Hi sorry if this might be a repetitive question but all of a sudden when i try to upload any code the arduino nano every board it compiles the sketch fine but its stuck on uploading. When its stuck, i try to press the upload button again and this is the error i get (otherwise if i don't do anything it will remain in "uploading forever":
Arduino: 1.8.13 (Windows 10), Board: "Arduino Nano Every, None (ATMEGA4809)"
Sketch uses 2830 bytes (5%) of program storage space. Maximum is 49152 bytes.
Global variables use 177 bytes (2%) of dynamic memory, leaving 5967 bytes for local variables. Maximum is 6144 bytes.
Forcing reset using 1200bps open/close on port COM5
processing.app.debug.RunnerException
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:152)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:77)
at processing.app.SketchController.upload(SketchController.java:732)
at processing.app.SketchController.exportApplet(SketchController.java:703)
at processing.app.Editor$UploadHandler.run(Editor.java:2055)
at java.lang.Thread.run(Thread.java:748)
Caused by: processing.app.SerialException: Error touching serial port 'COM5'.
at processing.app.Serial.touchForCDCReset(Serial.java:107)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:136)
... 5 more
Caused by: jssc.SerialPortException: Port name - COM5; Method name - openPort(); Exception type - Port busy.
at jssc.SerialPort.openPort(SerialPort.java:164)
at processing.app.Serial.touchForCDCReset(Serial.java:101)
... 6 more
An error occurred while uploading the sketch
sorry if this is a repeated thread but i've been searching for 2 days now and cant find a solution for this. Thanks
