\packages\arduino\tools"
time="2024-05-06T16:14:23+03:00" level=info msg="Loading tools from dir: C:\Users\rimms\AppData\Local\Arduino15\packages\arduino\tools"
time="2024-05-06T16:14:23+03:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2024-05-06T16:14:23+03:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2024-05-06T16:14:23+03:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2024-05-06T16:14:23+03:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2024-05-06T16:14:23+03:00" level=info msg="Loaded tool" tool="arduino:bossac@1.9.1-arduino5"
time="2024-05-06T16:14:23+03:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
time="2024-05-06T16:14:23+03:00" level=info msg="Loaded tool" tool="arduino:openocd@0.11.0-arduino2"
time="2024-05-06T16:14:23+03:00" level=info msg="Loading package builtin from: C:\Users\rimms\AppData\Local\Arduino15\packages\builtin"
time="2024-05-06T16:14:23+03:00" level=info msg="Checking existence of 'tools' path: C:\Users\rimms\AppData\Local\Arduino15\packages\builtin\tools"
time="2024-05-06T16:14:23+03:00" level=info msg="Loading tools from dir: C:\Users\rimms\AppData\Local\Arduino15\packages\builtin\tools"
time="2024-05-06T16:14:23+03:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-05-06T16:14:23+03:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2024-05-06T16:14:23+03:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2024-05-06T16:14:23+03:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2024-05-06T16:14:23+03:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2024-05-06T16:14:23+03:00" level=info msg="Loading package esp32 from: C:\Users\rimms\AppData\Local\Arduino15\packages\esp32"
time="2024-05-06T16:14:23+03:00" level=info msg="Checking existence of 'tools' path: C:\Users\rimms\AppData\Local\Arduino15\packages\esp32\tools"
time="2024-05-06T16:14:23+03:00" level=info msg="Loading tools from dir: C:\Users\rimms\AppData\Local\Arduino15\packages\esp32\tools"
time="2024-05-06T16:14:23+03:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.5.1"
time="2024-05-06T16:14:23+03:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2024-05-06T16:14:23+03:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
time="2024-05-06T16:14:23+03:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
time="2024-05-06T16:14:23+03:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
time="2024-05-06T16:14:23+03:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-05-06T16:14:23+03:00" level=info msg="Adding libraries dir" dir="C:\Users\rimms\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13\libraries" location=platform
time="2024-05-06T16:14:23+03:00" level=info msg="Adding libraries dir" dir="C:\Users\rimms\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.1.0\libraries" location=platform
time="2024-05-06T16:14:23+03:00" level=info msg="Adding libraries dir" dir="C:\Users\rimms\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries" location=platform
time="2024-05-06T16:14:23+03:00" level=info msg="Loading libraries index file" index="c:\Users\rimms\AppData\Local\Arduino15\library_index.json"
2024-05-06T13:14:23.390Z daemon INFO time="2024-05-06T16:14:23+03:00" level=info msg="Adding libraries dir" dir="C:\Users\rimms\AppData\Local\Arduino15\libraries" location=ide
time="2024-05-06T16:14:23+03:00" level=info msg="Adding libraries dir" dir="c:\Users\rimms\OneDrive\المستندات\Arduino\libraries" location=user
2024-05-06T13:14:23.600Z root INFO Deploy plugins list: 23.6 ms [Finished 0.720 s after backend start]
2024-05-06T13:14:23.702Z daemon INFO time="2024-05-06T16:14:23+03:00" level=warning msg="Error loading library" error="rpc error: code = Internal desc = loading library from c:\Users\rimms\OneDrive\المستندات\Arduino\libraries\libraries: invalid library: no header files found"
2024-05-06T13:14:23.704Z discovery-log INFO start resolved watching
2024-05-06T13:14:23.704Z daemon INFO time="2024-05-06T16:14:23+03:00" level=info msg="starting discovery builtin:dfu-discovery process"
