I work with Arduino Nano boards with ATmega168 processors. I have several and they all seem to work, blinking LEDs as per the sketch and I am fiddling around with Hall effect switches, all is fine. But I also have a 4 digit display with TM1637 driver and I cannot get it to work.
I installed and ran everything conform this:
http://robojax.com/learn/arduino/?vid=robojax-TM1637
The library is found, I cannot compile the test sketch. After I remove the arduino.h inclusion I can compile and upload, but it does not work. Is there some other variant of arduino.h I should have in the library?
BTW, this is the code (of which I remove the include arduino.h line to make it compilable):
#include <Arduino.h>
#include <TM1637Display.h>
// Module connection pins (Digital Pins)
#define CLK 2
#define DIO 3
// The amount of time (in milliseconds) between tests
#define TEST_DELAY 2000
const uint8_t SEG_DONE[] = {
SEG_B | SEG_C | SEG_D | SEG_E | SEG_G, // d
SEG_A | SEG_B | SEG_C | SEG_D | SEG_E | SEG_F, // O
SEG_C | SEG_E | SEG_G, // n
SEG_A | SEG_D | SEG_E | SEG_F | SEG_G // E
TM1637Display display(CLK, DIO);
int k;
uint8_t data[] = { 0xff, 0xff, 0xff, 0xff };
display.setBrightness(0x0f);
// All segments on
display.setSegments(data);
delay(TEST_DELAY);
// Selectively set different digits
data[0] = 0b01001001;
data[1] = display.encodeDigit(1);
data[2] = display.encodeDigit(2);
data[3] = display.encodeDigit(3);
for(k = 3; k >= 0; k--) {
display.setSegments(data, 1, k);
delay(TEST_DELAY);
display.setSegments(data+2, 2, 2);
delay(TEST_DELAY);
display.setSegments(data+2, 2, 1);
delay(TEST_DELAY);
display.setSegments(data+1, 3, 1);
delay(TEST_DELAY);
// Show decimal numbers with/without leading zeros
bool lz = false;
for (uint8_t z = 0; z < 2; z++) {
for(k = 0; k < 10000; k += k*4 + 7) {
display.showNumberDec(k, lz);
delay(TEST_DELAY);
lz = true;
// Show decimal number whose length is smaller than 4
for(k = 0; k < 4; k++)
data[k] = 0;
// Run through all the dots
for(k=0; k <= 4; k++) {
display.showNumberDecEx(0, (0x80 >> k), true);
delay(TEST_DELAY);
display.showNumberDec(153, false, 3, 1);
delay(TEST_DELAY);
display.showNumberDec(22, false, 2, 2);
delay(TEST_DELAY);
display.showNumberDec(0, true, 1, 3);
delay(TEST_DELAY);
display.showNumberDec(0, true, 1, 2);
delay(TEST_DELAY);
display.showNumberDec(0, true, 1, 1);
delay(TEST_DELAY);
display.showNumberDec(0, true, 1, 0);
delay(TEST_DELAY);
// Brightness Test
data[k] = 0xff;
for(k = 0; k < 7; k++) {
display.setBrightness(k);
delay(TEST_DELAY);
// On/Off test
for(k = 0; k < 4; k++) {
display.setBrightness(7, false); // Turn off
delay(TEST_DELAY);
display.setBrightness(7, true); // Turn on
delay(TEST_DELAY);
// Done!
display.setSegments(SEG_DONE);
while(1);
Help is appreciated,
Cheers,
Hugo
