Simple nRF24L01+ 2.4GHz transceiver demo
Introduction
The nRF24L01+ 2.4GHz transceiver modules are cheap and very effective but I have come across a few Threads in which people were having trouble with them so I thought it might be useful to gather together in one place a basic step-by-step sequence for getting them to work.
EDIT 03 Feb 2021 - For this Tutorial install Version 1.1.7 of the RF24 library (available with the Arduino Library Manager). More information in Reply #30.
Edit 29 Aug 2016. I have today downloaded and successfully tested all 3 pairs of programs with Arduino IDE 1.6.3 - 2 small corrections were needed for SimpleTxAckPayload.ino
Edit 06 Sep 2017 2016 (oops). Modified examples 1 and 2 to listen on Pipe 1 in accordance with the text
Edit 18 Mar 2017 Added Reply #29 with a simple program to check the connection with the Arduino
TMRh20 version of the RF24 library
This tutorial uses the TMRh20 version of the RF24 library which fixes some problems in the earlier ManiacBug version. Unfortunately, however, TMRh20 did not think to give his version a different name so it can be difficult to be certain which one is on your PC. If, before reading this, you have downloaded and installed the RF24 library the simplest thing may be to delete all traces of it and then download and install the TMrh20 version. Note that the demo programs will NOT work with the ManiacBug version of the library.
nRF24L01+ module pin connections
The nRF24 modules that I am using look like this.
With the pins uppermost and the antenna on the right hand side the pin connections are
Arduino connections
Because the nRF24s use SPI to communicate with the Arduino they must use Arduino pins 13, 12 and 11 (SCK, MISO and MOSI). It is also necessary to connect the CSN and CE pins and any of the Arduino I/O pins can be used for them. However for demo purposes it seems easiest to use pins 10 and 9 so that all 5 connections are adjacent on pins 13 to 9. I use some female-male jumper wires to connect to the nRF24 for test and development. The jumper wires come as a piece of ribbon cable and if you separate a piece with 5 wires and allocate the wires to suit the Arduino pins it is very easy to connect and disconnect the nRF24 from the Arduino without getting the connections mixed up.
If you are using pins other than 10 and 9 for CSN and CE you must still set pin 10 for OUTPUT to ensure that the Uno acts as the SPI master.
Powering the nRF24L01+ module
The nRF24 modules require a 3.3v power supply. Be careful NOT to connect the VCC pin to a 5v power supply. I have found that they work satisfactorily when connected to the 3.3v pin on my Unos.
It is recommended to plce a 10µF capacitor across VCC and GND as near to the module as possible and I have found this essential when I made some units with an Atmega328 chip on a breadboard. The capacitor stabilizes the power supply for the module. However I have not found it necessary to use a capacitor with my Uno (or Mega). But if you believe you have followed all the other instructions correctly and are having problems it would certainly be a good idea to install a capacitor.
Resetting the nRF24
It seems that on some occasions the nRF24 does not reset after a new program is uploaded to the Arduino. This can prevent the program from working properly. If you think that is the case then disconnect the Arduino from the USB cable and reconnect it.
Some of the jargon explained
Because the nRF24s are transceivers they can obviously transmit and receive. To try to avoid confusion I will assume that you are using one them (which I will refer to as TX or "master") to transmit and another one (RX or "slave") to receive.
Like a lot of other equipment (WiFi and Bluetooth, for example) the nRF24L01+ modules broadcast on the 2.4GHz band. The precise frequency is determined by the channel that is selected. Both TX and RX must use the same channel. The default channel for the RF24 library is 76.
When the TX sends a message every RX listening on the same channel will receive the message. The TX includes an "address" in the message and the RX will ignore messages that do not have its address. The address is similar in concept to a phone number except that you cannot easily change the number of your phone. The address is a 5 byte number.
The nRF24L01+ modules can listen on any or all of 6 "pipes". Unfortunately in some RF24 demo programs the variable that is used to hold the address is given the name "pipe" even though pipes and addresses are quite different. For the purpose of this tutorial I will only be using one pipe (pipe 1) for listening. Note that pipe 0 is the only writing pipe. It is possible to listen on pipe 0 but it is simpler to leave that excusively for writing.
The 6 pipes allow an nRF24 to listen for messages from 6 other devices with 6 different addresses. But those devices may not transmit at the exact same time.
