I need HELP - SOS.
Been struggling to get Arduino 2.3.6 to start in my laptop on Linux Mint 21.3. I thought it was an easy task.
I downloaded the file and followed the instructions to the dot.
It is failing with the grpc error, see details of error log below.
To test the internet connection i was able to manually download from a browser the following file shown in this part of the logs:
url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
but the same fails when running the Arduino ide app.
Here is the log, with debug output from the gRPC package enabled:
$ export GRPC_VERBOSITY=DEBUG
$ export GRPC_TRACE=all
$ ./arduino-ide.AppImage
Arduino IDE 2.3.6
Checking for frontend application configuration customizations. Module path: /tmp/.mount_arduin6x80U7/resources/app/lib/backend/electron-main.js, destination 'package.json': /tmp/.mount_arduin6x80U7/resources/app/package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.6" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.2.0" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2025-04-09T11:24:04.835Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{},"showWindowEarly":true,"splashScreenOptions":{},"uriScheme":"arduino-ide"},"defaultLocale":"","validatePreferencesSchema":false,"reloadOnReconnect":true,"uriScheme":"theia","preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.6","cliVersion":"1.2.0","buildDate":"2025-04-09T11:24:04.835Z"}
Starting backend process. PID: 11336
Showing main window early
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///home/issah/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2025-12-08T02:42:46.933Z root INFO Backend u.initialize: 26.8 ms [Finished 0.500 s after backend start]
2025-12-08T02:42:46.934Z root INFO Backend Object.initialize: 25.6 ms [Finished 0.500 s after backend start]
2025-12-08T02:42:46.934Z root INFO Backend a.initialize: 1.1 ms [Finished 0.500 s after backend start]
2025-12-08T02:42:46.934Z root INFO Backend a.initialize: 1.0 ms [Finished 0.500 s after backend start]
2025-12-08T02:42:46.934Z root INFO Backend u.initialize: 1.2 ms [Finished 0.501 s after backend start]
2025-12-08T02:42:46.936Z root INFO Backend l.initialize: 26.5 ms [Finished 0.501 s after backend start]
2025-12-08T02:42:46.940Z root INFO configured all backend app contributions
2025-12-08T02:42:46.941Z root INFO Backend l.onStart: 0.8 ms [Finished 0.509 s after backend start]
2025-12-08T02:42:46.941Z root INFO Backend d.onStart: 0.1 ms [Finished 0.509 s after backend start]
2025-12-08T02:42:46.941Z root INFO Backend a.onStart: 0.2 ms [Finished 0.510 s after backend start]
2025-12-08T02:42:46.941Z config INFO >>> Initializing CLI configuration...
2025-12-08T02:42:46.941Z root INFO Backend x.onStart: 0.2 ms [Finished 0.510 s after backend start]
2025-12-08T02:42:46.941Z config INFO Loading CLI configuration from /home/issah/.arduinoIDE/arduino-cli.yaml...
2025-12-08T02:42:46.941Z daemon INFO Starting daemon from /tmp/.mount_arduin6x80U7/resources/app/lib/backend/resources/arduino-cli...
2025-12-08T02:42:46.941Z root INFO Backend w.onStart: 0.2 ms [Finished 0.510 s after backend start]
2025-12-08T02:42:46.941Z discovery-log INFO start
2025-12-08T02:42:46.941Z discovery-log INFO start new deferred
2025-12-08T02:42:46.941Z root INFO Backend v.onStart: 0.1 ms [Finished 0.510 s after backend start]
2025-12-08T02:42:46.941Z root INFO Backend a.onStart: 0.0 ms [Finished 0.510 s after backend start]
2025-12-08T02:42:46.944Z root INFO Theia app listening on http://127.0.0.1:38943.
2025-12-08T02:42:46.944Z root INFO Finished starting backend application: 2.1 ms [Finished 0.512 s after backend start]
2025-12-08T02:42:46.949Z root WARN The local plugin referenced by local-dir:/home/issah/.arduinoIDE/plugins does not exist.
2025-12-08T02:42:46.949Z root WARN The local plugin referenced by local-dir:/home/issah/.arduinoIDE/deployedPlugins does not exist.
2025-12-08T02:42:46.958Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]}}
2025-12-08T02:42:46.958Z config INFO Loading fallback CLI configuration to get 'directories.data' and 'directories.user'
2025-12-08T02:42:47.057Z root INFO Resolve plugins list: 115.0 ms [Finished 0.626 s after backend start]
2025-12-08T02:42:47.146Z daemon INFO time="2025-12-08T13:42:47+11:00" level=info msg="arduino-cli version 1.2.0"
2025-12-08T02:42:47.146Z daemon INFO time="2025-12-08T13:42:47+11:00" level=info msg="Using config file: /home/issah/.arduinoIDE/arduino-cli.yaml"
time="2025-12-08T13:42:47+11:00" level=info msg="Executing `arduino-cli daemon`"
2025-12-08T02:42:47.158Z daemon INFO Daemon is now listening on 127.0.0.1:46025
{"IP":"127.0.0.1","Port":"46025"}
2025-12-08T02:42:47.158Z root ERROR D 2025-12-08T02:42:47.154Z | v1.13.0 11336 | resolving_load_balancer | dns:localhost:46025 IDLE -> IDLE
2025-12-08T02:42:47.158Z root ERROR D 2025-12-08T02:42:47.154Z | v1.13.0 11336 | connectivity_state | (1) dns:localhost:46025 IDLE -> IDLE
2025-12-08T02:42:47.158Z root ERROR D 2025-12-08T02:42:47.155Z | v1.13.0 11336 | dns_resolver | Resolver constructed for target dns:localhost:46025
2025-12-08T02:42:47.158Z root ERROR D 2025-12-08T02:42:47.156Z | v1.13.0 11336 | backoff | {0} constructed initialDelay=1000 multiplier=1.6 jitter=0.2 maxDelay=120000
2025-12-08T02:42:47.158Z root ERROR D 2025-12-08T02:42:47.156Z | v1.13.0 11336 | backoff | {1} constructed initialDelay=1000 multiplier=1.6 jitter=0.2 maxDelay=120000
2025-12-08T02:42:47.158Z root ERROR D 2025-12-08T02:42:47.156Z | v1.13.0 11336 | channel | (1) dns:localhost:46025 Channel constructed with options {
"grpc.max_send_message_length": 536870912,
"grpc.max_receive_message_length": 536870912,
"grpc.primary_user_agent": "arduino-ide/2.3.6"
2025-12-08T02:42:47.158Z root ERROR D 2025-12-08T02:42:47.156Z | v1.13.0 11336 | channel_stacktrace | (1) Channel constructed
at new t.InternalChannel (/tmp/.mount_arduin6x80U7/resources/app/lib/backend/main.js:2:4427149)
at new t.ChannelImplementation (/tmp/.mount_arduin6x80U7/resources/app/lib/backend/main.js:2:717276)
at new t.Client (/tmp/.mount_arduin6x80U7/resources/app/lib/backend/main.js:2:3781473)
at new s (/tmp/.mount_arduin6x80U7/resources/app/lib/backend/main.js:2:3311235)
at t.createArduinoCoreServiceClient (/tmp/.mount_arduin6x80U7/resources/app/lib/backend/main.js:2:4737191)
at y.createClient (/tmp/.mount_arduin6x80U7/resources/app/lib/backend/main.js:2:102917)
at y.create (/tmp/.mount_arduin6x80U7/resources/app/lib/backend/main.js:2:101875)
at /tmp/.mount_arduin6x80U7/resources/app/lib/backend/main.js:2:100771
at /tmp/.mount_arduin6x80U7/resources/app/lib/backend/main.js:2:6419737
at s.invoke (/tmp/.mount_arduin6x80U7/resources/app/lib/backend/main.js:2:6419827)
2025-12-08T02:42:47.158Z root ERROR D 2025-12-08T02:42:47.156Z | v1.13.0 11336 | channel | (1) dns:localhost:46025 createResolvingCall [0] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Create", deadline=Infinity
2025-12-08T02:42:47.158Z root ERROR D 2025-12-08T02:42:47.156Z | v1.13.0 11336 | resolving_call | [0] Created
2025-12-08T02:42:47.158Z root ERROR D 2025-12-08T02:42:47.156Z | v1.13.0 11336 | resolving_call | [0] Deadline: Infinity
2025-12-08T02:42:47.158Z root ERROR D 2025-12-08T02:42:47.157Z | v1.13.0 11336 | resolving_call | [0] start called
2025-12-08T02:42:47.158Z root ERROR D 2025-12-08T02:42:47.157Z | v1.13.0 11336 | backoff | {0} runOnce()
2025-12-08T02:42:47.158Z root ERROR D 2025-12-08T02:42:47.157Z | v1.13.0 11336 | backoff | {0} runTimer(delay=1000)
2025-12-08T02:42:47.158Z root ERROR D 2025-12-08T02:42:47.157Z | v1.13.0 11336 | dns_resolver | Looking up DNS hostname localhost
2025-12-08T02:42:47.158Z root ERROR D 2025-12-08T02:42:47.157Z | v1.13.0 11336 | resolving_load_balancer | dns:localhost:46025 IDLE -> CONNECTING
2025-12-08T02:42:47.158Z root ERROR D 2025-12-08T02:42:47.157Z | v1.13.0 11336 | connectivity_state | (1) dns:localhost:46025 IDLE -> CONNECTING
2025-12-08T02:42:47.158Z root ERROR D 2025-12-08T02:42:47.157Z | v1.13.0 11336 | backoff | {1} runOnce()
2025-12-08T02:42:47.158Z root ERROR D 2025-12-08T02:42:47.157Z | v1.13.0 11336 | backoff | {1} runTimer(delay=1000)
2025-12-08T02:42:47.158Z root ERROR D 2025-12-08T02:42:47.157Z | v1.13.0 11336 | resolving_call | [0] startRead called
2025-12-08T02:42:47.158Z root ERROR D 2025-12-08T02:42:47.157Z | v1.13.0 11336 | resolving_call | [0] write() called with message of length 0
2025-12-08T02:42:47.158Z root ERROR D 2025-12-08T02:42:47.157Z | v1.13.0 11336 | resolving_call | [0] halfClose called
2025-12-08T02:42:47.158Z daemon INFO Daemon is running.
