Arduino iDE not uploading via USBasp
Hi everyone, can please somebody help me with usbasp programmer in arduino ide ? When i try to upload hex in IDE by usbasp programmer i get error message : avrdude: warning: cannot set sck period. please check for usbasp firmware update. avrdude: error: program enable: target doesn't answer. 0 avrdude: initialization failed, rc=-1 Double check connections and try again, or use -F to override this check. so i done update firmware in usbasp via arduino as isp programmer, and i still getting same error... But connections are okay, when i try to upload hex with avrdudess it works, and i didnt touched any connection like usb disconnect and isp connections. Thanks
stepus:
This error is caused by using the libusb-win32 driver with Arduino's version of avrdude:
The solution is to use the libusbK driver instead:
  • Download Zadig: http://zadig.akeo.ie/. Note that Zadig is recommended on the official USBasp page: USBasp - USB programmer for Atmel AVR controllers - fischl.de.
  • Plug in your USBasp
  • Start Zadig
  • From the dropdown menu, select USBasp. If it doesn't show up on the menu, then select Options > List all devices and check again.
  • Click the up or down arrows next to the Driver selection box on the right side until you see libusbK.
  • Click the "Replace Driver" button.
  • After it finishes you can close Zadig.
many thanks pert, it works ! i have used zadig earlier to install driver libusb0(v1.2.6.0) - that works only for extremeburner,avrdudess. I didnt know that for use in arduino is needed libusbK - and it also works in extremeburner etc.
You're welcome. I'm glad to hear it's working now. Enjoy!
Per
