Arduino Nano 33 IOT and Arduino IOT Cloud
This is my first time using the Arduino Nano 33 IoT board. I want to connect it to the Arduino IoT Cloud, but when I upload a code that uses a cloud connection, the Arduino Nano 33 IoT keeps connecting and disconnecting. I also tried uploading the ready-made Arduino sketch, but it only made the connect/disconnect issue more frequent.
I already updated the WIFININA firmware and download the Arduino Agent.
I know that the WiFi connection is working because of the connectToWifi.ino file is working fine for me. Please share your knowledge if you have any experience with the Arduino Nano 33 IoT board or using the Arduino IoT Cloud. What could've been the problem, and how can I fix it? I appreciate any help you can provide.
Board: Arduino Nano 33 IOT
Operating System: Windows 10
File: connectToWifi.ino
#include <WiFiNINA.h>
//please enter your sensitive data in the Secret tab
char ssid[] = "**************";                // your network SSID (name)
char pass[] = "*************";                // your network password (use for WPA, or use as key for WEP)
int status = WL_IDLE_STATUS;             // the Wi-Fi radio's status
int ledState = LOW;                       //ledState used to set the LED
unsigned long previousMillisInfo = 0;     //will store last time Wi-Fi information was updated
unsigned long previousMillisLED = 0;      // will store the last time LED was updated
const int intervalInfo = 5000;            // interval at which to update the board information
  //Initialize serial and wait for port to open:
  while (!Serial);
  // set the LED as output
  pinMode(LED_BUILTIN, OUTPUT);
  // attempt to connect to Wi-Fi network:
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to network: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  // you're connected now, so print out the data:
  Serial.println("You're connected to the network");
  Serial.println("---------------------------------------");
  unsigned long currentMillisInfo = millis();
  // check if the time after the last update is bigger the interval
  if (currentMillisInfo - previousMillisInfo >= intervalInfo) {
    previousMillisInfo = currentMillisInfo;
    Serial.println("Board Information:");
    // print your board's IP address:
    IPAddress ip = WiFi.localIP();
    Serial.print("IP Address: ");
    Serial.println(ip);
    // print your network's SSID:
    Serial.println("Network Information:");
    Serial.print("SSID: ");
    Serial.println(WiFi.SSID());
    // print the received signal strength:
    long rssi = WiFi.RSSI();
    Serial.print("signal strength (RSSI):");
    Serial.println(rssi);
  unsigned long currentMillisLED = millis();
  // measure the signal strength and convert it into a time interval
  int intervalLED = WiFi.RSSI() * -10;
  // check if the time after the last blink is bigger the interval
  if (currentMillisLED - previousMillisLED >= intervalLED) {
    previousMillisLED = currentMillisLED;
    // if the LED is off turn it on and vice-versa:
    if (ledState == LOW) {
      ledState = HIGH;
      ledState = LOW;
    // set the LED with the ledState of the variable:
    digitalWrite(LED_BUILTIN, ledState);
I am getting the same with an RP2040Connect. To be fair I only started using it yesterday. Updated firmware and it is fine with no action code or sensors connected. As soon as I add I2C AHT20 to the board it chucks it off the network after about 3 seconds, never to reconnect. I'm on a Macbook Pro and I'm wondering if that might be at the root of the problem.
just found this in another post - disable the watchdog:
ArduinoCloud.begin(ArduinoIoTPreferredConnection, false);
MLX90614 and oLed display not connecting to arduino nano 33 iot when connecting to Arduino iot cloud i used MAX30100,MLX90614,Oled screen and AD8232 sensors
Please anybody help me
  Sketch generated by the Arduino IoT Cloud Thing "IOT Based Remote Patient Monitoring system"
  https://create.arduino.cc/cloud/things/d638babb-7f2b-448c-89f6-08093a79e06a
  Arduino IoT Cloud Variables description
  The following variables are automatically generated and updated when changes are made to the Thing
  float ecg;
  float hrv;
  CloudHeartRate hr;
  CloudPercentage spo2;
  CloudTemperature object;
  Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
  which are called when their values are changed from the Dashboard.
