PS C:\Program Files\Arduino IDE> $Env:GRPC_VERBOSITY = "DEBUG"
PS C:\Program Files\Arduino IDE> $Env:GRPC_TRACE = "all"
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
D 2024-12-19T18:42:20.057Z | index | Loading @grpc/grpc-js version 1.9.5
Arduino IDE 2.3.4
Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.4" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.1.1" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-12-03T10:03:03.490Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.4","cliVersion":"1.1.1","buildDate":"2024-12-03T10:03:03.490Z"}
Starting backend process. PID: 28876
D 2024-12-19T18:42:20.424Z | index | Loading @grpc/grpc-js version 1.9.5
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/sullimak/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-12-19T18:42:20.477Z root INFO Backend Object.initialize: 2.8 ms [Finished 0.336 s after backend start]
2024-12-19T18:42:20.477Z root INFO Backend Object.configure: 2.3 ms [Finished 0.336 s after backend start]
2024-12-19T18:42:20.477Z root INFO Backend s.onStart: 1.0 ms [Finished 0.336 s after backend start]
2024-12-19T18:42:20.478Z root INFO Backend s.configure: 0.2 ms [Finished 0.350 s after backend start]
2024-12-19T18:42:20.478Z root INFO Backend d.onStart: 0.2 ms [Finished 0.350 s after backend start]
2024-12-19T18:42:20.478Z root INFO Backend d.configure: 0.1 ms [Finished 0.350 s after backend start]
2024-12-19T18:42:20.479Z root INFO Backend d.initialize: 13.9 ms [Finished 0.350 s after backend start]
2024-12-19T18:42:20.479Z root INFO Backend c.onStart: 0.1 ms [Finished 0.350 s after backend start]
2024-12-19T18:42:20.479Z root INFO Backend a.configure: 0.2 ms [Finished 0.350 s after backend start]
2024-12-19T18:42:20.480Z config INFO >>> Initializing CLI configuration...
2024-12-19T18:42:20.480Z root INFO Backend c.initialize: 0.3 ms [Finished 0.350 s after backend start]
2024-12-19T18:42:20.480Z root INFO Backend x.onStart: 0.4 ms [Finished 0.351 s after backend start]
2024-12-19T18:42:20.480Z config INFO Loading CLI configuration from c:\Users\sullimak\.arduinoIDE\arduino-cli.yaml...
2024-12-19T18:42:20.481Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-12-19T18:42:20.481Z root INFO Backend a.initialize: 0.2 ms [Finished 0.351 s after backend start]
2024-12-19T18:42:20.481Z root INFO Backend w.onStart: 0.6 ms [Finished 0.352 s after backend start]
2024-12-19T18:42:20.481Z root INFO Backend r.configure: 0.9 ms [Finished 0.352 s after backend start]
2024-12-19T18:42:20.481Z discovery-log INFO start
2024-12-19T18:42:20.481Z discovery-log INFO start new deferred
2024-12-19T18:42:20.481Z root INFO Backend d.initialize: 0.2 ms [Finished 0.352 s after backend start]
2024-12-19T18:42:20.481Z root INFO Backend y.onStart: 1.0 ms [Finished 0.353 s after backend start]
2024-12-19T18:42:20.481Z root INFO Backend r.configure: 0.9 ms [Finished 0.353 s after backend start]
2024-12-19T18:42:20.481Z root INFO Backend a.onStart: 0.3 ms [Finished 0.353 s after backend start]
2024-12-19T18:42:20.481Z root INFO Backend h.configure: 0.2 ms [Finished 0.353 s after backend start]
2024-12-19T18:42:20.481Z root INFO Backend s.configure: 0.1 ms [Finished 0.354 s after backend start]
2024-12-19T18:42:20.481Z root INFO Backend l.configure: 0.0 ms [Finished 0.354 s after backend start]
2024-12-19T18:42:20.482Z root INFO Theia app listening on http://127.0.0.1:58194.
2024-12-19T18:42:20.482Z root INFO Finished starting backend application: 1.7 ms [Finished 0.355 s after backend start]
2024-12-19T18:42:20.487Z root WARN The local plugin referenced by local-dir:/c%3A/Users/sullimak/.arduinoIDE/plugins does not exist.
2024-12-19T18:42:20.487Z root WARN The local plugin referenced by local-dir:/c%3A/Users/sullimak/.arduinoIDE/extensions does not exist.
2024-12-19T18:42:20.487Z root WARN The local plugin referenced by local-dir:C:\Users\sullimak\.arduinoIDE\plugins does not exist.
2024-12-19T18:42:20.490Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\sullimak\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\sullimak\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\sullimak\\OneDrive - Schaeffler\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-12-19T18:42:20.490Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-12-19T18:42:20.490Z config INFO Loaded the CLI configuration.
2024-12-19T18:42:20.492Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/sullimak/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/sullimak/OneDrive%20-%20Schaeffler/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-12-19T18:42:20.492Z config INFO Validating the CLI configuration...
2024-12-19T18:42:20.492Z config INFO The CLI config is valid.
2024-12-19T18:42:20.492Z config INFO <<< Initialized the CLI configuration.
2024-12-19T18:42:20.501Z root INFO Resolve plugins list: 21.0 ms [Finished 0.374 s after backend start]
2024-12-19T18:42:20.549Z daemon INFO time="2024-12-19T13:42:20-05:00" level=info msg="arduino-cli version 1.1.1"
time="2024-12-19T13:42:20-05:00" level=info msg="Using config file: c:\\Users\\sullimak\\.arduinoIDE\\arduino-cli.yaml"
time="2024-12-19T13:42:20-05:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:58196
{"IP":"127.0.0.1","Port":"58196"}
2024-12-19T18:42:20.549Z root ERROR D 2024-12-19T18:42:20.547Z | resolving_load_balancer | dns:localhost:58196 IDLE -> IDLE
2024-12-19T18:42:20.549Z root ERROR D 2024-12-19T18:42:20.547Z | connectivity_state | (1) dns:localhost:58196 IDLE -> IDLE
2024-12-19T18:42:20.549Z root ERROR D 2024-12-19T18:42:20.547Z | dns_resolver | Resolver constructed for target dns:localhost:58196
2024-12-19T18:42:20.549Z root ERROR D 2024-12-19T18:42:20.547Z | channel | (1) dns:localhost:58196 Channel constructed with options {
"grpc.max_send_message_length": 536870912,
"grpc.max_receive_message_length": 536870912,
"grpc.primary_user_agent": "arduino-ide/2.3.4"
2024-12-19T18:42:20.549Z root ERROR D 2024-12-19T18:42:20.547Z | channel_stacktrace | (1) Channel constructed
at new t.InternalChannel (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:974883)
at new t.ChannelImplementation (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:927551)
at new t.Client (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:945055)
at new s (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1013000)
at t.createArduinoCoreServiceClient (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:41260)
at v.createClient (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:776583)
at v.create (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:775541)
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:774437
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1221089
at i.invoke (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1221179)
2024-12-19T18:42:20.549Z root ERROR D 2024-12-19T18:42:20.548Z | channel | (1) dns:localhost:58196 createResolvingCall [0] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Create", deadline=Infinity
2024-12-19T18:42:20.549Z root ERROR D 2024-12-19T18:42:20.548Z | resolving_call | [0] Created
2024-12-19T18:42:20.549Z root ERROR D 2024-12-19T18:42:20.548Z | resolving_call | [0] Deadline: Infinity
2024-12-19T18:42:20.549Z root ERROR D 2024-12-19T18:42:20.548Z | resolving_call | [0] start called
2024-12-19T18:42:20.549Z root ERROR D 2024-12-19T18:42:20.548Z | dns_resolver | Looking up DNS hostname localhost
2024-12-19T18:42:20.549Z root ERROR D 2024-12-19T18:42:20.549Z | resolving_load_balancer | dns:localhost:58196 IDLE -> CONNECTING
2024-12-19T18:42:20.549Z root ERROR D 2024-12-19T18:42:20.549Z | connectivity_state | (1) dns:localhost:58196 IDLE -> CONNECTING
2024-12-19T18:42:20.549Z root ERROR D 2024-12-19T18:42:20.549Z | channel | (1) dns:localhost:58196 callRefTimer.ref | configSelectionQueue.length=1 pickQueue.length=0
2024-12-19T18:42:20.549Z root ERROR D 2024-12-19T18:42:20.549Z | resolving_call | [0] startRead called
2024-12-19T18:42:20.550Z root ERROR D 2024-12-19T18:42:20.549Z | resolving_call | [0] write() called with message of length 0
2024-12-19T18:42:20.550Z root ERROR D 2024-12-19T18:42:20.549Z | resolving_call | [0] halfClose called
2024-12-19T18:42:20.550Z daemon INFO Daemon is running.