Radio interference
Note that if 2 or more TXs transmit at the same time on the same channel they will interfere with each other and the message will not be receivable. That is why an NRF24 cannot receive messages on its 6 pipes at the same instant.
Messages will also be garbled if (say) a nearby Wifi system transmits at the same time on the exact same frequency.
However each individual transmission is very short (a few millisecs) so that it is unlikely that the transmission from your TX will overlap with something else.
Edit 14 Oct 2016 -- It has been pointed out that this is not accurate. I am leaving the erroneous text so that people who may already have read it will understand the changes
Data is sent in 32 byte packets
The nRF24L01+ modules transmit data in 32 byte packets. If you only want to send a few bytes the RF24 library will automaatically pad out the message with \0 chars. If you attempt to send more than 32 bytes it will be transmitted as a number of packets. For this tutorial I will not be sending more than 32 bytes. Also, I do not intend to cover the dynamic payload feature which allows the user to select a smaller packet size to reduce transmission time.
Revised version
Data Packets
The nRF24L01+ modules can transmit a maximum of 32 bytes in a single message. If you need to send more you will need to break it into a number of separate messages. For this tutorial I will not be sending more than 32 bytes.
There are two modes of operation {A} a fixed payload size which defaults to 32 bytes and can be changed with setPayloadSize() and {B} a dynamic payload mode which is chosen with enableDynamicPayloads(). The dynamic payload mode is automatically applied when you choose the ackPayload feature (see Example 2). You can check the payload size with getDynamicPayloadSize().
When using dynamic payloads you must ensure that you read all the bytes that are received or the communication will break down.
Data validation
The nRF24s automatically include sophisticated systems to identify whether the data received matches the data that was sent. If the data is not received correctly the RX will not show data available() and will not send an acknowledgment. That means the TX will consider the transmission to have failed. You will see in the example programs that the TX is instructed automatically to retry the transmission up to 5 time before giving up. (The max is 15).
In your RX code you can therefore assume that if data is available() it will be correct.
Also note that, unlike Arduino Serial communication, when the RF24 library shows data as available() it means that the entire mesage has been correctly received.
Program style
In the example programs I have tried to use the same style that I used in Serial Input Basics and in Planning and Implementing a Program
By arranging the parts into small functions it should be easy to incorporate them into other programs.
Continues in next Post
nRF24L01's not communicating
NRF24L01+PA+LNA dont work (Arduino Nano & ELEGOO Mega2560 R3)
Nrf24l01 module not working
Problem with NRF24
Simple signal wire over 5-7m distance
Problem with NRF24L01 receiver with Arduino Nano
Basic NRF24L01 sketch
RF24 transmit/receive Basics
NRF24 Basic problem
NRF24 fails to send data
Problem with transmitting data via nRF24l01
My nrf problem (external antenna) (somethings not working)
RC Car DC motor code
Arduino nano with nrf24l01
NRF24L01+PA not working
Can I use an esp32 as an nrfl01?
Replacing USB/Serial data transmission with NRF24L01 - radio.read problem
nRF24L01, radios work fine, need data type help
NRF24 not receiving. Help needed
[NRF24L01] Trying out and debugging Robin2's SimpleRX.ino and SimpleTX.ino
I cant get my NRf24's to work
Nrf24l01 receiving random data
Arduino, nrf24l01, screen, RGB
Nrf24 bidirectional
NRF24L01 module not connecting?
Brand New NRF24, Broken?
nRF24L01 not communicating
Issues in provided code for nRF24L01
Nrf24l01 not communicating with my arduino micro
Problem in 2 way comunication between nrf24l01+
NRF24L01 can't manage to send information
NRF24L01+ not working on Leonardo
2 nRF24L01 won't transmit or receive, but seem to be functional
Arduino + LCD + nRF24L01
Question about nrf24l01+pa+lna board with Mega 2560(RX) and UNO(TX))
Nrf24 init failed even with correct connections and same code?
Help with sending data from 2 tx module to one RX module
Nrf24l01 arduino doesnt work
NRF24l01 send and receive help
How to get nRF24 module to work
NRF24L01+PA+LNA not Working
Transceivers that actually work
Nrf24l01 cant communicate with each other
ATmega328P microcontroller and nRF24L01 no serial data received
Problem with nrf24l01 acknowledgements
Problems with 2.4g wireless system
nRF24L01P+PA+LNA always receiving
How do you wirelessly control a 360 degree servo motor with a potentiometer using nRF24L01+ chips between 2 Arduino Nanos?
