beybi
October 26, 2022, 6:19am
1
Hello All,
I have a problem with one of my Arduino board that called "Arduino 101" (NOT Industrial 101).
I've tried several combination of Board Library(Intel Curie Board) and Arduino IDE version, however I couldn't succeed it.
The problem is, whenever I tried to compile a code (even sample blink project), I am getting below error;
fatal error: runtime: bsdthread_register error
runtime stack:
runtime.throw(0x1122f8, 0x21)
/ssd/go/src/runtime/panic.go:566 +0x95 fp=0x7ff7bfeff5c0 sp=0x7ff7bfeff5a0
runtime.goenvs()
/ssd/go/src/runtime/os_darwin.go:88 +0xa0 fp=0x7ff7bfeff5f0 sp=0x7ff7bfeff5c0
runtime.schedinit()
/ssd/go/src/runtime/proc.go:450 +0x9c fp=0x7ff7bfeff630 sp=0x7ff7bfeff5f0
runtime.rt0_go(0x7ff7bfeff660, 0x4, 0x7ff7bfeff660, 0x1000, 0x4, 0x7ff7bfeff810, 0x7ff7bfeff86c, 0x7ff7bfeff86f, 0x7ff7bfeff8ee, 0x0, ...)
/ssd/go/src/runtime/asm_amd64.s:145 +0x14f fp=0x7ff7bfeff638 sp=0x7ff7bfeff630
exit status 2
Compilation error: exit status 2
The strange thing is, Arduino IDE works great with Arduino UNO. No problem at all! Whenever, I tried to use Arduino 101, I am getting error.
Combination of Boards and IDEs version;
Arduino IDE 2.0 - Intel Curie Board 2.0.5 -> Failed Compile and Upload
Arduino IDE 2.0 - Intel Curie Board 2.0.4 -> Failed Compile and Upload
Arduino IDE 2.0 - Intel Curie Board 2.0.2-> Failed Compile and Upload
Arduino IDE 2.0 - Intel Curie Board 1.0.7-> Succeed Compile and Failed Upload
Arduino IDE 2.0 - Intel Curie Board 1.0.6-> Succeed Compile and Failed Upload
For Arduino Legacy IDE, exact same combinations were tried, still same result.
My concern is, I bought the Arduino 101 board for BLE works that needs occasionally. If every software update can broke the my boards integrity, I've a doubt to buy experimental Arduino product!
Thank you,
Best Regards.
Hi @beybi
I found some information about this error here:
I'm going to ask you to post some additional information that might help us to identify the specific tool that is producing this error.
NOTE: These instructions will not solve the problem. They are only intended to gather more information which might provide a clue that eventually leads to a solution.
Please do this:
Select File > Preferences from the Arduino IDE menus.
Check the box next to "Show verbose output during: ☐ compilation ".
Click the OK button.
Select Sketch > Verify/Compile from the Arduino IDE menus.
Wait for the compilation to fail.
You will see a "Compilation error: ... " notification at the bottom right corner of the Arduino IDE window. Click the COPY ERROR MESSAGES button on that notification.
Open a forum reply here by clicking the Reply button.
Click the </> icon on the post composer toolbar.
This will add the forum's code block markup (``` ) to your reply to make sure the error messages are correctly formatted.
Press Ctrl +V .
This will paste the compilation output into the code block.
Move the cursor outside of the code tags before you add any additional text to your reply.
Click the Reply button to post the output.
In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt file and then attach that file to a reply here:
Open any text editor program.
Paste the copied output into the text editor.
Save the file in .txt format.
Click the "Upload" icon ( ) on the post composer toolbar:
Select the .txt file you saved.
Click the Open button.
Click the Reply button to publish the post.
Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt file onto the post composer field to attach it.
beybi
October 26, 2022, 7:11am
3
Hi @ptillisch ,
Thanks for answering quickly
I could not upload any file, system said that I am new user and so on... I'll upload it in nasty way. So sorry!
The thing is that bothers me, How the IDE finds the /ssd/go directory and try to use go in there. Do you have any idea?