2024-12-19T18:42:20.551Z root ERROR D 2024-12-19T18:42:20.550Z | dns_resolver | Resolved addresses for target dns:localhost:58196: [::1:58196,127.0.0.1:58196]
2024-12-19T18:42:20.551Z root ERROR D 2024-12-19T18:42:20.550Z | subchannel | (2) ::1:58196 Subchannel constructed with options {
2024-12-19T18:42:20.551Z root ERROR D 2024-12-19T18:42:20.550Z | subchannel_refcount | (2) ::1:58196 refcount 0 -> 1
2024-12-19T18:42:20.551Z root ERROR D 2024-12-19T18:42:20.550Z | subchannel | (3) 127.0.0.1:58196 Subchannel constructed with options {
2024-12-19T18:42:20.551Z root ERROR D 2024-12-19T18:42:20.550Z | subchannel_refcount | (3) 127.0.0.1:58196 refcount 0 -> 1
2024-12-19T18:42:20.551Z root ERROR D 2024-12-19T18:42:20.550Z | subchannel_refcount | (2) ::1:58196 refcount 1 -> 2
2024-12-19T18:42:20.551Z root ERROR D 2024-12-19T18:42:20.550Z | subchannel_refcount | (3) 127.0.0.1:58196 refcount 1 -> 2
2024-12-19T18:42:20.551Z root ERROR D 2024-12-19T18:42:20.551Z | pick_first | Start connecting to subchannel with address ::1:58196
2024-12-19T18:42:20.551Z root ERROR D 2024-12-19T18:42:20.551Z | pick_first | IDLE -> CONNECTING
2024-12-19T18:42:20.551Z root ERROR D 2024-12-19T18:42:20.551Z | resolving_load_balancer | dns:localhost:58196 CONNECTING -> CONNECTING
2024-12-19T18:42:20.551Z root ERROR D 2024-12-19T18:42:20.551Z | channel | (1) dns:localhost:58196 callRefTimer.unref | configSelectionQueue.length=1 pickQueue.length=0
2024-12-19T18:42:20.551Z root ERROR D 2024-12-19T18:42:20.551Z | connectivity_state | (1) dns:localhost:58196 CONNECTING -> CONNECTING
2024-12-19T18:42:20.552Z root ERROR D 2024-12-19T18:42:20.551Z | subchannel | (2) ::1:58196 IDLE -> CONNECTING
2024-12-19T18:42:20.553Z root ERROR D 2024-12-19T18:42:20.551Z | transport | dns:localhost:58196 creating HTTP/2 session to ::1:58196
2024-12-19T18:42:20.553Z root ERROR D 2024-12-19T18:42:20.552Z | channel | (1) dns:localhost:58196 createRetryingCall [1] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Create"
2024-12-19T18:42:20.553Z root ERROR D 2024-12-19T18:42:20.552Z | resolving_call | [0] Created child [1]
2024-12-19T18:42:20.553Z root ERROR D 2024-12-19T18:42:20.552Z | retrying_call | [1] start called
2024-12-19T18:42:20.553Z root ERROR D 2024-12-19T18:42:20.552Z | channel | (1) dns:localhost:58196 createLoadBalancingCall [2] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Create"
2024-12-19T18:42:20.553Z root ERROR D 2024-12-19T18:42:20.552Z | retrying_call | [1] Created child call [2] for attempt 1
2024-12-19T18:42:20.553Z root ERROR D 2024-12-19T18:42:20.552Z | load_balancing_call | [2] start called
2024-12-19T18:42:20.553Z root ERROR D 2024-12-19T18:42:20.552Z | load_balancing_call | [2] Pick called
2024-12-19T18:42:20.553Z root ERROR D 2024-12-19T18:42:20.552Z | load_balancing_call | [2] Pick result: QUEUE subchannel: null status: undefined undefined
2024-12-19T18:42:20.553Z root ERROR D 2024-12-19T18:42:20.552Z | channel | (1) dns:localhost:58196 callRefTimer.ref | configSelectionQueue.length=0 pickQueue.length=1
2024-12-19T18:42:20.553Z root ERROR D 2024-12-19T18:42:20.552Z | retrying_call | [1] startRead called
2024-12-19T18:42:20.553Z root ERROR D 2024-12-19T18:42:20.552Z | load_balancing_call | [2] startRead called
2024-12-19T18:42:20.553Z root ERROR D 2024-12-19T18:42:20.553Z | retrying_call | [1] write() called with message of length 5
2024-12-19T18:42:20.553Z root ERROR D 2024-12-19T18:42:20.553Z | load_balancing_call | [2] write() called with message of length 5
2024-12-19T18:42:20.553Z root ERROR D 2024-12-19T18:42:20.553Z | retrying_call | [1] halfClose called
2024-12-19T18:42:20.553Z root ERROR D 2024-12-19T18:42:20.553Z | transport | dns:localhost:58196 connection failed with error connect ECONNREFUSED ::1:58196
2024-12-19T18:42:20.553Z root ERROR D 2024-12-19T18:42:20.553Z | subchannel | (2) ::1:58196 CONNECTING -> TRANSIENT_FAILURE
2024-12-19T18:42:20.553Z root ERROR D 2024-12-19T18:42:20.553Z | pick_first | Start connecting to subchannel with address 127.0.0.1:58196
2024-12-19T18:42:20.554Z root ERROR D 2024-12-19T18:42:20.553Z | subchannel | (3) 127.0.0.1:58196 IDLE -> CONNECTING
2024-12-19T18:42:20.554Z root ERROR D 2024-12-19T18:42:20.553Z | transport | dns:localhost:58196 creating HTTP/2 session to 127.0.0.1:58196
2024-12-19T18:42:20.555Z root ERROR D 2024-12-19T18:42:20.554Z | subchannel | (3) 127.0.0.1:58196 CONNECTING -> READY
2024-12-19T18:42:20.555Z root ERROR D 2024-12-19T18:42:20.554Z | pick_first | Pick subchannel with address 127.0.0.1:58196
2024-12-19T18:42:20.555Z root ERROR D 2024-12-19T18:42:20.554Z | subchannel_refcount | (3) 127.0.0.1:58196 refcount 2 -> 3
2024-12-19T18:42:20.555Z root ERROR D 2024-12-19T18:42:20.554Z | subchannel_refcount | (2) ::1:58196 refcount 2 -> 1
2024-12-19T18:42:20.555Z root ERROR D 2024-12-19T18:42:20.554Z | subchannel_refcount | (3) 127.0.0.1:58196 refcount 3 -> 2
2024-12-19T18:42:20.555Z root ERROR D 2024-12-19T18:42:20.554Z | pick_first | CONNECTING -> READY
2024-12-19T18:42:20.555Z root ERROR D 2024-12-19T18:42:20.554Z | resolving_load_balancer | dns:localhost:58196 CONNECTING -> READY
2024-12-19T18:42:20.555Z root ERROR D 2024-12-19T18:42:20.554Z | channel | (1) dns:localhost:58196 callRefTimer.unref | configSelectionQueue.length=0 pickQueue.length=0
2024-12-19T18:42:20.555Z root ERROR D 2024-12-19T18:42:20.554Z | load_balancing_call | [2] Pick called
2024-12-19T18:42:20.555Z root ERROR D 2024-12-19T18:42:20.554Z | load_balancing_call | [2] Pick result: COMPLETE subchannel: (3) 127.0.0.1:58196 status: undefined undefined
2024-12-19T18:42:20.555Z root ERROR D 2024-12-19T18:42:20.554Z | connectivity_state | (1) dns:localhost:58196 CONNECTING -> READY
2024-12-19T18:42:20.555Z root ERROR D 2024-12-19T18:42:20.555Z | transport_flowctrl | (4) 127.0.0.1:58196 local window size: 65535 remote window size: 65535
2024-12-19T18:42:20.555Z root ERROR D 2024-12-19T18:42:20.555Z | transport_internals | (4) 127.0.0.1:58196 session.closed=false session.destroyed=false session.socket.destroyed=false
2024-12-19T18:42:20.555Z root ERROR D 2024-12-19T18:42:20.555Z | load_balancing_call | [2] Created child call [3]
2024-12-19T18:42:20.555Z root ERROR D 2024-12-19T18:42:20.555Z | subchannel_call | [3] write() called with message of length 5
2024-12-19T18:42:20.555Z root ERROR D 2024-12-19T18:42:20.555Z | subchannel_call | [3] sending data chunk of length 5
2024-12-19T18:42:20.555Z root ERROR D 2024-12-19T18:42:20.555Z | load_balancing_call | [2] halfClose called
2024-12-19T18:42:20.555Z root ERROR D 2024-12-19T18:42:20.555Z | subchannel_call | [3] end() called
2024-12-19T18:42:20.555Z root ERROR D 2024-12-19T18:42:20.555Z | subchannel_call | [3] calling end() on HTTP/2 stream
2024-12-19T18:42:20.556Z root ERROR D 2024-12-19T18:42:20.556Z | transport | (4) 127.0.0.1:58196 local settings acknowledged by remote: {"headerTableSize":4096,"enablePush":true,"initialWindowSize":65535,"maxFrameSize":16384,"maxConcurrentStreams":4294967295,"maxHeaderListSize":4294967295,"maxHeaderSize":4294967295,"enableConnectProtocol":false}
2024-12-19T18:42:20.561Z root ERROR D 2024-12-19T18:42:20.560Z | subchannel_call | [3] Received server headers:
:status: 200
content-type: application/grpc
2024-12-19T18:42:20.561Z root ERROR D 2024-12-19T18:42:20.560Z | load_balancing_call | [2] Received metadata
2024-12-19T18:42:20.561Z root ERROR D 2024-12-19T18:42:20.560Z | retrying_call | [1] Received metadata from child [2]
2024-12-19T18:42:20.561Z root ERROR D 2024-12-19T18:42:20.560Z | retrying_call | [1] Committing call [2] at index 0
2024-12-19T18:42:20.561Z root ERROR D 2024-12-19T18:42:20.561Z | resolving_call | [0] Received metadata
2024-12-19T18:42:20.561Z root ERROR D 2024-12-19T18:42:20.561Z | subchannel_call | [3] receive HTTP/2 data frame of length 9
2024-12-19T18:42:20.561Z root ERROR D 2024-12-19T18:42:20.561Z | subchannel_call | [3] parsed message of length 9
