Arduino Micro with XBee
I can't get an XBee talking when hooked up to the Arduino Micro. I know this because I do not see another XBee at another computer listening to the one connected to the Micro.
I use an XBee Pro S1 connected to the Arduino Micro as shown in the picture attached.
When I connect the XBee with the Arduino UNO it works perfectly and I see the output on another computer. So this is the evidence I connected it properly.
I changed TX and RX already without effect. And I use the line ..
while (!Serial) {};
recommended for the Arduino Micro.
Complete coding is as follows:
  while (!Serial) {};
 Serial.println(millis());
I suspect here some specialities with the Arduino Micro.
Thanks for your help.
Regards, AgeBee
Two remarks:
  1. I made a mistake in the coding. It must read:
 while (!Serial) ;
However, this does not change the result, i.e. I still can't see any output at the second XBee.
  1. I see the TX LED flashing on the Arduino Micro.
So, it seems to me, that the data do not reach the XBee.
AgeBee:
Two remarks:
 while (!Serial) ;
It's the same thing.
Even better would be:
while (!Serial)  {
That way it's easy to see that it's an empty loop.
Found the solution !
Since the Arduino Micro is connected through a USB cable I can't use PINs 0 and 1 since the USB uses them.
I used SoftwareSerial to get me two other PINS, 8 and 9.
Code is like this, I used a LED to check optically.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(7, 8); // RX, TX
int led = 13;
  while (!Serial);
  pinMode(led, OUTPUT);
  mySerial.begin(9600);
  digitalWrite(led, HIGH);
  mySerial.println(millis());
  digitalWrite(led, LOW);