{\rtf1\ansi\ansicpg1252\cocoartf2639
\cocoatextscaling0\cocoaplatform0{\fonttbl\f0\fswiss\fcharset0 Helvetica;}
{\colortbl;\red255\green255\blue255;}
{\*\expandedcolortbl;;}
\paperw11900\paperh16840\margl1440\margr1440\vieww11520\viewh8400\viewkind0
\pard\tx566\tx1133\tx1700\tx2267\tx2834\tx3401\tx3968\tx4535\tx5102\tx5669\tx6236\tx6803\pardirnatural\partightenfactor0
\f0\fs24 \cf0 Using board 'arduino_101' from platform in folder: /Users/x-user/Library/Arduino15/packages/Intel/hardware/arc32/2.0.4\
Using core 'arduino' from platform in folder: /Users/x-user/Library/Arduino15/packages/Intel/hardware/arc32/2.0.4\
Detecting libraries used...\
/Users/x-user/Library/Arduino15/packages/Intel/tools/arc-elf32/1.6.9+1.0.1/bin/arc-elf32-g++ -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -fno-rtti -fno-exceptions -fcheck-new -D__ARDUINO_ARC__ -std=c++11 -DCONFIG_BLUETOOTH_PERIPHERAL -DCONFIG_BLUETOOTH_CENTRAL -DCONFIG_BLUETOOTH_GATT_CLIENT -w -x c++ -E -CC -DF_CPU=32000000L -DARDUINO=10607 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM -I/Users/x-user/Library/Arduino15/packages/Intel/hardware/arc32/2.0.4/system/libarc32_arduino101/common -I/Users/x-user/Library/Arduino15/packages/Intel/hardware/arc32/2.0.4/system/libarc32_arduino101/drivers -I/Users/x-user/Library/Arduino15/packages/Intel/hardware/arc32/2.0.4/system/libarc32_arduino101/bootcode -I/Users/x-user/Library/Arduino15/packages/Intel/hardware/arc32/2.0.4/system/libarc32_arduino101/framework/include -I/Users/x-user/Library/Arduino15/packages/Intel/hardware/arc32/2.0.4/cores/arduino -I/Users/x-user/Library/Arduino15/packages/Intel/hardware/arc32/2.0.4/variants/arduino_101 /private/var/folders/dl/cdjfr_wx1lv48vd5mzr4klj80000gp/T/arduino-sketch-5CEDF04D633012E523AC2E5C948FE18F/sketch/Blink.ino.cpp -o /dev/null\
Generating function prototypes...\
/Users/x-user/Library/Arduino15/packages/Intel/tools/arc-elf32/1.6.9+1.0.1/bin/arc-elf32-g++ -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -fno-rtti -fno-exceptions -fcheck-new -D__ARDUINO_ARC__ -std=c++11 -DCONFIG_BLUETOOTH_PERIPHERAL -DCONFIG_BLUETOOTH_CENTRAL -DCONFIG_BLUETOOTH_GATT_CLIENT -w -x c++ -E -CC -DF_CPU=32000000L -DARDUINO=10607 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM -I/Users/x-user/Library/Arduino15/packages/Intel/hardware/arc32/2.0.4/system/libarc32_arduino101/common -I/Users/x-user/Library/Arduino15/packages/Intel/hardware/arc32/2.0.4/system/libarc32_arduino101/drivers -I/Users/x-user/Library/Arduino15/packages/Intel/hardware/arc32/2.0.4/system/libarc32_arduino101/bootcode -I/Users/x-user/Library/Arduino15/packages/Intel/hardware/arc32/2.0.4/system/libarc32_arduino101/framework/include -I/Users/x-user/Library/Arduino15/packages/Intel/hardware/arc32/2.0.4/cores/arduino -I/Users/x-user/Library/Arduino15/packages/Intel/hardware/arc32/2.0.4/variants/arduino_101 /private/var/folders/dl/cdjfr_wx1lv48vd5mzr4klj80000gp/T/arduino-sketch-5CEDF04D633012E523AC2E5C948FE18F/sketch/Blink.ino.cpp -o /private/var/folders/dl/cdjfr_wx1lv48vd5mzr4klj80000gp/T/arduino-sketch-5CEDF04D633012E523AC2E5C948FE18F/preproc/ctags_target_for_gcc_minus_e.cpp\
