Arduino Nano BLE 33 failed initiation with RFM69HCW
Hello. I've been trying to communicate two RFM69HCW (433 MHz) to each other while connecting it to Arduino Nano 33 BLE however, I've been getting 'LoRa initialization failed' error. Here's my connections:
Arduino Nano 33 ---------- RFM69HCW
3.3 V ---------- 3.3 V
GND ---------- GND
D13 ---------- SCK
D12(CIPO) ---------- MOSI
D11 (COPI) --------- MISO
D10 --------- CS (Chip Select)
D9 --------- RST
D2 --------- DI0
Here's the code I'm using that I got from the internet.
#include <SPI.h>              // include libraries
#include <LoRa.h>
const int csPin = 10;          // LoRa radio chip select
const int resetPin = 9;       // LoRa radio reset
const int irqPin = 2;         // change for your board; must be a hardware interrupt pin
String outgoing;              // outgoing message
String message;               // input message
byte msgCount = 0;            // count of outgoing messages
byte localAddress = 0x01;     // address of this device
byte destination = 0x02;      // destination to send to
long lastSendTime = 10000;        // last send time
int interval = 2000;          // interval between sends
  Serial.begin(9600);                   // initialize serial
  while (!Serial);
  Serial.println("LoRa RFM9x Radio - Transmitter");
  // override the default CS, reset, and IRQ pins (optional)
  LoRa.setPins(csPin, resetPin, irqPin);// set CS, reset, IRQ pin
  if (!LoRa.begin(434E6)) {             // initialize ratio at 915 MHz
    Serial.println("LoRa initialization failed. Check your connections.");
    while (true);                       // if failed, do nothing
  Serial.println("LoRa initialization succeeded.");
  delay (1000);
  Serial.println("Please enter your message:");
  delay (1000);
  if (millis() - lastSendTime > interval) {
    while(Serial.available())
      Serial.print("Sending message: ");
      message = Serial.readString();
      sendMessage(message);
      //Serial.print("Sending: " + message);
      Serial.print(message);
    lastSendTime = millis();            // timestamp the message
    interval = random(10) + 1000;    // 2-3 seconds
  // parse for a packet, and call onReceive with the result:
  onReceive(LoRa.parsePacket());
void sendMessage(String outgoing) {
  LoRa.beginPacket();                   // start packet
  LoRa.write(destination);              // add destination address
  LoRa.write(localAddress);             // add sender address
  LoRa.write(msgCount);                 // add message ID
  LoRa.write(outgoing.length());        // add payload length
  LoRa.print(outgoing);                 // add payload
  LoRa.endPacket();                     // finish packet and send it
  msgCount++;                           // increment message ID
void onReceive(int packetSize) {
  if (packetSize == 0) return;          // if there's no packet, return
  // read packet header bytes:
  int recipient = LoRa.read();          // recipient address
  byte sender = LoRa.read();            // sender address
  byte incomingMsgId = LoRa.read();     // incoming msg ID
  byte incomingLength = LoRa.read();    // incoming msg length
  String incoming = "";
  while (LoRa.available()) {
    incoming += (char)LoRa.read();
  if (incomingLength != incoming.length()) {   // check length for error
    Serial.println("error: message length does not match length");
    return;                             // skip rest of function
  // if the recipient isn't this device or broadcast,
  if (recipient != localAddress && recipient != 0xFF) {
    Serial.println("This message is not for me.");
  // if message is for this device, or broadcast, print details:
  Serial.println("You have received a data!");
  Serial.println("Received from: 0x" + String(sender, HEX));
  Serial.println("Sent to: 0x" + String(recipient, HEX));
  //Serial.println("Message ID: " + String(incomingMsgId));
  Serial.println("Message length: " + String(incomingLength));
  Serial.println("Message: " + incoming);
  Serial.println("RSSI: " + String(LoRa.packetRssi()));
  Serial.println("Snr: " + String(LoRa.packetSnr()));
Thats as expected.
The RFM69HCW is not a LoRa device.
Hello @srnet what should I do with this error?
Perhaps use a library that is designed for the RFM69HCW ?
I see. perhaps I can use the RF69 library from this repository RFM69, hope it will work this time
Hello @srnet I already used a RFM69HCW library but still they werent communicating huhuhu. I'm losing all my hopes already.