Problem using NRF24
Help Needed with my NRF24L01+ modules
Help - NRF24L01 Random Receivings/ No Show
Need help with NRF24L01
Help with nRF24L01 for RC Airplane!
Need a platform to make, test, and code for a digital mockup of arduino hardware. Should it be Wokwi, Fritzing, Flowcode, or Something Else?
NRF24L01 not working? / omg solved but i have another question
Nrf24l01 one servo and one dc moter(L298n) need code
Relocate thermostat wirelessly
NRF24L01 PA + LNA impossible to get to work
Simultaneous servo and esc control with NRF24l01 over two servos
NRF24L01+ working but only without antenna
nRF24L01 module check if transmitter is responding
Powering nrf24lo1+pa
Arduino with nrf2401 module
Possibility control nrf24l01 by handy andremote control another nrf24l01
Latching Button Code not Working over NRF24L01
Cant get NRF24L01+ to work with Arduino Mega
Help with project from beginner!
nRF24L01 not transmitting
Uno to Pro Micro with nRF24L01
NRF24L01 and MFRC522 using SPI
Inactive accounts
nRF24L01+ ack fallisce sempre con dati ricevuti, pipe corrette?
No communication between Nano and Mega using nRF's despite using a capacitors
NRF24l01 receiving problem
Code for water level indicator
NRF24L01 Bidirectional Communication
Nrf24l01 works with arduino nano but not with uno
nRF24 antennas not working
Basic NR24RFL01 and arduino" error message"
Bionic Arm for my physically disabled teacher
Seperating data from nRF24L01 received 2
Arduino nrf24l01 AckPayload problem
How do i use the accellstepper() library, run() to accelerate but don't decelerate? decelerate/accelerate only if the speed changes
NRF24L01 Not Working
NRF24L01 works on nano but not on uno
NRF24l01 broken or I'm just bad?
I made a project to control servo motor wirelessly using potentiometer using nrf24l01. But the circuit didn't work properly. I don't know why, here's
Nrf2401 RC transmitter and receiver
Why nRF24L01 stopped working?
Serial read data from labview to another arduino wirelessly
Remote Control Sailboat RF transmitter and receiver
Urgently Need Help!
Dark Ride - Sabertooth 2x60 with nRF24l01 transceiver
Nrf24lo1 + PA connection to arduino pro mini 5v
Issue with nRF24L01 module and arduino uno
Question about data type received by NRF24L01
nRF24L01 receiving gibberish data
Using nRF24L01 to create arudino transmitter and receiver
NRF24L01 not working with arduino uno and nano
Trouble connecting nRF24L01 wireless module
nRF24L01 Wiring with 10 Pins
Share tips you have come across
How to establish a bi-directional binary communication system using two arduinos
Nrf24l01+pa+lna
NRFL01+ problems
NRF24L01+ for RC Car
2 NRF24L01s not communicating properly
Send and receive Accelerometer Data from ADXL 335 through NRF24l01
Cant figure out how to send joystick data through the NRF24L01
KY-040 with the STM32F103C8T6
Breadboard Adapter
Arduino and NRF24lo1 code HELP!
NRF24l01 not receiving (or transmitting?)
How to decoding rf remote 433 by NRF24L01
Wireless Communication from mutliple arduino to a single arduino
Telemetry using nrf24, arduino and pixhawk
Having trouble with my nrf24l01s
Nrf24l01 problem occured
Help with NRF24l01
Nrf4l01 not working still
Receiving '0' value in NRF24l01 receiver, whereas transmitter sending different int values. Need urgent help please!