2025-12-08T02:42:47.162Z config INFO Loaded fallback CLI configuration: {"directories":{"user":"/home/issah/Arduino","data":"/home/issah/.arduino15"}}
2025-12-08T02:42:47.162Z config INFO Merged CLI configuration with the fallback: {"directories":{"user":"/home/issah/Arduino","data":"/home/issah/.arduino15"},"board_manager":{"additional_urls":[]}}
2025-12-08T02:42:47.162Z config INFO Loaded the CLI configuration.
2025-12-08T02:42:47.165Z root ERROR D 2025-12-08T02:42:47.164Z | v1.13.0 11336 | backoff | {0} reset() running=true
2025-12-08T02:42:47.165Z root ERROR D 2025-12-08T02:42:47.164Z | v1.13.0 11336 | backoff | {0} runTimer(delay=1993)
2025-12-08T02:42:47.165Z root ERROR D 2025-12-08T02:42:47.164Z | v1.13.0 11336 | backoff | {0} stop()
2025-12-08T02:42:47.165Z root ERROR D 2025-12-08T02:42:47.164Z | v1.13.0 11336 | dns_resolver | Resolved addresses for target dns:localhost:46025: [127.0.0.1:46025]
2025-12-08T02:42:47.165Z root ERROR D 2025-12-08T02:42:47.164Z | v1.13.0 11336 | backoff | {1} stop()
2025-12-08T02:42:47.165Z root ERROR D 2025-12-08T02:42:47.164Z | v1.13.0 11336 | backoff | {1} reset() running=false
2025-12-08T02:42:47.165Z root ERROR D 2025-12-08T02:42:47.164Z | v1.13.0 11336 | pick_first | updateAddressList([127.0.0.1:46025])
2025-12-08T02:42:47.165Z root ERROR D 2025-12-08T02:42:47.165Z | v1.13.0 11336 | pick_first | connectToAddressList([127.0.0.1:46025])
2025-12-08T02:42:47.165Z root ERROR D 2025-12-08T02:42:47.165Z | v1.13.0 11336 | backoff | {2} constructed initialDelay=1000 multiplier=1.6 jitter=0.2 maxDelay=120000
2025-12-08T02:42:47.165Z root ERROR D 2025-12-08T02:42:47.165Z | v1.13.0 11336 | subchannel | (1) 127.0.0.1:46025 Subchannel constructed with options {
2025-12-08T02:42:47.165Z root ERROR D 2025-12-08T02:42:47.165Z | v1.13.0 11336 | subchannel_refcount | (1) 127.0.0.1:46025 refcount 0 -> 1
2025-12-08T02:42:47.165Z root ERROR D 2025-12-08T02:42:47.165Z | v1.13.0 11336 | subchannel_refcount | (1) 127.0.0.1:46025 refcount 1 -> 2
2025-12-08T02:42:47.165Z root ERROR D 2025-12-08T02:42:47.165Z | v1.13.0 11336 | pick_first | Start connecting to subchannel with address 127.0.0.1:46025
2025-12-08T02:42:47.165Z root ERROR D 2025-12-08T02:42:47.165Z | v1.13.0 11336 | pick_first | IDLE -> CONNECTING
2025-12-08T02:42:47.165Z root ERROR D 2025-12-08T02:42:47.165Z | v1.13.0 11336 | resolving_load_balancer | dns:localhost:46025 CONNECTING -> CONNECTING
2025-12-08T02:42:47.165Z root ERROR D 2025-12-08T02:42:47.165Z | v1.13.0 11336 | connectivity_state | (1) dns:localhost:46025 CONNECTING -> CONNECTING
2025-12-08T02:42:47.167Z root ERROR D 2025-12-08T02:42:47.165Z | v1.13.0 11336 | channel | (1) dns:localhost:46025 callRefTimer.unref | configSelectionQueue.length=0 pickQueue.length=0
2025-12-08T02:42:47.167Z root ERROR D 2025-12-08T02:42:47.166Z | v1.13.0 11336 | subchannel | (1) 127.0.0.1:46025 IDLE -> CONNECTING
2025-12-08T02:42:47.167Z root ERROR D 2025-12-08T02:42:47.166Z | v1.13.0 11336 | backoff | {2} runOnce()
2025-12-08T02:42:47.167Z root ERROR D 2025-12-08T02:42:47.166Z | v1.13.0 11336 | backoff | {2} runTimer(delay=1000)
2025-12-08T02:42:47.167Z root ERROR D 2025-12-08T02:42:47.166Z | v1.13.0 11336 | transport | dns:localhost:46025 127.0.0.1:46025 Waiting for secureConnector to be ready
2025-12-08T02:42:47.167Z root ERROR D 2025-12-08T02:42:47.166Z | v1.13.0 11336 | transport | dns:localhost:46025 127.0.0.1:46025 secureConnector is ready
2025-12-08T02:42:47.167Z root ERROR D 2025-12-08T02:42:47.166Z | v1.13.0 11336 | channel | (1) dns:localhost:46025 createRetryingCall [1] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Create"
2025-12-08T02:42:47.167Z root ERROR D 2025-12-08T02:42:47.166Z | v1.13.0 11336 | resolving_call | [0] Created child [1]
2025-12-08T02:42:47.167Z root ERROR D 2025-12-08T02:42:47.166Z | v1.13.0 11336 | retrying_call | [1] start called
2025-12-08T02:42:47.167Z root ERROR D 2025-12-08T02:42:47.166Z | v1.13.0 11336 | channel | (1) dns:localhost:46025 createLoadBalancingCall [2] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Create"
2025-12-08T02:42:47.167Z root ERROR D 2025-12-08T02:42:47.166Z | v1.13.0 11336 | retrying_call | [1] Created child call [2] for attempt 1
2025-12-08T02:42:47.167Z root ERROR D 2025-12-08T02:42:47.166Z | v1.13.0 11336 | load_balancing_call | [2] start called
2025-12-08T02:42:47.167Z root ERROR D 2025-12-08T02:42:47.166Z | v1.13.0 11336 | load_balancing_call | [2] Pick called
2025-12-08T02:42:47.167Z root ERROR D 2025-12-08T02:42:47.166Z | v1.13.0 11336 | load_balancing_call | [2] Pick result: QUEUE subchannel: null status: undefined undefined
2025-12-08T02:42:47.167Z root ERROR D 2025-12-08T02:42:47.166Z | v1.13.0 11336 | channel | (1) dns:localhost:46025 callRefTimer.ref | configSelectionQueue.length=0 pickQueue.length=1
2025-12-08T02:42:47.167Z root ERROR D 2025-12-08T02:42:47.167Z | v1.13.0 11336 | retrying_call | [1] startRead called
2025-12-08T02:42:47.167Z root ERROR D 2025-12-08T02:42:47.167Z | v1.13.0 11336 | load_balancing_call | [2] startRead called
2025-12-08T02:42:47.167Z root ERROR D 2025-12-08T02:42:47.167Z | v1.13.0 11336 | retrying_call | [1] write() called with message of length 5
2025-12-08T02:42:47.167Z root ERROR D 2025-12-08T02:42:47.167Z | v1.13.0 11336 | load_balancing_call | [2] write() called with message of length 5
2025-12-08T02:42:47.167Z root ERROR D 2025-12-08T02:42:47.167Z | v1.13.0 11336 | retrying_call | [1] halfClose called
2025-12-08T02:42:47.171Z root ERROR D 2025-12-08T02:42:47.168Z | v1.13.0 11336 | transport | dns:localhost:46025 127.0.0.1:46025 Established TCP connection
2025-12-08T02:42:47.171Z root ERROR D 2025-12-08T02:42:47.168Z | v1.13.0 11336 | transport | dns:localhost:46025 127.0.0.1:46025 Established secure connection
2025-12-08T02:42:47.175Z root ERROR D 2025-12-08T02:42:47.173Z | v1.13.0 11336 | subchannel | (1) 127.0.0.1:46025 CONNECTING -> READY
2025-12-08T02:42:47.175Z root ERROR D 2025-12-08T02:42:47.173Z | v1.13.0 11336 | backoff | {2} stop()
2025-12-08T02:42:47.175Z root ERROR D 2025-12-08T02:42:47.173Z | v1.13.0 11336 | backoff | {2} reset() running=false
2025-12-08T02:42:47.175Z root ERROR D 2025-12-08T02:42:47.173Z | v1.13.0 11336 | pick_first | Pick subchannel with address 127.0.0.1:46025
2025-12-08T02:42:47.175Z root ERROR D 2025-12-08T02:42:47.173Z | v1.13.0 11336 | subchannel_refcount | (1) 127.0.0.1:46025 refcount 2 -> 3
2025-12-08T02:42:47.175Z root ERROR D 2025-12-08T02:42:47.173Z | v1.13.0 11336 | subchannel_refcount | (1) 127.0.0.1:46025 refcount 3 -> 2
2025-12-08T02:42:47.175Z root ERROR D 2025-12-08T02:42:47.173Z | v1.13.0 11336 | pick_first | CONNECTING -> READY
2025-12-08T02:42:47.175Z root ERROR D 2025-12-08T02:42:47.173Z | v1.13.0 11336 | resolving_load_balancer | dns:localhost:46025 CONNECTING -> READY
2025-12-08T02:42:47.175Z root ERROR D 2025-12-08T02:42:47.173Z | v1.13.0 11336 | channel | (1) dns:localhost:46025 callRefTimer.unref | configSelectionQueue.length=0 pickQueue.length=0
2025-12-08T02:42:47.175Z root ERROR D 2025-12-08T02:42:47.173Z | v1.13.0 11336 | load_balancing_call | [2] Pick called
2025-12-08T02:42:47.175Z root ERROR D 2025-12-08T02:42:47.173Z | v1.13.0 11336 | load_balancing_call | [2] Pick result: COMPLETE subchannel: (1) 127.0.0.1:46025 status: undefined undefined
2025-12-08T02:42:47.175Z root ERROR D 2025-12-08T02:42:47.173Z | v1.13.0 11336 | connectivity_state | (1) dns:localhost:46025 CONNECTING -> READY
2025-12-08T02:42:47.175Z root ERROR D 2025-12-08T02:42:47.174Z | v1.13.0 11336 | transport_flowctrl | (1) 127.0.0.1:46025 local window size: 65535 remote window size: 65535
2025-12-08T02:42:47.175Z root ERROR D 2025-12-08T02:42:47.174Z | v1.13.0 11336 | transport_internals | (1) 127.0.0.1:46025 session.closed=false session.destroyed=false session.socket.destroyed=false
2025-12-08T02:42:47.175Z root ERROR D 2025-12-08T02:42:47.175Z | v1.13.0 11336 | load_balancing_call | [2] Created child call [3]
2025-12-08T02:42:47.175Z root ERROR D 2025-12-08T02:42:47.175Z | v1.13.0 11336 | subchannel_call | [3] write() called with message of length 5
2025-12-08T02:42:47.175Z root ERROR D 2025-12-08T02:42:47.175Z | v1.13.0 11336 | subchannel_call | [3] sending data chunk of length 5
2025-12-08T02:42:47.176Z root ERROR D 2025-12-08T02:42:47.176Z | v1.13.0 11336 | load_balancing_call | [2] halfClose called
2025-12-08T02:42:47.176Z root ERROR D 2025-12-08T02:42:47.176Z | v1.13.0 11336 | subchannel_call | [3] end() called
2025-12-08T02:42:47.176Z root ERROR D 2025-12-08T02:42:47.176Z | v1.13.0 11336 | subchannel_call | [3] calling end() on HTTP/2 stream
2025-12-08T02:42:47.176Z root ERROR D 2025-12-08T02:42:47.176Z | v1.13.0 11336 | transport | (1) 127.0.0.1:46025 local settings acknowledged by remote: {"headerTableSize":4096,"enablePush":true,"initialWindowSize":65535,"maxFrameSize":16384,"maxConcurrentStreams":4294967295,"maxHeaderListSize":4294967295,"maxHeaderSize":4294967295,"enableConnectProtocol":false}
2025-12-08T02:42:47.190Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///home/issah/.arduino15","sketchDirUri":"file:///home/issah/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2025-12-08T02:42:47.190Z config INFO Validating the CLI configuration...
2025-12-08T02:42:47.194Z root ERROR D 2025-12-08T02:42:47.193Z | v1.13.0 11336 | subchannel_call | [3] Received server headers:
:status: 200
content-type: application/grpc
