Arduino MKR 1400 HTTPS certificate issue
Hello, ive been wanting to make my arduino mkr1400 connect to InfluxDB and send data there via POST.
However it seems like the InfluxDB cloud only accepts requests via HTTPS.
I implemented commands from the SSLCertificateManagement_Example.ino into GSMSSLWebClient.ino like this after adding the keys into arduino_secrets.h:
// libraries
#include <MKRGSM.h>
#include "arduino_secrets.h"
// Please enter your sensitive data in the Secret tab or arduino_secrets.h
// PIN Number
const char PINNUMBER[]     = SECRET_PINNUMBER;
// APN data
const char GPRS_APN[]      = SECRET_GPRS_APN;
const char GPRS_LOGIN[]    = SECRET_GPRS_LOGIN;
const char GPRS_PASSWORD[] = SECRET_GPRS_PASSWORD;
// initialize the library instance
GSMSSLClient client;
GPRS gprs;
GSM gsmAccess(true);
// URL, path and port (for example: arduino.cc)
char server[] = "europe-west1-1.gcp.cloud2.influxdata.com";
int port = 443; // port 443 is the default for HTTPS
  // initialize serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.println("Starting Arduino web client.");
  // connection state
  bool connected = false;
  // After starting the modem with GSM.begin()
  // attach the shield to the GPRS network with the APN, login and password
  while (!connected) {
    if ((gsmAccess.begin(PINNUMBER) == GSM_READY) &&
        (gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD) == GPRS_READY)) {
      connected = true;
      Serial.println("Not connected");
  client.eraseTrustedRoot();
  client.setUserRoots(SECRET_GSM_ROOT_CERTS, SECRET_GSM_ROOT_SIZE);
  client.setSignedCertificate(SECRET_CERT, "MKRGSM01", sizeof(SECRET_CERT));
  client.setPrivateKey(SECRET_KEY, "MKRGSMKEY01", sizeof(SECRET_KEY));
  client.useSignedCertificate("MKRGSM01");
  client.usePrivateKey("MKRGSMKEY01");
  client.setTrustedRoot("Let_s_Encrypt_Authority_X3");
  Serial.println("connecting...");
  // if you get a connection, report back via serial:
  if (client.connect(server, port)) {
    Serial.println("connected");
    // Make a HTTP request:
    client.println("GET /api/v2 HTTP/1.1");
    client.print("Host: europe-west1-1.gcp.cloud2.influxdata.com");
    client.println();
    // if you didn't get a connection to the server:
    Serial.println("connection failed");
  // if there are incoming bytes available
  // from the server, read them and print them:
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  // if the server's disconnected, stop the client:
  if (!client.available() && !client.connected()) {
    Serial.println("disconnecting.");
    client.stop();
    // do nothing forevermore:
    for (;;)
I looked at debug output from the modem and what looks suspicious to me is that the arduino sends "AT+USECMNG=2,0,"AddTrust_External_CA_Root"" command into the modem, however according to the documentation of the modem, the first parameter can only be 0,1 or 3.
Modem responds with "ERROR" as can be seen here:
17:29:52.168 -> Starting Arduino web client.
17:29:56.049 -> ⸮AT
17:29:56.234 -> OK
17:29:56.280 -> AT+IPR=921600
17:29:56.280 -> OK
17:29:56.374 -> AT
17:29:56.374 -> OK
17:29:56.374 -> AT+UPSV=3
17:29:56.374 -> OK
17:29:56.513 -> AT+CPIN?
17:29:56.513 -> ERROR
17:29:56.699 -> AT+CPIN?
17:29:56.699 -> ERROR
17:29:56.930 -> AT+CPIN?
17:29:56.930 -> +CPIN: READY
17:29:56.930 ->
17:29:56.930 -> OK
17:29:57.115 -> AT+CMGF=1
17:29:57.115 -> OK
17:29:57.300 -> AT+UDCONF=1,1
17:29:57.300 -> OK
17:29:57.532 -> AT+CTZU=1
17:29:57.532 -> OK
17:29:57.720 -> AT+UDTMFD=1,2
17:29:57.720 -> OK
17:29:57.905 -> AT+CREG?
17:29:57.905 -> +CREG: 0,0
17:29:57.905 ->
17:29:57.905 -> OK
17:29:58.138 -> AT+CREG?
