💡 Instead of creating your report here, use 'Report Issue' from the 'Help' menu …in VS Code to pre-fill useful information.
--Not able to access Help menu
Does this issue occur when all extensions are disabled?: Yes
- VS Code Version:
CLI
code 1.84.2 (commit 1a5daa3a0231a0fbba4f14db7ec463cf99d7768e)
App bundle:
1.84.2
1.85.0-insider
- OS Version:
14.2 Beta1 Beta2 Beta3
Steps to Reproduce:
1. Open vs code (CLI Double click)
2. VS code shown as blank, with no menu bar, or any window, just a close button.
Tried to Remove VS code
Tried clean uninstall - Delete $HOME/Library/Application Support/Code and ~/.vscode.
./code --verbose
[1117/161753.012728:ERROR:crash_report_database_mac.mm(753)] open lock /Users/jianchao/Library/Application Support/Code/Crashpad/pending/e4532cce-804d-4e6b-9971-04b271917a90.dmp: Resource temporarily unavailable (35)
2023-11-17 16:17:53.032 Electron[8913:112380] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
[8918:1117/161753.050328:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[8918:1117/161753.050651:WARNING:network_service.cc(217)] Mojo error in NetworkService: Received bad user message: Validation failed for network.mojom.NetworkService.4 [VALIDATION_ERROR_DESERIALIZATION_FAILED]
[main 2023-11-17T08:17:53.092Z] [File Watcher (node.js)] Request to start watching: /Users/jianchao/Library/Application Support/Code/User (excludes: <none>, includes: <all>, correlationId: <none>),/Users/jianchao/Library/Application Support/Code/User/settings.json (excludes: <none>, includes: <all>, correlationId: <none>)
[main 2023-11-17T08:17:53.096Z] Sending env to running instance...
[main 2023-11-17T08:17:53.097Z] [File Watcher (node.js)] Error: ENOENT: no such file or directory, stat '/Users/jianchao/Library/Application Support/Code/User/settings.json'
[main 2023-11-17T08:17:53.098Z] [File Watcher (node.js)] Started watching: '/Users/jianchao/Library/Application Support/Code/User'
[main 2023-11-17T08:17:53.147Z] Sent env to running instance. Terminating...
[main 2023-11-17T08:17:53.147Z] Lifecycle#kill()
[main 2023-11-17T08:17:53.147Z] Lifecycle#onWillShutdown.fire()
[1117/161753.191583:ERROR:directory_reader_posix.cc(42)] opendir /Users/jianchao/Library/Application Support/Code/Crashpad/attachments/9971181e-5ea0-4860-9c28-47716f673620: No such file or directory (2)
[8918:1117/161753.288011:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
./Electron --verbose
[1117/161427.386310:ERROR:crash_report_database_mac.mm(753)] open lock /Users/jianchao/Library/Application Support/Code/Crashpad/pending/9a0f12ca-9246-4429-be7f-b2f7c2999b84.dmp: Resource temporarily unavailable (35)
2023-11-17 16:14:27.403 Electron[8531:107062] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
[8535:1117/161427.421867:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[main 2023-11-17T08:14:27.461Z] [File Watcher (node.js)] Request to start watching: /Users/jianchao/Library/Application Support/Code/User (excludes: <none>, includes: <all>, correlationId: <none>),/Users/jianchao/Library/Application Support/Code/User/settings.json (excludes: <none>, includes: <all>, correlationId: <none>)
[main 2023-11-17T08:14:27.470Z] Starting VS Code
[main 2023-11-17T08:14:27.470Z] from: /Applications/Visual Studio Code.app/Contents/Resources/app
[main 2023-11-17T08:14:27.470Z] args: {
_: [],
diff: false,
merge: false,
add: false,
goto: false,
'new-window': false,
'reuse-window': false,
wait: false,
help: false,
'list-extensions': false,
'show-versions': false,
'pre-release': false,
version: false,
verbose: true,
status: false,
'prof-startup': false,
'no-cached-data': false,
'prof-v8-extensions': false,
'disable-extensions': false,
'disable-gpu': false,
'disable-chromium-sandbox': false,
'ms-enable-electron-run-as-node': false,
telemetry: false,
debugRenderer: false,
'enable-smoke-test-driver': false,
logExtensionHostCommunication: false,
'skip-release-notes': false,
'skip-welcome': false,
'disable-telemetry': false,
'disable-updates': false,
'use-inmemory-secretstorage': false,
'disable-workspace-trust': false,
'disable-crash-reporter': false,
'crash-reporter-id': '29be037f-7578-45dd-a0b3-b5e52f924e7f',
'skip-add-to-recently-opened': false,
'unity-launch': false,
'open-url': false,
'file-write': false,
'file-chmod': false,
force: false,
'do-not-sync': false,
trace: false,
'force-user-env': false,
'force-disable-user-env': false,
'open-devtools': false,
'disable-gpu-sandbox': false,
'__enable-file-policy': false,
'enable-coi': false,
'no-proxy-server': false,
'no-sandbox': false,
nolazy: false,
'force-renderer-accessibility': false,
'ignore-certificate-errors': false,
'allow-insecure-localhost': false,
'disable-dev-shm-usage': false,
'profile-temp': false,
logsPath: '/Users/jianchao/Library/Application Support/Code/logs/20231117T161427'
[main 2023-11-17T08:14:27.471Z] Resolving machine identifier...