NRF24L01+ servo hold position with joystick
Very weird NRF24L01
This code doesn't work. HELP
Arduino mini pro and nrf24L01 not working plaese help
nRF24 modules just won't work, struggling with code
NRF24L01 communication
NRF24L01 Communication Problem
Radiohead - examples not working
Supplying MPU6050 data to a second Arduino using bluetooth module
Help to correct the code
Nrf24l01 i can't add
Trouble with nRF24 Modules
Problems with the NRF24L01+ communication
Control relay module using nRF24l01, with using push button as toggle switch
Arduino works with nRF24L01 only when undervolted
NRF24L01 wont work with my mega
nRF24L01+ Not Working Correctly
NRF24L01 issues and won't work for whatever reason
nRF24l01 not working
Wireless advice
nRF24L01+ is communicating with Arduino but not other nRF24L01+
Not sure if previous version of library is being installed
Can't use arduino mega for nrf24l01+
Error with transmitter and receiver
NRF24 module fails to connect
Nrf24l01 saya tidak berfungsi, padahal pernah berfungsi satu kali, setelah itu tidak berfungsi sampai sekarang. Apakah penyebabnya?
NRF24 receiving garbage
Pls someone help me with radiocontrol !
NRF24l01 not receiving data
Problems with nrf24l01 + pa lna
Problems with nRF24L01 pair
Issues getting NRF24L01 to communicate
(SOLVED) Not showing any error or message when using NRF24L01
Помогите пожалуйста (я не знаю категорию)
nRF24L01 + PA + LNA Capacitor choice
Testing RF24L01 getting same results on many moduals
Wireless data exchange between two arduinos using NRF24L01
Using OV7670 camera code
NRF24L01 Transceiver Not Working
Convert ascii to int
I can't receive data with NRF24! [Please help]
nRF24LO1 project stopped working
NRF24 Modules Not Working
nRF24L01 not receiving messages from multiple slaves
Communicating between two arduinos using nrf24lo1 radio modules
Can't get NRF24L01+ to work - hardware issue?
Nrf24l01 Multiple channels
I would like to know how to control 2 rs775 dc motor and a servo using a nrf24l01 receiver and transmitter
How to control two servo motor each with a potentiometer controlled wirlessly through NRF24L01 and Arduino uno?
Question about NRF24L01 transceiver need help please
Using my NRF24 module!
Do you like the new forum?
Need help with LCD and nRF24L01+
Can not get NRF24L01 to work with 2 Nanos
NRF24 communication problem
Hardware advice for wireless (& sound-reactive) LED system
NRF24L01 bi-directional communication[opinion needed]
Communication between two nRF24L01+PA
Working with the Nrf24l01
Troubleshooting help for "Simple nRF24L01+ 2.4GHz transceiver demo"
Need help with adding nRFL01 communication to my code
Half duplex nrf24l01
Communication between 2 arduino's
Make led blink using two nrf24l01
NRF24L01 on atMega328p, RC-car
Nrf24l01 two way communication
NRF24 Basic problem
I am making a gesture controlled car using mpu6050 and nrf module and l293d ic with motors it is totally not working plz help
Having problem with NRF24l01 and arduino nano
NRF24 Basic problem
Creating remote version of code using NRF24
Can't make simple 2-way nrf24l01 code to work. Examples work fine, so shouldn't be a hardware issue
Send data from python by nRF24L01 to arduino receive data by nRF24L01
Help with Proof of Concept BT/Arduino Project
Need help my code dost work properly
Python/Raspi Sketch für nRF24L01
Having problem with nRF24
NRF24L01 module doesn't work
Using a nrf to send button signals to control a servo
Radio.available true even if NRF24 disconnected
nRF24 Single Variable Transmission
Nrf24l01 Not Starting with radio.begin(CE, CSN)
Should I use nRF24L01 or ESP8266 for wireless communication in RC Car?
WayinTop NRF24L01+ using RF24 Library
Help with nRF24 communications
Nrf24l01 not transmitting a string
Problem receiving data using nRF24L01
Store txt as variable
Remote control car radio receiving issues
Accelstepper and RF24 compatibility
Nrf24L01 Trying to add more buttons and Leds using states Help Please
Slow reaction time using Arudino Pro Mini with NRF24L01 Transceivers
nRF24l01 Not Writing
Whats wrong with this RC code?
nRF24L01 data synch problem
Need some help with ADT7420 data and communication with NRF24L01
Simple one way transmission
The following pair of programs sends a simple message "Message N" from the TX to the RX where N is a number that increments from 0 to 9 so that you can see that successive messages are sent and received.
