Hi I have some problems about connecting arduino nano with NRF24L01 module. and when I check the serial monitor on receiver side it only show the time stamp running and no any other texts.
P.
P.
The Arduino cannot power that module. The Arduino a power supply it is not! You need to power the NRF24L01 with an external power supply. Be sure to connect the grounds.
I use homemade versions of these adapters with good success.
Robin2's simple rf24 tutorial is what I used to get my radios to work. There is a program to test the physical (wired) connection between the radio module and its connected processor. See reply #30.emphasized text
Thanks for the advice @groundFungus
Actually I have already use the adapter but 8 will check that tutorial
Thank you!
