just tell me how can i turn a arduino into an guitar interface for guitar with a resolution of more than 16bit . schematics will be a great help
What's the budget?
zwieblum:
What's the budget?
well that can be flexible . im trying to make this to learn more about arduino ,so dont really mind if i have to pay more than 50$ with which i can easily buy a prebuild audio interface
Well, then buy an interface, disassemble it, try to paint the schematics and the identify the components. Then rebuild it. If you have too little knowledge, learn.
zwieblum:
no , i want to use as arduino .what im really trying to learn is about arduino in a practical application , and guitar interface is because its an old project . i used to make guitar apms and pedals . so thought as a next step i would try to covert the analog signals into digital using an arduino
Maybe it would be a good startingpoint to actually describw what you want to, if you have done any research on your own and what it is that you have problems with. If you want a "gimme all", then be prepared to be asked for a bunch more bucks than you want to spend.
zwieblum:
ouch
aah..the amplication part of guitar input is done . now i need an ADC to turn the input signal into 16bit digital output . i cant use the arduino direct as an adc because it has a low resolution . so was thinking if i could use some thing like ADS1115 ADC 16 BIT ADC to covert input signal to digital and send that to arduino digital input and somehow code the arduino in such a way that when i will connect it to pc it will show as an audio usb interface .
what else?..umm i have tiny bit of coding knowledge as i have to learn C and html in my college but apart from that youtube and forum like these are my best friend
That, I think, is where it all falls apart. The Arduino’s USB interface looks only like a serial port to the PC.
Other types of Arduino, like the Micro, can look like a HID MIDI interface, but I don’t know of any type of Arduino that is fast enough to look like an audio USB device, and if there is I don’t know if anyone has written a driver for this.
It is a very advanced project.
There are specialized chips for this. [u]Here's[/u] the 1st one I found.
"USB soundcards" use these kind of specialized chips and that's why you can buy a complete USB soundcard for less than $5 USD, or you can get a Behringer USB-guitar interface for about $30. These things don't have a programmable microcontroller.
You can get microcontroller chips with a "real" USB interface but writing your own firmware to work with the standard Windows or Mac USB audio drivers is "advanced programming". Writing your own firmware and a custom driver is even more advanced.
If you want to do digital signal processing you can also get [u]spealized DSP chips[/u]. But again this is advanced programming, some of these chips can be expensive, and you might have to buy a development kit for a few hundred dollars.
I assume most digital guitar "stomp boxes" use DSP chips. I'm pretty-sure most inexpensive effect boxes are analog, or maybe they use some very-simple digital processing (perhaps without a microprocessor).
P.S.
It's not practical or economical to build something like [u]this[/u]. They have a team of electronic, mechanical, and software engineers and automated production equipment. The fixed-costs are high but the variable (per-unit) costs are low. They buy the components in bulk, the custom parts are manufactured in bulk, and assembly is done with very-little per-unit labor, and it's low-cost labor.
For the same reasons it's not worth repairing a unit like that. Diagnosis & repair typically requires an hour (or more) of expensive-skilled labor, and if the repair is not done at the factory the replacement parts have to be purchased & shipped in small quantities.
DVDdoug:
There are specialized chips for this. [u]Here's[/u] the 1st one I found."USB soundcards" use these kind of specialized chips and that's why you can buy a complete USB soundcard for less than $5 USD, or you can get a Behringer USB-guitar interface for about $30. These things don't have a programmable microcontroller.
P.S.
It's not practical or economical to build something like [u]this[/u]. They have a team of electronic, mechanical, and software engineers and automated production equipment. The fixed-costs are high but the variable (per-unit) costs are low. They buy the components in bulk, the custom parts are manufactured in bulk, and assembly is done with very-little per-unit labor, and it's low-cost labor.For the same reasons it's not worth repairing a unit like that. Diagnosis & repair typically requires an hour (or more) of expensive-skilled labor, and if the repair is not done at the factory the replacement parts have to be purchased & shipped in small quantities.
thank you very much sir . it was a great help . now i know where to look to
There is always the Teensy with an Audio interface shield not the cheapest of solutions but you will the advantage of being able to interfere with the audio. I think the 3.6 supports Audio over USB but it's 16bit 44.1khz.
Bovski:
Post from last August, don't do this. Plus OP said:-
So still in need of external hardware what ever processor you use.
Thanks for the price information.. It's really helpful
As mentioned above, the Teensy Audio library for 3.X devices are USB audio class compliant. The Teensy 4.0 is not yet class compliant.
I have a Teensy guitar audio shield that does all the complex preamp, gain control and low-noise analog power generation for a high quality guitar DSP processor. It allows you to start playing with and designing your own effects on day one instead of messing around with a lot of analog design, soldering and noisy DIY circuits.
You can get more info including schematics on Tindie.