/Users/x-user/Library/Arduino15/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /private/var/folders/dl/cdjfr_wx1lv48vd5mzr4klj80000gp/T/arduino-sketch-5CEDF04D633012E523AC2E5C948FE18F/preproc/ctags_target_for_gcc_minus_e.cpp\
Compiling sketch...\
/Users/x-user/Library/Arduino15/packages/Intel/tools/arc-elf32/1.6.9+1.0.1/bin/arc-elf32-g++ -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -fcheck-new -D__ARDUINO_ARC__ -std=c++11 -DCONFIG_BLUETOOTH_PERIPHERAL -DCONFIG_BLUETOOTH_CENTRAL -DCONFIG_BLUETOOTH_GATT_CLIENT -DF_CPU=32000000L -DARDUINO=10607 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM -I/Users/x-user/Library/Arduino15/packages/Intel/hardware/arc32/2.0.4/system/libarc32_arduino101/common -I/Users/x-user/Library/Arduino15/packages/Intel/hardware/arc32/2.0.4/system/libarc32_arduino101/drivers -I/Users/x-user/Library/Arduino15/packages/Intel/hardware/arc32/2.0.4/system/libarc32_arduino101/bootcode -I/Users/x-user/Library/Arduino15/packages/Intel/hardware/arc32/2.0.4/system/libarc32_arduino101/framework/include -I/Users/x-user/Library/Arduino15/packages/Intel/hardware/arc32/2.0.4/cores/arduino -I/Users/x-user/Library/Arduino15/packages/Intel/hardware/arc32/2.0.4/variants/arduino_101 /private/var/folders/dl/cdjfr_wx1lv48vd5mzr4klj80000gp/T/arduino-sketch-5CEDF04D633012E523AC2E5C948FE18F/sketch/Blink.ino.cpp -o /private/var/folders/dl/cdjfr_wx1lv48vd5mzr4klj80000gp/T/arduino-sketch-5CEDF04D633012E523AC2E5C948FE18F/sketch/Blink.ino.cpp.o\
Compiling libraries...\
Compiling core...\
Using previously compiled file: /private/var/folders/dl/cdjfr_wx1lv48vd5mzr4klj80000gp/T/arduino-sketch-5CEDF04D633012E523AC2E5C948FE18F/core/variant.cpp.o\
Using precompiled core: /private/var/folders/dl/cdjfr_wx1lv48vd5mzr4klj80000gp/T/arduino-core-cache/core_Intel_arc32_arduino_101_01b564c4638b6e541d134848e8773c99.a\
Linking everything together...\
/Users/x-user/Library/Arduino15/packages/Intel/tools/arc-elf32/1.6.9+1.0.1/bin/arc-elf32-gcc -nostartfiles -nodefaultlibs -nostdlib -static -Wl,-X -Wl,-N -Wl,-mcpu=quarkse_em -Wl,-marcelf -Wl,--gc-sections -T/Users/x-user/Library/Arduino15/packages/Intel/hardware/arc32/2.0.4/variants/arduino_101/linker_scripts/flash.ld -Wl,-Map,/private/var/folders/dl/cdjfr_wx1lv48vd5mzr4klj80000gp/T/arduino-sketch-5CEDF04D633012E523AC2E5C948FE18F/Blink.ino.map -o /private/var/folders/dl/cdjfr_wx1lv48vd5mzr4klj80000gp/T/arduino-sketch-5CEDF04D633012E523AC2E5C948FE18F/Blink.ino.elf -L/private/var/folders/dl/cdjfr_wx1lv48vd5mzr4klj80000gp/T/arduino-sketch-5CEDF04D633012E523AC2E5C948FE18F -L/Users/x-user/Library/Arduino15/packages/Intel/hardware/arc32/2.0.4/variants/arduino_101 -Wl,--no-whole-archive -Wl,--start-group -lnsim -lc -lm -lgcc -larc32drv_arduino101 /private/var/folders/dl/cdjfr_wx1lv48vd5mzr4klj80000gp/T/arduino-sketch-5CEDF04D633012E523AC2E5C948FE18F/sketch/Blink.ino.cpp.o /private/var/folders/dl/cdjfr_wx1lv48vd5mzr4klj80000gp/T/arduino-sketch-5CEDF04D633012E523AC2E5C948FE18F/core/variant.cpp.o /private/var/folders/dl/cdjfr_wx1lv48vd5mzr4klj80000gp/T/arduino-sketch-5CEDF04D633012E523AC2E5C948FE18F/../arduino-core-cache/core_Intel_arc32_arduino_101_01b564c4638b6e541d134848e8773c99.a\