2025-12-08T02:42:47.194Z root ERROR D 2025-12-08T02:42:47.193Z | v1.13.0 11336 | load_balancing_call | [2] Received metadata
2025-12-08T02:42:47.194Z root ERROR D 2025-12-08T02:42:47.193Z | v1.13.0 11336 | retrying_call | [1] Received metadata from child [2]
2025-12-08T02:42:47.194Z root ERROR D 2025-12-08T02:42:47.193Z | v1.13.0 11336 | retrying_call | [1] Committing call [2] at index 0
2025-12-08T02:42:47.194Z root ERROR D 2025-12-08T02:42:47.193Z | v1.13.0 11336 | resolving_call | [0] Received metadata
2025-12-08T02:42:47.195Z root ERROR D 2025-12-08T02:42:47.194Z | v1.13.0 11336 | subchannel_call | [3] receive HTTP/2 data frame of length 9
2025-12-08T02:42:47.195Z root ERROR D 2025-12-08T02:42:47.194Z | v1.13.0 11336 | subchannel_call | [3] parsed message of length 9
2025-12-08T02:42:47.195Z root ERROR D 2025-12-08T02:42:47.194Z | v1.13.0 11336 | subchannel_call | [3] pushing to reader message of length 9
2025-12-08T02:42:47.195Z root ERROR D 2025-12-08T02:42:47.194Z | v1.13.0 11336 | load_balancing_call | [2] Received message
2025-12-08T02:42:47.195Z root ERROR D 2025-12-08T02:42:47.194Z | v1.13.0 11336 | retrying_call | [1] Received message from child [2]
2025-12-08T02:42:47.195Z root ERROR D 2025-12-08T02:42:47.194Z | v1.13.0 11336 | resolving_call | [0] Received message
2025-12-08T02:42:47.195Z root ERROR D 2025-12-08T02:42:47.194Z | v1.13.0 11336 | resolving_call | [0] Finished filtering received message
2025-12-08T02:42:47.196Z root ERROR D 2025-12-08T02:42:47.195Z | v1.13.0 11336 | subchannel_call | [3] Received server trailers:
grpc-status: 0
grpc-message:
2025-12-08T02:42:47.196Z root ERROR D 2025-12-08T02:42:47.196Z | v1.13.0 11336 | subchannel_call | [3] received status code 0 from server
2025-12-08T02:42:47.196Z root ERROR D 2025-12-08T02:42:47.196Z | v1.13.0 11336 | subchannel_call | [3] received status details string "" from server
2025-12-08T02:42:47.197Z root ERROR D 2025-12-08T02:42:47.196Z | v1.13.0 11336 | subchannel_call | [3] ended with status: code=0 details=""
2025-12-08T02:42:47.197Z root ERROR D 2025-12-08T02:42:47.196Z | v1.13.0 11336 | load_balancing_call | [2] Received status
2025-12-08T02:42:47.197Z root ERROR D 2025-12-08T02:42:47.196Z | v1.13.0 11336 | load_balancing_call | [2] ended with status: code=0 details="" start time=2025-12-08T02:42:47.166Z
2025-12-08T02:42:47.197Z root ERROR D 2025-12-08T02:42:47.196Z | v1.13.0 11336 | retrying_call | [1] Received status from child [2]
2025-12-08T02:42:47.197Z root ERROR D 2025-12-08T02:42:47.196Z | v1.13.0 11336 | retrying_call | [1] state=COMMITTED handling status with progress PROCESSED from child [2] in state ACTIVE
2025-12-08T02:42:47.197Z root ERROR D 2025-12-08T02:42:47.196Z | v1.13.0 11336 | retrying_call | [1] ended with status: code=0 details="" start time=2025-12-08T02:42:47.166Z
2025-12-08T02:42:47.197Z root ERROR D 2025-12-08T02:42:47.196Z | v1.13.0 11336 | resolving_call | [0] Received status
2025-12-08T02:42:47.197Z root ERROR D 2025-12-08T02:42:47.196Z | v1.13.0 11336 | resolving_call | [0] ended with status: code=0 details=""
2025-12-08T02:42:47.197Z root ERROR D 2025-12-08T02:42:47.197Z | v1.13.0 11336 | subchannel_call | [3] HTTP/2 stream closed with code 0
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.197Z | v1.13.0 11336 | channel | (1) dns:localhost:46025 createResolvingCall [4] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Init", deadline=Infinity
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.197Z | v1.13.0 11336 | resolving_call | [4] Created
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.197Z | v1.13.0 11336 | resolving_call | [4] Deadline: Infinity
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.197Z | v1.13.0 11336 | resolving_call | [4] start called
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.197Z | v1.13.0 11336 | resolving_call | [4] write() called with message of length 4
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.197Z | v1.13.0 11336 | resolving_call | [4] halfClose called
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.197Z | v1.13.0 11336 | channel | (1) dns:localhost:46025 createRetryingCall [5] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Init"
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.197Z | v1.13.0 11336 | resolving_call | [4] Created child [5]
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.197Z | v1.13.0 11336 | retrying_call | [5] start called
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.197Z | v1.13.0 11336 | channel | (1) dns:localhost:46025 createLoadBalancingCall [6] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Init"
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.197Z | v1.13.0 11336 | retrying_call | [5] Created child call [6] for attempt 1
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.197Z | v1.13.0 11336 | load_balancing_call | [6] start called
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.197Z | v1.13.0 11336 | load_balancing_call | [6] Pick called
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.197Z | v1.13.0 11336 | load_balancing_call | [6] Pick result: COMPLETE subchannel: (1) 127.0.0.1:46025 status: undefined undefined
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.197Z | v1.13.0 11336 | transport_flowctrl | (1) 127.0.0.1:46025 local window size: 65526 remote window size: 65535
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.197Z | v1.13.0 11336 | transport_internals | (1) 127.0.0.1:46025 session.closed=false session.destroyed=false session.socket.destroyed=false
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.197Z | v1.13.0 11336 | load_balancing_call | [6] Created child call [7]
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.197Z | v1.13.0 11336 | retrying_call | [5] write() called with message of length 9
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.197Z | v1.13.0 11336 | load_balancing_call | [6] write() called with message of length 9
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.197Z | v1.13.0 11336 | subchannel_call | [7] write() called with message of length 9
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.197Z | v1.13.0 11336 | subchannel_call | [7] sending data chunk of length 9
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.198Z | v1.13.0 11336 | retrying_call | [5] halfClose called
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.198Z | v1.13.0 11336 | resolving_call | [4] startRead called
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.198Z | v1.13.0 11336 | retrying_call | [5] startRead called
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.198Z | v1.13.0 11336 | load_balancing_call | [6] startRead called
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.198Z | v1.13.0 11336 | load_balancing_call | [6] halfClose called
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.198Z | v1.13.0 11336 | subchannel_call | [7] end() called
2025-12-08T02:42:47.198Z root ERROR D 2025-12-08T02:42:47.198Z | v1.13.0 11336 | subchannel_call | [7] calling end() on HTTP/2 stream
2025-12-08T02:42:47.199Z config INFO The CLI config is valid.
2025-12-08T02:42:47.200Z config INFO <<< Initialized the CLI configuration.
2025-12-08T02:42:47.206Z daemon INFO time="2025-12-08T13:42:47+11:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2025-12-08T02:42:47.206Z root ERROR D 2025-12-08T02:42:47.206Z | v1.13.0 11336 | subchannel_call | [7] Received server headers:
:status: 200
2025-12-08T02:42:47.206Z root ERROR D 2025-12-08T02:42:47.206Z | v1.13.0 11336 | load_balancing_call | [6] Received metadata
2025-12-08T02:42:47.206Z root ERROR D 2025-12-08T02:42:47.206Z | v1.13.0 11336 | retrying_call | [5] Received metadata from child [6]
2025-12-08T02:42:47.206Z root ERROR D 2025-12-08T02:42:47.206Z | v1.13.0 11336 | retrying_call | [5] Committing call [6] at index 0
2025-12-08T02:42:47.206Z root ERROR D 2025-12-08T02:42:47.206Z | v1.13.0 11336 | resolving_call | [4] Received metadata
2025-12-08T02:42:47.207Z root ERROR D 2025-12-08T02:42:47.206Z | v1.13.0 11336 | subchannel_call | [7] receive HTTP/2 data frame of length 115
2025-12-08T02:42:47.207Z root ERROR D 2025-12-08T02:42:47.206Z | v1.13.0 11336 | subchannel_call | [7] parsed message of length 115
2025-12-08T02:42:47.207Z root ERROR D 2025-12-08T02:42:47.206Z | v1.13.0 11336 | subchannel_call | [7] pushing to reader message of length 115
2025-12-08T02:42:47.207Z root ERROR D 2025-12-08T02:42:47.206Z | v1.13.0 11336 | load_balancing_call | [6] Received message
2025-12-08T02:42:47.207Z root ERROR D 2025-12-08T02:42:47.206Z | v1.13.0 11336 | retrying_call | [5] Received message from child [6]
2025-12-08T02:42:47.207Z root ERROR D 2025-12-08T02:42:47.206Z | v1.13.0 11336 | resolving_call | [4] Received message
2025-12-08T02:42:47.207Z root ERROR D 2025-12-08T02:42:47.206Z | v1.13.0 11336 | resolving_call | [4] Finished filtering received message
2025-12-08T02:42:47.207Z root ERROR D 2025-12-08T02:42:47.207Z | v1.13.0 11336 | resolving_call | [4] startRead called
2025-12-08T02:42:47.207Z root ERROR D 2025-12-08T02:42:47.207Z | v1.13.0 11336 | retrying_call | [5] startRead called
2025-12-08T02:42:47.207Z root ERROR D 2025-12-08T02:42:47.207Z | v1.13.0 11336 | load_balancing_call | [6] startRead called
2025-12-08T02:42:47.209Z root ERROR D 2025-12-08T02:42:47.208Z | v1.13.0 11336 | subchannel_call | [7] receive HTTP/2 data frame of length 192
