Hi. I am running a 2015 MacBook Pro with macOS Monterey (I couldn't find any topics for this issue related to Macs). My arduino software (2.x) worked really well for a time, but then it suddenly wouldn't get past the pulsing logo loading screen. I re-downloaded it, but I still have the same issue. Any ideas?
Hi @m1cah2010. I'm going to ask you to run Arduino IDE from the command line, then post the output in a reply here.
This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
- Close all Arduino IDE windows if the IDE is already running.
- Open your Applications folder in Finder.
- Open the Utilities folder.
- Double-click on "Terminal".
- Type the following command in the Terminal window:
"/Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE"
- Press Enter
- Wait until you are sure the IDE startup has gone into the hang state
(as indicated by no additional output being printed to the Terminal window). - Switch back to the Terminal window if the Arduino IDE window took the focus.
- Press ⌘+A.
This will select all the text in the Terminal window. - Press ⌘+C.
This will copy the selected text to the clipboard. - Open a forum reply here by clicking the "Reply" button.
- Click the
<CODE/>
icon on the post composer toolbar.
This will add the forum's code block markup (```
) to your reply to make sure the output is correctly formatted.
- Press ⌘+V.
This will paste the output into the code block. - Move the cursor outside of the code block markup before you add any additional text to your reply.
- Click the "Reply" button to post the output.
Please let me know if you have any questions or problems while following those instructions.
This is only a section. It keeps repeating the same message forever until I close the app:
Micah@Mac-M ~ % "/Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE"
Arduino IDE 2.2.2-nightly-20230926
Checking for frontend application configuration customizations. Module path: /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/electron-main.js, destination 'package.json': /Applications/Arduino IDE.app/Contents/Resources/app/package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.2.2-nightly-20230926" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.34.0" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2023-09-26T03:24:59.799Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.2.2-nightly-20230926","cliVersion":"0.34.0","buildDate":"2023-09-26T03:24:59.799Z"}
Starting backend process. PID: 95414
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///Users/Micah/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-09-27T17:54:38.096Z root INFO Backend Object.initialize: 8.8 ms [Finished 0.760 s after backend start]
2023-09-27T17:54:38.098Z root INFO Backend Object.configure: 7.7 ms [Finished 0.760 s after backend start]
2023-09-27T17:54:38.099Z root INFO Backend a.onStart: 2.0 ms [Finished 0.760 s after backend start]
2023-09-27T17:54:38.102Z root INFO Backend a.configure: 1.9 ms [Finished 0.862 s after backend start]
2023-09-27T17:54:38.104Z root INFO Backend u.onStart: 1.9 ms [Finished 0.862 s after backend start]
2023-09-27T17:54:38.108Z root INFO Backend d.configure: 1.3 ms [Finished 0.864 s after backend start]
2023-09-27T17:54:38.111Z root WARN Backend d.initialize took longer than the expected maximum 50 milliseconds: 104.4 ms [Finished 0.865 s after backend start]
2023-09-27T17:54:38.112Z root INFO Backend c.onStart: 1.1 ms [Finished 0.865 s after backend start]
2023-09-27T17:54:38.115Z root INFO Backend s.configure: 5.7 ms [Finished 0.871 s after backend start]
2023-09-27T17:54:38.123Z config INFO >>> Initializing CLI configuration...
2023-09-27T17:54:38.123Z root INFO Backend c.initialize: 1.5 ms [Finished 0.872 s after backend start]
2023-09-27T17:54:38.125Z root INFO Backend P.onStart: 3.4 ms [Finished 0.874 s after backend start]
2023-09-27T17:54:38.130Z config INFO Loading CLI configuration from /Users/Micah/.arduinoIDE/arduino-cli.yaml...