fatal error: runtime: bsdthread_register error\
/Users/x-user/Library/Arduino15/packages/Intel/tools/arduino101load/2.0.1/arduino101load -c "-from=\\"/private/var/folders/dl/cdjfr_wx1lv48vd5mzr4klj80000gp/T/arduino-sketch-5CEDF04D633012E523AC2E5C948FE18F/Blink.ino.elf\\"" "-to=\\"/private/var/folders/dl/cdjfr_wx1lv48vd5mzr4klj80000gp/T/arduino-sketch-5CEDF04D633012E523AC2E5C948FE18F/../arduino101_sketch.debug.elf\\""\
runtime stack:\
runtime.throw(0x1122f8, 0x21)\
/ssd/go/src/runtime/panic.go:566 +0x95 fp=0x7ff7bfeff5c0 sp=0x7ff7bfeff5a0\
runtime.goenvs()\
/ssd/go/src/runtime/os_darwin.go:88 +0xa0 fp=0x7ff7bfeff5f0 sp=0x7ff7bfeff5c0\
runtime.schedinit()\
/ssd/go/src/runtime/proc.go:450 +0x9c fp=0x7ff7bfeff630 sp=0x7ff7bfeff5f0\
runtime.rt0_go(0x7ff7bfeff660, 0x4, 0x7ff7bfeff660, 0x1000, 0x4, 0x7ff7bfeff810, 0x7ff7bfeff86c, 0x7ff7bfeff86f, 0x7ff7bfeff8ee, 0x0, ...)\
/ssd/go/src/runtime/asm_amd64.s:145 +0x14f fp=0x7ff7bfeff638 sp=0x7ff7bfeff630\
exit status 2\
Compilation error: exit status 2}
Hi. I apologize for the inconvenience with the forum's new user restrictions. The software will automatically promote you to "trust level 1" after you use the forum for only a little while, after which the restriction will be lifted.
beybi:
/Users/x-user/Library/Arduino15/packages/Intel/tools/arduino101load/2.0.1/arduino101load -c "-from=\"/private/var/folders/dl/cdjfr_wx1lv48vd5mzr4klj80000gp/T/arduino-sketch-5CEDF04D633012E523AC2E5C948FE18F/Blink.ino.elf\"" "-to=\"/private/var/folders/dl/cdjfr_wx1lv48vd5mzr4klj80000gp/T/arduino-sketch-5CEDF04D633012E523AC2E5C948FE18F/../arduino101_sketch.debug.elf\""
runtime stack:
runtime.goenvs()
runtime.schedinit()
exit status 2
From this output, I can see the error is with the arduino101load tool, which is hosted in this repository:
You are welcome to submit a bug report there. However, we can see from looking at that repository and at the arduino/ArduinoCore-arc32 repository of the "Intel Curie Boards " platform of the retired Arduino 101 board that there has not been any development activity in many years, and you can see there are many unacknowledged bug reports in the latter repository. So I'm afraid it might be quite some time, if ever, before the Arduino company provides a fix. Of course the Arduino community is amazing so it might well be that they will come to the rescue of those affected with a community solution.
If you have purchased this board recently enough that it is still under warranty, my recommendation is to contact the seller and request a return. You will probably be happier spending that money on another product that is not in a retired status.
I have now submitted a formal bug report to the issue tracker for the problematic arduino101load tool dependency:
opened 05:10PM - 29 Jan 23 UTC
### Describe the problem
The binaries provided as release assets in this repo… sitory fail with a `bsdthread_register` or `segmentation fault` error when used on a machine running a recent version of macOS.
