MKR1400-how do I troubleshoot a POST request?
I'm trying to send a POST request to an online server, but failing to connect. How can I troubleshoot/debug the connection?
Code follows:
#include <MKRGSM.h>
#include <ArduinoJson.h>
GSMSSLClient client;
GPRS gprs;
GSM gsmAccess;
// Specify IP address or hostname
char server[] = "webhook.site/ce480c43-95a8-4f1e-b996-bc02f6d1adaa";
int port = 443; // port 443 is the default for HTTPS
DynamicJsonDocument doc(1024);
  bool connected = false;
  while (!connected) {
  if ((gsmAccess.begin(PINNUMBER) == GSM_READY) &&
       (gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD) == GPRS_READY)) {
    connected = true;
    Serial.println("Connected");
     Serial.println("Not connected");
  doc["latitude"] = latitude;
  doc["longitude"] = longitude;
  doc["altitude"] = altitude;
  String location;
  serializeJson(doc, location);
if (client.connect(server, port)) {
    client.print("POST ");
    client.print("https://");
    client.print(server);
    client.println(" HTTP/1.1");
    client.println("Content-Type: application/json;");
    client.println();
    client.println(location);
    // if you didn't get a connection to the server:
    Serial.println("connection failed");
With
GSM gsmAccess(true);
and then watch the serial monitor.
Thank you.
This
This is the output I got on the serial monitor. I'm not sure how to parse it.
I am not seeing a POST request on the webhook site.
Starting Arduino web client.
TAT
OK
AT+IPR=921600
OK
AT
OK
AT+UPSV=3
OK
AT+CPIN?
ERROR
AT+CPIN?
+CPIN: READY
OK
AT+CMGF=1
OK
AT+UDCONF=1,1
OK
AT+CTZU=1
OK
AT+UDTMFD=1,2
AT+CREG?
+CREG: 0,0
OK
+UMWI: 0,1
+UMWI: 0,2
+UMWI: 0,3
+UMWI: 0,4
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,5
OK
AT+UCALLSTAT=1
OK
AT+CGATT=1
OK
AT+UPSD=0,1,"prepay.pelion"
OK
AT+UPSD=0,6,3
OK
AT+UPSD=0,2,"arduino"
OK
AT+UPSD=0,3,"arduino"
OK
AT+UPSD=0,7,"0.0.0.0"
OK
AT+UPSDA=0,3
OK
AT+UPSND=0,8
+UPSND: 0,8,1
OK
Connected
AT+USECMNG=0,0,"AddTrust_External_CA_Root",1082
+USECMNG: 0,0,"AddTrust_External_CA_Root","1d3554048578b03f42424dbf20730a3f"
OK
AT+USECMNG=0,0,"Baltimore_CyberTrust_Root",891
+USECMNG: 0,0,"Baltimore_CyberTrust_Root","acb694a59c17e0d791529bb19706a6e4"
OK
AT+USECMNG=0,0,"COMODO_RSA_Certification_Authority",1500
+USECMNG: 0,0,"COMODO_RSA_Certification_Authority","1b31b0714036cc143691adc43efdec18"
OK
AT+USECMNG=0,0,"DST_Root_CA_X3",846
+USECMNG: 0,0,"DST_Root_CA_X3","410352dc0ff7501b16f0028eba6f45c5"
OK
AT+USECMNG=0,0,"DigiCert_High_Assurance_EV_Root_CA",969
+USECMNG: 0,0,"DigiCert_High_Assurance_EV_Root_CA","d474de575c39b2d39c8583c5c065498a"
OK
AT+USECMNG=0,0,"Entrust_Root_Certification_Authority",1173
+USECMNG: 0,0,"Entrust_Root_Certification_Authority","d6a5c3ed5ddd3e00c13d87921f1d3fe4"
OK
AT+USECMNG=0,0,"Equifax_Secure_Certificate_Authority",804
+USECMNG: 0,0,"Equifax_Secure_Certificate_Authority","67cb9dc013248a829bb2171ed11becd4"
OK
AT+USECMNG=0,0,"GeoTrust_Global_CA",856
+USECMNG: 0,0,"GeoTrust_Global_CA","f775ab29fb514eb7775eff053c998ef5"
OK
AT+USECMNG=0,0,"GeoTrust_Primary_Certification_Authority_G3",1026
+USECMNG: 0,0,"GeoTrust_Primary_Certification_Authority_G3","b5e83436c910445848706d2e83d4b805"
OK
AT+USECMNG=0,0,"GlobalSign",958
+USECMNG: 0,0,"GlobalSign","9414777e3e5efd8f30bd41b0cfe7d030"
OK
AT+USECMNG=0,0,"Go_Daddy_Root_Certificate_Authority_G2",969
+USECMNG: 0,0,"Go_Daddy_Root_Certificate_Authority_G2","803abc22c1e6fb8d9b3b274a321b9a01"
OK
AT+USECMNG=0,0,"VeriSign_Class_3_Public_Primary_Certification_Authority_G5",1239
+USECMNG: 0,0,"VeriSign_Class_3_Public_Primary_Certification_Authority_G5","cb17e431673ee209fe455793f30afa1c"
OK
AT+USECMNG=2,0,"AmazonRootCA1"
ERROR
AT+USECMNG=0,0,"Starfield_Services_Root_Certificate_Authority_G2",1011
+USECMNG: 0,0,"Starfield_Services_Root_Certificate_Authority_G2","173574af7b611cebf4f93ce2ee40f9a2"
OK
AT+USOCR=6
+USOCR: 0
OK
AT+USOSEC=0,1,0
OK
AT+USECPRF=0,0,1
OK
AT+USOCO=0,"webhook.site",443
ERROR
AT+USOCL=0
ERROR
connection failed
Welcome to the club! I'm already fighting a long battle on this field of shame...
