I'm using Arduino Mega 2560 board and ESP8266-01
I wanna connect my ESP8266-01 to my PHP website. I just wanna request URL like this,
"mysite.000webhost.com/index.php?out"
and I have wrote a PHP code to connect to my firebase. PHP site and firebase both are working fine.
But the problem is how can I load my URL with arduino code?
Please someone help me with this case I'm tired for find a solution with this case. ![]()
This is my code.
int ledPin = 13; // LED+
// int temp_sensor = A0; // LM35 Output
pinMode(ledPin, OUTPUT); // Set ledPin as Output
Serial.begin(9600); // PC Arduino Serial Monitor
Serial1.begin(115200); // Arduino to ESP01 Communication
connectWiFi(); // To connect to Wifi
// float analog_val = analogRead(temp_sensor); // Read Analog Temperature
//j=tempc;
digitalWrite(ledPin, HIGH); // LED ON
delay(500); // wait for 500 mSec
digitalWrite(ledPin, LOW); // LED OFF
Serial1.println("AT+CIPMUX=0\r\n"); // To Set MUX = 0
delay(500); // Wait for 2 sec
// TCP connection
String cmd = "AT+CIPSTART=\"TCP\",\""; // TCP connection with https://thingspeak.com server
// cmd += "184.106.153.149"; // IP addr of api.thingspeak.com
cmd += "mywebsite.000webhostapp.com"; // ip address of my site
cmd += "\",80\r\n\r\n"; // Port No. = 80
Serial1.println(cmd); // Display above Command on PC
Serial.println(cmd); // Send above command to Rx1, Tx1
delay(2000); // Wait for 20 Sec
if(Serial1.find("ERROR")) // If returns error in TCP connection
Serial.println("AT+CIPSTART error"); // Display error msg to PC
//return;
// prepare GET string
String getStr = "POST /index.php?in HTTP/1.0 ";
getStr += "Host: mywebsite.000webhostapp.com";
// getStr += apiKey;
// getStr +="&field1=";
// getStr += analog_val;
getStr += "\r\n\r\n";
Serial.println(getStr); // Display GET String on PC
cmd = "AT+CIPSEND="; // send data length
cmd += String(getStr.length());
cmd+="\r\n";
Serial.println(cmd); // Display Data length on PC
Serial1.println(cmd); // Send Data length command to Tx1, Rx1
delay(1000); // wait for 20sec
if(Serial1.find(">")) // If prompt opens //verify connection with cloud
Serial.println("connected to Cloud"); // Display confirmation msg to PC
Serial1.print(getStr); // Send GET String to Rx1, Tx1
Serial1.println("AT+CIPCLOSE\r\n"); // Send Close Connection command to Rx1, Tx1
Serial.println("AT+CIPCLOSE"); // Display Connection closed command on PC
// thingspeak free version needs 16 sec delay between updates
// delay(1000); // wait for 16sec
boolean connectWiFi() { // Connect to Wifi Function
Serial1.println("AT+CWMODE=1\r\n"); // Setting Mode = 1
delay(100); // wait for 100 mSec
String cmd = "AT+CWJAP=\""; // Connect to WiFi
cmd += "Silver-WiFi"; // ssid_name
cmd += "\",\"";
cmd += "MyWifi123"; // password
cmd += "\"\r\n";
Serial.println(cmd); // Display Connect Wifi Command on PC
Serial1.println(cmd); // send Connect WiFi command to Rx1, Tx1
delay(500); // wait for 10 sec
Serial1.println("AT+CWJAP?"); // Verify Connected WiFi
if(Serial1.find("+CWJAP"))
Serial.println("OK, Connected to WiFi."); // Display Confirmation msg on PC
return true;
Serial.println("Can not connect to the WiFi."); // Display Error msg on PC
return false;