This is apparently caused by the vintage version of Go used to generate the build:
https://github.com/golang/go/wiki/MacOS12BSDThreadRegisterIssue
### To reproduce
Download the binary from the release asset and attempt to execute it on a machine running a recent version of macOS.
```text
% sw_vers
ProductName: macOS
ProductVersion: 13.2
BuildVersion: 22D49
% mkdir /tmp/arduino101load-demo
% cd /tmp/arduino101load-demo
% curl --location --output arduino101load-2.0.1-darwin_amd64.tar.bz2 https://github.com/facchinm/arduino101load/releases/download/2.0.1/arduino101load-2.0.1-darwin_amd64.tar.bz2
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 1033k 100 1033k 0 0 517k 0 0:00:01 0:00:01 --:--:-- 989k
% tar -xf arduino101load-2.0.1-darwin_amd64.tar.bz2
% bin/arduino101load --help
zsh: segmentation fault bin/arduino101load --help
🐛 The valid invocation errored.
### Expected behavior
Builds are available for the users of modern macOS machines.
### Proposed solution
Convert the project to a Go module and build with a recent version of Go.
The produced binary works as expected:
```text
% git clone --depth 1 https://github.com/facchinm/arduino101load
Cloning into 'arduino101load'...
remote: Enumerating objects: 18, done.
remote: Counting objects: 100% (18/18), done.
remote: Compressing objects: 100% (17/17), done.
remote: Total 18 (delta 2), reused 12 (delta 1), pack-reused 0
Receiving objects: 100% (18/18), 198.18 KiB | 622.00 KiB/s, done.
Resolving deltas: 100% (2/2), done.
% cd arduino101load
% go version
go version go1.19.5 darwin/amd64
% go mod init github.com/facchinm/arduino101load
go: creating new go.mod: module github.com/facchinm/arduino101load
go: to add module requirements and sums:
go mod tidy
% go mod tidy
go: finding module for package github.com/mattn/go-shellwords
go: downloading github.com/mattn/go-shellwords v1.0.12
go: found github.com/mattn/go-shellwords in github.com/mattn/go-shellwords v1.0.12
% go build
% ./arduino101load --help
Usage of ./arduino101load:
-bin string
Location of sketch binary
-ble_fw_pos int
BLE FW ID offset
-ble_fw_str string
BLE FW ID string
-c Copy bin_file to bin_save
-core string
Firmware location
-dfu string
Location of dfu-util binaries
-f Force firmware update
-from string
Original file location
-port string
Upload serial port
-q Show quiet logging (default true)
-rtos_fw_pos int
RTOS FW ID offset
-rtos_fw_str string
RTOS FW ID string
-to string
Save file location
-v Show verbose logging
For the sake of simplicity, the above was done on the macOS machine, but the binary produced by cross compiling per the instructions in the readme works just as well, so there is no difficulty in producing the builds.
### Additional context
The above demo was on an Apple Silicon-based Mac machine running the [**Rosetta 2** interpreter](https://en.wikipedia.org/wiki/Rosetta_(software)#Rosetta_2) because that is the only machine I have access to, but the same problem also occur on an x86 Mac, as reported by users of the Arduino 101 board:
- https://forum.arduino.cc/t/compilation-error-exit-status-2/1079262
- https://forum.arduino.cc/t/arduino-ide-is-not-working-with-intel-curie-board-on-macos/1046077
On the x86 machine, the error message is a bit more verbose:
```text
runtime stack:
runtime.goenvs()
runtime.schedinit()
exit status 2
I didn't submit a report to the "Intel Curie Boards" platform because I saw there was an existing report:
opened 07:22PM - 28 Aug 22 UTC