Means the modem failed creating a socket to webhook.site on port 443.
ERROR
AT+USOCL=0
The modem answers ERROR...how exciting...
Then tries to close the never opened socket. Answer is ERROR
So, this is the core of the problem. The baseband (the modem) is a seperate "computer" with firmware etc. You can only communicate with AT commands but you can never control or debug whats happening between the modem and the network.
I see. Is there anything else that can be done here?
What all programmers do. Find the bug, don't lose your nerve... Good luck!
Hi!
I try to find a working example to post data with mkr1400. A simple get request is working but I can't post data.
I modified this code only to post data:
https://www.hackster.io/smgs/does-the-light-inside-your-fridge-go-off-when-the-door-shuts-6b0de2
Here is my code:
Can anybody help me what could be the problem?
(The same post working from postman)
Thanks
This is the serial monitor output:
⸮AT
OK
AT+IPR=921600
OK
AT
OK
AT+UPSV=3
OK
AT+CPIN?
ERROR
AT+CPIN?
ERROR
AT+CPIN?
ERROR
AT+CPIN?
ERROR
AT+CPIN?
ERROR
AT+CPIN?
ERROR
AT+CPIN?
ERROR
AT+CPIN?
ERROR
AT+CPIN?
ERROR
AT+CPIN?
ERROR
AT+CPIN?
ERROR
AT+CPIN?
+CPIN: SIM PIN
OK
AT+CPIN="6836"
OK
AT+CMGF=1
OK
AT+UDCONF=1,1
OK
AT+CTZU=1
OK
AT+UDTMFD=1,2
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,1
OK
AT+UCALLSTAT=1
OK
AT+CGATT=1
OK
AT+UPSD=0,1,"internet.vodafone.net"
OK
AT+UPSD=0,6,3
OK
AT+UPSD=0,2,""
OK
AT+UPSD=0,3,""
OK
OK
AT+UPSDA=0,3
OK
AT+UPSND=0,8
+UPSND: 0,8,1
OK
connecting...
AT+CSQ
+CSQ: 25,2
OK
Connecting to HTTP Server...
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
ERROR
OK
AT+USOCR=6
+USOCR: 0
OK
AT+USOSEC=0,1,0
OK
AT+USECPRF=0,0,1
OK
AT+USOCO=0,"api.thingspeak.com",443
OK
Connected!