SimpleTx.ino
// SimpleTx - the master or the transmitter
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define CE_PIN   9
#define CSN_PIN 10
const byte slaveAddress[5] = {'R','x','A','A','A'};
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
char dataToSend[10] = "Message 0";
char txNum = '0';
unsigned long currentMillis;
unsigned long prevMillis;
unsigned long txIntervalMillis = 1000; // send once per second
    Serial.println("SimpleTx Starting");
    radio.begin();
    radio.setDataRate( RF24_250KBPS );
    radio.setRetries(3,5); // delay, count
    radio.openWritingPipe(slaveAddress);
    currentMillis = millis();
    if (currentMillis - prevMillis >= txIntervalMillis) {
        send();
        prevMillis = millis();
void send() {
    bool rslt;
    rslt = radio.write( &dataToSend, sizeof(dataToSend) );
        // Always use sizeof() as it gives the size as the number of bytes.
        // For example if dataToSend was an int sizeof() would correctly return 2
    Serial.print("Data Sent ");
    Serial.print(dataToSend);
    if (rslt) {
        Serial.println("  Acknowledge received");
        updateMessage();
    else {
        Serial.println("  Tx failed");
void updateMessage() {
        // so you can see that new data is being sent
    txNum += 1;
    if (txNum > '9') {
        txNum = '0';
    dataToSend[8] = txNum;
SimpleRx.ino
// SimpleRx - the slave or the receiver
#include <SPI.h>
#include <RF24.h>
#define CE_PIN   9
#define CSN_PIN 10
const byte thisSlaveAddress[5] = {'R','x','A','A','A'};
char dataReceived[10]; // this must match dataToSend in the TX
bool newData = false;
    Serial.println("SimpleRx Starting");
    radio.begin();
    radio.openReadingPipe(1, thisSlaveAddress);
    radio.startListening();
    getData();
    showData();
void getData() {
    if ( radio.available() ) {
        radio.read( &dataReceived, sizeof(dataReceived) );
        newData = true;
void showData() {
    if (newData == true) {
        Serial.print("Data received ");
        Serial.println(dataReceived);
        newData = false;
Edit 20 Jul 2018 ...
When working properly the Rx program should show "Data received Message n" in which n varies from 0 to 9. This should be printed at about one second intervals.
if all you see is "Data received" repeating much more quickly then there is a problem - most likely theArduino is not communicating properly with its nRF24. See Reply #29 for more info
Two-way transmission
If the slave is required to send data back to the master it would seem necessary for the two devices to swap roles. Among other things that will mean that the "master" will need an address as well as the slave. The question of timing also needs to be considered - for example, how long should the master continue listening for the reply from the slave? And, if the slave is trying to write rather than listen it may miss a transmission from the master.
Two-way transmission using the ackPayload concept
The complications of swapping roles can be completely avoided by using the ackPayload concept. The idea is that the slave puts data in the ackPayload buffer BEFORE it receives a message from the master and then the data in the ackPayload buffer is sent automatically as part of the normal acknowledgment process without your code needing to make the devices swap roles.
The ackPayload concept can only be used when the amount of data transferring from slave to master is 32 bytes or less.
It also means that the data sent from the slave is always a step behind the data received by the slave. For example the ackPayoad cannot take account of the data received in the message for which it is the acknowledgment.
ackPayload example
In this example the slave will send a pair of numbers back to the master.
// SimpleTxAckPayload - the master or the transmitter
#include <SPI.h>
#include <RF24.h>
#define CE_PIN   9
#define CSN_PIN 10
char txNum = '0';
int ackData[2] = {-1, -1}; // to hold the two values coming from the slave
    Serial.println(F("Source File /mnt/sdb1/SGT-Prog/Arduino/ForumDemos/nRF24Tutorial/SimpleTxAckPayload.ino"));
    Serial.println("SimpleTxAckPayload Starting");
    radio.begin();
    radio.enableAckPayload();
    radio.setRetries(5,5); // delay, count
                                       // 5 gives a 1500 µsec delay which is needed for a 32 byte ackPayload
        send();
    showData();
void send() {
    bool rslt;
    if (rslt) {
        if ( radio.isAckPayloadAvailable() ) {
            radio.read(&ackData, sizeof(ackData));
            newData = true;
        else {
            Serial.println("  Acknowledge but no data ");
        updateMessage();
    else {
void showData() {
        Serial.print("  Acknowledge data ");
        Serial.print(ackData[0]);
        Serial.print(", ");
        Serial.println(ackData[1]);
        newData = false;
    txNum += 1;
    if (txNum > '9') {
        txNum = '0';
SimpleRxAckPayload.ino
// SimpleRxAckPayload- the slave or the receiver
#include <SPI.h>
#include <RF24.h>
#define CE_PIN   9
#define CSN_PIN 10
int ackData[2] = {109, -4000}; // the two values to be sent to the master
    Serial.println("SimpleRxAckPayload Starting");
    radio.begin();
    radio.writeAckPayload(1, &ackData, sizeof(ackData)); // pre-load data
    getData();
    showData();
void getData() {
        updateReplyData();
        newData = true;
void showData() {
        Serial.print(" ackPayload sent ");
        Serial.print(", ");
        newData = false;
void updateReplyData() {
    ackData[0] -= 1;
    ackData[1] -= 1;
    if (ackData[0] < 100) {
        ackData[0] = 109;
    if (ackData[1] < -4009) {
        ackData[1] = -4000;
    radio.writeAckPayload(1, &ackData, sizeof(ackData)); // load the payload for the next time
Edit 05 Dec 2016 to correct the wrong pipe reference in the function updateReplyData(). Apologies for any confusion.