2024-12-19T18:42:20.561Z root ERROR D 2024-12-19T18:42:20.561Z | subchannel_call | [3] pushing to reader message of length 9
2024-12-19T18:42:20.561Z root ERROR D 2024-12-19T18:42:20.561Z | load_balancing_call | [2] Received message
2024-12-19T18:42:20.561Z root ERROR D 2024-12-19T18:42:20.561Z | retrying_call | [1] Received message from child [2]
2024-12-19T18:42:20.561Z root ERROR D 2024-12-19T18:42:20.561Z | resolving_call | [0] Received message
2024-12-19T18:42:20.561Z root ERROR D 2024-12-19T18:42:20.561Z | resolving_call | [0] Finished filtering received message
2024-12-19T18:42:20.562Z root ERROR D 2024-12-19T18:42:20.561Z | subchannel_call | [3] Received server trailers:
grpc-status: 0
grpc-message:
2024-12-19T18:42:20.562Z root ERROR D 2024-12-19T18:42:20.562Z | subchannel_call | [3] received status code 0 from server
2024-12-19T18:42:20.562Z root ERROR D 2024-12-19T18:42:20.562Z | subchannel_call | [3] received status details string "" from server
2024-12-19T18:42:20.562Z root ERROR D 2024-12-19T18:42:20.562Z | subchannel_call | [3] close http2 stream with code 0
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.562Z | subchannel_call | [3] ended with status: code=0 details=""
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.562Z | load_balancing_call | [2] Received status
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.562Z | load_balancing_call | [2] ended with status: code=0 details=""
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.562Z | retrying_call | [1] Received status from child [2]
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.562Z | retrying_call | [1] state=COMMITTED handling status with progress PROCESSED from child [2] in state ACTIVE
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.562Z | retrying_call | [1] ended with status: code=0 details=""
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.562Z | resolving_call | [0] Received status
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.562Z | resolving_call | [0] ended with status: code=0 details=""
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.562Z | subchannel_call | [3] HTTP/2 stream closed with code 0
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.562Z | channel | (1) dns:localhost:58196 createResolvingCall [4] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Init", deadline=Infinity
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.562Z | resolving_call | [4] Created
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.562Z | resolving_call | [4] Deadline: Infinity
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.562Z | resolving_call | [4] start called
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.563Z | resolving_call | [4] write() called with message of length 4
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.563Z | resolving_call | [4] halfClose called
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.563Z | channel | (1) dns:localhost:58196 createRetryingCall [5] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Init"
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.563Z | resolving_call | [4] Created child [5]
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.563Z | retrying_call | [5] start called
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.563Z | channel | (1) dns:localhost:58196 createLoadBalancingCall [6] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Init"
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.563Z | retrying_call | [5] Created child call [6] for attempt 1
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.563Z | load_balancing_call | [6] start called
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.563Z | load_balancing_call | [6] Pick called
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.563Z | load_balancing_call | [6] Pick result: COMPLETE subchannel: (3) 127.0.0.1:58196 status: undefined undefined
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.563Z | transport_flowctrl | (4) 127.0.0.1:58196 local window size: 65526 remote window size: 65535
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.563Z | transport_internals | (4) 127.0.0.1:58196 session.closed=false session.destroyed=false session.socket.destroyed=false
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.563Z | load_balancing_call | [6] Created child call [7]
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.563Z | retrying_call | [5] write() called with message of length 9
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.563Z | load_balancing_call | [6] write() called with message of length 9
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.563Z | subchannel_call | [7] write() called with message of length 9
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.563Z | subchannel_call | [7] sending data chunk of length 9
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.563Z | retrying_call | [5] halfClose called
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.563Z | resolving_call | [4] startRead called
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.563Z | retrying_call | [5] startRead called
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.563Z | load_balancing_call | [6] startRead called
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.563Z | load_balancing_call | [6] halfClose called
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.563Z | subchannel_call | [7] end() called
2024-12-19T18:42:20.563Z root ERROR D 2024-12-19T18:42:20.563Z | subchannel_call | [7] calling end() on HTTP/2 stream
2024-12-19T18:42:20.571Z root ERROR D 2024-12-19T18:42:20.571Z | subchannel_call | [7] Received server headers:
:status: 200
2024-12-19T18:42:20.571Z root ERROR D 2024-12-19T18:42:20.571Z | load_balancing_call | [6] Received metadata
2024-12-19T18:42:20.571Z root ERROR D 2024-12-19T18:42:20.571Z | retrying_call | [5] Received metadata from child [6]
2024-12-19T18:42:20.571Z root ERROR D 2024-12-19T18:42:20.571Z | retrying_call | [5] Committing call [6] at index 0
2024-12-19T18:42:20.571Z root ERROR D 2024-12-19T18:42:20.571Z | resolving_call | [4] Received metadata
2024-12-19T18:42:20.572Z root ERROR D 2024-12-19T18:42:20.571Z | subchannel_call | [7] receive HTTP/2 data frame of length 115
2024-12-19T18:42:20.572Z root ERROR D 2024-12-19T18:42:20.571Z | subchannel_call | [7] parsed message of length 115
2024-12-19T18:42:20.572Z root ERROR D 2024-12-19T18:42:20.571Z | subchannel_call | [7] pushing to reader message of length 115
2024-12-19T18:42:20.572Z root ERROR D 2024-12-19T18:42:20.571Z | load_balancing_call | [6] Received message
2024-12-19T18:42:20.572Z root ERROR D 2024-12-19T18:42:20.571Z | retrying_call | [5] Received message from child [6]
2024-12-19T18:42:20.572Z root ERROR D 2024-12-19T18:42:20.571Z | resolving_call | [4] Received message
2024-12-19T18:42:20.572Z root ERROR D 2024-12-19T18:42:20.571Z | resolving_call | [4] Finished filtering received message
2024-12-19T18:42:20.572Z root ERROR D 2024-12-19T18:42:20.572Z | resolving_call | [4] startRead called
2024-12-19T18:42:20.572Z root ERROR D 2024-12-19T18:42:20.572Z | retrying_call | [5] startRead called
2024-12-19T18:42:20.572Z root ERROR D 2024-12-19T18:42:20.572Z | load_balancing_call | [6] startRead called
2024-12-19T18:42:20.597Z daemon INFO time="2024-12-19T13:42:20-05:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-12-19T18:42:20.968Z root INFO Deploy plugins list: 21.0 ms [Finished 0.841 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-12-19T18:42:21.583Z root ERROR D 2024-12-19T18:42:21.583Z | subchannel | (2) ::1:58196 TRANSIENT_FAILURE -> CONNECTING
2024-12-19T18:42:21.583Z root ERROR D 2024-12-19T18:42:21.583Z | transport | dns:localhost:58196 creating HTTP/2 session to ::1:58196
2024-12-19T18:42:21.584Z root ERROR D 2024-12-19T18:42:21.584Z | transport | dns:localhost:58196 connection failed with error connect ECONNREFUSED ::1:58196