2025-12-08T02:42:47.209Z root ERROR D 2025-12-08T02:42:47.209Z | v1.13.0 11336 | subchannel_call | [7] parsed message of length 192
2025-12-08T02:42:47.209Z root ERROR D 2025-12-08T02:42:47.209Z | v1.13.0 11336 | subchannel_call | [7] pushing to reader message of length 192
2025-12-08T02:42:47.209Z root ERROR D 2025-12-08T02:42:47.209Z | v1.13.0 11336 | load_balancing_call | [6] Received message
2025-12-08T02:42:47.209Z root ERROR D 2025-12-08T02:42:47.209Z | v1.13.0 11336 | retrying_call | [5] Received message from child [6]
2025-12-08T02:42:47.209Z root ERROR D 2025-12-08T02:42:47.209Z | v1.13.0 11336 | resolving_call | [4] Received message
2025-12-08T02:42:47.209Z root ERROR D 2025-12-08T02:42:47.209Z | v1.13.0 11336 | resolving_call | [4] Finished filtering received message
2025-12-08T02:42:47.209Z root ERROR D 2025-12-08T02:42:47.209Z | v1.13.0 11336 | resolving_call | [4] startRead called
2025-12-08T02:42:47.209Z root ERROR D 2025-12-08T02:42:47.209Z | v1.13.0 11336 | retrying_call | [5] startRead called
2025-12-08T02:42:47.209Z root ERROR D 2025-12-08T02:42:47.209Z | v1.13.0 11336 | load_balancing_call | [6] startRead called
2025-12-08T02:42:47.209Z root ERROR D 2025-12-08T02:42:47.209Z | v1.13.0 11336 | subchannel_call | [7] receive HTTP/2 data frame of length 622
2025-12-08T02:42:47.209Z root ERROR D 2025-12-08T02:42:47.209Z | v1.13.0 11336 | subchannel_call | [7] parsed message of length 622
2025-12-08T02:42:47.209Z root ERROR D 2025-12-08T02:42:47.209Z | v1.13.0 11336 | subchannel_call | [7] pushing to reader message of length 622
2025-12-08T02:42:47.210Z root ERROR D 2025-12-08T02:42:47.209Z | v1.13.0 11336 | resolving_call | [4] Received message
2025-12-08T02:42:47.210Z root ERROR D 2025-12-08T02:42:47.209Z | v1.13.0 11336 | resolving_call | [4] Finished filtering received message
2025-12-08T02:42:47.210Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp: lookup downloads.arduino.cc on [::1]:53: read udp [::1]:37238->[::1]:53: read: connection refused
2025-12-08T02:42:47.210Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | resolving_call | [4] startRead called
2025-12-08T02:42:47.210Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | retrying_call | [5] startRead called
2025-12-08T02:42:47.210Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | load_balancing_call | [6] startRead called
2025-12-08T02:42:47.210Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | subchannel_call | [7] receive HTTP/2 data frame of length 416
2025-12-08T02:42:47.210Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | subchannel_call | [7] parsed message of length 416
2025-12-08T02:42:47.210Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | subchannel_call | [7] pushing to reader message of length 416
2025-12-08T02:42:47.210Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | load_balancing_call | [6] Received message
2025-12-08T02:42:47.210Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | retrying_call | [5] Received message from child [6]
2025-12-08T02:42:47.210Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | resolving_call | [4] Received message
2025-12-08T02:42:47.210Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | resolving_call | [4] Finished filtering received message
2025-12-08T02:42:47.210Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file /home/issah/.arduino15/package_index.json: open /home/issah/.arduino15/package_index.json: no such file or directory
2025-12-08T02:42:47.210Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | subchannel_call | [7] receive HTTP/2 data frame of length 160
2025-12-08T02:42:47.210Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | subchannel_call | [7] parsed message of length 160
2025-12-08T02:42:47.210Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | subchannel_call | [7] pushing to reader message of length 160
2025-12-08T02:42:47.210Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2025-12-08T02:42:47.210Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | subchannel_call | [7] receive HTTP/2 data frame of length 158
2025-12-08T02:42:47.210Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | subchannel_call | [7] parsed message of length 158
2025-12-08T02:42:47.210Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | subchannel_call | [7] pushing to reader message of length 158
2025-12-08T02:42:47.210Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2025-12-08T02:42:47.210Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | subchannel_call | [7] receive HTTP/2 data frame of length 132
2025-12-08T02:42:47.210Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | subchannel_call | [7] parsed message of length 132
2025-12-08T02:42:47.210Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | subchannel_call | [7] pushing to reader message of length 132
2025-12-08T02:42:47.210Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open /home/issah/.arduino15/library_index.json: no such file or directory
2025-12-08T02:42:47.212Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | subchannel_call | [7] Received server trailers:
grpc-status: 0
grpc-message:
2025-12-08T02:42:47.212Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | subchannel_call | [7] received status code 0 from server
2025-12-08T02:42:47.212Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | subchannel_call | [7] received status details string "" from server
2025-12-08T02:42:47.212Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | subchannel_call | [7] ended with status: code=0 details=""
2025-12-08T02:42:47.212Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | load_balancing_call | [6] Received status
2025-12-08T02:42:47.212Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | load_balancing_call | [6] ended with status: code=0 details="" start time=2025-12-08T02:42:47.197Z
2025-12-08T02:42:47.212Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | retrying_call | [5] Received status from child [6]
2025-12-08T02:42:47.212Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | retrying_call | [5] state=COMMITTED handling status with progress PROCESSED from child [6] in state ACTIVE
2025-12-08T02:42:47.212Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | retrying_call | [5] ended with status: code=0 details="" start time=2025-12-08T02:42:47.197Z
2025-12-08T02:42:47.212Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | resolving_call | [4] Received status
2025-12-08T02:42:47.212Z root ERROR D 2025-12-08T02:42:47.210Z | v1.13.0 11336 | resolving_call | [4] ended with status: code=0 details=""
2025-12-08T02:42:47.213Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Loading index file: loading json index file /home/issah/.arduino15/package_index.json: open /home/issah/.arduino15/package_index.json: no such file or directory
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
[library-index] - code: 9, message: Loading index file: reading library_index.json: open /home/issah/.arduino15/library_index.json: no such file or directory
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | channel | (1) dns:localhost:46025 createResolvingCall [8] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/UpdateIndex", deadline=Infinity
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | resolving_call | [8] Created
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | resolving_call | [8] Deadline: Infinity
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | resolving_call | [8] start called
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | resolving_call | [8] write() called with message of length 4
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | resolving_call | [8] halfClose called
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | channel | (1) dns:localhost:46025 createResolvingCall [9] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/UpdateLibrariesIndex", deadline=Infinity
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | resolving_call | [9] Created
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | resolving_call | [9] Deadline: Infinity
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | resolving_call | [9] start called
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | resolving_call | [9] write() called with message of length 4
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | resolving_call | [9] halfClose called
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | channel | (1) dns:localhost:46025 createRetryingCall [10] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/UpdateIndex"
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | resolving_call | [8] Created child [10]
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | retrying_call | [10] start called
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | channel | (1) dns:localhost:46025 createLoadBalancingCall [11] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/UpdateIndex"
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | retrying_call | [10] Created child call [11] for attempt 1
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | load_balancing_call | [11] start called
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | load_balancing_call | [11] Pick called
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | load_balancing_call | [11] Pick result: COMPLETE subchannel: (1) 127.0.0.1:46025 status: undefined undefined