2024-05-06T13:14:23.704Z daemon INFO time="2024-05-06T16:14:23+03:00" level=info msg="starting discovery builtin:serial-discovery process"
2024-05-06T13:14:23.704Z daemon INFO time="2024-05-06T16:14:23+03:00" level=info msg="starting discovery builtin:mdns-discovery process"
2024-05-06T13:14:23.707Z daemon INFO time="2024-05-06T16:14:23+03:00" level=info msg="started discovery builtin:mdns-discovery process"
time="2024-05-06T16:14:23+03:00" level=info msg="started discovery builtin:dfu-discovery process"
time="2024-05-06T16:14:23+03:00" level=info msg="sending command HELLO 1 "arduino-cli 0.35.3" to discovery builtin:mdns-discovery"
time="2024-05-06T16:14:23+03:00" level=info msg="sending command HELLO 1 "arduino-cli 0.35.3" to discovery builtin:dfu-discovery"
2024-05-06T13:14:23.708Z daemon INFO time="2024-05-06T16:14:23+03:00" level=info msg="started discovery builtin:serial-discovery process"
time="2024-05-06T16:14:23+03:00" level=info msg="sending command HELLO 1 "arduino-cli 0.35.3" to discovery builtin:serial-discovery"
2024-05-06T13:14:23.716Z daemon INFO time="2024-05-06T16:14:23+03:00" level=info msg="from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1"
2024-05-06T13:14:23.716Z daemon INFO time="2024-05-06T16:14:23+03:00" level=info msg="sending command START_SYNC to discovery builtin:mdns-discovery"
time="2024-05-06T16:14:23+03:00" level=info msg="from discovery builtin:mdns-discovery received message type: start_sync, message: OK"
2024-05-06T13:14:23.717Z daemon INFO time="2024-05-06T16:14:23+03:00" level=info msg="from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1"
2024-05-06T13:14:23.717Z daemon INFO time="2024-05-06T16:14:23+03:00" level=info msg="sending command START_SYNC to discovery builtin:serial-discovery"
time="2024-05-06T16:14:23+03:00" level=info msg="from discovery builtin:serial-discovery received message type: start_sync, message: OK"
2024-05-06T13:14:23.718Z daemon INFO time="2024-05-06T16:14:23+03:00" level=info msg="from discovery builtin:dfu-discovery received message type: hello, message: OK, protocol version: 1"
2024-05-06T13:14:23.718Z daemon INFO time="2024-05-06T16:14:23+03:00" level=info msg="sending command START_SYNC to discovery builtin:dfu-discovery"
2024-05-06T13:14:23.719Z daemon INFO time="2024-05-06T16:14:23+03:00" level=info msg="from discovery builtin:dfu-discovery received message type: start_sync, message: OK"
2024-05-06T13:14:23.747Z daemon INFO time="2024-05-06T16:14:23+03:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: COM6"
time="2024-05-06T16:14:23+03:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: COM4"
2024-05-06T13:14:23.747Z daemon INFO time="2024-05-06T16:14:23+03:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: COM3"
2024-05-06T13:14:23.748Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[{"name":"Arduino Uno","fqbn":"arduino:avr:uno","isHidden":false}],"port":{"address":"COM6","label":"COM6","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0x0043"],["serialNumber","85731303433351A051E1"],["vid","0x2341"]],"hardwareId":"85731303433351A051E1"}},"error":""}
2024-05-06T13:14:23.749Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM4","label":"COM4","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2024-05-06T13:14:23.749Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM3","label":"COM3","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-05-06T13:14:24.247Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-05-06T13:14:24.302Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <c:\Users\rimms\Downloads\Car_Parking_System\Car_Parking_System.ino>, response: <c:\Users\rimms\Downloads\Car_Parking_System>.
2024-05-06T13:14:24.374Z root INFO Start frontend contributions: 205.8 ms [Finished 1.093 s after frontend start]
2024-05-06T13:14:24.374Z root INFO Changed application state from 'init' to 'started_contributions'.
2024-05-06T13:14:24.382Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2024-05-06T13:14:24.382Z root INFO >>> Restoring the layout state...