2024-12-19T18:42:21.584Z root ERROR D 2024-12-19T18:42:21.584Z | subchannel | (2) ::1:58196 CONNECTING -> TRANSIENT_FAILURE
2024-12-19T18:42:21.584Z root ERROR D 2024-12-19T18:42:21.584Z | subchannel | (2) ::1:58196 TRANSIENT_FAILURE -> IDLE
2024-12-19T18:42:21.620Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-12-19T18:42:26.214Z root ERROR D 2024-12-19T18:42:26.213Z | subchannel_call | [7] receive HTTP/2 data frame of length 198
2024-12-19T18:42:26.215Z root ERROR D 2024-12-19T18:42:26.214Z | subchannel_call | [7] parsed message of length 198
2024-12-19T18:42:26.215Z root ERROR D 2024-12-19T18:42:26.214Z | subchannel_call | [7] pushing to reader message of length 198
2024-12-19T18:42:26.215Z root ERROR D 2024-12-19T18:42:26.214Z | load_balancing_call | [6] Received message
2024-12-19T18:42:26.215Z root ERROR D 2024-12-19T18:42:26.214Z | retrying_call | [5] Received message from child [6]
2024-12-19T18:42:26.215Z root ERROR D 2024-12-19T18:42:26.214Z | resolving_call | [4] Received message
2024-12-19T18:42:26.215Z root ERROR D 2024-12-19T18:42:26.214Z | resolving_call | [4] Finished filtering received message
2024-12-19T18:42:26.215Z root ERROR D 2024-12-19T18:42:26.215Z | resolving_call | [4] startRead called
2024-12-19T18:42:26.215Z root ERROR D 2024-12-19T18:42:26.215Z | retrying_call | [5] startRead called
2024-12-19T18:42:26.215Z root ERROR D 2024-12-19T18:42:26.215Z | load_balancing_call | [6] startRead called
2024-12-19T18:42:26.216Z root ERROR D 2024-12-19T18:42:26.215Z | subchannel_call | [7] receive HTTP/2 data frame of length 634
2024-12-19T18:42:26.216Z root ERROR D 2024-12-19T18:42:26.215Z | subchannel_call | [7] parsed message of length 634
2024-12-19T18:42:26.216Z root ERROR D 2024-12-19T18:42:26.215Z | subchannel_call | [7] pushing to reader message of length 634
2024-12-19T18:42:26.216Z root ERROR D 2024-12-19T18:42:26.215Z | load_balancing_call | [6] Received message
2024-12-19T18:42:26.216Z root ERROR D 2024-12-19T18:42:26.215Z | retrying_call | [5] Received message from child [6]
2024-12-19T18:42:26.216Z root ERROR D 2024-12-19T18:42:26.215Z | resolving_call | [4] Received message
2024-12-19T18:42:26.216Z root ERROR D 2024-12-19T18:42:26.215Z | resolving_call | [4] Finished filtering received message
2024-12-19T18:42:26.216Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp 104.18.10.21:443: connectex: No connection could be made because the target machine actively refused it.
2024-12-19T18:42:26.216Z root ERROR D 2024-12-19T18:42:26.216Z | resolving_call | [4] startRead called
2024-12-19T18:42:26.216Z root ERROR D 2024-12-19T18:42:26.216Z | retrying_call | [5] startRead called
2024-12-19T18:42:26.216Z root ERROR D 2024-12-19T18:42:26.216Z | load_balancing_call | [6] startRead called
2024-12-19T18:42:26.216Z root ERROR D 2024-12-19T18:42:26.216Z | subchannel_call | [7] receive HTTP/2 data frame of length 526
2024-12-19T18:42:26.216Z root ERROR D 2024-12-19T18:42:26.216Z | subchannel_call | [7] parsed message of length 526
2024-12-19T18:42:26.216Z root ERROR D 2024-12-19T18:42:26.216Z | subchannel_call | [7] pushing to reader message of length 526
2024-12-19T18:42:26.216Z root ERROR D 2024-12-19T18:42:26.216Z | load_balancing_call | [6] Received message
2024-12-19T18:42:26.216Z root ERROR D 2024-12-19T18:42:26.216Z | retrying_call | [5] Received message from child [6]
2024-12-19T18:42:26.216Z root ERROR D 2024-12-19T18:42:26.216Z | resolving_call | [4] Received message
2024-12-19T18:42:26.216Z root ERROR D 2024-12-19T18:42:26.216Z | resolving_call | [4] Finished filtering received message
2024-12-19T18:42:26.216Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\sullimak\AppData\Local\Arduino15\package_index.json: open C:\Users\sullimak\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2024-12-19T18:42:26.217Z root ERROR D 2024-12-19T18:42:26.217Z | subchannel_call | [7] receive HTTP/2 data frame of length 160
2024-12-19T18:42:26.217Z root ERROR D 2024-12-19T18:42:26.217Z | subchannel_call | [7] parsed message of length 160
2024-12-19T18:42:26.217Z root ERROR D 2024-12-19T18:42:26.217Z | subchannel_call | [7] pushing to reader message of length 160
2024-12-19T18:42:26.217Z root ERROR D 2024-12-19T18:42:26.217Z | load_balancing_call | [6] Received message
2024-12-19T18:42:26.217Z root ERROR D 2024-12-19T18:42:26.217Z | retrying_call | [5] Received message from child [6]
2024-12-19T18:42:26.217Z root ERROR D 2024-12-19T18:42:26.217Z | resolving_call | [4] Received message
2024-12-19T18:42:26.217Z root ERROR D 2024-12-19T18:42:26.217Z | resolving_call | [4] Finished filtering received message
2024-12-19T18:42:26.217Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2024-12-19T18:42:26.217Z root ERROR D 2024-12-19T18:42:26.217Z | resolving_call | [4] startRead called
2024-12-19T18:42:26.217Z root ERROR D 2024-12-19T18:42:26.217Z | retrying_call | [5] startRead called
2024-12-19T18:42:26.217Z root ERROR D 2024-12-19T18:42:26.217Z | load_balancing_call | [6] startRead called
2024-12-19T18:42:26.217Z root ERROR D 2024-12-19T18:42:26.217Z | subchannel_call | [7] receive HTTP/2 data frame of length 158
2024-12-19T18:42:26.217Z root ERROR D 2024-12-19T18:42:26.217Z | subchannel_call | [7] parsed message of length 158
2024-12-19T18:42:26.217Z root ERROR D 2024-12-19T18:42:26.217Z | subchannel_call | [7] pushing to reader message of length 158
2024-12-19T18:42:26.217Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2024-12-19T18:42:26.217Z root ERROR D 2024-12-19T18:42:26.217Z | subchannel_call | [7] receive HTTP/2 data frame of length 170
2024-12-19T18:42:26.217Z root ERROR D 2024-12-19T18:42:26.217Z | subchannel_call | [7] parsed message of length 170
2024-12-19T18:42:26.217Z root ERROR D 2024-12-19T18:42:26.217Z | subchannel_call | [7] pushing to reader message of length 170
2024-12-19T18:42:26.217Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\sullimak\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-12-19T18:42:26.217Z daemon INFO time="2024-12-19T13:42:26-05:00" level=info msg="Loading hardware from: C:\\Users\\sullimak\\AppData\\Local\\Arduino15\\packages"
time="2024-12-19T13:42:26-05:00" level=info msg="Loading libraries index file" index="C:\\Users\\sullimak\\AppData\\Local\\Arduino15\\library_index.json"
time="2024-12-19T13:42:26-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\sullimak\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
time="2024-12-19T13:42:26-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\sullimak\\OneDrive - Schaeffler\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.248Z | subchannel_call | [7] Received server trailers:
grpc-status: 0
grpc-message:
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.248Z | subchannel_call | [7] received status code 0 from server
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.248Z | subchannel_call | [7] received status details string "" from server
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.248Z | subchannel_call | [7] close http2 stream with code 0
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.248Z | subchannel_call | [7] ended with status: code=0 details=""
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.248Z | load_balancing_call | [6] Received status
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.248Z | load_balancing_call | [6] ended with status: code=0 details=""
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.248Z | retrying_call | [5] Received status from child [6]
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.248Z | retrying_call | [5] state=COMMITTED handling status with progress PROCESSED from child [6] in state ACTIVE
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.248Z | retrying_call | [5] ended with status: code=0 details=""
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.248Z | resolving_call | [4] Received status
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.248Z | resolving_call | [4] ended with status: code=0 details=""