2023-09-27T17:54:38.136Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:38.142Z root INFO Backend s.initialize: 1.4 ms [Finished 0.878 s after backend start]
2023-09-27T17:54:38.143Z root INFO Backend w.onStart: 4.8 ms [Finished 0.882 s after backend start]
2023-09-27T17:54:38.144Z root INFO Backend r.configure: 8.0 ms [Finished 0.882 s after backend start]
2023-09-27T17:54:38.144Z discovery-log INFO start
2023-09-27T17:54:38.145Z discovery-log INFO start new deferred
2023-09-27T17:54:38.145Z root INFO Backend d.initialize: 2.0 ms [Finished 0.886 s after backend start]
2023-09-27T17:54:38.145Z root INFO Backend y.onStart: 9.9 ms [Finished 0.894 s after backend start]
2023-09-27T17:54:38.146Z root INFO Backend r.configure: 8.1 ms [Finished 0.895 s after backend start]
2023-09-27T17:54:38.146Z root INFO Backend s.onStart: 7.2 ms [Finished 0.912 s after backend start]
2023-09-27T17:54:38.147Z root INFO Backend h.configure: 8.1 ms [Finished 0.913 s after backend start]
2023-09-27T17:54:38.147Z root INFO Backend a.configure: 1.3 ms [Finished 0.916 s after backend start]
2023-09-27T17:54:38.147Z root INFO Backend s.configure: 0.2 ms [Finished 0.916 s after backend start]
2023-09-27T17:54:38.147Z root INFO Backend l.configure: 0.2 ms [Finished 0.917 s after backend start]
2023-09-27T17:54:38.151Z root INFO Theia app listening on http://localhost:57522.
2023-09-27T17:54:38.152Z root INFO Finished starting backend application: 6.8 ms [Finished 0.921 s after backend start]
2023-09-27T17:54:38.159Z root WARN The local plugin referenced by local-dir:/Users/Micah/.arduinoIDE/plugins does not exist.
2023-09-27T17:54:38.160Z root WARN The local plugin referenced by local-dir:/Users/Micah/.arduinoIDE/extensions does not exist.
Restoring workspace roots: /Users/Micah/Documents/Arduino/My Arduino/CEB_Circuit/CEB_Circuit.ino
isTempSketch: false. Input was /Users/Micah/Documents/Arduino/My Arduino/CEB_Circuit/CEB_Circuit.ino
2023-09-27T17:54:38.390Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"/Users/kidshall/Library/Arduino15","downloads":"/Users/kidshall/Library/Arduino15/staging","user":"/Users/kidshall/Documents/Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-09-27T17:54:38.391Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-09-27T17:54:38.391Z config INFO Loaded the CLI configuration.
2023-09-27T17:54:38.406Z config WARN Could not ensure user directory existence: /Users/kidshall/Documents/Arduino Error: EACCES: permission denied, mkdir '/Users/kidshall'
2023-09-27T17:54:38.407Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///Users/kidshall/Library/Arduino15","sketchDirUri":"file:///Users/kidshall/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2023-09-27T17:54:38.408Z config INFO Validating the CLI configuration...
