Arduino Nano clone and Driving Servo with Servo library
I am working on the Small project which has 4 continuous rotating Servo
To drive the servos I am using Arduino Nano clone and the ServoLibrary
The PWM pins I am using is D5,D6,D9 and D10
To use the Servo Library the above Pins Map to pin 8,9,12, 13 (from the Diagram shown on http://kiwitricopter.blogspot.com/2012/10/arduino-xbee-receiver-arduino-nano-v30.html)
When I Use Servo.writeMillisecond function nothing happened to the Servo.
Also when I connect to D9 the servo automatically starts rotating even when I haven't attached them in the program.
I want to confirm if the pins i am using are correct, or if the servo lib does not work with Arduino nano.
#include <Servo.h>
servo myServo
  myServo.attach(9)
  myServo.writeMiliseconds(1600)
void loop
Regards
Saurabh
The Servo library uses any pins, not just PWM.
Connect the ground first, maybe you have it floating?
THanks MarkT,
I was confused about the pin Number now all sorted, Thanks for the Reply.
Regards
Saurabh