2024-05-06T13:14:24.382Z root INFO ------- SERIALIZED LAYOUT DATA -------
2024-05-06T13:14:24.382Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/rimms/Downloads/Car_Parking_System/Car_Parking_System.ino"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":7,"column":1},"position":{"lineNumber":7,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":69,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{"locked":false}"}],"currentIndex":0}},"pinned":[false],"size":227,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":true,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{"parts":[{"partId":"debug:threads:-1","collapsed":false,"hidden":false,"relativeSize":1.384,"originalContainerId":"debug:view-container:-1","originalContainerTitle":{"label":"debug","iconClass":"codicon codicon-debug-alt","closeable":true},"widget":{"constructionOptions":{"factoryId":"debug:threads"},"innerWidgetState":"{}"}},{"partId":"debug:frames:-1","collapsed":false,"hidden":false,"relativeSize":1.384,"originalContainerId":"debug:view-container:-1","originalContainerTitle":{"label":"debug","iconClass":"codicon codicon-debug-alt","closeable":true},"widget":{"constructionOptions":{"factoryId":"debug:frames"},"innerWidgetState":"{}"}},{"partId":"debug:variables:-1","collapsed":false,"hidden":false,"relativeSize":1.384,"originalContainerId":"debug:view-container:-1","originalContainerTitle":{"label":"debug","iconClass":"codicon codicon-debug-alt","closeable":true},"widget":{"constructionOptions":{"factoryId":"debug:variables"},"innerWidgetState":"{}"}},{"partId":"debug:watch:-1","collapsed":false,"hidden":false,"relativeSize":1.384,"originalContainerId":"debug:view-container:-1","originalContainerTitle":{"label":"debug","iconClass":"codicon codicon-debug-alt","closeable":true},"widget":{"constructionOptions":{"factoryId":"debug:watch"},"innerWidgetState":"{}"}},{"partId":"debug:breakpoints:-1","collapsed":false,"hidden":false,"relativeSize":1.384,"originalContainerId":"debug:view-container:-1","originalContainerTitle":{"label":"debug","iconClass":"codicon codicon-debug-alt","closeable":true},"widget":{"constructionOptions":{"factoryId":"debug:breakpoints"},"innerWidgetState":"{}"}},{"partId":"plugin-view:cortex-debug.peripherals","collapsed":true,"hidden":true,"originalContainerId":"debug:view-container:-1","originalContainerTitle":{"label":"debug","iconClass":"codicon codicon-debug-alt","closeable":true},"widget":{"constructionOptions":{"factoryId":"plugin-view","options":{"id":"plugin-view:cortex-debug.peripherals","viewId":"cortex-debug.peripherals"}},"innerWidgetState":"{\"label\":\"Cortex Peripherals\",\"widgets\":[],\"suppressUpdateViewVisibility\":false,\"currentViewContainerId\":\"debug\"}"}},{"partId":"plugin-view:cortex-debug.registers","collapsed":true,"hidden":true,"originalContainerId":"debug:view-container:-1","originalContainerTitle":{"label":"debug","iconClass":"codicon codicon-debug-alt","closeable":true},"widget":{"constructionOptions":{"factoryId":"plugin-view","options":{"id":"plugin-view:cortex-debug.registers","viewId":"cortex-debug.registers"}},"innerWidgetState":"{\"label\":\"Cortex Registers\",\"widgets\":[],\"suppressUpdateViewVisibility\":false,\"currentViewContainerId\":\"debug\"}"}}],"title":{"label":"debug","iconClass":"codicon codicon-debug-alt","closeable":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{"parts":[{"partId":"search-in-workspace","collapsed":false,"hidden":false,"originalContainerId":"search-view-container","originalContainerTitle":{"label":"Search","iconClass":"codicon codicon-search","closeable":true},"widget":{"constructionOptions":{"factoryId":"search-in-workspace"},"innerWidgetState":"{\"matchCaseState\":{\"className\":\"codicon codicon-case-sensitive\",\"enabled\":false,\"title\":\"Match Case\"},\"wholeWordState\":{\"className\":\"codicon codicon-whole-word\",\"enabled\":false,\"title\":\"Match Whole Word\"},\"regExpState\":{\"className\":\"codicon codicon-regex\",\"enabled\":false,\"title\":\"Use Regular Expression\"},\"includeIgnoredState\":{\"className\":\"codicon codicon-eye\",\"enabled\":false,\"title\":\"Include Ignored Files\"},\"showSearchDetails\":false,\"searchInWorkspaceOptions\":{\"matchCase\":false,\"matchWholeWord\":false,\"useRegExp\":false,\"includeIgnored\":false,\"include\":[],\"exclude\":[],\"maxResults\":2000},\"searchTerm\":\"\",\"replaceTerm\":\"\",\"showReplaceField\":false,\"searchHistoryState\":{\"history\":[],\"index\":0},\"replaceHistoryState\":{\"history\":[],\"index\":0},\"includeHistoryState\":{\"history\":[],\"index\":0},\"excludeHistoryState\":{\"history\":[],\"index\":0}}"}}],"title":{"label":"Search","iconClass":"fa fa-arduino-search","closeable":true}}"},"rank":5,"expanded":false,"pinned":false}],"size":268},"rightPanel":{"type":"sidepanel","items":[]},"activeWidgetId":"outputView"}
2024-05-06T13:14:24.382Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2024-05-06T13:14:24.433Z root INFO [97a2f2f6-8d9c-4a10-9306-4ff06f03467d] Waiting for backend deployment: 57.7 ms [Finished 1.149 s after frontend start]
2024-05-06T13:14:24.701Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632) starting instance
2024-05-06T13:14:25.709Z root INFO [97a2f2f6-8d9c-4a10-9306-4ff06f03467d] Sync of 23 plugins: 1316.7 ms [Finished 2.466s after frontend start]
2024-05-06T13:14:25.880Z root INFO <<< The layout has been successfully restored.
