Arduino Mega to Arduino Nano Serial Communication Problems
Hey all,
I'm using an Arduino Mega to send sensor data, an integer, to three Arduinos via serial using the Mega's multi serial function.
I wrote the code for the Nano's and ran it using the console in the IDE for testing. When I did this, the OLED the Nano was outputting to was displaying the correct integers but when I tied the Nano's to the serial pins on the Mega and set the Mega to just output a constant integer on all serial ports except for the one the USB is using, the displays on all of the Nano's displayed nothing but their TX lights were flashing. For debugging, I plugged in one of the Nano's into my computer and kept the rest on the power rail and had it output what it was receiving to the console. What it was writing was squares, which immediately lead me to think the baud rate was off. I tried a few baud rates but then realized that wasn't the issue. I also tried adding a 1 second delay to the serial read to allow for it more time to collect the integer I was sending over serial although this wouldn't work, the data needs to be as close to real-time as possible. That also didn't work. Below is the "Sender" code from the Mega, it's just a test script right now, in the future it will be real-time data from a sensor. Also down below is the "Reciever" code or the code running on all three Nanos. Code is sloppy right now but any support is appreciated!
Sender Code
int testval = 0;
  // initialize both serial ports:
  Serial1.begin(9600);
  Serial2.begin(9600);
  Serial3.begin(9600);
testval = "200";
Serial1.write(testval);
Serial2.write(testval);
Serial3.write(testval);
  if (Serial1.available()) {
    int inByte = Serial1.read();
    Serial.write(inByte);
  if (Serial2.available()) {
  if (Serial3.available()) {
Receiver Code
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_GFX.h>
// OLED display TWI address
#define OLED_ADDR   0x3C
Adafruit_SSD1306 display(-1);
#if (SSD1306_LCDHEIGHT != 64)
#error("Height incorrect, please fix Adafruit_SSD1306.h!");
#endif
int value;
int sensordata;
  // initialize and clear display
  display.begin(SSD1306_SWITCHCAPVCC, OLED_ADDR);
  display.clearDisplay();
  display.display();
   // display the header
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.setCursor(31,2);
  display.print("WATER LEVEL");
  //Convert Serial Data
    if( Serial.available())
    char ch = Serial.read();
    if(ch >= '0' && ch <= '9') // is this an ascii digit between 0 and 9?
       value = (value * 10) + (ch - '0'); // yes, accumulate the value
    else if (ch == 10)  // is the character the newline character
       sensordata = value;  // set var to the accumulated value
       Serial.println(sensordata);
       value = 0; // reset val to 0 ready for the next sequence of digits
display.setTextSize(4);
  display.setTextColor(WHITE, BLACK);
if (sensordata <= 99) {
   // display value
  display.setCursor(16,20);
  display.print("     ");
  display.setCursor(33,20);
  display.print(sensordata);
 display.print("%");
  } else if ( 99 < sensordata < 600) {
 display.setCursor(28,20);
  display.print("     ");
  display.print("%");
  if (sensordata <= 30) {
  display.setCursor(34,55);
  display.print("LOW WATER");
  display.print("         ");
  // update display with all of the above graphics
  display.display();
testval = "200";
What the heck? That string is NOT an int.
What you are storing in the variable is the (useless) address where the string literal is stored.
If there is data on Serial2, read from Serial1. Hmmm...
If there is data on Serial3, read from Serial1. Hmmm...
You never send that character.
