Arduino Nano (clone) + DK electronics NANO Ethernet Shield V1.0 (ENC28J60)
I have a Arduino Nano (clone CH340 ; working perfectly) + I just bought a DK Electronics NANO Ethernet Shield V1.0 (ENC28J60):
I inserted the shield, installed the classic UIP Ethernet Library:
and uploaded many different examples, but it does not work.
I tried direct connection to PC, connection with a home router, double checked the IP / DHCP parameters. Both don't recognize the device.
Is there a trick to make it work?
B
PS: I have tried many power supply units, so I don't think this is the problem. Moreover the orange and green LEDs of the Ethernet shield blink (but a little bit too randomly).
PS2: Linked topic: Ethershield V1.1 ENC28j60 problem - Networking, Protocols, and Devices - Arduino Forum
try to set pin 7 HIGH. it is connected to reset of the enc28j60 on the shield.
try the Ethernet library WebClient example. change the include to UIPEthernet and comment out the hardwareStatus() test
Thanks @Juraj for your answer. Which pin 7?
Digital 7 (pin 10) or Digital 4 (pin 7)
Would you have a link to be sure to use the right sketch?
Thanks in advance!
blahop:
Thanks in advance!
the pin labeled D7
https://www.arduino.cc/en/Tutorial/WebClient
Hi
Did you found solution for this problem ?
I had the same issue and I've tried this approach
https://www.mikrocontroller.net/topic/477142#5899322
and for me this worked, now me shield work perfectly fine and it get IP assigned via dhcp
hope this helps you
Hubert26:
Hi
hope this helps you
Thanks a lot, for me this worked!! Also my ENC28J60 shield was defective.