2024-05-06T13:14:25.923Z root INFO Initialize the workbench layout: 1527.1 ms [Finished 2.639 s after frontend start]
2024-05-06T13:14:25.924Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2024-05-06T13:14:25.925Z root INFO [97a2f2f6-8d9c-4a10-9306-4ff06f03467d] Loading plugin contributions
2024-05-06T13:14:25.925Z root INFO [97a2f2f6-8d9c-4a10-9306-4ff06f03467d] Load contributions of 23 plugins: 41.9 ms [Finished 2.681 s after frontend start]
2024-05-06T13:14:25.929Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2024-05-06T13:14:25.929Z root WARN a registered grammar configuration for 'cpp' language is overridden
2024-05-06T13:14:26.009Z root ERROR [hosted-plugin: 18632] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
2024-05-06T13:14:26.009Z root ERROR [hosted-plugin: 18632] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.windows as cortex-debug.armToolchainPath is null
2024-05-06T13:14:26.009Z root ERROR [hosted-plugin: 18632] Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
2024-05-06T13:14:26.009Z root ERROR [hosted-plugin: 18632] Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
2024-05-06T13:14:26.009Z root ERROR [hosted-plugin: 18632] Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
2024-05-06T13:14:26.009Z root ERROR [hosted-plugin: 18632] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
2024-05-06T13:14:26.009Z root ERROR [hosted-plugin: 18632] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
2024-05-06T13:14:26.009Z root ERROR [hosted-plugin: 18632] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
2024-05-06T13:14:26.009Z root ERROR [hosted-plugin: 18632] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
2024-05-06T13:14:26.009Z root ERROR [hosted-plugin: 18632] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
2024-05-06T13:14:26.009Z root ERROR [hosted-plugin: 18632] Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
2024-05-06T13:14:26.009Z root ERROR [hosted-plugin: 18632] Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.osx as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
2024-05-06T13:14:26.009Z root ERROR [hosted-plugin: 18632] Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer isnull
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2024-05-06T13:14:26.213Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): PluginManagerExtImpl/init()
2024-05-06T13:14:26.215Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): initializing(vscode-arduino-api@0.1.2 with C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-05-06T13:14:26.301Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): initializing(cortex-debug@1.5.1 with C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-05-06T13:14:26.301Z root INFO [hosted-plugin: 18632] Debugger contribution has been registered: cortex-debug
2024-05-06T13:14:26.301Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): initializing(vscode-arduino-tools@0.1.3 with C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-05-06T13:14:26.302Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): initializing(cpp@1.52.1 with C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-05-06T13:14:26.302Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): initializing(json@1.46.1 with C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-05-06T13:14:26.303Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): initializing(json-language-features@1.46.1 with C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-05-06T13:14:26.303Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): initializing(vscode-language-pack-bg@1.48.3 with C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-05-06T13:14:26.304Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): initializing(vscode-language-pack-cs@1.80.0 with C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-05-06T13:14:26.304Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): initializing(vscode-language-pack-de@1.80.0 with C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-05-06T13:14:26.305Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): initializing(vscode-language-pack-es@1.80.0 with C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-05-06T13:14:26.305Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): initializing(vscode-language-pack-fr@1.80.0 with C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-05-06T13:14:26.305Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): initializing(vscode-language-pack-hu@1.48.3 with C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-05-06T13:14:26.306Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): initializing(vscode-language-pack-it@1.80.0 with C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-05-06T13:14:26.306Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): initializing(vscode-language-pack-ja@1.80.0 with C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-05-06T13:14:26.306Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): initializing(vscode-language-pack-ko@1.80.0 with C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-05-06T13:14:26.306Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): initializing(vscode-language-pack-nl@1.48.3 with C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-05-06T13:14:26.307Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): initializing(vscode-language-pack-pl@1.80.0 with