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | channel | (1) dns:localhost:46025 createRetryingCall [12] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/UpdateLibrariesIndex"
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | resolving_call | [9] Created child [12]
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | retrying_call | [12] start called
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | channel | (1) dns:localhost:46025 createLoadBalancingCall [13] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/UpdateLibrariesIndex"
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | retrying_call | [12] Created child call [13] for attempt 1
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | load_balancing_call | [13] start called
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | load_balancing_call | [13] Pick called
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.212Z | v1.13.0 11336 | load_balancing_call | [13] Pick result: COMPLETE subchannel: (1) 127.0.0.1:46025 status: undefined undefined
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | transport_flowctrl | (1) 127.0.0.1:46025 local window size: 63731 remote window size: 65535
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | transport_internals | (1) 127.0.0.1:46025 session.closed=false session.destroyed=false session.socket.destroyed=false
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | load_balancing_call | [11] Created child call [14]
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | load_balancing_call | [13] Created child call [15]
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | retrying_call | [10] write() called with message of length 9
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | load_balancing_call | [11] write() called with message of length 9
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | subchannel_call | [14] write() called with message of length 9
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | subchannel_call | [14] sending data chunk of length 9
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | retrying_call | [10] halfClose called
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | retrying_call | [12] write() called with message of length 9
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | load_balancing_call | [13] write() called with message of length 9
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | subchannel_call | [15] write() called with message of length 9
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | subchannel_call | [15] sending data chunk of length 9
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | retrying_call | [12] halfClose called
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | resolving_call | [8] startRead called
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | retrying_call | [10] startRead called
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | load_balancing_call | [11] startRead called
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | resolving_call | [9] startRead called
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | retrying_call | [12] startRead called
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | load_balancing_call | [13] startRead called
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | subchannel_call | [7] HTTP/2 stream closed with code 0
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | load_balancing_call | [11] halfClose called
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | subchannel_call | [14] end() called
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | subchannel_call | [14] calling end() on HTTP/2 stream
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | load_balancing_call | [13] halfClose called
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | subchannel_call | [15] end() called
2025-12-08T02:42:47.213Z root ERROR D 2025-12-08T02:42:47.213Z | v1.13.0 11336 | subchannel_call | [15] calling end() on HTTP/2 stream
2025-12-08T02:42:47.213Z daemon INFO time="2025-12-08T13:42:47+11:00" level=info msg="Loading hardware from: /home/issah/.arduino15/packages"
time="2025-12-08T13:42:47+11:00" level=info msg="Loading libraries index file" index=/home/issah/.arduino15/library_index.json
time="2025-12-08T13:42:47+11:00" level=info msg="Adding libraries dir" dir=/home/issah/.arduino15/libraries isSingleLibrary=false location=ide
time="2025-12-08T13:42:47+11:00" level=info msg="Adding libraries dir" dir=/home/issah/Arduino/libraries isSingleLibrary=false location=user
2025-12-08T02:42:47.215Z daemon INFO time="2025-12-08T13:42:47+11:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
time="2025-12-08T13:42:47+11:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2025-12-08T02:42:47.216Z root ERROR D 2025-12-08T02:42:47.216Z | v1.13.0 11336 | subchannel_call | [14] Received server headers:
:status: 200
2025-12-08T02:42:47.216Z root ERROR D 2025-12-08T02:42:47.216Z | v1.13.0 11336 | load_balancing_call | [11] Received metadata
2025-12-08T02:42:47.216Z root ERROR D 2025-12-08T02:42:47.216Z | v1.13.0 11336 | retrying_call | [10] Received metadata from child [11]
2025-12-08T02:42:47.216Z root ERROR D 2025-12-08T02:42:47.216Z | v1.13.0 11336 | retrying_call | [10] Committing call [11] at index 0
2025-12-08T02:42:47.216Z root ERROR D 2025-12-08T02:42:47.216Z | v1.13.0 11336 | resolving_call | [8] Received metadata
2025-12-08T02:42:47.217Z root ERROR D 2025-12-08T02:42:47.216Z | v1.13.0 11336 | subchannel_call | [14] receive HTTP/2 data frame of length 112
2025-12-08T02:42:47.217Z root ERROR D 2025-12-08T02:42:47.216Z | v1.13.0 11336 | subchannel_call | [14] parsed message of length 112
2025-12-08T02:42:47.217Z root ERROR D 2025-12-08T02:42:47.216Z | v1.13.0 11336 | subchannel_call | [14] pushing to reader message of length 112
2025-12-08T02:42:47.217Z root ERROR D 2025-12-08T02:42:47.216Z | v1.13.0 11336 | load_balancing_call | [11] Received message
2025-12-08T02:42:47.217Z root ERROR D 2025-12-08T02:42:47.216Z | v1.13.0 11336 | retrying_call | [10] Received message from child [11]
2025-12-08T02:42:47.217Z root ERROR D 2025-12-08T02:42:47.216Z | v1.13.0 11336 | resolving_call | [8] Received message
2025-12-08T02:42:47.217Z root ERROR D 2025-12-08T02:42:47.216Z | v1.13.0 11336 | resolving_call | [8] Finished filtering received message
2025-12-08T02:42:47.217Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2025-12-08T02:42:47.217Z root ERROR D 2025-12-08T02:42:47.217Z | v1.13.0 11336 | resolving_call | [8] startRead called
2025-12-08T02:42:47.217Z root ERROR D 2025-12-08T02:42:47.217Z | v1.13.0 11336 | retrying_call | [10] startRead called
2025-12-08T02:42:47.217Z root ERROR D 2025-12-08T02:42:47.217Z | v1.13.0 11336 | load_balancing_call | [11] startRead called
2025-12-08T02:42:47.217Z root ERROR D 2025-12-08T02:42:47.217Z | v1.13.0 11336 | subchannel_call | [15] Received server headers:
:status: 200
2025-12-08T02:42:47.217Z root ERROR D 2025-12-08T02:42:47.217Z | v1.13.0 11336 | load_balancing_call | [13] Received metadata
2025-12-08T02:42:47.217Z root ERROR D 2025-12-08T02:42:47.217Z | v1.13.0 11336 | retrying_call | [12] Received metadata from child [13]
2025-12-08T02:42:47.217Z root ERROR D 2025-12-08T02:42:47.217Z | v1.13.0 11336 | retrying_call | [12] Committing call [13] at index 0
2025-12-08T02:42:47.217Z root ERROR D 2025-12-08T02:42:47.217Z | v1.13.0 11336 | resolving_call | [9] Received metadata
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.217Z | v1.13.0 11336 | subchannel_call | [15] receive HTTP/2 data frame of length 113
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.217Z | v1.13.0 11336 | subchannel_call | [15] parsed message of length 113
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.217Z | v1.13.0 11336 | subchannel_call | [15] pushing to reader message of length 113
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.217Z | v1.13.0 11336 | load_balancing_call | [13] Received message
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.217Z | v1.13.0 11336 | retrying_call | [12] Received message from child [13]
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.217Z | v1.13.0 11336 | resolving_call | [9] Received message
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.217Z | v1.13.0 11336 | resolving_call | [9] Finished filtering received message
2025-12-08T02:42:47.218Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | resolving_call | [9] startRead called
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | retrying_call | [12] startRead called
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | load_balancing_call | [13] startRead called
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | subchannel_call | [15] receive HTTP/2 data frame of length 189
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | subchannel_call | [15] parsed message of length 189
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | subchannel_call | [15] pushing to reader message of length 189
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | load_balancing_call | [13] Received message
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | retrying_call | [12] Received message from child [13]
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | resolving_call | [9] Received message
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | resolving_call | [9] Finished filtering received message