2024-12-19T18:42:26.251Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Loading index file: loading json index file C:\Users\sullimak\AppData\Local\Arduino15\package_index.json: open C:\Users\sullimak\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
[library-index] - code: 9, message: Loading index file: reading library_index.json: open C:\Users\sullimak\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.250Z | channel | (1) dns:localhost:58196 createResolvingCall [8] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/UpdateIndex", deadline=Infinity
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.250Z | resolving_call | [8] Created
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.250Z | resolving_call | [8] Deadline: Infinity
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.250Z | resolving_call | [8] start called
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.250Z | resolving_call | [8] write() called with message of length 4
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.250Z | resolving_call | [8] halfClose called
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.250Z | channel | (1) dns:localhost:58196 createResolvingCall [9] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/UpdateLibrariesIndex", deadline=Infinity
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.250Z | resolving_call | [9] Created
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.250Z | resolving_call | [9] Deadline: Infinity
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.250Z | resolving_call | [9] start called
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.250Z | resolving_call | [9] write() called with message of length 4
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.250Z | resolving_call | [9] halfClose called
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.251Z | channel | (1) dns:localhost:58196 createRetryingCall [10] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/UpdateIndex"
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.251Z | resolving_call | [8] Created child [10]
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.251Z | retrying_call | [10] start called
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.251Z | channel | (1) dns:localhost:58196 createLoadBalancingCall [11] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/UpdateIndex"
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.251Z | retrying_call | [10] Created child call [11] for attempt 1
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.251Z | load_balancing_call | [11] start called
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.251Z | load_balancing_call | [11] Pick called
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.251Z | load_balancing_call | [11] Pick result: COMPLETE subchannel: (3) 127.0.0.1:58196 status: undefined undefined
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.251Z | channel | (1) dns:localhost:58196 createRetryingCall [12] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/UpdateLibrariesIndex"
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.251Z | resolving_call | [9] Created child [12]
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.251Z | retrying_call | [12] start called
2024-12-19T18:42:26.251Z root ERROR D 2024-12-19T18:42:26.251Z | channel | (1) dns:localhost:58196 createLoadBalancingCall [13] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/UpdateLibrariesIndex"
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.251Z | retrying_call | [12] Created child call [13] for attempt 1
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.251Z | load_balancing_call | [13] start called
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.251Z | load_balancing_call | [13] Pick called
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.251Z | load_balancing_call | [13] Pick result: COMPLETE subchannel: (3) 127.0.0.1:58196 status: undefined undefined
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.251Z | transport_flowctrl | (4) 127.0.0.1:58196 local window size: 63565 remote window size: 65535
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.251Z | transport_internals | (4) 127.0.0.1:58196 session.closed=false session.destroyed=false session.socket.destroyed=false
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.251Z | load_balancing_call | [11] Created child call [14]
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.251Z | load_balancing_call | [13] Created child call [15]
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.251Z | retrying_call | [10] write() called with message of length 9
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.251Z | load_balancing_call | [11] write() called with message of length 9
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.251Z | subchannel_call | [14] write() called with message of length 9
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.251Z | subchannel_call | [14] sending data chunk of length 9
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.251Z | retrying_call | [10] halfClose called
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.251Z | retrying_call | [12] write() called with message of length 9
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.251Z | load_balancing_call | [13] write() called with message of length 9
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.251Z | subchannel_call | [15] write() called with message of length 9
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.251Z | subchannel_call | [15] sending data chunk of length 9
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.251Z | retrying_call | [12] halfClose called
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.252Z | resolving_call | [8] startRead called
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.252Z | retrying_call | [10] startRead called
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.252Z | load_balancing_call | [11] startRead called
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.252Z | resolving_call | [9] startRead called
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.252Z | retrying_call | [12] startRead called
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.252Z | load_balancing_call | [13] startRead called
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.252Z | subchannel_call | [7] HTTP/2 stream closed with code 0
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.252Z | load_balancing_call | [11] halfClose called
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.252Z | subchannel_call | [14] end() called
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.252Z | subchannel_call | [14] calling end() on HTTP/2 stream
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.252Z | load_balancing_call | [13] halfClose called
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.252Z | subchannel_call | [15] end() called
2024-12-19T18:42:26.252Z root ERROR D 2024-12-19T18:42:26.252Z | subchannel_call | [15] calling end() on HTTP/2 stream
2024-12-19T18:42:26.252Z daemon INFO time="2024-12-19T13:42:26-05:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-12-19T18:42:26.253Z daemon INFO time="2024-12-19T13:42:26-05:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-12-19T18:42:26.253Z daemon INFO time="2024-12-19T13:42:26-05:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-12-19T18:42:26.253Z root ERROR D 2024-12-19T18:42:26.253Z | subchannel_call | [15] Received server headers:
:status: 200
2024-12-19T18:42:26.253Z root ERROR D 2024-12-19T18:42:26.253Z | load_balancing_call | [13] Received metadata
2024-12-19T18:42:26.253Z root ERROR D 2024-12-19T18:42:26.253Z | retrying_call | [12] Received metadata from child [13]
2024-12-19T18:42:26.253Z root ERROR D 2024-12-19T18:42:26.253Z | retrying_call | [12] Committing call [13] at index 0
2024-12-19T18:42:26.253Z root ERROR D 2024-12-19T18:42:26.253Z | resolving_call | [9] Received metadata
