So my uncle is putting together a kit to run some high power LED lights on his motorcycle and the kit uses an attiny13, he'd like to reprogram it to match exactly what he wants.
He doesn't have a ton of C knowledge and hasn't used a microcontroller before.
I'm curious if a hex file can be built with the arduino IDE and then stuffed into the attiny13 using either an arduinoISP or ladyada's isp programmer.
Mainly what I want is the much nicer and simpler arduino IDE. Looking at the AVR C code gave me a headache.
There are two parts to the Arduino software: the IDE and the libraries. The IDE can be configured to work with any AVR processor. The libraries are really designed to work with a processor that has more Flash and SRAM than the ATtiny13.
If your uncle (or you) really wants to use the Arduino libraries he is far better off replacing the ATtiny13 with a "bigger" processor. The ATtiny85 (and "up") is a good choice.
If your uncle (or you) doesn't mind directly manipulating registers then the ATtiny13 with the Arduino IDE are a good choice.
I have used both PWM pins but, on the ATTiny13, I'm using assembler.
ATTiny45's are another option too -- no bootloader but using the Arduino
as an ISP has worked well for me.
