My Leonardo is a non-official compatible one, when I try to upload my programme, IDE suggested "uploading" for a long long time, and report errors as below:
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
Found programmer: Id = "�"; type = �
Software Version = i.
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: error: programmer did not respond to command: leave prog mode
avrdude: error: programmer did not respond to command: exit bootloader
Failed uploading: uploading error: exit status
These errors suggests any hardware failure with my board&USB cable or software errors like drivers?Help me! Sincere thanks!!! This programme matters a lot to me!!
Hi @chengxii. I'm going to ask you to provide the full verbose output from an upload attempt.
This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
- Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
The "Preferences" dialog will open. - Uncheck the box next to Show verbose output during:
☑compile in the "Preferences" dialog. - Check the box next to Show verbose output during: ☐ upload.
- Click the "OK" button.
The "Preferences" dialog will close. - Attempt an upload, as you did before.
- Wait for the upload to fail.
- You will see an "Upload error: ..." notification at the bottom right corner of the Arduino IDE window. Click the "COPY ERROR MESSAGES" button on that notification.
- Open a reply here on this forum topic by clicking the "Reply" button.
- Click the
<CODE/>icon on the post composer toolbar.
This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
- Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
This will paste the error output from the upload into the code block. - Move the cursor outside of the code block markup before you add any additional text to your reply.
- Click the "Reply" button to publish the post.