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | subchannel_call | [14] receive HTTP/2 data frame of length 188
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | subchannel_call | [14] parsed message of length 188
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | subchannel_call | [14] pushing to reader message of length 188
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | load_balancing_call | [11] Received message
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | retrying_call | [10] Received message from child [11]
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | resolving_call | [8] Received message
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | resolving_call | [8] Finished filtering received message
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | resolving_call | [8] startRead called
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | retrying_call | [10] startRead called
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | load_balancing_call | [11] startRead called
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | subchannel_call | [15] receive HTTP/2 data frame of length 73
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | subchannel_call | [15] parsed message of length 73
2025-12-08T02:42:47.218Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | subchannel_call | [15] pushing to reader message of length 73
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | subchannel_call | [15] Received server trailers:
grpc-status: 13
grpc-message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp: lookup downloads.arduino.cc on [::1]:53: read udp [::1]:59926->[::1]:53: read: connection refused
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | subchannel_call | [15] received status code 13 from server
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | subchannel_call | [15] received status details string "Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp: lookup downloads.arduino.cc on [::1]:53: read udp [::1]:59926->[::1]:53: read: connection refused" from server
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | subchannel_call | [15] ended with status: code=13 details="Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp: lookup downloads.arduino.cc on [::1]:53: read udp [::1]:59926->[::1]:53: read: connection refused"
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | load_balancing_call | [13] Received status
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | load_balancing_call | [13] ended with status: code=13 details="Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp: lookup downloads.arduino.cc on [::1]:53: read udp [::1]:59926->[::1]:53: read: connection refused" start time=2025-12-08T02:42:47.212Z
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | retrying_call | [12] Received status from child [13]
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | retrying_call | [12] state=COMMITTED handling status with progress PROCESSED from child [13] in state ACTIVE
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | retrying_call | [12] ended with status: code=13 details="Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp: lookup downloads.arduino.cc on [::1]:53: read udp [::1]:59926->[::1]:53: read: connection refused" start time=2025-12-08T02:42:47.212Z
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | resolving_call | [9] Received status
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.218Z | v1.13.0 11336 | resolving_call | [9] ended with status: code=13 details="Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp: lookup downloads.arduino.cc on [::1]:53: read udp [::1]:59926->[::1]:53: read: connection refused"
2025-12-08T02:42:47.219Z root ERROR Failed to update platform, library indexes. Error: 13 INTERNAL: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp: lookup downloads.arduino.cc on [::1]:53: read udp [::1]:59926->[::1]:53: read: connection refused
at t.callErrorFromStatus (/tmp/.mount_arduin6x80U7/resources/app/lib/backend/main.js:2:987037)
at Object.onReceiveStatus (/tmp/.mount_arduin6x80U7/resources/app/lib/backend/main.js:2:3785786)
at Object.onReceiveStatus (/tmp/.mount_arduin6x80U7/resources/app/lib/backend/main.js:2:2216111)
at /tmp/.mount_arduin6x80U7/resources/app/lib/backend/main.js:2:4354680
at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
at s.makeServerStreamRequest (/tmp/.mount_arduin6x80U7/resources/app/lib/backend/main.js:2:3785553)
at s.updateLibrariesIndex (/tmp/.mount_arduin6x80U7/resources/app/lib/backend/main.js:2:3311624)
at /tmp/.mount_arduin6x80U7/resources/app/lib/backend/main.js:2:104891
at /tmp/.mount_arduin6x80U7/resources/app/lib/backend/main.js:2:105084
at new Promise (<anonymous>)
at y.doUpdateIndex (/tmp/.mount_arduin6x80U7/resources/app/lib/backend/main.js:2:105063)
at y.updateLibraryIndex (/tmp/.mount_arduin6x80U7/resources/app/lib/backend/main.js:2:104863)
at y.updateIndex (/tmp/.mount_arduin6x80U7/resources/app/lib/backend/main.js:2:104137)
at y.initInstanceWithFallback (/tmp/.mount_arduin6x80U7/resources/app/lib/backend/main.js:2:102369)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | channel | (1) dns:localhost:46025 createResolvingCall [16] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Init", deadline=Infinity
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | resolving_call | [16] Created
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | resolving_call | [16] Deadline: Infinity
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | resolving_call | [16] start called
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | resolving_call | [16] write() called with message of length 4
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | resolving_call | [16] halfClose called
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | channel | (1) dns:localhost:46025 createRetryingCall [17] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Init"
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | resolving_call | [16] Created child [17]
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | retrying_call | [17] start called
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | channel | (1) dns:localhost:46025 createLoadBalancingCall [18] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Init"
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | retrying_call | [17] Created child call [18] for attempt 1
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | load_balancing_call | [18] start called
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | load_balancing_call | [18] Pick called
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | load_balancing_call | [18] Pick result: COMPLETE subchannel: (1) 127.0.0.1:46025 status: undefined undefined
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | transport_flowctrl | (1) 127.0.0.1:46025 local window size: 63056 remote window size: 65526
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | transport_internals | (1) 127.0.0.1:46025 session.closed=false session.destroyed=false session.socket.destroyed=false
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | load_balancing_call | [18] Created child call [19]
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | retrying_call | [17] write() called with message of length 9
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | load_balancing_call | [18] write() called with message of length 9
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | subchannel_call | [19] write() called with message of length 9
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | subchannel_call | [19] sending data chunk of length 9
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | retrying_call | [17] halfClose called
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | resolving_call | [16] startRead called
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | retrying_call | [17] startRead called
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | load_balancing_call | [18] startRead called
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | subchannel_call | [15] HTTP/2 stream closed with code 0
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | subchannel_call | [14] receive HTTP/2 data frame of length 72
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | subchannel_call | [14] parsed message of length 72
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | subchannel_call | [14] pushing to reader message of length 72
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | load_balancing_call | [11] Received message
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | retrying_call | [10] Received message from child [11]
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | resolving_call | [8] Received message
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | resolving_call | [8] Finished filtering received message
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | resolving_call | [8] startRead called
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | retrying_call | [10] startRead called
2025-12-08T02:42:47.219Z root ERROR D 2025-12-08T02:42:47.219Z | v1.13.0 11336 | load_balancing_call | [11] startRead called
2025-12-08T02:42:47.220Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | subchannel_call | [14] Received server trailers:
grpc-status: 13
grpc-message: Some indexes could not be updated.