[main 2023-11-17T08:14:27.471Z] Resolved machine identifier: d87a1dc09175cfbf244b6510461983d7d38fb57baae9ea422e8549b411d9f35d
[main 2023-11-17T08:14:27.471Z] Main->SharedProcess#connect
[main 2023-11-17T08:14:27.473Z] StorageMainService: creating application storage
[main 2023-11-17T08:14:27.474Z] ElectronURLListener: waiting for window to be ready to handle URLs...
[main 2023-11-17T08:14:27.474Z] lifecycle (main): phase changed (value: 2)
[main 2023-11-17T08:14:27.474Z] windowsManager#open
[main 2023-11-17T08:14:27.474Z] windowsManager#open pathsToOpen [
backupPath: '/Users/jianchao/Library/Application Support/Code/Backups/1700206242876',
remoteAuthority: undefined
[main 2023-11-17T08:14:27.474Z] windowsManager#doOpenEmpty {
restore: true,
remoteAuthority: undefined,
filesToOpen: undefined,
forceNewWindow: true
[main 2023-11-17T08:14:27.475Z] IPC Object URL: Registered new channel vscode:79d70a8f-a649-4814-bb5f-104a679de298.
[main 2023-11-17T08:14:27.475Z] window#validateWindowState: validating window state on 2 display(s) { mode: 1, x: 704, y: 264, width: 1024, height: 768 }
[main 2023-11-17T08:14:27.479Z] window#validateWindowState: multi-monitor working area { x: 0, y: 38, width: 1728, height: 1079 }
[main 2023-11-17T08:14:27.479Z] window#ctor: using window state { mode: 1, x: 704, y: 264, width: 1024, height: 768 }
[main 2023-11-17T08:14:27.510Z] window#load: attempt to load window (id: 1)
[main 2023-11-17T08:14:27.517Z] windowsManager#open used window count 1 (workspacesToOpen: 0, foldersToOpen: 0, emptyToRestore: 1, emptyToOpen: 0)
[main 2023-11-17T08:14:27.517Z] lifecycle (main): phase changed (value: 3)
[main 2023-11-17T08:14:27.517Z] resolveShellEnv(): running (macOS/Linux)
[main 2023-11-17T08:14:27.517Z] getUnixShellEnvironment#runAsNode undefined
[main 2023-11-17T08:14:27.517Z] getUnixShellEnvironment#noAttach undefined
[main 2023-11-17T08:14:27.518Z] getUnixShellEnvironment#env {
TERM_SESSION_ID: 'w0t0p0:AFDDB487-D1A3-4C75-BDA2-DAA2B3FCA6DA',
SSH_AUTH_SOCK: '/private/tmp/com.apple.launchd.f4b8IoiKFY/Listeners',
LC_TERMINAL_VERSION: '3.4.22',
COLORFGBG: '7;0',
ITERM_PROFILE: 'Default',
XPC_FLAGS: '0x0',
PWD: '/Applications/Visual Studio Code.app/Contents/MacOS',
SHELL: '/bin/zsh',
__CFBundleIdentifier: 'com.googlecode.iterm2',
SECURITYSESSIONID: '186ab',
LC_CTYPE: 'UTF-8',
TERM_PROGRAM_VERSION: '3.4.22',
NARRATIVE_CLIENT_SOCK: '/private/tmp/com.apple.launchd.EE9fbjfDWp/Listeners',