C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-05-06T13:14:26.307Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): initializing(vscode-language-pack-pt-BR@1.80.0 with C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-05-06T13:14:26.307Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): initializing(vscode-language-pack-ru@1.80.0 with C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-05-06T13:14:26.307Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): initializing(vscode-language-pack-tr@1.80.0 with C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-05-06T13:14:26.307Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): initializing(vscode-language-pack-uk@1.48.3 with C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-05-06T13:14:26.308Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): initializing(vscode-language-pack-zh-hans@1.80.0 with C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-05-06T13:14:26.308Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): initializing(vscode-language-pack-zh-hant@1.80.0 with C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-05-06T13:14:26.310Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): PluginManagerExtImpl/loadPlugin(C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-api\extension\dist\extension.js)
2024-05-06T13:14:26.312Z root INFO [hosted-plugin: 18632] calling activation function on Arduino IDE API for VS Code extensions
2024-05-06T13:14:26.313Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): PluginManagerExtImpl/loadPlugin(C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2024-05-06T13:14:26.331Z root INFO [hosted-plugin: 18632] calling activation function on JSON Language Features (built-in)
2024-05-06T13:14:26.365Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): PluginManagerExtImpl/loadPlugin(C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\extension.js)
2024-05-06T13:14:26.392Z root INFO [hosted-plugin: 18632] calling activation function on VS Code Arduino Tools
2024-05-06T13:14:26.415Z root INFO [97a2f2f6-8d9c-4a10-9306-4ff06f03467d] Starting plugins.
2024-05-06T13:14:26.417Z root INFO [hosted-plugin: 18632] PLUGIN_HOST(18632): PluginManagerExtImpl/loadPlugin(C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2024-05-06T13:14:26.629Z root ERROR ---- !!!SLOW!!! DURATION: search took 260.492 ms. Args: [{"query":"","type":"All","topic":"All"}] ----
2024-05-06T13:14:26.630Z root INFO [hosted-plugin: 18632] Debug configuration provider has been registered: cortex-debug, trigger: 1
calling activation function on Cortex-Debug
GDB server console created
2024-05-06T13:14:26.686Z root INFO [97a2f2f6-8d9c-4a10-9306-4ff06f03467d] Start of 23 plugins: 760.8 ms [Finished 3.445s after frontend start]
2024-05-06T13:14:26.880Z root INFO Frontend application start: 2653.1 ms [Finished 3.999 s after backend start]
Checking for update
2024-05-06T13:14:26.895Z root INFO Replace loading indicator with ready workbench UI (animation): 828.3 ms [Finished 3.511 s after frontend start]
2024-05-06T13:14:26.896Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2024-05-06T13:14:26.896Z root WARN Linked preference "workbench.colorCustomizations" not found.
2024-05-06T13:14:27.136Z root ERROR ---- !!!SLOW!!! DURATION: search took 240.321 ms. Args: [{"type":"Updatable"}] ----
2024-05-06T13:14:27.137Z root INFO Starting language server: arduino:avr:uno
2024-05-06T13:14:27.140Z daemon INFO time="2024-05-06T16:14:27+03:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
time="2024-05-06T16:14:27+03:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2024-05-06T16:14:27+03:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
time="2024-05-06T16:14:27+03:00" level=info msg="Tool required for debug" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2024-05-06T16:14:27+03:00" level=info msg="Tool required for debug" tool="esp32:esptool_py@4.5.1"
time="2024-05-06T16:14:27+03:00" level=info msg="Tool required for debug" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2024-05-06T16:14:27+03:00" level=info msg="Tool required for debug" tool="builtin:mdns-discovery@1.0.9"
time="2024-05-06T16:14:27+03:00" level=info msg="Tool required for debug" tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-05-06T16:14:27+03:00" level=info msg="Tool required for debug" tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
time="2024-05-06T16:14:27+03:00" level=info msg="Tool required for debug" tool="esp32:mkspiffs@0.2.3"
time="2024-05-06T16:14:27+03:00" level=info msg="Tool required for debug" tool="arduino:bossac@1.9.1-arduino5"
time="2024-05-06T16:14:27+03:00" level=info msg="Tool required for debug" tool="builtin:dfu-discovery@0.1.2"
time="2024-05-06T16:14:27+03:00" level=info msg="Tool required for debug" tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
time="2024-05-06T16:14:27+03:00" level=info msg="Tool required for debug" tool="builtin:serial-monitor@0.14.1"
time="2024-05-06T16:14:27+03:00" level=info msg="Tool required for debug" tool="arduino:openocd@0.11.0-arduino2"
time="2024-05-06T16:14:27+03:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
time="2024-05-06T16:14:27+03:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
time="2024-05-06T16:14:27+03:00" level=info msg="Tool required for debug" tool="builtin:serial-discovery@1.4.0"
2024-05-06T13:14:27.141Z root ERROR Failed to get debug config: arduino:avr:uno, undefined Error: Debugging is not supported.
