Arduino nano as a bluetooth HID code sending keyboard?
Hello,
I am trying to get arduino working as a HID bluetooth keyboard. I have a arduino nano with 15 buttons and a HC-05 Bluetooth module. What I need is to send these button inputs to a android device as a basic bluetooth keyboard. The buttons are simple, up, down, left right, volume up, down and so on.
My main concern is whether it will work and how to pair/send these commands to the android device.
Also is it possible that the recieveing android device to have a USB bluetooth dongle which will be specifically paired with this custom HID Blueetooth keyboard ?
Atleast on paper it should work am I correct ?
A HC-05 does only know the bluetooth serial profile. You cannot use it for another profile (as HID would be).
so if I am getting this right HC-05 cannot be used as a HID transmitter ?
welo78:
Correct.
And could you point me to a module that can be used as this ?
OR
I saw some arduino modified boards WITH a built in bluetooth a.k.a BlueDuino would that work ?
Your missing the HID portion.
Where are your bluetooth 'commands' going?
On a PC, there are several Arduino variants that can act as a HID device once connected.
As in take some external bluetooth 'command' and then convert/parse this in to a keyboard or mouse input/behavior to the connected PC
I cant comment on an Android device.
This looks like it might do
Hy everyone,
I just drop the information like that but if you want to do hid from an HC-05, it is possible!
You only have to write the software of an RN-42 on the HC-05 because they have the same chip, the CSR BC417.
For any one how will be interested for doing that, there is a link to a tutorial were it is explain with much more informations and details : Bluetooth HID gamepad using HC-05 module - mitxela.com