Edit 18 Mar 2017 - see Reply #17 for a version that works with multiple slaves
Edit 21 Feb 2019 to change setup() in RxAckPayload so the payload is uploaded after startListening()
Edit 20 Jan 2020 to increase delay in setRetries() to allow for longer ackPayloads. Details in section 7.4.2 of the Nordic nRF24L01+ datasheet
Two-way transmission by swapping roles
I have not found a need for this approach but I will illustrate it in case it is useful for someone else.
In this example the two nRF24s (master and slave) spend most of their time listening and only switch to talking for the minimum time needed to send a message. As with the ackPayload example the slave only sends a message in response to a message from the master.
MasterSwapRoles.ino
// MasterSwapRoles
#include <SPI.h>
#include <RF24.h>
#define CE_PIN   9
#define CSN_PIN 10
const byte masterAddress[5] = {'T','X','a','a','a'};
char txNum = '0';
int dataReceived[2]; // to hold the data from the slave - must match replyData[] in the slave
    Serial.println("MasterSwapRoles Starting");
    radio.begin();
    radio.openReadingPipe(1, masterAddress);
    send(); // to get things started
    prevMillis = millis(); // set clock
        send();
    getData();
    showData();
void send() {
        radio.stopListening();
            bool rslt;
        if (rslt) {
            updateMessage();
        else {
void getData() {
        newData = true;
void showData() {
        Serial.print(dataReceived[0]);
        Serial.print(", ");
        Serial.println(dataReceived[1]);
        newData = false;
    txNum += 1;
    if (txNum > '9') {
        txNum = '0';
SlaveSwapRoles.ino
// SlaveSwapRoles
#include <SPI.h>
#include <RF24.h>
#define CE_PIN   9
#define CSN_PIN 10
char dataReceived[10]; // must match dataToSend in master
int replyData[2] = {109, -4000}; // the two values to be sent to the master
    Serial.println("SlaveSwapRoles Starting");
    radio.begin();
    radio.openWritingPipe(masterAddress); // NB these are swapped compared to the master
    radio.openReadingPipe(1, slaveAddress);
    getData();
    showData();
    send();
void send() {
            bool rslt;
            rslt = radio.write( &replyData, sizeof(replyData) );
        Serial.print("Reply Sent ");
        Serial.print(replyData[0]);
        Serial.print(", ");
        Serial.println(replyData[1]);
        if (rslt) {
            Serial.println("Acknowledge Received");
            updateReplyData();
        else {
            Serial.println("Tx failed");
        newData = false;
void getData() {
        newData = true;
void showData() {
    replyData[0] -= 1;
    replyData[1] -= 1;
    if (replyData[0] < 100) {
        replyData[0] = 109;
    if (replyData[1] < -4009) {
        replyData[1] = -4000;
End of Tutorial
...R
Edit 02 September 2019 to remove reference to broken link
Reserved for future use
...R
I have the Due and 2560 boards but no Unos. I suppose these instructions apply for them too?
I wish I could find something similar for STM32F407 Discovery boards, too.
Some thing is wrong with RF24 lib.
Ever since I updated my RF24 library (and Arduino IDE) to the latest, the nRF24L01+ seemed to have stopped working.
