Arduino nano rp2040 connect - not shown on any port
Im using an original arduino nano rp2040 connect for simple projects. It was working fine with projects such as using a KY-038 sound sensor and using the BLE module.
After i uploaded a code from tinkercad to the nano it uploaded the code but then it stopped showing on any port after i disconnected it and connect it again via usb.
I have tried:
- disconnecting it, pressing the reset button, connecting it to pc, then trying to upload the blink schedule. (doesn't work as it doesn't appear in any port or similar.)
- checked the device manager to try update the drivers and it says that it has all correct drivers (On device manager says "Unkown USB Device (Device descriptor request failed))"
- double pressing the rest button
The red led on the board is blinking.
The code is the following:
#define PIN 2	 // input pin Neopixel is attached to
#define NUMPIXELS      12 // number of neopixels in strip
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
int delayval = 100; // timing delay in milliseconds
int redColor = 0;
int greenColor = 0;
int blueColor = 0;
  // Initialize the NeoPixel library.
  pixels.begin();
  setColor();
  for (int i=0; i < NUMPIXELS; i++) {
    // pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
    pixels.setPixelColor(i, pixels.Color(redColor, greenColor, blueColor));
    // This sends the updated pixel color to the hardware.
    pixels.show();
    // Delay for a period of time (in milliseconds).
    delay(delayval);
// setColor()
// picks random values to set for RGB
void setColor(){
  redColor = random(0, 255);
  greenColor = random(0,255);
  blueColor = random(0, 255);
Please, help me
This posting on the forum may help to solve your problems.
Just look at post #6 by Dozie.
Thank you so much!! For real.
The solution from the post you told sent me to this link to reset the firmware and worked like a charmed!
