Arduino mkr nb1500 + imu sleep interrupt
Hardware: arduino mkr nb1500 + arduino mkr imu shield
Goal: after x seconds of no motion detected activate low power mode, once motion is detected activate normal power mode
Currently i managed to set the imu in low power mode, which is activated after 5s of no motion, and is set in normal power mode once motion is detected.
Now i would like to also put the host (arduino mkr nb1500) into low power mode once the imu low power mode is triggered. This should be possible with the use of the interrupt pin.
I am having trouble achieving this in actual code. I am able to read the INT_STA register and detect the interrupts; 64 is motion detected, 128 is no motion detected.
I thought about using the arduino low power library [Arduino Low Power - Arduino Reference], but even a simple timed sleep does not work. It doesn't wake up anymore.
Any tips/hints to lead me in the right directions are appreciated!
#include <Adafruit_BNO055.h>
#include "ArduinoLowPower.h"
#define BNO055_ADDRESS          0x28
#define BNO055_INT_STA          0x37
#define BNO055_PWR_MODE         0x3E
#define BNO055_OPR_MODE         0x3D
#define BNO055_ACC_NM_SET       0x16
#define BNO055_PAGE_ID          0x07
Adafruit_BNO055 bno = Adafruit_BNO055();
imu::Vector<3> acc;
int x = 1;
  while (!Serial);
  Serial.println("Serial communication started");
  initializeIMU();
  acc = bno.getVector(Adafruit_BNO055::VECTOR_ACCELEROMETER);
  Serial.print("Acc_x: "); Serial.println(acc.x());
  // interrupt pin from imu: 64 = any motion detected, 128 = no motion detected
  uint8_t imuTrigger = readByte(BNO055_ADDRESS, BNO055_INT_STA);
  Serial.println(imuTrigger);
  // Sleep for 10s, it doesn't wake up after 10s which i did expect to happen
  LowPower.sleep(10000);
void writeByte(uint8_t address, uint8_t subAddress, uint8_t data)
  Wire.beginTransmission(address);  // Initialize the Tx buffer
  Wire.write(subAddress);           // Put slave register address in Tx buffer
  Wire.write(data);                 // Put data in Tx buffer
  Wire.endTransmission();           // Send the Tx buffer
uint8_t readByte(uint8_t address, uint8_t subAddress)
  uint8_t data; // `data` will store the register data
  Wire.endTransmission(false);             // Send the Tx buffer, but send a restart to keep connection alive
  Wire.requestFrom(address, (size_t) 1);   // Read one byte from slave register address
  data = Wire.read();                      // Fill Rx buffer with result
  return data;                             // Return data read from slave register
void initializeIMU()
  bno.begin();
  delay(20);
  writeByte(BNO055_ADDRESS, BNO055_OPR_MODE, 0x00); // Put IMU in operation mode; 0x00 = config, 0x08 is IMU fusion mode
  delay(20);
  writeByte(BNO055_ADDRESS, BNO055_PWR_MODE, 0x01); // Put IMU in low power mode
  Serial.println("IMU low power mode selected");
  delay(20);
  writeByte(BNO055_ADDRESS, BNO055_PAGE_ID, 0x01);    // SELECT PAGE 1 TO CONFIGRE SETTINGS of page 1
  delay(20);
  //  writeByte(BNO055_ADDRESS, BNO055_ACC_NM_SET, 0x7E); // 336s (~5.5 min), max duration
  writeByte(BNO055_ADDRESS, BNO055_ACC_NM_SET, 0x09); // 5s usefull for testing
  Serial.println("no motion to low power duration: 5s");
  delay(20);
  writeByte(BNO055_ADDRESS, BNO055_PAGE_ID, 0x00);    // SELECT PAGE 0 TO CONFIGRE SETTINGS of page 0
  delay(20);
  writeByte(BNO055_ADDRESS, BNO055_OPR_MODE, 0x08); // Operation mode: IMU fusion mode
  Serial.println("IMU fusion mode selected");
  delay(100);
Some microcontrollers have different sleep modes, and in some way the CPU is completely off, so it can't wake up, because it's not processing anything.