2023-09-27T17:54:38.408Z root ERROR Check accessible failed for input: /Users/kidshall/Documents/Arduino Error: ENOENT: no such file or directory, scandir '/Users/kidshall/Documents/Arduino'
2023-09-27T17:54:38.409Z config ERROR Failed to initialize the CLI configuration. Error: InvalidConfigError:
- Could not access the sketchbook location at '/Users/kidshall/Documents/Arduino': Error: ENOENT: no such file or directory, scandir '/Users/kidshall/Documents/Arduino'
at P.validateCliConfig (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:579373)
at async P.initConfig (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:577192)
2023-09-27T17:54:38.414Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:38.415Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
at Socket.<anonymous> (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:46444)
at Socket.emit (node:events:513:28)
at addChunk (node:internal/streams/readable:324:12)
at readableAddChunk (node:internal/streams/readable:297:9)
at Readable.push (node:internal/streams/readable:234:10)
at Pipe.onStreamRead (node:internal/stream_base_commons:190:23)
2023-09-27T17:54:38.415Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:38.417Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:38.441Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:38.442Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:38.444Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:38.445Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:38.471Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:38.472Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:38.472Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:38.473Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:38.481Z root INFO Resolve plugins list: 353.1 ms [Finished 1.250 s after backend start]
2023-09-27T17:54:38.500Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:38.500Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:38.501Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:38.507Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:38.561Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:38.562Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:38.563Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:38.563Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:38.603Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:38.603Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:38.610Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:38.611Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:38.760Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:38.761Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:38.761Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:38.761Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:38.956Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:38.957Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:38.957Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:38.957Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:39.168Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:39.169Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:39.169Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:39.170Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:39.286Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:39.286Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:39.287Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:39.287Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:39.592Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:39.593Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:39.593Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:39.594Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:39.873Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:39.883Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:39.884Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:39.886Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:40.379Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:40.380Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:40.380Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:40.383Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:40.642Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:40.642Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:40.642Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:40.643Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:40.891Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:40.891Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:40.892Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:40.892Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:41.130Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.133Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.133Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:41.134Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:41.321Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.322Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.322Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:41.323Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:41.338Z root INFO Deploy plugins list: 353.1 ms [Finished 4.108 s after backend start]
2023-09-27T17:54:41.340Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.341Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.341Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:41.342Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:41.369Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.370Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.370Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:41.371Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:41.428Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.429Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.429Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:41.429Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:41.478Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.480Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.480Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:41.480Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:41.559Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.564Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.570Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:41.577Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:41.608Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.608Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.609Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:41.609Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:41.636Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.637Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.637Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:41.638Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:41.665Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.665Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.666Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:41.666Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:41.692Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.693Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.693Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:41.694Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:41.712Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.712Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.718Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:41.719Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:41.743Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.744Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.744Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:41.745Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:41.763Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.764Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.767Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:41.767Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:41.798Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.799Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.799Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:41.800Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:41.822Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.822Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.822Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:41.823Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:41.849Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.850Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.850Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:41.851Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:41.871Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.872Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.872Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:41.873Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:41.893Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.895Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.896Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:41.900Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:41.923Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.923Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.924Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:41.928Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:41.954Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.956Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.956Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:41.956Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:41.981Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.981Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:41.982Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:41.982Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:42.003Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.005Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.005Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:42.007Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:42.034Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.035Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.035Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:42.036Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:42.061Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.061Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.062Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:42.062Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:42.083Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.084Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.084Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:42.085Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:42.109Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.111Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.111Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:42.112Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:42.133Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.135Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.135Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:42.137Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:42.167Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.167Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.167Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:42.168Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:42.188Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.189Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.189Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:42.192Z daemon INFO Daemon exited with exit code: 7.
Opening channel for service path '/services/electron-window'.
2023-09-27T17:54:42.221Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.222Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.222Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:42.222Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:42.243Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.243Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.244Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:42.244Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:42.272Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.272Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.273Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:42.273Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:42.292Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.293Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.293Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:42.294Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:42.312Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.313Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.314Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:42.316Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:42.347Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.348Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.348Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:42.348Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:42.380Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.381Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.381Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:42.382Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:42.403Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.403Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.404Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:42.404Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:42.431Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.431Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.432Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:42.432Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:42.454Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.454Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.454Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:42.455Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:42.479Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.479Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.479Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:42.480Z daemon INFO Daemon exited with exit code: 7.
2023-09-27T17:54:42.509Z daemon INFO Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.510Z daemon ERROR Error: Error: invalid path creating config dir: /Users/kidshall/Library/Arduino15 error: mkdir /Users/kidshall: permission denied
2023-09-27T17:54:42.510Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-09-27T17:54:42.511Z daemon INFO Daemon exited with exit code: 7.
2
OK, great. That is useful.
Is your current macOS username "kidshall"?
I ask because one possible cause of this "permission denied" error is changing your macOS username. Arduino IDE generates some configuration files. If those files were generated at a time you had a different macOS username, the paths in the configuration data point to locations under the folder for the old username. After you change your username, the IDE can no longer access those locations, which causes a "permission denied" error.
Yes, my username is now Micah. I have changed it. The weird thing is that I re-installed it after I changed my username. Is there a way we can get it to stop looking for the files in that username?
I'll provide instructions you can follow to fix the configuration:
- Close any Arduino IDE windows if they are open.
- Open the file at the following path in any text editor:
(where/Users/<username>/.arduinoIDE/arduino-cli.yaml
<username>
is your macOS username) - Change all occurrences of
kidshall
in the file to your new macOS username (" Micah"). - Save the file.
Now try starting Arduino IDE again. Hopefully it will start up completely and be fully fuctional.