  These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
#include <SoftWire.h>
#include "MAX30100_PulseOximeter.h"
#include "MAX30100.h"
#include <Adafruit_MLX90614.h>
#include <Adafruit_GFX.h>
#include <U8x8lib.h>
#include <avr/dtostrf.h>
#define REPORTING_PERIOD_MS     500   //update rate of hr, spo2, ambient, object, hrv, etc parameters in milli seconds
#define DISPLAY_INTERVAL        5     //update rate for the i2c display = REPORTING_PERIOD_MS*DISPLAY_INTERVAL
#define COMPENSATION            5     //compensation in object temperature. Different body parts have different temperatures. Fingers are around 5 degF lower than core body temperature
// objects
PulseOximeter pox;    //this offers spo2 and hr calculation
Adafruit_MLX90614 mlx = Adafruit_MLX90614();
U8X8_SH1106_128X64_NONAME_HW_I2C u8x8(/* reset=*/ U8X8_PIN_NONE);
MAX30100 sensor;
//variables
uint32_t tsLastReport = 0;
int count = 0, flag = 0, PatientID = 0;
float ambient;
long time1 = 0, time2 = 0;
uint16_t ir = 0, red = 0,  mic; ;
char str_hrv[10], str_object[10], str_ambient[10], str_ir[10], str_red[10];
// Callback (registered below) fired when a pulse is detected
void onBeatDetected()
    time1 = micros() - time2;
    time2 = micros();
  // Initialize serial and wait for port to open:
  // This delay gives the chance to wait for a Serial Monitor without blocking if none is found
//display connected
    u8x8.begin();
    u8x8.setPowerSave(0);
    u8x8.setFont(u8x8_font_chroma48medium8_r);
    //pinMode(10, INPUT); // Setup for leads off detection LO +
    //pinMode(11, INPUT); // Setup for leads off detection LO -
    while (!Serial) {
      ; // wait for serial port to connect. Needed for native USB port only
    // Initialize the PulseOximeter instance
    // Failures are generally due to an improper I2C wiring, missing power supply
    // or wrong target chip
    if (!pox.begin(PULSEOXIMETER_DEBUGGINGMODE_RAW_VALUES)) {
        //Serial.println("FAILED");
        for(;;);
        //Serial.println("SUCCESS");
    // The default current for the IR LED is 50mA and it could be changed
    //   by uncommenting the following line. Check MAX30100_Registers.h for all the
    //   available options.
    pox.setIRLedCurrent(MAX30100_LED_CURR_11MA);
    // Register a callback for the beat detection
    pox.setOnBeatDetectedCallback(onBeatDetected);
    mlx.begin();
    time2 = micros();
  // Defined in thingProperties.h
  initProperties();
  // Connect to Arduino IoT Cloud
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
     The following function allows you to obtain more information
     related to the state of network and IoT Cloud connection and errors
     the higher number the more granular information you’ll get.
     The default is 0 (only errors).
     Maximum is 4
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
  ArduinoCloud.update();
  // Your code here
  // Make sure to call update as fast as possible
    pox.update();
    sensor.update();
    //reading continuous functions (signals) every loop
    while (sensor.getRawValues(&ir, &red)) {}
    ecg = analogRead(A0);
    ecg = map(ecg, 250, 500, 0, 100);
    delay(1);
    // Asynchronously calculate other variables every REPORTING_PERIOD_MS
    // For hr and spo2, a value of 0 means "invalid", for object and ambient temperatures a value less than 70 degF or higher than 110 degF can be considered abnormal
    if (millis() - tsLastReport > REPORTING_PERIOD_MS) {
        hr = pox.getHeartRate();
        spo2 = pox.getSpO2();
        ambient = mlx.readAmbientTempF();
        object = mlx.readObjectTempF() + COMPENSATION;
        hrv = (60000000/hr - (float)time1)/1000;
        //send_serial();
        tsLastReport = millis();
        count++;
        flag = 0;
    //Display all variables on the display after DISPLAY_INTERVAL seconds
    if ((count%DISPLAY_INTERVAL == 0) && (flag != 1)) {
      flag = 1;   //This flag makes sure the display is updated only once every DISPLAY_INTERVAL seconds
      Wire.end();
      send_display();
      Wire.begin();
    Telemetry();
void send_display() {
  u8x8.clearDisplay();
  u8x8.setCursor(0,1);
  u8x8.print("HRV:");
  u8x8.print(hrv);
  u8x8.print(" ms");
  u8x8.setCursor(0,2);
  u8x8.print("SpO2:");
  u8x8.print(spo2);
  u8x8.print(" %");
  u8x8.setCursor(0,3);
  u8x8.print("HR:");
  u8x8.print(hr);
  u8x8.print(" bpm");
  u8x8.setCursor(0,4);
  u8x8.print("Temp:");
  u8x8.print(object);
  u8x8.print(" degF");
  u8x8.setCursor(0,5);
  u8x8.print("ecg:");
  u8x8.print(ecg);
  u8x8.setCursor(0,6);
  u8x8.print("mic");
  u8x8.print(mic);
  //delay(200);
//serial telemetry for edge impulse data forwarder
void Telemetry() {
  char buffer[150];
  dtostrf(hrv, 4, 2, str_hrv);
  dtostrf(object, 4, 2, str_object);
  dtostrf(ambient, 4, 2, str_ambient);
  dtostrf((float)ir/100, 5, 2, str_ir);
  dtostrf((float)red/100, 5, 2, str_red);
  sprintf(buffer,"%d,%d,%d,%d,%s,%s,%s,%s,%s,%d",PatientID,count/10,hr,spo2,str_hrv,str_object,str_ambient,str_ir,str_red,ecg);
Sounds like we have similar issues with the IoT Cloud.
As a next step I will test my project without Arduino IoT Cloud.
