Hi i have made a program on the M0 pro but as the M0 pro has been retired is there another alternative arduino i can use and what adjustments do i need to make to the program for it to work on that arduino
The project im working on is a device that measures the resistance of cables and it will mark them as pass if its within a certain range, the arduino im using is used to power a adafruit thermal printer and a LCD with I2C module
The most obvious answer would be the Zero, which uses the same microcontroller and also has the EDBG. The pinout almost matches, two of the GPIO pins are switched though.
If you like to stick with the SAMD architecture but don't need the onboard debugger or the shield compatibility, I'd consider the MKR ZERO: https://store.arduino.cc/usa/arduino-mkrzero
I think the breadboard-friendly form factor is a big improvement and the price is reasonable.