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger… =machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/trenskow/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/trenskow/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/trenskow/Documents/Arduino/libraries -fqbn=Intel:arc32:arduino_101 -vid-pid=8087_0AB6 -ide-version=10819 -build-path /var/folders/pz/kz0b20y15v7_hpvd7db9067c0000gn/T/arduino_build_193391 -warnings=none -build-cache /var/folders/pz/kz0b20y15v7_hpvd7db9067c0000gn/T/arduino_cache_825497 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduino101load.path=/Users/trenskow/Library/Arduino15/packages/Intel/tools/arduino101load/2.0.1 -prefs=runtime.tools.arduino101load-2.0.1.path=/Users/trenskow/Library/Arduino15/packages/Intel/tools/arduino101load/2.0.1 -prefs=runtime.tools.dfu-util.path=/Users/trenskow/Library/Arduino15/packages/arduino/tools/dfu-util/0.9.0-arduino1 -prefs=runtime.tools.dfu-util-0.9.0-arduino1.path=/Users/trenskow/Library/Arduino15/packages/arduino/tools/dfu-util/0.9.0-arduino1 -prefs=runtime.tools.openocd.path=/Users/trenskow/Library/Arduino15/packages/Intel/tools/openocd/0.9.0+0.1 -prefs=runtime.tools.openocd-0.9.0+0.1.path=/Users/trenskow/Library/Arduino15/packages/Intel/tools/openocd/0.9.0+0.1 -prefs=runtime.tools.arc-elf32.path=/Users/trenskow/Library/Arduino15/packages/Intel/tools/arc-elf32/1.6.9+1.0.1 -prefs=runtime.tools.arc-elf32-1.6.9+1.0.1.path=/Users/trenskow/Library/Arduino15/packages/Intel/tools/arc-elf32/1.6.9+1.0.1 -prefs=runtime.tools.flashpack.path=/Users/trenskow/Library/Arduino15/packages/Intel/tools/flashpack/2.0.0 -prefs=runtime.tools.flashpack-2.0.0.path=/Users/trenskow/Library/Arduino15/packages/Intel/tools/flashpack/2.0.0 -verbose /Users/trenskow/Documents/Arduino/sketch_aug27a/sketch_aug27a.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/trenskow/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/trenskow/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/trenskow/Documents/Arduino/libraries -fqbn=Intel:arc32:arduino_101 -vid-pid=8087_0AB6 -ide-version=10819 -build-path /var/folders/pz/kz0b20y15v7_hpvd7db9067c0000gn/T/arduino_build_193391 -warnings=none -build-cache /var/folders/pz/kz0b20y15v7_hpvd7db9067c0000gn/T/arduino_cache_825497 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduino101load.path=/Users/trenskow/Library/Arduino15/packages/Intel/tools/arduino101load/2.0.1 -prefs=runtime.tools.arduino101load-2.0.1.path=/Users/trenskow/Library/Arduino15/packages/Intel/tools/arduino101load/2.0.1 -prefs=runtime.tools.dfu-util.path=/Users/trenskow/Library/Arduino15/packages/arduino/tools/dfu-util/0.9.0-arduino1 -prefs=runtime.tools.dfu-util-0.9.0-arduino1.path=/Users/trenskow/Library/Arduino15/packages/arduino/tools/dfu-util/0.9.0-arduino1 -prefs=runtime.tools.openocd.path=/Users/trenskow/Library/Arduino15/packages/Intel/tools/openocd/0.9.0+0.1 -prefs=runtime.tools.openocd-0.9.0+0.1.path=/Users/trenskow/Library/Arduino15/packages/Intel/tools/openocd/0.9.0+0.1 -prefs=runtime.tools.arc-elf32.path=/Users/trenskow/Library/Arduino15/packages/Intel/tools/arc-elf32/1.6.9+1.0.1 -prefs=runtime.tools.arc-elf32-1.6.9+1.0.1.path=/Users/trenskow/Library/Arduino15/packages/Intel/tools/arc-elf32/1.6.9+1.0.1 -prefs=runtime.tools.flashpack.path=/Users/trenskow/Library/Arduino15/packages/Intel/tools/flashpack/2.0.0 -prefs=runtime.tools.flashpack-2.0.0.path=/Users/trenskow/Library/Arduino15/packages/Intel/tools/flashpack/2.0.0 -verbose /Users/trenskow/Documents/Arduino/sketch_aug27a/sketch_aug27a.ino
Using board 'arduino_101' from platform in folder: /Users/trenskow/Library/Arduino15/packages/Intel/hardware/arc32/2.0.5
Using core 'arduino' from platform in folder: /Users/trenskow/Library/Arduino15/packages/Intel/hardware/arc32/2.0.5