They were working fine previously.
My setup is Mega 2560 R3 with one nRF24L01+ (with CE and CSN as 9 and 10 as in code)
and the other is Nano 3.0 with another nRF24L01+ (CE & CSN = 9 and 10).
I powered the radios with on board 3.3v regulator, no extra caps and it was all working fine.
Just needed to update/change my code recently and thats when it happened. Compiling my code with the new library seemed to have caused the trouble (or perhaps the IDE updated SPI.h - Arduino 1.6.12).
So I came to this thread, and copy pasted the examples for test. Still no communication.
Tried the many examples included in RF24 lib (pingpair, getting started, call handling, transfer etc)
Nothing seems to work.
BTW the radios, I bought from Chinese store online, but the Mega and Nano are genuine (bought from UK).
Just in case Arduino/nordic implemented some anti-pirated checks.
Is anyone else having problems.
burhanmz:
If the previous library was the one of ManiacBug some things are changed so some previous sketch doesn't work.
Take care not to have the two libraries at the same time since the IDE can use the wrong one.
I guess this needs correction :
In the SimpleRxAckPayload.ino sketch , inside the function updateReplyData() the following line,
radio.writeAckPayload(0, &ackData, sizeof(ackData)); // load the payload for the next time
needs to have 1 in place of 0.
Otherwise the Tx module complains of No Data feedback.
I plugged the wire to 3.3 and 5V entry. I didn#t notice any difference.
I reused the simple example.
Here is the code:
#include <SPI.h>
#include <RF24.h>
#define CE_PIN   9
#define CSN_PIN 10
char txNum = '0';
    radio.begin();
        send();
void send() {
    bool rslt;
    if (rslt) {
        updateMessage();
    else {
    txNum += 1;
    if (txNum > '9') {
        txNum = '0';
and
#include <SPI.h>
#include <RF24.h>
#define CE_PIN   9
#define CSN_PIN 10
    radio.begin();
    getData();
    showData();
void getData() {
        newData = true;
void showData() {
        newData = false;
I get:
SimpleTx Starting
And
Data received
Data received
Data received
Apparently the information is not sent by the transmitter.
I have also set-up two nRF's with two Uno's and am trying get the simpleTx and simpleRx one way communication working; it's not working.
I'm using this library:
I've followed Robin2's instructions, added the 10uf capacitor for stabilizing power, and my nRF modules look like the ones in his picture.
Still no luck; i get this on the sender:
SimpleTx Starting
Data Sent Message 0 Tx failed
And this on the receiver:
SimpleRx Starting
Data received Message 0
No errors other wise. Has anyone successfully gotten "Simple one way transmission" working with Robin2's provided SimpleTx and SimpleRx code?
Ali
Thanks for this fantastic guide Robin, having a simple sent/receive program is really useful.
I have a strange issue when trying to use the NRF24L01 radios. I have it all wired up, but whenever my sketch calls the radio.write function the program freezes. I've used Serial.print to debug and can see that the program steps through correctly all the way until it reaches the radio.write call, and then it jut stops working completely.
I've also tried commenting out the radio.write call and the program works fine- obviously it gives a 'Tx failed' response, but that is to be expected.
This error persists in both your example sketch and all of the examples that come with the library.
Do you have any thoughts on what could be causing this? It is doing my head in.
EDIT: I should say that I am powering the radio module with an LM3940 regulator with plenty of bypass and filtering capacitance.
pleas where is the video to this process ?
how can i use three transmitter and one reciever. could you pls explain with new adress format of the tmrh 20 library. iam really confused with new format
Thanks Robin I've read it all but I'm wondering what the output looks like in the Serial monitor.
Is it actually even possible to send messages (master) like 'a' 'b' 'd' 'z', and to read these out in your Arduino (slave) to let your Arduino react to that message and then send a message back to the master.
Hi @Robin2.
I like a lot your samples. I have already worked with NRF24 last year. 3 TX and 1 RX. Each TX with its address and its pipe, so everything works fine.
Now I want to start another project.
The RX node will be an arduino with a SIM800L GSM module. I want it to send to a web page, or with MQTT broker all the data that it receives. It acts as a gateway between NRF24 net and GPRS data.
But my question is about TX nodes. I want to do them in next months, and I don't want to reprogram the TX sketch
For example, I want to put one TX node in my room to get temperature. Two months after, I will put another one that measures wattage and voltage in my home, after another one that measures temperature and humity in the outside.