PATH: '/Users/jianchao/Library/Python/3.9/bin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/homebrew/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/Applications/Wireshark.app/Contents/MacOS:/usr/local/share/dotnet:~/.dotnet/tools',
TERM_PROGRAM: 'iTerm.app',
LC_TERMINAL: 'iTerm2',
COLORTERM: 'truecolor',
COMMAND_MODE: 'unix2003',
TERM: 'xterm-256color',
HOME: '/Users/jianchao',
TMPDIR: '/var/folders/vk/75nn6wts2j53wfngs35pw8n40000gn/T/',
USER: 'jianchao',
XPC_SERVICE_NAME: '0',
LOGNAME: 'jianchao',
LaunchInstanceID: '504AB7F7-C535-4388-9F23-A5C7C696F79D',
__CF_USER_TEXT_ENCODING: '0x1F5:0x0:0x0',
ITERM_SESSION_ID: 'w0t0p0:AFDDB487-D1A3-4C75-BDA2-DAA2B3FCA6DA',
SHLVL: '1',
OLDPWD: '/Applications/Visual Studio Code.app/Contents',
P9K_TTY: 'old',
_P9K_TTY: '/dev/ttys000',
ZSH: '/Users/jianchao/.oh-my-zsh',
PAGER: 'less',
LESS: '-R',
LSCOLORS: 'Gxfxcxdxbxegedabagacad',
LS_COLORS: 'di=1;36:ln=35:so=32:pi=33:ex=31:bd=34;46:cd=34;43:su=30;41:sg=30;46:tw=30;42:ow=30;43',
P9K_SSH: '0',
_P9K_SSH_TTY: '/dev/ttys000',
_: '/Applications/Visual Studio Code.app/Contents/MacOS/./Electron',
ORIGINAL_XDG_CURRENT_DESKTOP: 'undefined',
VSCODE_CWD: '/Applications/Visual Studio Code.app/Contents/MacOS',
VSCODE_NLS_CONFIG: '{"locale":"en-us","osLocale":"en-cn","availableLanguages":{},"_languagePackSupport":true}',
VSCODE_CODE_CACHE_PATH: '/Users/jianchao/Library/Application Support/Code/CachedData/1a5daa3a0231a0fbba4f14db7ec463cf99d7768e',
VSCODE_IPC_HOOK: '/Users/jianchao/Library/Application Support/Code/1.84-main.sock',
VSCODE_PID: '8531',
ELECTRON_RUN_AS_NODE: '1',
ELECTRON_NO_ATTACH_CONSOLE: '1',
VSCODE_RESOLVING_ENVIRONMENT: '1'
[main 2023-11-17T08:14:27.520Z] getUnixShellEnvironment#shell /bin/zsh
[main 2023-11-17T08:14:27.520Z] getUnixShellEnvironment#spawn ["-i","-l","-c"] '/Applications/Visual Studio Code.app/Contents/MacOS/Electron' --ms-enable-electron-run-as-node -p '"27244601c26a" + JSON.stringify(process.env) + "27244601c26a"'
[main 2023-11-17T08:14:27.523Z] update#setState idle
[1117/161427.561841:ERROR:directory_reader_posix.cc(42)] opendir /Users/jianchao/Library/Application Support/Code/Crashpad/attachments/b4462f05-3d13-45a5-8d91-89957517e5c0: No such file or directory (2)
[8535:1117/161427.598907:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
[8531:1117/161427.689267:ERROR:network_service_instance_impl.cc(558)] Network service crashed, restarting service.