17:30:03.976 -> +CREG: 0,1
17:30:03.976 ->
17:30:03.976 -> OK
17:30:04.208 -> AT+UCALLSTAT=1
17:30:04.208 -> OK
17:30:04.302 -> AT+CGATT=1
17:30:04.302 -> OK
17:30:04.488 -> AT+UPSD=0,1,"internet"
17:30:04.488 -> OK
17:30:04.718 -> AT+UPSD=0,6,3
17:30:04.718 -> OK
17:30:04.905 -> AT+UPSD=0,2,""
17:30:04.905 -> OK
17:30:05.091 -> AT+UPSD=0,3,""
17:30:05.138 -> OK
17:30:05.323 -> AT+UPSD=0,7,"0.0.0.0"
17:30:05.323 -> OK
17:30:05.507 -> AT+UPSDA=0,3
17:30:06.110 -> OK
17:30:06.297 -> AT+UPSND=0,8
17:30:06.342 -> +UPSND: 0,8,1
17:30:06.342 ->
17:30:06.342 -> OK
17:30:06.342 -> AT+USECMNG=2,0,"AddTrust_External_CA_Root"
17:30:06.342 -> ERROR
17:30:06.390 -> AT+USECMNG=2,0,"Baltimore_CyberTrust_Root"
17:30:06.390 -> ERROR
17:30:06.390 -> AT+USECMNG=2,0,"COMODO_RSA_Certification_Authority"
17:30:06.437 -> AT+USECMNG=2,0,"DST_Root_CA_X3"
17:30:06.437 -> OK
17:30:06.484 -> AT+USECMNG=2,0,"DigiCert_High_Assurance_EV_Root_CA"
17:30:06.484 -> ERROR
17:30:06.484 -> AT+USECMNG=2,0,"Entrust_Root_Certification_Authority"
17:30:06.531 -> AT+USECMNG=2,0,"Equifax_Secure_Certificate_Authority"
17:30:06.531 -> ERROR
17:30:06.531 -> AT+USECMNG=2,0,"GeoTrust_Global_CA"
17:30:06.578 -> AT+USECMNG=2,0,"GeoTrust_Primary_Certification_Authority_G3"
17:30:06.578 -> ERROR
17:30:06.578 -> AT+USECMNG=2,0,"GlobalSign"
17:30:06.625 -> AT+USECMNG=2,0,"Go_Daddy_Root_Certificate_Authority_G2"
17:30:06.625 -> ERROR
17:30:06.625 -> AT+USECMNG=2,0,"VeriSign_Class_3_Public_Primary_Certification_Authority_G5"
17:30:06.672 -> AT+USECMNG=2,0,"AmazonRootCA1"
17:30:06.672 -> ERROR
17:30:06.672 -> AT+USECMNG=2,0,"Starfield_Services_Root_Certificate_Authority_G2"
17:30:06.718 -> ERROR
17:30:06.718 -> AT+USECMNG=0,1,"MKRGSM01",0
17:30:06.764 -> AT+USECMNG=0,2,"MKRGSMKEY01",0
17:30:06.764 -> ERROR
17:30:06.764 -> AT+USECPRF=0,5,"MKRGSM01"
17:30:06.764 -> OK
17:30:06.810 -> AT+USECPRF=0,6,"MKRGSMKEY01"
17:30:06.810 -> OK
17:30:06.810 -> AT+USECPRF=0,3,"Let_s_Encrypt_Authority_X3"
17:30:06.810 -> OK
17:30:06.810 -> connecting...
17:30:06.856 -> AT+USECMNG=0,0,"DST_Root_CA_X3",846
17:30:07.041 -> +USECMNG: 0,0,"DST_Root_CA_X3","410352dc0ff7501b16f0028eba6f45c5"
17:30:07.041 ->
17:30:07.041 -> OK
17:30:07.041 -> AT+USECMNG=0,0,"Let_s_Encrypt_Authority_X3",1174
17:30:07.227 -> +USECMNG: 0,0,"Let_s_Encrypt_Authority_X3","b15409274f54ad8f023d3b85a5ecec5d"
17:30:07.227 ->
17:30:07.227 -> OK
17:30:07.366 -> AT+USOCR=6
17:30:07.366 -> +USOCR: 0
17:30:07.366 ->
17:30:07.366 -> OK
17:30:07.549 -> AT+USOSEC=0,1,0
17:30:07.549 -> OK
17:30:07.779 -> AT+USECPRF=0,0,1
17:30:07.779 -> OK
17:30:07.965 -> AT+USOCO=0,"europe-west1-1.gcp.cloud2.influxdata.com",443
17:30:09.874 -> ERROR
17:30:09.967 ->
17:30:09.967 -> +UUSOCL: 0
17:30:10.107 -> AT+USOCL=0
17:30:10.107 -> ERROR
17:30:10.107 -> connection failed
17:30:10.107 ->
17:30:10.107 -> disconnecting.
Did anyone encounter similar problem?
Is there any way how to fix this?
2 means Remove an imported certificate or private key. it likely comes from client.eraseTrustedRoot(). Shouldn't that be client.eraseAllCertificates();?
Yes, you are correct.
Also, after removing the whole
The output from the module all run with OK results, sadly the connection still doesnt work(i tried writing the link without "https://", that doesnt work either):
19:18:17.664 -> connecting...
