Hello. I downloaded ch340g driver to my arduino nano. But when I try to upload code I see the same errors.
vrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Farid\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM5
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x5f
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x5f
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x5f
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x5f
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x5f
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x5f
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x5f
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x5f
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x5f
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x5f
avrdude done. Thank you.
Failed uploading: uploading error: exit status 1
How can I solve this?
That indicates that you're using the "328P" option under tools / processor in the IDE. Try the "old bootloader" option. If that also fails, you might have a Nano with 168 so try that option.
And if that fails as well, please post a link to the Nano that you bought.
If that is a reply to my post, I did not ask for a picture but a link. If it's a picture, make sure that the print on the main chip is readable; it might not be an Atmel/Microchip IC.
OOPS, missed the post by ptillisch When you press and release the reset button on your board, does the onboard L-LED flash a short flash or a few quick flashes; I'm not referring to the blinking of the LED with 1 second interval.
