Hello!
I’m trying to use Arduino Nano 33 BLE with a screen to create something to an aircraft Attitude Indicator and Directional Gyro. For that purpose I would need to have precise Euler angles. I found out that Nano comes with 9DOF sensor and I attempted the use the Madgwick library to transform the sensor data into useful angles.
However, it looks like drifting along the yaw axis is happening, and also when moving the board along pitch and yaw axis it takes the filter a long while to catch up, sometimes even a few seconds to arrive at the result.
Another solution would be to attempt to use Adafruit BNO055 that claims to provide the Euler angles directly. However, I think a more elegant solution would be to adjust my code to make it work with the sensor that is already provided on the Nano.
Ideas? thanks
//#include "Arduino_LSM6DS3.h"
#include "MadgwickAHRS.h"
#include "Arduino_LSM9DS1.h"
// initialize a Madgwick filter:
Madgwick filter;
// sensor's sample rate is fixed at 104 Hz:
const float sensorRate = 104.00;
float sax, say, saz, sgx, sgy, sgz;
// attempt to start the IMU:
if (!IMU.begin()) {
Serial.println("Failed to initialize IMU");
// stop here if you can't access the IMU:
while (true);
// start the filter to run at the sample rate:
filter.begin(sensorRate);
long lastPrint = 0;
long nz = 0;
float x = 0, y = 0, z = 0;
// values for acceleration and rotation:
float xAcc, yAcc, zAcc;
float xGyro, yGyro, zGyro;
// values for orientation:
float roll, pitch, heading;
// check if the IMU is ready to read:
if (IMU.accelerationAvailable() &&
IMU.gyroscopeAvailable()) {
// read accelerometer &and gyrometer:
IMU.readAcceleration(xAcc, yAcc, zAcc);
IMU.readGyroscope(xGyro, yGyro, zGyro);
nz++;
if (nz < 500) //hold the board still until nz is 500 for calibration
sgz += zGyro;
sgx += xGyro;
sgy += yGyro;
x = sgx / nz;
y = sgy / nz;
z = sgz / nz;
// update the filter, which computes orientation:
filter.updateIMU(xGyro - x, yGyro - y, zGyro - z, xAcc, yAcc, zAcc);
// print the heading, pitch and roll
roll = filter.getRoll();
pitch = filter.getPitch();
heading = filter.getYaw();
long a = millis();
if (lastPrint + 333 < millis())
lastPrint = a;
Serial.print(nz);
Serial.print(" Acc ");
Serial.print(xAcc);
Serial.print(" ");
Serial.print(yAcc);
Serial.print(" ");
Serial.print(zAcc);
Serial.print(" ");
Serial.print("Gyr ");
Serial.print(xGyro);
Serial.print(" ");
Serial.print(yGyro);
Serial.print(" ");
Serial.print(zGyro);
Serial.print(" avg ");
Serial.print(" ~~Orientation: ");
Serial.print(heading);
Serial.print(" ");
Serial.print(pitch);
Serial.print(" ");
Serial.println(roll);
