Arduino Music Help!
How it does possible to write a arduino code to make the music without use the Tone Function? And make sounds?
Below is the code I found from https://www.arduino.cc/en/Tutorial/PlayMelody
But, I want to use arduino to make sound without the Tune Function. How can I do it?
/* Play Melody
- Program to play melodies stored in an array, it requires to know
- about timing issues and about how to play tones.
- The calculation of the tones is made following the mathematical
- operation:
- timeHigh = 1/(2 * toneFrequency) = period / 2
- where the different tones are described as in the table:
- note frequency period PW (timeHigh)
- c 261 Hz 3830 1915
- d 294 Hz 3400 1700
- e 329 Hz 3038 1519
- f 349 Hz 2864 1432
- g 392 Hz 2550 1275
- a 440 Hz 2272 1136
- b 493 Hz 2028 1014
- C 523 Hz 1912 956
- (cleft) 2005 D. Cuartielles for K3
*/int ledPin = 13;
int speakerOut = 9;
byte names[] = {'c', 'd', 'e', 'f', 'g', 'a', 'b', 'C'};
int tones[] = {1915, 1700, 1519, 1432, 1275, 1136, 1014, 956};
byte melody[] = "2d2a1f2c2d2a2d2c2f2d2a2c2d2a1f2c2d2a2a2g2p8p8p8p";
// count length: 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0
// 10 20 30
int count = 0;
int count2 = 0;
int count3 = 0;
int MAX_COUNT = 24;
int statePin = LOW;void setup() {
pinMode(ledPin, OUTPUT);
}void loop() {
analogWrite(speakerOut, 0);
for (count = 0; count < MAX_COUNT; count++) {
statePin = !statePin;
digitalWrite(ledPin, statePin);
for (count3 = 0; count3 <= (melody[count2] - 48) * 30; count3++) {
for (count2=0;count2<8;count2++) {
if (names[count2] == melody[count2 + 1]) {
analogWrite(speakerOut,500);
delayMicroseconds(tones[count2]);
if (melody[count*2 + 1] == 'p') {
// make a pause of a certain size
delayMicroseconds(500);