2024-12-19T18:42:26.254Z root ERROR D 2024-12-19T18:42:26.253Z | subchannel_call | [15] receive HTTP/2 data frame of length 113
2024-12-19T18:42:26.254Z root ERROR D 2024-12-19T18:42:26.253Z | subchannel_call | [15] parsed message of length 113
2024-12-19T18:42:26.254Z root ERROR D 2024-12-19T18:42:26.253Z | subchannel_call | [15] pushing to reader message of length 113
2024-12-19T18:42:26.254Z root ERROR D 2024-12-19T18:42:26.253Z | load_balancing_call | [13] Received message
2024-12-19T18:42:26.254Z root ERROR D 2024-12-19T18:42:26.253Z | retrying_call | [12] Received message from child [13]
2024-12-19T18:42:26.254Z root ERROR D 2024-12-19T18:42:26.253Z | resolving_call | [9] Received message
2024-12-19T18:42:26.254Z root ERROR D 2024-12-19T18:42:26.253Z | resolving_call | [9] Finished filtering received message
2024-12-19T18:42:26.254Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2024-12-19T18:42:26.254Z root ERROR D 2024-12-19T18:42:26.254Z | resolving_call | [9] startRead called
2024-12-19T18:42:26.254Z root ERROR D 2024-12-19T18:42:26.254Z | retrying_call | [12] startRead called
2024-12-19T18:42:26.254Z root ERROR D 2024-12-19T18:42:26.254Z | load_balancing_call | [13] startRead called
2024-12-19T18:42:26.254Z root ERROR D 2024-12-19T18:42:26.254Z | subchannel_call | [14] Received server headers:
:status: 200
2024-12-19T18:42:26.254Z root ERROR D 2024-12-19T18:42:26.254Z | load_balancing_call | [11] Received metadata
2024-12-19T18:42:26.254Z root ERROR D 2024-12-19T18:42:26.254Z | retrying_call | [10] Received metadata from child [11]
2024-12-19T18:42:26.254Z root ERROR D 2024-12-19T18:42:26.254Z | retrying_call | [10] Committing call [11] at index 0
2024-12-19T18:42:26.254Z root ERROR D 2024-12-19T18:42:26.254Z | resolving_call | [8] Received metadata
2024-12-19T18:42:26.254Z root ERROR D 2024-12-19T18:42:26.254Z | subchannel_call | [14] receive HTTP/2 data frame of length 112
2024-12-19T18:42:26.254Z root ERROR D 2024-12-19T18:42:26.254Z | subchannel_call | [14] parsed message of length 112
2024-12-19T18:42:26.254Z root ERROR D 2024-12-19T18:42:26.254Z | subchannel_call | [14] pushing to reader message of length 112
2024-12-19T18:42:26.254Z root ERROR D 2024-12-19T18:42:26.254Z | load_balancing_call | [11] Received message
2024-12-19T18:42:26.254Z root ERROR D 2024-12-19T18:42:26.254Z | retrying_call | [10] Received message from child [11]
2024-12-19T18:42:26.254Z root ERROR D 2024-12-19T18:42:26.254Z | resolving_call | [8] Received message
2024-12-19T18:42:26.254Z root ERROR D 2024-12-19T18:42:26.254Z | resolving_call | [8] Finished filtering received message
2024-12-19T18:42:26.254Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2024-12-19T18:42:26.255Z root ERROR D 2024-12-19T18:42:26.254Z | resolving_call | [8] startRead called
2024-12-19T18:42:26.255Z root ERROR D 2024-12-19T18:42:26.254Z | retrying_call | [10] startRead called
2024-12-19T18:42:26.255Z root ERROR D 2024-12-19T18:42:26.254Z | load_balancing_call | [11] startRead called
2024-12-19T18:42:30.562Z root ERROR D 2024-12-19T18:42:30.562Z | subchannel_refcount | (2) ::1:58196 refcount 1 -> 0
2024-12-19T18:42:31.722Z root ERROR D 2024-12-19T18:42:31.721Z | subchannel_call | [15] receive HTTP/2 data frame of length 195
2024-12-19T18:42:31.722Z root ERROR D 2024-12-19T18:42:31.721Z | subchannel_call | [15] parsed message of length 195
2024-12-19T18:42:31.722Z root ERROR D 2024-12-19T18:42:31.721Z | subchannel_call | [15] pushing to reader message of length 195
2024-12-19T18:42:31.722Z root ERROR D 2024-12-19T18:42:31.721Z | load_balancing_call | [13] Received message
2024-12-19T18:42:31.722Z root ERROR D 2024-12-19T18:42:31.721Z | retrying_call | [12] Received message from child [13]
2024-12-19T18:42:31.722Z root ERROR D 2024-12-19T18:42:31.721Z | resolving_call | [9] Received message
2024-12-19T18:42:31.722Z root ERROR D 2024-12-19T18:42:31.721Z | resolving_call | [9] Finished filtering received message
2024-12-19T18:42:31.722Z root ERROR D 2024-12-19T18:42:31.722Z | resolving_call | [9] startRead called
2024-12-19T18:42:31.722Z root ERROR D 2024-12-19T18:42:31.722Z | retrying_call | [12] startRead called
2024-12-19T18:42:31.722Z root ERROR D 2024-12-19T18:42:31.722Z | load_balancing_call | [13] startRead called
2024-12-19T18:42:31.723Z root ERROR D 2024-12-19T18:42:31.722Z | subchannel_call | [15] receive HTTP/2 data frame of length 73
2024-12-19T18:42:31.723Z root ERROR D 2024-12-19T18:42:31.722Z | subchannel_call | [15] parsed message of length 73
2024-12-19T18:42:31.723Z root ERROR D 2024-12-19T18:42:31.722Z | subchannel_call | [15] pushing to reader message of length 73
2024-12-19T18:42:31.723Z root ERROR D 2024-12-19T18:42:31.722Z | load_balancing_call | [13] Received message
2024-12-19T18:42:31.723Z root ERROR D 2024-12-19T18:42:31.722Z | retrying_call | [12] Received message from child [13]
2024-12-19T18:42:31.723Z root ERROR D 2024-12-19T18:42:31.722Z | resolving_call | [9] Received message
2024-12-19T18:42:31.723Z root ERROR D 2024-12-19T18:42:31.722Z | resolving_call | [9] Finished filtering received message
2024-12-19T18:42:31.723Z root ERROR D 2024-12-19T18:42:31.723Z | resolving_call | [9] startRead called
2024-12-19T18:42:31.723Z root ERROR D 2024-12-19T18:42:31.723Z | retrying_call | [12] startRead called
2024-12-19T18:42:31.723Z root ERROR D 2024-12-19T18:42:31.723Z | load_balancing_call | [13] startRead called
2024-12-19T18:42:31.724Z root ERROR D 2024-12-19T18:42:31.723Z | subchannel_call | [15] Received server trailers:
grpc-status: 13
grpc-message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp 104.18.10.21:443: connectex: No connection could be made because the target machine actively refused it.
2024-12-19T18:42:31.724Z root ERROR D 2024-12-19T18:42:31.723Z | subchannel_call | [15] received status code 13 from server
2024-12-19T18:42:31.724Z root ERROR D 2024-12-19T18:42:31.723Z | subchannel_call | [15] received status details string "Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp 104.18.10.21:443: connectex: No connection could be made because the target machine actively refused it." from server
2024-12-19T18:42:31.724Z root ERROR D 2024-12-19T18:42:31.723Z | subchannel_call | [15] ended with status: code=13 details="Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp 104.18.10.21:443: connectex: No connection could be made because the target machine actively refused it."
2024-12-19T18:42:31.724Z root ERROR D 2024-12-19T18:42:31.723Z | subchannel_call | [15] close http2 stream with code 8
2024-12-19T18:42:31.724Z root ERROR D 2024-12-19T18:42:31.723Z | load_balancing_call | [13] Received status
2024-12-19T18:42:31.724Z root ERROR D 2024-12-19T18:42:31.723Z | load_balancing_call | [13] ended with status: code=13 details="Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp 104.18.10.21:443: connectex: No connection could be made because the target machine actively refused it."
2024-12-19T18:42:31.724Z root ERROR D 2024-12-19T18:42:31.723Z | retrying_call | [12] Received status from child [13]
2024-12-19T18:42:31.724Z root ERROR D 2024-12-19T18:42:31.723Z | retrying_call | [12] state=COMMITTED handling status with progress PROCESSED from child [13] in state ACTIVE
2024-12-19T18:42:31.724Z root ERROR D 2024-12-19T18:42:31.723Z | retrying_call | [12] ended with status: code=13 details="Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp 104.18.10.21:443: connectex: No connection could be made because the target machine actively refused it."
2024-12-19T18:42:31.724Z root ERROR D 2024-12-19T18:42:31.723Z | resolving_call | [9] Received status
2024-12-19T18:42:31.724Z root ERROR D 2024-12-19T18:42:31.723Z | resolving_call | [9] ended with status: code=13 details="Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp 104.18.10.21:443: connectex: No connection could be made because the target machine actively refused it."