19:18:17.710 -> AT+USECMNG=0,0,"AddTrust_External_CA_Root",1082
19:18:17.898 -> +USECMNG: 0,0,"AddTrust_External_CA_Root","1d3554048578b03f42424dbf20730a3f"
19:18:17.898 ->
19:18:17.898 -> OK
19:18:17.898 -> AT+USECMNG=0,0,"Baltimore_CyberTrust_Root",891
19:18:18.085 -> +USECMNG: 0,0,"Baltimore_CyberTrust_Root","acb694a59c17e0d791529bb19706a6e4"
19:18:18.132 ->
19:18:18.132 -> OK
19:18:18.132 -> AT+USECMNG=0,0,"COMODO_RSA_Certification_Authority",1500
19:18:18.317 -> +USECMNG: 0,0,"COMODO_RSA_Certification_Authority","1b31b0714036cc143691adc43efdec18"
19:18:18.317 ->
19:18:18.317 -> OK
19:18:18.364 -> AT+USECMNG=0,0,"DST_Root_CA_X3",846
19:18:18.553 -> +USECMNG: 0,0,"DST_Root_CA_X3","410352dc0ff7501b16f0028eba6f45c5"
19:18:18.553 ->
19:18:18.553 -> OK
19:18:18.553 -> AT+USECMNG=0,0,"DigiCert_High_Assurance_EV_Root_CA",969
19:18:18.787 -> +USECMNG: 0,0,"DigiCert_High_Assurance_EV_Root_CA","d474de575c39b2d39c8583c5c065498a"
19:18:18.787 ->
19:18:18.787 -> OK
19:18:18.787 -> AT+USECMNG=0,0,"Entrust_Root_Certification_Authority",1173
19:18:18.974 -> +USECMNG: 0,0,"Entrust_Root_Certification_Authority","d6a5c3ed5ddd3e00c13d87921f1d3fe4"
19:18:18.974 ->
19:18:18.974 -> OK
19:18:19.021 -> AT+USECMNG=0,0,"Equifax_Secure_Certificate_Authority",804
19:18:19.211 -> +USECMNG: 0,0,"Equifax_Secure_Certificate_Authority","67cb9dc013248a829bb2171ed11becd4"
19:18:19.211 ->
19:18:19.211 -> OK
19:18:19.211 -> AT+USECMNG=0,0,"GeoTrust_Global_CA",856
19:18:19.397 -> +USECMNG: 0,0,"GeoTrust_Global_CA","f775ab29fb514eb7775eff053c998ef5"
19:18:19.443 ->
19:18:19.443 -> OK
19:18:19.443 -> AT+USECMNG=0,0,"GeoTrust_Primary_Certification_Authority_G3",1026
19:18:19.631 -> +USECMNG: 0,0,"GeoTrust_Primary_Certification_Authority_G3","b5e83436c910445848706d2e83d4b805"
19:18:19.631 ->
19:18:19.631 -> OK
19:18:19.678 -> AT+USECMNG=0,0,"GlobalSign",958
19:18:19.866 -> +USECMNG: 0,0,"GlobalSign","9414777e3e5efd8f30bd41b0cfe7d030"
19:18:19.866 ->
19:18:19.866 -> OK
19:18:19.866 -> AT+USECMNG=0,0,"Go_Daddy_Root_Certificate_Authority_G2",969
19:18:20.050 -> +USECMNG: 0,0,"Go_Daddy_Root_Certificate_Authority_G2","803abc22c1e6fb8d9b3b274a321b9a01"
19:18:20.050 ->
19:18:20.050 -> OK
19:18:20.097 -> AT+USECMNG=0,0,"VeriSign_Class_3_Public_Primary_Certification_Authority_G5",1239
19:18:20.281 -> +USECMNG: 0,0,"VeriSign_Class_3_Public_Primary_Certification_Authority_G5","cb17e431673ee209fe455793f30afa1c"
19:18:20.281 ->
19:18:20.281 -> OK
19:18:20.281 -> AT+USECMNG=2,0,"AmazonRootCA1"
19:18:20.328 -> ERROR
19:18:20.328 -> AT+USECMNG=0,0,"Starfield_Services_Root_Certificate_Authority_G2",1011
19:18:20.514 -> +USECMNG: 0,0,"Starfield_Services_Root_Certificate_Authority_G2","173574af7b611cebf4f93ce2ee40f9a2"
19:18:20.514 ->
19:18:20.514 -> OK
19:18:20.652 -> AT+USOCR=6
19:18:20.652 -> +USOCR: 0
19:18:20.652 ->
19:18:20.652 -> OK
19:18:20.841 -> AT+USOSEC=0,1,0
19:18:20.841 -> OK
19:18:21.028 -> AT+USECPRF=0,0,1
19:18:21.028 -> OK
19:18:21.262 -> AT+USOCO=0,"https://europe-west1-1.gcp.cloud2.influxdata.com",443
19:18:21.873 -> ERROR
19:18:21.965 ->
19:18:21.965 -> +UUSOCL: 0
19:18:22.059 -> AT+USOCL=0
19:18:22.059 -> ERROR
19:18:22.059 -> connection failed
19:18:22.059 ->
19:18:22.059 -> disconnecting.
if your server requires HTTPS, then you need to connect using HTTPS. if you remove the part that instruct to use HTTPS it won't work...
are you sure your SECRET_CERT, SECRET_KEY are correct?
But it loads the certs correctly according to the output no?
I am not sure, how do i find that out?
but do those certs match what's required?
I think i understand the issue now. I didnt make or create any SECRET_CERT and SECRET_KEY.
I am not sure how to obtain them but at least i know the direction where to look now.
Yes they need to match with the server side