/Users/trenskow/Library/Arduino15/packages/Intel/tools/arc-elf32/1.6.9+1.0.1/bin/arc-elf32-g++ -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -fno-rtti -fno-exceptions -fcheck-new -D__ARDUINO_ARC__ -std=c++11 -DCONFIG_BLUETOOTH_PERIPHERAL -DCONFIG_BLUETOOTH_CENTRAL -DCONFIG_BLUETOOTH_GATT_CLIENT -w -x c++ -E -CC -DF_CPU=32000000L -DARDUINO=10819 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM -I/Users/trenskow/Library/Arduino15/packages/Intel/hardware/arc32/2.0.5/system/libarc32_arduino101/common -I/Users/trenskow/Library/Arduino15/packages/Intel/hardware/arc32/2.0.5/system/libarc32_arduino101/drivers -I/Users/trenskow/Library/Arduino15/packages/Intel/hardware/arc32/2.0.5/system/libarc32_arduino101/bootcode -I/Users/trenskow/Library/Arduino15/packages/Intel/hardware/arc32/2.0.5/system/libarc32_arduino101/framework/include -I/Users/trenskow/Library/Arduino15/packages/Intel/hardware/arc32/2.0.5/cores/arduino -I/Users/trenskow/Library/Arduino15/packages/Intel/hardware/arc32/2.0.5/variants/arduino_101 /var/folders/pz/kz0b20y15v7_hpvd7db9067c0000gn/T/arduino_build_193391/sketch/sketch_aug27a.ino.cpp -o /dev/null
/Users/trenskow/Library/Arduino15/packages/Intel/tools/arc-elf32/1.6.9+1.0.1/bin/arc-elf32-g++ -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -fno-rtti -fno-exceptions -fcheck-new -D__ARDUINO_ARC__ -std=c++11 -DCONFIG_BLUETOOTH_PERIPHERAL -DCONFIG_BLUETOOTH_CENTRAL -DCONFIG_BLUETOOTH_GATT_CLIENT -w -x c++ -E -CC -DF_CPU=32000000L -DARDUINO=10819 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM -I/Users/trenskow/Library/Arduino15/packages/Intel/hardware/arc32/2.0.5/system/libarc32_arduino101/common -I/Users/trenskow/Library/Arduino15/packages/Intel/hardware/arc32/2.0.5/system/libarc32_arduino101/drivers -I/Users/trenskow/Library/Arduino15/packages/Intel/hardware/arc32/2.0.5/system/libarc32_arduino101/bootcode -I/Users/trenskow/Library/Arduino15/packages/Intel/hardware/arc32/2.0.5/system/libarc32_arduino101/framework/include -I/Users/trenskow/Library/Arduino15/packages/Intel/hardware/arc32/2.0.5/cores/arduino -I/Users/trenskow/Library/Arduino15/packages/Intel/hardware/arc32/2.0.5/variants/arduino_101 /var/folders/pz/kz0b20y15v7_hpvd7db9067c0000gn/T/arduino_build_193391/sketch/sketch_aug27a.ino.cpp -o /var/folders/pz/kz0b20y15v7_hpvd7db9067c0000gn/T/arduino_build_193391/preproc/ctags_target_for_gcc_minus_e.cpp
/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/pz/kz0b20y15v7_hpvd7db9067c0000gn/T/arduino_build_193391/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Users/trenskow/Library/Arduino15/packages/Intel/tools/arc-elf32/1.6.9+1.0.1/bin/arc-elf32-g++ -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -fcheck-new -D__ARDUINO_ARC__ -std=c++11 -DCONFIG_BLUETOOTH_PERIPHERAL -DCONFIG_BLUETOOTH_CENTRAL -DCONFIG_BLUETOOTH_GATT_CLIENT -DF_CPU=32000000L -DARDUINO=10819 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM -I/Users/trenskow/Library/Arduino15/packages/Intel/hardware/arc32/2.0.5/system/libarc32_arduino101/common -I/Users/trenskow/Library/Arduino15/packages/Intel/hardware/arc32/2.0.5/system/libarc32_arduino101/drivers -I/Users/trenskow/Library/Arduino15/packages/Intel/hardware/arc32/2.0.5/system/libarc32_arduino101/bootcode -I/Users/trenskow/Library/Arduino15/packages/Intel/hardware/arc32/2.0.5/system/libarc32_arduino101/framework/include -I/Users/trenskow/Library/Arduino15/packages/Intel/hardware/arc32/2.0.5/cores/arduino -I/Users/trenskow/Library/Arduino15/packages/Intel/hardware/arc32/2.0.5/variants/arduino_101 /var/folders/pz/kz0b20y15v7_hpvd7db9067c0000gn/T/arduino_build_193391/sketch/sketch_aug27a.ino.cpp -o /var/folders/pz/kz0b20y15v7_hpvd7db9067c0000gn/T/arduino_build_193391/sketch/sketch_aug27a.ino.cpp.o
Compiling core...