at Object.callback (C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:81340)
at Object.onReceiveStatus (C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:788706)
at Object.onReceiveStatus (C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:784657)
at Object.onReceiveStatus (C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:784102)
at C:\Users\rimms\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:870224
at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
2024-05-06T13:14:27.141Z root ERROR Request checkDebugEnabled failed with error: Debugging is not supported. Error: Debugging is not supported.
Update for version 2.3.2 is not available (latest version: 2.3.2, downgrade is allowed).
2024-05-06T13:14:27.496Z daemon INFO time="2024-05-06T16:14:27+03:00" level=info msg="Adding libraries dir" dir="C:\Users\rimms\AppData\Local\Arduino15\libraries" location=ide
2024-05-06T13:14:27.496Z daemon INFO time="2024-05-06T16:14:27+03:00" level=info msg="Adding libraries dir" dir="C:\Users\rimms\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries" location=platform
2024-05-06T13:14:27.497Z daemon INFO time="2024-05-06T16:14:27+03:00" level=info msg="Adding libraries dir" dir="c:\Users\rimms\OneDrive\المستندات\Arduino\libraries" location=user
2024-05-06T13:14:27.736Z daemon INFO time="2024-05-06T16:14:27+03:00" level=info msg="Resolving include Wire.h for archavr"
time="2024-05-06T16:14:27+03:00" level=info msg=" found better lib" lib=Wire prio=6B0
2024-05-06T13:14:27.772Z daemon INFO time="2024-05-06T16:14:27+03:00" level=info msg="Resolving include LiquidCrystal_I2C.h for arch avr"
time="2024-05-06T16:14:27+03:00" level=info msg=" found better lib" lib="LiquidCrystal I2C" prio=6B1
2024-05-06T13:14:28.415Z daemon INFO time="2024-05-06T16:14:28+03:00" level=info msg="Adding libraries dir" dir="C:\Users\rimms\AppData\Local\Arduino15\libraries" location=ide
2024-05-06T13:14:28.416Z daemon INFO time="2024-05-06T16:14:28+03:00" level=info msg="Adding libraries dir" dir="C:\Users\rimms\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries" location=platform
2024-05-06T13:14:28.416Z daemon INFO time="2024-05-06T16:14:28+03:00" level=info msg="Adding libraries dir" dir="c:\Users\rimms\OneDrive\المستندات\Arduino\libraries" location=user
I moved your topic to an appropriate forum category @rimk.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Hi @rimk
Unfortunately there is a bug in the sketch compiler that causes it to fail to find the library when it is installed under a path that contains this sort of character:
The workaround will be to configure Arduino IDE to use a different path to store libraries. I'll provide instructions you can follow to do that:
  1. Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
    The "Preferences" dialog will open.
  2. Click the "BROWSE" button on the right side of the "Sketchbook location" field.
    The "Select a new sketchbook location" dialog will open.
  3. Select a folder in any location that contains only basic ASCII characters (the characters A-z, 0-9, _, -, . are safe).
    :warning: Make sure to pick a location that will be safe to store your files since, in addition to containing installed libraries, the sketchbook is a convenient location to save your sketches.
  4. Click the "Choose" button in the "Select a new sketchbook location" dialog.
  5. Click the "OK" button in the "Preferences" dialog.
  6. Move all the files from the folder at the path of the old sketchbook location:
    to the folder at the path of the new sketchbook location you set in the Arduino IDE preferences.
Once you have finished performing the instructions above, try compiling your sketch again. Hopefully the compilation will be successful this time.