[main 2023-11-17T08:14:27.692Z] [File Watcher (node.js)] Error: ENOENT: no such file or directory, stat '/Users/jianchao/Library/Application Support/Code/User/settings.json'
[main 2023-11-17T08:14:27.698Z] [File Watcher (node.js)] Started watching: '/Users/jianchao/Library/Application Support/Code/User'
[main 2023-11-17T08:14:27.722Z] getUnixShellEnvironment#raw 27244601c26a{"TERM_SESSION_ID":"w0t0p0:AFDDB487-D1A3-4C75-BDA2-DAA2B3FCA6DA","SSH_AUTH_SOCK":"/private/tmp/com.apple.launchd.f4b8IoiKFY/Listeners","LC_TERMINAL_VERSION":"3.4.22","COLORFGBG":"7;0","ITERM_PROFILE":"Default","XPC_FLAGS":"0x0","PWD":"/Applications/Visual Studio Code.app/Contents/MacOS","SHELL":"/bin/zsh","__CFBundleIdentifier":"com.googlecode.iterm2","SECURITYSESSIONID":"186ab","LC_CTYPE":"UTF-8","TERM_PROGRAM_VERSION":"3.4.22","NARRATIVE_CLIENT_SOCK":"/private/tmp/com.apple.launchd.EE9fbjfDWp/Listeners","PATH":"/Users/jianchao/Library/Python/3.9/bin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/homebrew/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/Applications/Wireshark.app/Contents/MacOS:/usr/local/share/dotnet:~/.dotnet/tools:/Users/jianchao/Library/Python/3.9/bin","TERM_PROGRAM":"iTerm.app","LC_TERMINAL":"iTerm2","COLORTERM":"truecolor","COMMAND_MODE":"unix2003","TERM":"xterm-256color","HOME":"/Users/jianchao","TMPDIR":"/var/folders/vk/75nn6wts2j53wfngs35pw8n40000gn/T/","USER":"jianchao","XPC_SERVICE_NAME":"0","LOGNAME":"jianchao","LaunchInstanceID":"504AB7F7-C535-4388-9F23-A5C7C696F79D","__CF_USER_TEXT_ENCODING":"0x1F5:0x0:0x0","ITERM_SESSION_ID":"w0t0p0:AFDDB487-D1A3-4C75-BDA2-DAA2B3FCA6DA","SHLVL":"1","OLDPWD":"/Applications/Visual Studio Code.app/Contents/MacOS","P9K_TTY":"old","_P9K_TTY":"/dev/ttys000","ZSH":"/Users/jianchao/.oh-my-zsh","PAGER":"less","LESS":"-R","LSCOLORS":"Gxfxcxdxbxegedabagacad","LS_COLORS":"di=1;36:ln=35:so=32:pi=33:ex=31:bd=34;46:cd=34;43:su=30;41:sg=30;46:tw=30;42:ow=30;43","_P9K_SSH_TTY":"","ORIGINAL_XDG_CURRENT_DESKTOP":"undefined","VSCODE_CWD":"/Applications/Visual Studio Code.app/Contents/MacOS","VSCODE_NLS_CONFIG":"{\"locale\":\"en-us\",\"osLocale\":\"en-cn\",\"availableLanguages\":{},\"_languagePackSupport\":true}","VSCODE_CODE_CACHE_PATH":"/Users/jianchao/Library/Application Support/Code/CachedData/1a5daa3a0231a0fbba4f14db7ec463cf99d7768e","VSCODE_IPC_HOOK":"/Users/jianchao/Library/Application Support/Code/1.84-main.sock","VSCODE_PID":"8531","ELECTRON_RUN_AS_NODE":"1","ELECTRON_NO_ATTACH_CONSOLE":"1","VSCODE_RESOLVING_ENVIRONMENT":"1","P9K_SSH":"0","_":"/Applications/Visual Studio Code.app/Contents/MacOS/Electron"}27244601c26a
[main 2023-11-17T08:14:27.722Z] getUnixShellEnvironment#stderr (anon):setopt:7: can't change option: monitor
[ERROR]: gitstatus failed to initialize.
Add the following parameter to ~/.zshrc for extra diagnostics on error:
GITSTATUS_LOG_LEVEL=DEBUG
Restart Zsh to retry gitstatus initialization:
exec zsh
[main 2023-11-17T08:14:27.723Z] getUnixShellEnvironment#result {
COLORFGBG: '7;0',
XPC_FLAGS: '0x0',
SHELL: '/bin/zsh',
LC_CTYPE: 'UTF-8',
PATH: '/Users/jianchao/Library/Python/3.9/bin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/homebrew/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/Applications/Wireshark.app/Contents/MacOS:/usr/local/share/dotnet:~/.dotnet/tools:/Users/jianchao/Library/Python/3.9/bin',
USER: 'jianchao',
SHLVL: '1',
OLDPWD: '/Applications/Visual Studio Code.app/Contents/MacOS',
P9K_TTY: 'old',
PAGER: 'less',
LESS: '-R',
_P9K_SSH_TTY: '',
VSCODE_PID: '8531',
P9K_SSH: '0',
_: '/Applications/Visual Studio Code.app/Contents/MacOS/Electron'
[8557:1117/161427.728678:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[8557:1117/161427.866589:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
[8531:1117/161427.867837:ERROR:network_service_instance_impl.cc(558)] Network service crashed, restarting service.
[8558:1117/161427.900885:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[8558:1117/161428.035779:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
[8531:1117/161428.036995:ERROR:network_service_instance_impl.cc(558)] Network service crashed, restarting service.
