Arduino Lidar TF MINI Problem (return 0) Seeed
Hello everyone,
I recently tried to follow the code and assembly instructions provided by the manufacturer for a Lidar sensor, but unfortunately, I am only getting 0 values in return. I am not sure what the issue could be and I am having trouble understanding the problem.
These is the code and the instructions I followed so, in fact with the if condition I have no return.
Has anyone experienced a similar issue or have any advice on how to troubleshoot this problem? Any help would be greatly appreciated.
Thank you.
Please post your code, in code tags,
like this
Also, tell us more about your sensor.
Please read and follow the instructions in the "How to get the best out of this forum" post.
Sorry, there is the code
> Blockquote
void getTFminiData(int* distance, int* strength) {
  static char i = 0;
  char j = 0;
  int checksum = 0;
  static int rx[9];
  if(Serial.available()) {
    rx[i] = Serial.read();
    if(rx[0] != 0x59) {
      i = 0;
    } else if(i == 1 && rx[1] != 0x59) {
      i = 0;
    } else if(i == 8) {
      for(j = 0; j < 8; j++) {
        checksum += rx[j];
      if(rx[8] == (checksum % 256)) {
        *distance = rx[2] + rx[3] * 256;
        *strength = rx[4] + rx[5] * 256;
      i = 0;
      i++;
  int distance = 0;
  int strength = 0;
  getTFminiData(&distance, &strength);
  while(!distance) {
    if(distance) {
      Serial.print(distance);
      Serial.print("cm\t");
      Serial.print("strength: ");
      Serial.println(strength);
Thank you sorry.
So I use an Arduino Yun with a Mac Laptop with the IDE arduino 1.8.9
I plugged the 5V and the GND and when I transfer my code to my arduino then i Plug mi TX to my RX on Arduino
It sounds like the sensor and the Arduino are not communicating. But there is not enough information in your posts to guess why.
What does this mean?
Please post a picture of a hand drawn wiring diagram, with pins and connections clearly labeled, and a photo of your setup.
There is the picture :
TFmini's TX is plugged on Arduino's RX.
That is a picture of an Arduino Uno, taken from the TFmini library web site.
You claim to have a Arduino Yun, which is a completely different board.
Do not expect valid answers from the forum if you post incorrect information.
It's the same but if you want there is mine :
TTFmini's TX is plugged on Arduino's RX and
TTFmini's RX is plugged on Arduno's TX.