2024-12-19T18:42:31.725Z root ERROR Failed to update platform, library indexes. Error: 13 INTERNAL: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp 104.18.10.21:443: connectex: No connection could be made because the target machine actively refused it.
at t.callErrorFromStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:921712)
at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:949334)
at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:942356)
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1028497
at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
at s.makeServerStreamRequest (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:949101)
at s.updateLibrariesIndex (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1013389)
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:778557
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:778750
at new Promise (<anonymous>)
at v.doUpdateIndex (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:778729)
at v.updateLibraryIndex (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:778529)
at v.updateIndex (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:777803)
at v.initInstanceWithFallback (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:776035)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.724Z | channel | (1) dns:localhost:58196 createResolvingCall [16] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Init", deadline=Infinity
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.724Z | resolving_call | [16] Created
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.724Z | resolving_call | [16] Deadline: Infinity
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.724Z | resolving_call | [16] start called
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.724Z | resolving_call | [16] write() called with message of length 4
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.724Z | resolving_call | [16] halfClose called
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.724Z | channel | (1) dns:localhost:58196 createRetryingCall [17] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Init"
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.724Z | resolving_call | [16] Created child [17]
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.724Z | retrying_call | [17] start called
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.724Z | channel | (1) dns:localhost:58196 createLoadBalancingCall [18] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Init"
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.724Z | retrying_call | [17] Created child call [18] for attempt 1
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.724Z | load_balancing_call | [18] start called
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.724Z | load_balancing_call | [18] Pick called
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.724Z | load_balancing_call | [18] Pick result: COMPLETE subchannel: (3) 127.0.0.1:58196 status: undefined undefined
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.724Z | transport_flowctrl | (4) 127.0.0.1:58196 local window size: 63072 remote window size: 65526
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.724Z | transport_internals | (4) 127.0.0.1:58196 session.closed=false session.destroyed=false session.socket.destroyed=false
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.725Z | load_balancing_call | [18] Created child call [19]
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.725Z | retrying_call | [17] write() called with message of length 9
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.725Z | load_balancing_call | [18] write() called with message of length 9
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.725Z | subchannel_call | [19] write() called with message of length 9
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.725Z | subchannel_call | [19] sending data chunk of length 9
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.725Z | retrying_call | [17] halfClose called
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.725Z | resolving_call | [16] startRead called
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.725Z | retrying_call | [17] startRead called
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.725Z | load_balancing_call | [18] startRead called
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.725Z | subchannel_call | [15] HTTP/2 stream closed with code 8
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.725Z | load_balancing_call | [18] halfClose called
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.725Z | subchannel_call | [19] end() called
2024-12-19T18:42:31.725Z root ERROR D 2024-12-19T18:42:31.725Z | subchannel_call | [19] calling end() on HTTP/2 stream
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.725Z | subchannel_call | [14] receive HTTP/2 data frame of length 194
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.725Z | subchannel_call | [14] parsed message of length 194
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.725Z | subchannel_call | [14] pushing to reader message of length 194
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.725Z | load_balancing_call | [11] Received message
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.725Z | retrying_call | [10] Received message from child [11]
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.725Z | resolving_call | [8] Received message
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.725Z | resolving_call | [8] Finished filtering received message
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.726Z | resolving_call | [8] startRead called
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.726Z | retrying_call | [10] startRead called
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.726Z | load_balancing_call | [11] startRead called
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.726Z | subchannel_call | [14] receive HTTP/2 data frame of length 72
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.726Z | subchannel_call | [14] parsed message of length 72
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.726Z | subchannel_call | [14] pushing to reader message of length 72
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.726Z | load_balancing_call | [11] Received message
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.726Z | retrying_call | [10] Received message from child [11]
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.726Z | resolving_call | [8] Received message
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.726Z | resolving_call | [8] Finished filtering received message
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.726Z | subchannel_call | [14] Received server trailers:
grpc-status: 13
grpc-message: Some indexes could not be updated.
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.726Z | subchannel_call | [14] received status code 13 from server
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.726Z | subchannel_call | [14] received status details string "Some indexes could not be updated." from server
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.726Z | subchannel_call | [14] ended with status: code=13 details="Some indexes could not be updated."
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.726Z | subchannel_call | [14] close http2 stream with code 8
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.726Z | load_balancing_call | [11] Received status
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.726Z | load_balancing_call | [11] ended with status: code=13 details="Some indexes could not be updated."
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.726Z | retrying_call | [10] Received status from child [11]
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.726Z | retrying_call | [10] state=COMMITTED handling status with progress PROCESSED from child [11] in state ACTIVE
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.726Z | retrying_call | [10] ended with status: code=13 details="Some indexes could not be updated."
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.726Z | resolving_call | [8] Received status
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.726Z | resolving_call | [8] ended with status: code=13 details="Some indexes could not be updated."
2024-12-19T18:42:31.726Z root ERROR D 2024-12-19T18:42:31.726Z | subchannel_call | [14] HTTP/2 stream closed with code 8
2024-12-19T18:42:31.727Z root ERROR D 2024-12-19T18:42:31.727Z | subchannel_call | [19] Received server headers:
:status: 200
2024-12-19T18:42:31.727Z root ERROR D 2024-12-19T18:42:31.727Z | load_balancing_call | [18] Received metadata
2024-12-19T18:42:31.727Z root ERROR D 2024-12-19T18:42:31.727Z | retrying_call | [17] Received metadata from child [18]
2024-12-19T18:42:31.727Z root ERROR D 2024-12-19T18:42:31.727Z | retrying_call | [17] Committing call [18] at index 0
2024-12-19T18:42:31.727Z root ERROR D 2024-12-19T18:42:31.727Z | resolving_call | [16] Received metadata
2024-12-19T18:42:31.727Z root ERROR D 2024-12-19T18:42:31.727Z | subchannel_call | [19] receive HTTP/2 data frame of length 115
2024-12-19T18:42:31.727Z root ERROR D 2024-12-19T18:42:31.727Z | subchannel_call | [19] parsed message of length 115
2024-12-19T18:42:31.727Z root ERROR D 2024-12-19T18:42:31.727Z | subchannel_call | [19] pushing to reader message of length 115
2024-12-19T18:42:31.727Z root ERROR D 2024-12-19T18:42:31.727Z | load_balancing_call | [18] Received message
2024-12-19T18:42:31.727Z root ERROR D 2024-12-19T18:42:31.727Z | retrying_call | [17] Received message from child [18]
2024-12-19T18:42:31.727Z root ERROR D 2024-12-19T18:42:31.727Z | resolving_call | [16] Received message
2024-12-19T18:42:31.727Z root ERROR D 2024-12-19T18:42:31.727Z | resolving_call | [16] Finished filtering received message
2024-12-19T18:42:31.727Z root ERROR D 2024-12-19T18:42:31.727Z | resolving_call | [16] startRead called
2024-12-19T18:42:31.727Z root ERROR D 2024-12-19T18:42:31.727Z | retrying_call | [17] startRead called
2024-12-19T18:42:31.727Z root ERROR D 2024-12-19T18:42:31.727Z | load_balancing_call | [18] startRead called
2024-12-19T18:42:31.727Z daemon INFO time="2024-12-19T13:42:31-05:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-12-19T18:42:37.056Z root ERROR D 2024-12-19T18:42:37.055Z | subchannel_call | [19] receive HTTP/2 data frame of length 198
2024-12-19T18:42:37.056Z root ERROR D 2024-12-19T18:42:37.055Z | subchannel_call | [19] parsed message of length 198
2024-12-19T18:42:37.056Z root ERROR D 2024-12-19T18:42:37.055Z | subchannel_call | [19] pushing to reader message of length 198
2024-12-19T18:42:37.056Z root ERROR D 2024-12-19T18:42:37.056Z | load_balancing_call | [18] Received message
2024-12-19T18:42:37.056Z root ERROR D 2024-12-19T18:42:37.056Z | retrying_call | [17] Received message from child [18]
2024-12-19T18:42:37.056Z root ERROR D 2024-12-19T18:42:37.056Z | resolving_call | [16] Received message
2024-12-19T18:42:37.056Z root ERROR D 2024-12-19T18:42:37.056Z | resolving_call | [16] Finished filtering received message
2024-12-19T18:42:37.056Z root ERROR D 2024-12-19T18:42:37.056Z | resolving_call | [16] startRead called
2024-12-19T18:42:37.056Z root ERROR D 2024-12-19T18:42:37.056Z | retrying_call | [17] startRead called
2024-12-19T18:42:37.056Z root ERROR D 2024-12-19T18:42:37.056Z | load_balancing_call | [18] startRead called
2024-12-19T18:42:37.056Z root ERROR D 2024-12-19T18:42:37.056Z | subchannel_call | [19] receive HTTP/2 data frame of length 634
2024-12-19T18:42:37.056Z root ERROR D 2024-12-19T18:42:37.056Z | subchannel_call | [19] parsed message of length 634
2024-12-19T18:42:37.056Z root ERROR D 2024-12-19T18:42:37.056Z | subchannel_call | [19] pushing to reader message of length 634
2024-12-19T18:42:37.057Z root ERROR D 2024-12-19T18:42:37.056Z | resolving_call | [16] Finished filtering received message
2024-12-19T18:42:37.057Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp 104.18.10.21:443: connectex: No connection could be made because the target machine actively refused it.