Here's my code:
#include <RFM69.h>
#include <SPI.h>
// Addresses for this node. CHANGE THESE FOR EACH NODE!
#define NETWORKID     0   // Must be the same for all nodes (0 to 255)
#define MYNODEID      1   // My node ID (0 to 255)
#define TONODEID      2   // Destination node ID (0 to 254, 255 = broadcast)
// RFM69 frequency, uncomment the frequency of your module:
#define FREQUENCY   RF69_433MHZ
//#define FREQUENCY     RF69_915MHZ
// AES encryption (or not):
#define ENCRYPT       true // Set to "true" to use encryption
#define ENCRYPTKEY    "TOPSECRETPASSWRD" // Use the same 16-byte key on all nodes
// Use ACKnowledge when sending messages (or not):
#define USEACK        true // Request ACKs or not
// Packet sent/received indicator LED (optional):
#define LED           9 // LED positive pin
#define GND           8 // LED ground pin
// Create a library object for our RFM69HCW module:
RFM69 radio;
  // Open a serial port so we can send keystrokes to the module:
  Serial.print("Node ");
  Serial.print(MYNODEID,DEC);
  Serial.println(" ready");
  // Set up the indicator LED (optional):
  pinMode(LED,OUTPUT);
  digitalWrite(LED,LOW);
  pinMode(GND,OUTPUT);
  digitalWrite(GND,LOW);
  // Initialize the RFM69HCW:
  //  radio.setCS(10);  //uncomment if using Pro Micro
  radio.initialize(FREQUENCY, MYNODEID, NETWORKID);
  radio.setHighPower(); // Always use this for RFM69HCW
  // Turn on encryption if desired:
  if (ENCRYPT)
    radio.encrypt(ENCRYPTKEY);
  // Set up a "buffer" for characters that we'll send:
  static char sendbuffer[62];
  static int sendlength = 0;
  // SENDING
  // In this section, we'll gather serial characters and
  // send them to the other node if we (1) get a carriage return,
  // or (2) the buffer is full (61 characters).
  // If there is any serial input, add it to the buffer:
  if (Serial.available() > 0)
    char input = Serial.read();
    if (input != '\r') // not a carriage return
      sendbuffer[sendlength] = input;
      sendlength++;
    // If the input is a carriage return, or the buffer is full:
    if ((input == '\r') || (sendlength == 61)) // CR or buffer full
      // Send the packet!
      Serial.print("sending to node ");
      Serial.print(TONODEID, DEC);
      Serial.print(": [");
      for (byte i = 0; i < sendlength; i++)
        Serial.print(sendbuffer[i]);
      Serial.println("]");
      // There are two ways to send packets. If you want
      // acknowledgements, use sendWithRetry():
      if (USEACK)
        if (radio.sendWithRetry(TONODEID, sendbuffer, sendlength))
          Serial.println("ACK received!");
          Serial.println("no ACK received :(");
      // If you don't need acknowledgements, just use send():
      else // don't use ACK
        radio.send(TONODEID, sendbuffer, sendlength);
      sendlength = 0; // reset the packet
      Blink(LED,10);
  // RECEIVING
  // In this section, we'll check with the RFM69HCW to see
  // if it has received any packets:
  if (radio.receiveDone()) // Got one!
    // Print out the information:
    Serial.print("received from node ");
    Serial.print(radio.SENDERID, DEC);
    // The actual message is contained in the DATA array,
    // and is DATALEN bytes in size:
    for (byte i = 0; i < radio.DATALEN; i++)
      Serial.print((char)radio.DATA[i]);
    // RSSI is the "Receive Signal Strength Indicator",
    // smaller numbers mean higher power.
    Serial.print("], RSSI ");
    Serial.println(radio.RSSI);
    // Send an ACK if requested.
    // (You don't need this code if you're not using ACKs.)
    if (radio.ACKRequested())
      radio.sendACK();
      Serial.println("ACK sent");
    Blink(LED,10);
void Blink(byte PIN, int DELAY_MS)
// Blink an LED for a given number of ms
  digitalWrite(PIN,HIGH);
  delay(DELAY_MS);
  digitalWrite(PIN,LOW);