[8559:1117/161428.069475:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[8559:1117/161428.201892:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
[8531:1117/161428.203100:ERROR:network_service_instance_impl.cc(558)] Network service crashed, restarting service.
[8560:1117/161428.234557:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[8560:1117/161428.369627:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
[8531:1117/161428.370950:ERROR:network_service_instance_impl.cc(558)] Network service crashed, restarting service.
[8561:1117/161428.403503:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[8561:1117/161428.531455:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
[8531:1117/161428.532629:ERROR:network_service_instance_impl.cc(558)] Network service crashed, restarting service.
[8562:1117/161428.564235:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[8562:1117/161428.690366:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
[8531:1117/161428.691640:ERROR:network_service_instance_impl.cc(558)] Network service crashed, restarting service.
[8563:1117/161428.723794:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[8563:1117/161428.851290:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
[8531:1117/161428.852515:ERROR:network_service_instance_impl.cc(558)] Network service crashed, restarting service.
[8564:1117/161428.884945:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[8564:1117/161429.010734:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
[8531:1117/161429.011986:ERROR:network_service_instance_impl.cc(558)] Network service crashed, restarting service.
[8565:1117/161429.043679:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[8565:1117/161429.168278:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
[8531:1117/161429.169485:ERROR:network_service_instance_impl.cc(558)] Network service crashed, restarting service.
[8566:1117/161429.200710:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[8566:1117/161429.328157:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
[8531:1117/161429.329293:ERROR:network_service_instance_impl.cc(558)] Network service crashed, restarting service.
[8567:1117/161429.360955:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[8567:1117/161429.495920:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
[8531:1117/161429.497211:ERROR:network_service_instance_impl.cc(558)] Network service crashed, restarting service.
[8568:1117/161429.529902:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[8568:1117/161429.661677:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
[8531:1117/161429.662744:ERROR:network_service_instance_impl.cc(558)] Network service crashed, restarting service.
[8570:1117/161429.695126:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[8570:1117/161429.829989:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
[8531:1117/161429.831208:ERROR:network_service_instance_impl.cc(558)] Network service crashed, restarting service.
[8571:1117/161429.864573:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[8571:1117/161429.994821:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
[8531:1117/161429.995956:ERROR:network_service_instance_impl.cc(558)] Network service crashed, restarting service.
[main 2023-11-17T08:14:30.024Z] lifecycle (main): phase changed (value: 4)
[8572:1117/161430.027571:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[8572:1117/161430.159768:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
[8531:1117/161430.160921:ERROR:network_service_instance_impl.cc(558)] Network service crashed, restarting service.
[8573:1117/161430.193156:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[8573:1117/161430.319643:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
[8531:1117/161430.320755:ERROR:network_service_instance_impl.cc(558)] Network service crashed, restarting service.
[8574:1117/161430.352195:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[8574:1117/161430.478927:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
[8531:1117/161430.480107:ERROR:network_service_instance_impl.cc(558)] Network service crashed, restarting service.
[8575:1117/161430.511605:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[8575:1117/161430.640447:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
[8531:1117/161430.641655:ERROR:network_service_instance_impl.cc(558)] Network service crashed, restarting service.
[8576:1117/161430.674419:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[8576:1117/161430.811499:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
[8531:1117/161430.812638:ERROR:network_service_instance_impl.cc(558)] Network service crashed, restarting service.
[8577:1117/161430.844994:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[8577:1117/161430.977952:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
[8531:1117/161430.979142:ERROR:network_service_instance_impl.cc(558)] Network service crashed, restarting service.
[8578:1117/161431.010867:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[8578:1117/161431.147582:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
[8531:1117/161431.148760:ERROR:network_service_instance_impl.cc(558)] Network service crashed, restarting service.
[8579:1117/161431.179995:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[8579:1117/161431.319110:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
[8531:1117/161431.320335:ERROR:network_service_instance_impl.cc(558)] Network service crashed, restarting service.
[8580:1117/161431.353488:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[8580:1117/161431.489244:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
[8531:1117/161431.490471:ERROR:network_service_instance_impl.cc(558)] Network service crashed, restarting service.
[8581:1117/161431.522236:ERROR:validation_errors.cc(117)] Invalid message: VALIDATION_ERROR_DESERIALIZATION_FAILED
[8581:1117/161431.653856:ERROR:interface_endpoint_client.cc(697)] Message 647314295 rejected by interface network.mojom.NetworkService
[8531:1117/161431.655021:ERROR:network_service_instance_impl.cc(558)] Network service crashed, restarting service.