2024-12-19T18:42:37.057Z root ERROR D 2024-12-19T18:42:37.057Z | resolving_call | [16] startRead called
2024-12-19T18:42:37.057Z root ERROR D 2024-12-19T18:42:37.057Z | retrying_call | [17] startRead called
2024-12-19T18:42:37.057Z root ERROR D 2024-12-19T18:42:37.057Z | load_balancing_call | [18] startRead called
2024-12-19T18:42:37.057Z root ERROR D 2024-12-19T18:42:37.057Z | subchannel_call | [19] receive HTTP/2 data frame of length 526
2024-12-19T18:42:37.057Z root ERROR D 2024-12-19T18:42:37.057Z | subchannel_call | [19] parsed message of length 526
2024-12-19T18:42:37.057Z root ERROR D 2024-12-19T18:42:37.057Z | subchannel_call | [19] pushing to reader message of length 526
2024-12-19T18:42:37.057Z root ERROR D 2024-12-19T18:42:37.057Z | load_balancing_call | [18] Received message
2024-12-19T18:42:37.057Z root ERROR D 2024-12-19T18:42:37.057Z | retrying_call | [17] Received message from child [18]
2024-12-19T18:42:37.057Z root ERROR D 2024-12-19T18:42:37.057Z | resolving_call | [16] Received message
2024-12-19T18:42:37.057Z root ERROR D 2024-12-19T18:42:37.057Z | resolving_call | [16] Finished filtering received message
2024-12-19T18:42:37.057Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\sullimak\AppData\Local\Arduino15\package_index.json: open C:\Users\sullimak\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2024-12-19T18:42:37.057Z root ERROR D 2024-12-19T18:42:37.057Z | subchannel_call | [19] receive HTTP/2 data frame of length 160
2024-12-19T18:42:37.057Z root ERROR D 2024-12-19T18:42:37.057Z | subchannel_call | [19] parsed message of length 160
2024-12-19T18:42:37.057Z root ERROR D 2024-12-19T18:42:37.057Z | subchannel_call | [19] pushing to reader message of length 160
2024-12-19T18:42:37.058Z root ERROR D 2024-12-19T18:42:37.057Z | resolving_call | [16] Finished filtering received message
2024-12-19T18:42:37.058Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2024-12-19T18:42:37.058Z root ERROR D 2024-12-19T18:42:37.058Z | resolving_call | [16] startRead called
2024-12-19T18:42:37.058Z root ERROR D 2024-12-19T18:42:37.058Z | retrying_call | [17] startRead called
2024-12-19T18:42:37.058Z root ERROR D 2024-12-19T18:42:37.058Z | load_balancing_call | [18] startRead called
2024-12-19T18:42:37.058Z root ERROR D 2024-12-19T18:42:37.058Z | subchannel_call | [19] receive HTTP/2 data frame of length 158
2024-12-19T18:42:37.058Z root ERROR D 2024-12-19T18:42:37.058Z | subchannel_call | [19] parsed message of length 158
2024-12-19T18:42:37.058Z root ERROR D 2024-12-19T18:42:37.058Z | subchannel_call | [19] pushing to reader message of length 158
2024-12-19T18:42:37.058Z root ERROR D 2024-12-19T18:42:37.058Z | load_balancing_call | [18] Received message
2024-12-19T18:42:37.058Z root ERROR D 2024-12-19T18:42:37.058Z | retrying_call | [17] Received message from child [18]
2024-12-19T18:42:37.058Z root ERROR D 2024-12-19T18:42:37.058Z | resolving_call | [16] Received message
2024-12-19T18:42:37.058Z root ERROR D 2024-12-19T18:42:37.058Z | resolving_call | [16] Finished filtering received message
2024-12-19T18:42:37.058Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2024-12-19T18:42:37.058Z root ERROR D 2024-12-19T18:42:37.058Z | subchannel_call | [19] receive HTTP/2 data frame of length 170
2024-12-19T18:42:37.058Z root ERROR D 2024-12-19T18:42:37.058Z | subchannel_call | [19] parsed message of length 170
2024-12-19T18:42:37.058Z root ERROR D 2024-12-19T18:42:37.058Z | subchannel_call | [19] pushing to reader message of length 170
2024-12-19T18:42:37.058Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\sullimak\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-12-19T18:42:37.058Z daemon INFO time="2024-12-19T13:42:37-05:00" level=info msg="Loading hardware from: C:\\Users\\sullimak\\AppData\\Local\\Arduino15\\packages"
time="2024-12-19T13:42:37-05:00" level=info msg="Loading libraries index file" index="C:\\Users\\sullimak\\AppData\\Local\\Arduino15\\library_index.json"
time="2024-12-19T13:42:37-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\sullimak\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
time="2024-12-19T13:42:37-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\sullimak\\OneDrive - Schaeffler\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2024-12-19T18:42:37.091Z root ERROR D 2024-12-19T18:42:37.091Z | subchannel_call | [19] Received server trailers:
grpc-status: 0
grpc-message:
2024-12-19T18:42:37.091Z root ERROR D 2024-12-19T18:42:37.091Z | subchannel_call | [19] received status code 0 from server
2024-12-19T18:42:37.091Z root ERROR D 2024-12-19T18:42:37.091Z | subchannel_call | [19] received status details string "" from server
2024-12-19T18:42:37.091Z root ERROR D 2024-12-19T18:42:37.091Z | subchannel_call | [19] close http2 stream with code 0
2024-12-19T18:42:37.091Z root ERROR D 2024-12-19T18:42:37.091Z | subchannel_call | [19] ended with status: code=0 details=""
2024-12-19T18:42:37.091Z root ERROR D 2024-12-19T18:42:37.091Z | load_balancing_call | [18] Received status
2024-12-19T18:42:37.092Z root ERROR D 2024-12-19T18:42:37.091Z | load_balancing_call | [18] ended with status: code=0 details=""
2024-12-19T18:42:37.092Z root ERROR D 2024-12-19T18:42:37.091Z | retrying_call | [17] Received status from child [18]
2024-12-19T18:42:37.092Z root ERROR D 2024-12-19T18:42:37.091Z | retrying_call | [17] state=COMMITTED handling status with progress PROCESSED from child [18] in state ACTIVE
2024-12-19T18:42:37.092Z root ERROR D 2024-12-19T18:42:37.091Z | retrying_call | [17] ended with status: code=0 details=""
2024-12-19T18:42:37.092Z root ERROR D 2024-12-19T18:42:37.091Z | resolving_call | [16] Received status
2024-12-19T18:42:37.092Z root ERROR D 2024-12-19T18:42:37.091Z | resolving_call | [16] ended with status: code=0 details=""
2024-12-19T18:42:37.092Z root ERROR Uncaught Exception: Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-12-19T18:42:37.092Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:777546
at v.evaluateErrorStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:777562)
at async a.<anonymous> (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:777232)
2024-12-19T18:42:37.092Z root ERROR D 2024-12-19T18:42:37.092Z | subchannel_call | [19] HTTP/2 stream closed with code 0
Closing channel on service path '/services/electron-window'.
Closing channel on service path '/services/ide-updater'.
Stored workspaces roots:
No sketches were scheduled for deletion.
[18160:1219/135526.363:ERROR:command_buffer_proxy_impl.cc(319)] GPU state invalid after WaitForGetOffsetInRange.
Hi, the IDE starts then stalls. Please see the above.
Thanks for the help.