connected to:
api.thingspeak.com
443
Beginnning JSON Post Sequence
AT+USOWR=0,5,"504F535420"
+USOWR: 0,5
OK
AT+USOWR=0,21,"2F7570646174652E6A736F6E20485454502F312E31"
+USOWR: 0,21
OK
AT+USOWR=0,2,"0D0A"
+USOWR: 0,2
OK
POST /update.json HTTP/1.1
AT+USOWR=0,24,"486F73743A206170692E7468696E67737065616B2E636F6D"
+USOWR: 0,24
OK
AT+USOWR=0,2,"0D0A"
+USOWR: 0,2
OK
Host: api.thingspeak.com
AT+USOWR=0,53,"557365722D4167656E743A206D772E646F632E62756C6B2D757064617465202841726475696E6F204D4B522047534D203134303029"
+USOWR: 0,53
OK
AT+USOWR=0,2,"0D0A"
+USOWR: 0,2
OK
User-Agent: mw.doc.bulk-update (Arduino MKR GSM 1400)
AT+USOWR=0,17,"436F6E6E656374696F6E3A20636C6F7365"
+USOWR: 0,17
OK
AT+USOWR=0,2,"0D0A"
+USOWR: 0,2
OK
Connection: close
AT+USOWR=0,30,"436F6E74656E742D547970653A206170706C69636174696F6E2F6A736F6E"
+USOWR: 0,30
OK
AT+USOWR=0,2,"0D0A"
+USOWR: 0,2
OK
AT+USOWR=0,16,"436F6E74656E742D4C656E6774683A20"
+USOWR: 0,16
OK
Content-Length: AT+USOWR=0,3,"313236"
+USOWR: 0,3
OK
AT+USOWR=0,2,"0D0A"
+USOWR: 0,2
OK
126
AT+USOWR=0,2,"0D0A"
+USOWR: 0,2
OK
{"api_key":"1231231231321","field1":"32","latitude":"","longitude":"","status":"Arduino Test: "}AT+USOWR=0,1,"7B"
+USOWR: 0,1
OK
AT+USOWR=0,1,"22"
+USOWR: 0,1
OK
AT+USOWR=0,1,"61"
+USOWR: 0,1
OK
AT+USOWR=0,1,"70"
+USOWR: 0,1
OK
AT+USOWR=0,1,"69"
+USOWR: 0,1
OK
AT+USOWR=0,1,"5F"
+USOWR: 0,1
OK
AT+USOWR=0,1,"6B"
+USOWR: 0,1
OK
AT+USOWR=0,1,"65"
+USOWR: 0,1
OK
AT+USOWR=0,1,"79"
+USOWR: 0,1
OK
AT+USOWR=0,1,"22"
+USOWR: 0,1
OK
AT+USOWR=0,1,"3A"
+USOWR: 0,1
OK
AT+USOWR=0,1,"22"
+USOWR: 0,1
OK
AT+USOWR=0,1,"34"
+USOWR: 0,1
OK
AT+USOWR=0,1,"31"
+USOWR: 0,1
OK
AT+USOWR=0,1,"56"
+USOWR: 0,1
OK
AT+USOWR=0,1,"4C"
+USOWR: 0,1
OK
AT+USOWR=0,1,"39"
+USOWR: 0,1
OK
AT+USOWR=0,1,"39"
+USOWR: 0,1
OK
AT+USOWR=0,1,"35"
+USOWR: 0,1
OK
AT+USOWR=0,1,"41"
+USOWR: 0,1
OK
AT+USOWR=0,1,"59"
+USOWR: 0,1
OK
AT+USOWR=0,1,"4D"
+USOWR: 0,1
OK
AT+USOWR=0,1,"38"
+USOWR: 0,1
OK
AT+USOWR=0,1,"30"
+USOWR: 0,1
OK
AT+USOWR=0,1,"53"
+USOWR: 0,1
OK
AT+USOWR=0,1,"34"
+USOWR: 0,1
OK
AT+USOWR=0,1,"39"
+USOWR: 0,1
OK
AT+USOWR=0,1,"50"
+USOWR: 0,1
OK
AT+USOWR=0,1,"22"
+USOWR: 0,1
OK
AT+USOWR=0,1,"2C"
+USOWR: 0,1
OK
AT+USOWR=0,1,"22"
+USOWR: 0,1
OK
AT+USOWR=0,1,"66"
+USOWR: 0,1
OK
AT+USOWR=0,1,"69"
+USOWR: 0,1
OK
AT+USOWR=0,1,"65"
+USOWR: 0,1
OK
AT+USOWR=0,1,"6C"
+USOWR: 0,1
OK
AT+USOWR=0,1,"64"
+USOWR: 0,1
OK
AT+USOWR=0,1,"31"
+USOWR: 0,1
OK
AT+USOWR=0,1,"22"
+USOWR: 0,1
OK
AT+USOWR=0,1,"3A"
+USOWR: 0,1
OK
AT+USOWR=0,1,"22"
+USOWR: 0,1
OK
AT+USOWR=0,1,"33"
+USOWR: 0,1
OK
AT+USOWR=0,1,"32"
+USOWR: 0,1
OK
AT+USOWR=0,1,"22"
+USOWR: 0,1
OK
AT+USOWR=0,1,"2C"
+USOWR: 0,1
OK
AT+USOWR=0,1,"22"
+USOWR: 0,1
OK
AT+USOWR=0,1,"6C"
+USOWR: 0,1
OK
AT+USOWR=0,1,"61"
+USOWR: 0,1
OK
AT+USOWR=0,1,"74"
+USOWR: 0,1
OK
AT+USOWR=0,1,"69"
+USOWR: 0,1
OK
AT+USOWR=0,1,"74"
+USOWR: 0,1
OK
AT+USOWR=0,1,"75"
+USOWR: 0,1
OK
AT+USOWR=0,1,"64"