Using previously compiled file: /var/folders/pz/kz0b20y15v7_hpvd7db9067c0000gn/T/arduino_build_193391/core/variant.cpp.o
Using precompiled core: /var/folders/pz/kz0b20y15v7_hpvd7db9067c0000gn/T/arduino_cache_825497/core/core_Intel_arc32_arduino_101_a1fd1ac69f46a34538fd941255ee1dfb.a
/Users/trenskow/Library/Arduino15/packages/Intel/tools/arc-elf32/1.6.9+1.0.1/bin/arc-elf32-gcc -nostartfiles -nodefaultlibs -nostdlib -static -Wl,-X -Wl,-N -Wl,-mcpu=quarkse_em -Wl,-marcelf -Wl,--gc-sections -T/Users/trenskow/Library/Arduino15/packages/Intel/hardware/arc32/2.0.5/variants/arduino_101/linker_scripts/flash.ld -Wl,-Map,/var/folders/pz/kz0b20y15v7_hpvd7db9067c0000gn/T/arduino_build_193391/sketch_aug27a.ino.map -o /var/folders/pz/kz0b20y15v7_hpvd7db9067c0000gn/T/arduino_build_193391/sketch_aug27a.ino.elf -L/var/folders/pz/kz0b20y15v7_hpvd7db9067c0000gn/T/arduino_build_193391 -L/Users/trenskow/Library/Arduino15/packages/Intel/hardware/arc32/2.0.5/variants/arduino_101 -Wl,--no-whole-archive -Wl,--start-group -lnsim -lc -lm -lgcc -larc32drv_arduino101 /var/folders/pz/kz0b20y15v7_hpvd7db9067c0000gn/T/arduino_build_193391/sketch/sketch_aug27a.ino.cpp.o /var/folders/pz/kz0b20y15v7_hpvd7db9067c0000gn/T/arduino_build_193391/core/variant.cpp.o /var/folders/pz/kz0b20y15v7_hpvd7db9067c0000gn/T/arduino_build_193391/../arduino_cache_825497/core/core_Intel_arc32_arduino_101_a1fd1ac69f46a34538fd941255ee1dfb.a
/Users/trenskow/Library/Arduino15/packages/Intel/tools/arduino101load/2.0.1/arduino101load -c "-from=\"/var/folders/pz/kz0b20y15v7_hpvd7db9067c0000gn/T/arduino_build_193391/sketch_aug27a.ino.elf\"" "-to=\"/var/folders/pz/kz0b20y15v7_hpvd7db9067c0000gn/T/arduino_build_193391/../arduino101_sketch.debug.elf\""
signal: segmentation fault
/Applications/Arduino.app/Contents/Java/arduino-builder returned 255
Error compiling for board Arduino/Genuino 101.
But I did add a comment there with more details about the problem.
If anyone else is experiencing this problem, there is a workaround, which is to build arduino101load from the source code using Go .
This "DIY" workaround is a bit involved, but if anyone is interested I would be happy to provide instructions.
I have good news to share. This bug has been fixed in the latest 2.0.6 release of the "Intel Curie Boards " platform. The error should no longer occur after you use the Arduino IDE Boards Manager to install or update the platform to version 2.0.6.
Please let me know if you have any questions or problems when updating or using "Intel Curie Boards " 2.0.6.
