Arduino Nano + Ethernet shield ENC28J60
Hello.
I found, tried and works. Thank you.
How to do to be protected by a password? Basic Authentication?
// Watch video here: https://www.youtube.com/watch?v=M4mVDnlnzSA
// UIP is a proper library for Arduino Nano Ethernet shield
// NOTE: UIPEthernet library is not needed if you are using Arduino UNO/Duemilanove/Mega/etc.
// UIPEthernet library is used for Arduino Nano Ethernet Shield
#include <UIPEthernet.h> // Used for Ethernet
// **** ETHERNET SETTING ****
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0D, 0x78, 0xEE  };
// Change the IP below to your subnet if you have any issues
//    IPAddress ip(192, 168, 0, 115);
IPAddress ip(192, 168, 1, 115);
EthernetServer server(80);
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.print("IP Address: ");
  Serial.println(Ethernet.localIP());
  // listen for incoming clients
  if (client)
    Serial.println("-> New Connection");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected())
      if (client.available())
        char c = client.read();
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank)
          client.println("<html><title>Hello World!</title><body><h3>Hello World!</h3></body>");
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r')
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(10);
    // close the connection:
    client.stop();
    Serial.println("   Disconnected\n");
Your topic has been moved to amore suitable location on the forum as it does not seem to relate to IDE1.x.
I unfortunately can't answer your question.
please use the EthernetENC library.
there is no support for authentication. authentication is a matter of application protocols.
you could try this library for HTTP server
Hello.
I've already solved. The EthernetENC.h library works.
My IP camera is on IP 192.168.1.200
They need ping on her.
ICMPPING.H library doesn't work.
Don't you know about another library that works?
Thank you.
d:\ARDUINO+Arduino projekty\libraries\Arduino-Ping-master/ICMPPing.h:12:10: fatal error: utility/w5100.h: No such file or directory
#include <utility/w5100.h>