2025-12-08T02:42:47.220Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | subchannel_call | [14] received status code 13 from server
2025-12-08T02:42:47.220Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | subchannel_call | [14] received status details string "Some indexes could not be updated." from server
2025-12-08T02:42:47.220Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | subchannel_call | [14] ended with status: code=13 details="Some indexes could not be updated."
2025-12-08T02:42:47.220Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | load_balancing_call | [11] Received status
2025-12-08T02:42:47.220Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | load_balancing_call | [11] ended with status: code=13 details="Some indexes could not be updated." start time=2025-12-08T02:42:47.212Z
2025-12-08T02:42:47.220Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | retrying_call | [10] Received status from child [11]
2025-12-08T02:42:47.220Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | retrying_call | [10] state=COMMITTED handling status with progress PROCESSED from child [11] in state ACTIVE
2025-12-08T02:42:47.220Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | retrying_call | [10] ended with status: code=13 details="Some indexes could not be updated." start time=2025-12-08T02:42:47.212Z
2025-12-08T02:42:47.220Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | resolving_call | [8] Received status
2025-12-08T02:42:47.220Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | resolving_call | [8] ended with status: code=13 details="Some indexes could not be updated."
2025-12-08T02:42:47.220Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | subchannel_call | [14] HTTP/2 stream closed with code 0
2025-12-08T02:42:47.220Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | load_balancing_call | [18] halfClose called
2025-12-08T02:42:47.220Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | subchannel_call | [19] end() called
2025-12-08T02:42:47.220Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | subchannel_call | [19] calling end() on HTTP/2 stream
2025-12-08T02:42:47.220Z daemon INFO time="2025-12-08T13:42:47+11:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2025-12-08T02:42:47.220Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | subchannel_call | [19] Received server headers:
:status: 200
2025-12-08T02:42:47.220Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | load_balancing_call | [18] Received metadata
2025-12-08T02:42:47.220Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | retrying_call | [17] Received metadata from child [18]
2025-12-08T02:42:47.220Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | retrying_call | [17] Committing call [18] at index 0
2025-12-08T02:42:47.220Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | resolving_call | [16] Received metadata
2025-12-08T02:42:47.221Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | subchannel_call | [19] receive HTTP/2 data frame of length 115
2025-12-08T02:42:47.221Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | subchannel_call | [19] parsed message of length 115
2025-12-08T02:42:47.221Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | subchannel_call | [19] pushing to reader message of length 115
2025-12-08T02:42:47.221Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | load_balancing_call | [18] Received message
2025-12-08T02:42:47.221Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | retrying_call | [17] Received message from child [18]
2025-12-08T02:42:47.221Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | resolving_call | [16] Received message
2025-12-08T02:42:47.221Z root ERROR D 2025-12-08T02:42:47.220Z | v1.13.0 11336 | resolving_call | [16] Finished filtering received message
2025-12-08T02:42:47.221Z root ERROR D 2025-12-08T02:42:47.221Z | v1.13.0 11336 | resolving_call | [16] startRead called
2025-12-08T02:42:47.221Z root ERROR D 2025-12-08T02:42:47.221Z | v1.13.0 11336 | retrying_call | [17] startRead called
2025-12-08T02:42:47.221Z root ERROR D 2025-12-08T02:42:47.221Z | v1.13.0 11336 | load_balancing_call | [18] startRead called
2025-12-08T02:42:47.221Z root ERROR D 2025-12-08T02:42:47.221Z | v1.13.0 11336 | subchannel_call | [19] receive HTTP/2 data frame of length 192
2025-12-08T02:42:47.221Z root ERROR D 2025-12-08T02:42:47.221Z | v1.13.0 11336 | subchannel_call | [19] parsed message of length 192
2025-12-08T02:42:47.221Z root ERROR D 2025-12-08T02:42:47.221Z | v1.13.0 11336 | subchannel_call | [19] pushing to reader message of length 192
2025-12-08T02:42:47.221Z root ERROR D 2025-12-08T02:42:47.221Z | v1.13.0 11336 | load_balancing_call | [18] Received message
2025-12-08T02:42:47.221Z root ERROR D 2025-12-08T02:42:47.221Z | v1.13.0 11336 | retrying_call | [17] Received message from child [18]
2025-12-08T02:42:47.221Z root ERROR D 2025-12-08T02:42:47.221Z | v1.13.0 11336 | resolving_call | [16] Received message
2025-12-08T02:42:47.221Z root ERROR D 2025-12-08T02:42:47.221Z | v1.13.0 11336 | resolving_call | [16] Finished filtering received message
2025-12-08T02:42:47.221Z root ERROR D 2025-12-08T02:42:47.221Z | v1.13.0 11336 | subchannel_call | [19] receive HTTP/2 data frame of length 622
2025-12-08T02:42:47.221Z root ERROR D 2025-12-08T02:42:47.221Z | v1.13.0 11336 | subchannel_call | [19] parsed message of length 622
2025-12-08T02:42:47.221Z root ERROR D 2025-12-08T02:42:47.221Z | v1.13.0 11336 | subchannel_call | [19] pushing to reader message of length 622
2025-12-08T02:42:47.221Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp: lookup downloads.arduino.cc on [::1]:53: read udp [::1]:55524->[::1]:53: read: connection refused
2025-12-08T02:42:47.222Z root ERROR D 2025-12-08T02:42:47.221Z | v1.13.0 11336 | subchannel_call | [19] receive HTTP/2 data frame of length 416
2025-12-08T02:42:47.222Z root ERROR D 2025-12-08T02:42:47.221Z | v1.13.0 11336 | subchannel_call | [19] parsed message of length 416
2025-12-08T02:42:47.222Z root ERROR D 2025-12-08T02:42:47.221Z | v1.13.0 11336 | subchannel_call | [19] pushing to reader message of length 416
2025-12-08T02:42:47.222Z root ERROR D 2025-12-08T02:42:47.221Z | v1.13.0 11336 | load_balancing_call | [18] Received message
2025-12-08T02:42:47.222Z root ERROR D 2025-12-08T02:42:47.221Z | v1.13.0 11336 | retrying_call | [17] Received message from child [18]
2025-12-08T02:42:47.222Z root ERROR D 2025-12-08T02:42:47.221Z | v1.13.0 11336 | resolving_call | [16] Received message
2025-12-08T02:42:47.222Z root ERROR D 2025-12-08T02:42:47.221Z | v1.13.0 11336 | resolving_call | [16] Finished filtering received message
2025-12-08T02:42:47.222Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file /home/issah/.arduino15/package_index.json: open /home/issah/.arduino15/package_index.json: no such file or directory
2025-12-08T02:42:47.222Z root ERROR D 2025-12-08T02:42:47.222Z | v1.13.0 11336 | resolving_call | [16] startRead called