I want to program my RX gateway node to receive all these packets (different TXs and sizes) and send them to a web server.
The web server (PHP file) will read all data and "understand" it. RX gateway only cast the data. If I add in future another TX node, I have to change only PHP file to understand "another type of information" (see questions)
I have two questions:
  1. does NRF24 RX node listen only one pipe and all of TX nodes writting in that pipe ? (I HAVE TO USE ACK PAYLOADs to know TX that its info has been read)
    Will it be impossible for RX node to get all information ? Imagine 2 nodes --> probably OK, but with 20 nodes ????
  2. My payloads have to be something like this in order to mantain flexibility for future TX nodes:
  • 32 bytes
  • first byte will be the ID of the Node to be "understood" by my PHP page
  • after first byte all data in a row. PHP will be responsible for extract information of the rest of 31 bytes
Have you got any opinion or improvement about this way of transmiting data ?
Regards,
Robin2,
thank your for sample code. each one of them just worked out of the box for the most part. I'm using the nRF24L01 modules with the power amp and external antenna with the base module. I'm using a Mega as the master, one thing to point out for other people how are using the Mega, the pins are in a different location, MISO,MOIS,SCK,CSN are on pins d50-d53.
thanks,
Dan
I thought it would be helpful to add a slightly modified version of the program SimpleTxAckPayload.ino to illustrate how it can be used as a master with two slaves. And, of course, it could be extended to work with several slaves. For this example the slaves should each use the program SimpleRxAckPayload.ino with the address for one of the slaves changed to {'R','x','A','A','B'}. Please note this version does not use any extra pipes compared to the SimpleTxAckPayload program.
MultiTxAckPayload.ino
// MultiTxAckPayload - the master or the transmitter
//   works with two Arduinos as slaves
//     each slave should the SimpleRxAckPayload program
//       one with the adress {'R','x','A','A','A'}
//         and the other with {'R','x','A','A','B'}
#include <SPI.h>
#include <RF24.h>
#define CE_PIN   9
#define CSN_PIN 10
const byte numSlaves = 2;
const byte slaveAddress[numSlaves][5] = {
        // each slave needs a different address
                            {'R','x','A','A','A'},
//~ char dataToSend[10] = "Message 0";
char dataToSend[10] = "ToSlvN  0";
char txNum = '0';
    Serial.println(F("Source File = /mnt/SGT/SGT-Prog/Arduino/ForumDemos/nRF24Tutorial/MultiTxAckPayload.ino "));
    radio.begin();
        // radio.openWritingPipe(slaveAddress); -- moved to loop()
        send();
        // showData(); -- moved into send()
void send() {
        // call each slave in turn
    for (byte n = 0; n < numSlaves; n++){
            // open the writing pipe with the address of a slave
        radio.openWritingPipe(slaveAddress[n]);
            // include the slave number in the message
        dataToSend[5] = n + '0';
        bool rslt;
        Serial.print("  ========  For Slave ");
        Serial.print(n);
        Serial.println("  ========");
        Serial.print("  Data Sent ");
        if (rslt) {
                newData = true;
            else {
            updateMessage();
        else {
        showData();
        Serial.print("\n");
void showData() {
        Serial.print(", ");
        newData = false;
    txNum += 1;
    if (txNum > '9') {
        txNum = '0';
...R
In the last example, it gave me "tx failed" , even the data is received by the slaves...
With the Ackpayload method can you set up different replies depending on what slave has transmitted.
So my example would be I have one device acting as a master in a hub/spoke arrangement, lets supose a master device and slave devices A,B and C
Devices A B and C are monitoring the number of times some one presses a button connected to each device.
every x amount of time each node transmits back to the master the number of times its button has been pressed since the last update.
The master than takes all 3 values and calculates the % each button has been presses, then the next time the slave "checks in" it transmits back to each station its value to be displayed on a LED display.
so A transmits back 50, B 30 and C 20
The master calculates the % as 50,30,20%
next time A transmits back 30, B 20 and C 70.
The master would replay to A update with 50, B with 30 and C with 20 (results one step behind).
If this possible, I know in this case I could send all values back to all and have them work out what is for them but image if it was 100 devices or larger amounts of data.
Cheers