+USOWR: 0,1
OK
AT+USOWR=0,1,"65"
+USOWR: 0,1
OK
AT+USOWR=0,1,"22"
+USOWR: 0,1
OK
AT+USOWR=0,1,"3A"
+USOWR: 0,1
OK
AT+USOWR=0,1,"22"
+USOWR: 0,1
OK
AT+USOWR=0,1,"22"
+USOWR: 0,1
OK
AT+USOWR=0,1,"2C"
+USOWR: 0,1
OK
AT+USOWR=0,1,"22"
+USOWR: 0,1
OK
AT+USOWR=0,1,"6C"
+USOWR: 0,1
OK
AT+USOWR=0,1,"6F"
+USOWR: 0,1
OK
AT+USOWR=0,1,"6E"
+USOWR: 0,1
OK
AT+USOWR=0,1,"67"
+USOWR: 0,1
OK
AT+USOWR=0,1,"69"
+USOWR: 0,1
OK
AT+USOWR=0,1,"74"
+USOWR: 0,1
OK
AT+USOWR=0,1,"75"
+USOWR: 0,1
OK
AT+USOWR=0,1,"64"
+USOWR: 0,1
OK
AT+USOWR=0,1,"65"
+USOWR: 0,1
OK
AT+USOWR=0,1,"22"
+USOWR: 0,1
OK
AT+USOWR=0,1,"3A"
+USOWR: 0,1
OK
AT+USOWR=0,1,"22"
+USOWR: 0,1
OK
AT+USOWR=0,1,"22"
+USOWR: 0,1
OK
AT+USOWR=0,1,"2C"
+USOWR: 0,1
OK
AT+USOWR=0,1,"22"
+USOWR: 0,1
OK
AT+USOWR=0,1,"73"
+USOWR: 0,1
OK
AT+USOWR=0,1,"74"
+USOWR: 0,1
OK
AT+USOWR=0,1,"61"
+USOWR: 0,1
OK
AT+USOWR=0,1,"74"
+USOWR: 0,1
OK
AT+USOWR=0,1,"75"
+USOWR: 0,1
OK
AT+USOWR=0,1,"73"
+USOWR: 0,1
OK
AT+USOWR=0,1,"22"
+USOWR: 0,1
OK
AT+USOWR=0,1,"3A"
+USOWR: 0,1
OK
AT+USOWR=0,1,"22"
+USOWR: 0,1
OK
AT+USOWR=0,1,"41"
+USOWR: 0,1
OK
Why do you want to use the http protocol?
I think the mqtt protocol is much more suitable.
Thanks. I am not familiar with mqtt protocol. The final target to write the data to my database. Thingspeak just an exapmle to test post. At the end i would call my own web api to store data.
If i use mqtt i need an MQTT Broker if I am right.
One could use words like "arduino mqtt broker" and find many public MQTT Brokers available.
There are some advantages with small data amounts (persistent socket, less overhead etc) and you can provide the data to many endpoints, because the "server" is a broadcaster called broker.
Read some introductions and you will get it.
Yes, you are right, a mqtt broker (server) is needed, there are public ones (also with a web interface to debug and visualize( shiftr.io for example). I run a broker called mosquitto and wrote a node.js that acts as a receiver (listener) of the broadcast and writes the data in a database.
On the arduino site, as mentioned, you need a library (i use GitHub - 256dpi/arduino-mqtt: MQTT library for Arduino) but there are others.
The SARA410 modem on the mkr1500 has also a internal mqtt functionality, i started a lib under
GitHub - CptHolzschnauz/MKRNB: NBMQTT is a new class for the MKRNB library to use the internal MQTT functionality of the SARA R410 modem (my other name is cpt. holzschnauz ;=)
It's under construction, you can connect, send etc. but receiving data from the broker is not yet implemented (everyone is welcome to contribute!)
You can also stay with the http and find a POST solution or, maybe simpler, do a get request (like the example) with the data (example: blabla.html?data=helloworld ) and parse on the server.
Thanks instarep! It works fine with mqtt. I installed a mosquitto broker too.