2025-12-08T02:42:47.222Z root ERROR D 2025-12-08T02:42:47.222Z | v1.13.0 11336 | retrying_call | [17] startRead called
2025-12-08T02:42:47.222Z root ERROR D 2025-12-08T02:42:47.222Z | v1.13.0 11336 | load_balancing_call | [18] startRead called
2025-12-08T02:42:47.222Z root ERROR D 2025-12-08T02:42:47.222Z | v1.13.0 11336 | subchannel_call | [19] receive HTTP/2 data frame of length 160
2025-12-08T02:42:47.222Z root ERROR D 2025-12-08T02:42:47.222Z | v1.13.0 11336 | subchannel_call | [19] parsed message of length 160
2025-12-08T02:42:47.222Z root ERROR D 2025-12-08T02:42:47.222Z | v1.13.0 11336 | subchannel_call | [19] pushing to reader message of length 160
2025-12-08T02:42:47.222Z root ERROR D 2025-12-08T02:42:47.222Z | v1.13.0 11336 | load_balancing_call | [18] Received message
2025-12-08T02:42:47.222Z root ERROR D 2025-12-08T02:42:47.222Z | v1.13.0 11336 | retrying_call | [17] Received message from child [18]
2025-12-08T02:42:47.222Z root ERROR D 2025-12-08T02:42:47.222Z | v1.13.0 11336 | resolving_call | [16] Received message
2025-12-08T02:42:47.222Z root ERROR D 2025-12-08T02:42:47.222Z | v1.13.0 11336 | resolving_call | [16] Finished filtering received message
2025-12-08T02:42:47.222Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2025-12-08T02:42:47.222Z root ERROR D 2025-12-08T02:42:47.222Z | v1.13.0 11336 | subchannel_call | [19] receive HTTP/2 data frame of length 158
2025-12-08T02:42:47.222Z root ERROR D 2025-12-08T02:42:47.222Z | v1.13.0 11336 | subchannel_call | [19] parsed message of length 158
2025-12-08T02:42:47.222Z root ERROR D 2025-12-08T02:42:47.222Z | v1.13.0 11336 | subchannel_call | [19] pushing to reader message of length 158
2025-12-08T02:42:47.222Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2025-12-08T02:42:47.223Z root ERROR D 2025-12-08T02:42:47.222Z | v1.13.0 11336 | subchannel_call | [19] receive HTTP/2 data frame of length 132
2025-12-08T02:42:47.223Z root ERROR D 2025-12-08T02:42:47.222Z | v1.13.0 11336 | subchannel_call | [19] parsed message of length 132
2025-12-08T02:42:47.223Z root ERROR D 2025-12-08T02:42:47.222Z | v1.13.0 11336 | subchannel_call | [19] pushing to reader message of length 132
2025-12-08T02:42:47.223Z root ERROR D 2025-12-08T02:42:47.222Z | v1.13.0 11336 | load_balancing_call | [18] Received message
2025-12-08T02:42:47.223Z root ERROR D 2025-12-08T02:42:47.222Z | v1.13.0 11336 | retrying_call | [17] Received message from child [18]
2025-12-08T02:42:47.223Z root ERROR D 2025-12-08T02:42:47.222Z | v1.13.0 11336 | resolving_call | [16] Received message
2025-12-08T02:42:47.223Z root ERROR D 2025-12-08T02:42:47.222Z | v1.13.0 11336 | resolving_call | [16] Finished filtering received message
2025-12-08T02:42:47.223Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open /home/issah/.arduino15/library_index.json: no such file or directory
2025-12-08T02:42:47.223Z root ERROR D 2025-12-08T02:42:47.223Z | v1.13.0 11336 | resolving_call | [16] startRead called
2025-12-08T02:42:47.223Z root ERROR D 2025-12-08T02:42:47.223Z | v1.13.0 11336 | retrying_call | [17] startRead called
2025-12-08T02:42:47.223Z root ERROR D 2025-12-08T02:42:47.223Z | v1.13.0 11336 | load_balancing_call | [18] startRead called
2025-12-08T02:42:47.223Z daemon INFO time="2025-12-08T13:42:47+11:00" level=info msg="Loading hardware from: /home/issah/.arduino15/packages"
2025-12-08T02:42:47.223Z root ERROR D 2025-12-08T02:42:47.223Z | v1.13.0 11336 | subchannel_call | [19] Received server trailers:
grpc-status: 0
grpc-message:
2025-12-08T02:42:47.223Z root ERROR D 2025-12-08T02:42:47.223Z | v1.13.0 11336 | subchannel_call | [19] received status code 0 from server
2025-12-08T02:42:47.223Z root ERROR D 2025-12-08T02:42:47.223Z | v1.13.0 11336 | subchannel_call | [19] received status details string "" from server
2025-12-08T02:42:47.223Z root ERROR D 2025-12-08T02:42:47.223Z | v1.13.0 11336 | subchannel_call | [19] ended with status: code=0 details=""
2025-12-08T02:42:47.223Z root ERROR D 2025-12-08T02:42:47.223Z | v1.13.0 11336 | load_balancing_call | [18] Received status
2025-12-08T02:42:47.223Z root ERROR D 2025-12-08T02:42:47.223Z | v1.13.0 11336 | load_balancing_call | [18] ended with status: code=0 details="" start time=2025-12-08T02:42:47.219Z
2025-12-08T02:42:47.223Z root ERROR D 2025-12-08T02:42:47.223Z | v1.13.0 11336 | retrying_call | [17] Received status from child [18]
2025-12-08T02:42:47.223Z root ERROR D 2025-12-08T02:42:47.223Z | v1.13.0 11336 | retrying_call | [17] state=COMMITTED handling status with progress PROCESSED from child [18] in state ACTIVE
2025-12-08T02:42:47.223Z root ERROR D 2025-12-08T02:42:47.223Z | v1.13.0 11336 | retrying_call | [17] ended with status: code=0 details="" start time=2025-12-08T02:42:47.219Z
2025-12-08T02:42:47.223Z root ERROR D 2025-12-08T02:42:47.223Z | v1.13.0 11336 | resolving_call | [16] Received status
2025-12-08T02:42:47.223Z root ERROR D 2025-12-08T02:42:47.223Z | v1.13.0 11336 | resolving_call | [16] ended with status: code=0 details=""
2025-12-08T02:42:47.224Z root ERROR Uncaught Exception: Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2025-12-08T02:42:47.224Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
at /tmp/.mount_arduin6x80U7/resources/app/lib/backend/main.js:2:103880
at y.evaluateErrorStatus (/tmp/.mount_arduin6x80U7/resources/app/lib/backend/main.js:2:103896)
at async a.<anonymous> (/tmp/.mount_arduin6x80U7/resources/app/lib/backend/main.js:2:103566)
2025-12-08T02:42:47.224Z root ERROR D 2025-12-08T02:42:47.224Z | v1.13.0 11336 | subchannel_call | [19] HTTP/2 stream closed with code 0
2025-12-08T02:42:47.770Z root INFO Deploy plugins list: 828.3 ms [Finished 1.339 s after backend start]
2025-12-08T02:42:47.950Z root INFO creating connection for 1
2025-12-08T02:42:48.528Z root WARN A command editor.action.toggleStickyScroll is already registered.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2025-12-08T02:42:48.595Z root INFO Start frontend contributions: 179.2 ms [Finished 1.636 s after frontend start]
2025-12-08T02:42:48.595Z root INFO Changed application state from 'init' to 'started_contributions'.
2025-12-08T02:42:48.604Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2025-12-08T02:42:48.604Z root INFO >>> Restoring the layout state...
2025-12-08T02:42:48.619Z root INFO [32d267b0-100f-4f59-94af-ac37e97fafc9] Waiting for backend deployment: 32.1 ms [Finished 1.665 s after frontend start]
2025-12-08T02:42:48.942Z root INFO [hosted-plugin: 11455] PLUGIN_HOST(11455) starting instance
[Object: null prototype] {}
2025-12-08T02:42:49.303Z root INFO [32d267b0-100f-4f59-94af-ac37e97fafc9] Sync of 23 plugins: 686.3 ms [Finished 2.352 s after frontend start]
Closing channel on service path '/services/electron-window'.
Closing channel on service path '/services/ide-updater'.
Stored workspaces roots:
No sketches were scheduled for deletion.
