I have an Arduino Mega and a 2.8" Tft-Display-Shield from Adafruit. The Display is for the Arduino Uno, but the documentation says it can also be used with the Arduino Mega. Therefore it is needed to "solder three jumpers and you can use it at full speed on a Leonardo or Mega as well."
The Problem is that i don't know where i should solder these.
I know that the SPI-Pins on the Uno are Digital 13,12,11 and on the Mega 50,51,52.
I think i need to connect the ICSP-Pins of the Mega to some Pins on my Display-Shield.
The Problem here is that the back of the Display looks a little bit different than the one i linked above. My Display got no ICSP-Connectors, just some Pin-Holes on the side.
I guess i need to connect a jumper from the ICSP-Pins to these holes, but i dont know which hole belongs to which Pin.
I would appreciate if someone could help me.
If you need further information let me know.
cut the the three solder-bridges marked 11, 12, 13 with an Xacto knife.
solder the three bridges marked ICSP.
Now your screen will work on a Uno, Leo, Mega2560, Zero, Due, …
Just by plugging the Shield into the Arduino header sockets as Nature intended.
There is no need to connect any jumper wires.
If you want to use it on an STM32 Nucleo board you “make” the three solder-bridges marked 11, 12, 13
But remember to “un-make” before you use it on Leo, Mega2560, Zero, Due
See the two square pads under the P of the printed ICSP on the Shield pcb
With your soldering iron, apply some solder. The two squares will "join" with molten solder.
Repeat for the two square pads under the C
Repeat for the two square pads to the bottom left of the I (and above the printed SCK)
Cut the fine gold line between the two square pads above the 13.
Cut the fine gold line between the two square pads above the 12.
Cut the fine gold line between the two square pads above the 11.
The pair of adjacent square gold pads on a pcb is known as a "solder-bridge".
These are usually "normally open". You apply solder to "make"
Your "13, 12, 11" solder-bridges have a fine gold line between the pads. i.e. unusually "normally closed"
When you cut the fine line it turns the "normally closed" into "open".
Subsequent solder "makes".
Subsequent "heat and wipe" with a soldering iron will "un-make"
I have to apologize, the display i linked above is actually not the display i have.
They sent me an other display but stated it was from adafruit.
So on my display-shield there are no solder-bridges.
