I am using a duinotech motordriver shield to make a drone. it is currently attached to an arduino uno r3 but I am struggling to make it work. I have cut it back to absolute bare bones, i have only plugged my motors into the m1 terminal, with a 4xAA battery pack attached at the power terminals. this is the code I am uploading, but no matter what I do or change, it will not run.
I am relatively new to this, so I'm struggling to understand what i am doing wrong, especially since the motor will run when directly connected to the battery pack itself
Hey, thanks for the reply. So what you're saying is there is not enough power being supplied to the motor shield? What source do you recommend using for a shield like this? should I just use more batteries?
https://www.jaycar.com.au/hobby-motor-low-torque/p/YM2706. I have 4 of these (just testing with one in the M1 terminal at the moment). I did some research and saw that DC motors are better off with motor drivers, so I got mine from the same store. These are all the necessary specifications I could find:
