Arduino, need help with crazy interference
    pinMode(7, INPUT);
    pinMode(13, OUTPUT);
    Serial.println(digitalRead(7));
        digitalWrite(13, digitalRead(7));
This is it my code, one wire in pin 7. Touching the wire sets pin 7 to read high. Sometimes just waving my hands around is enough. And simply having my extension cord next to the arduino in a 30cm radius is enough to make it go off (with the wire plugged in). No matter which wire i put, even a short one it still does this. Plugging the arduino in a laptop does not help. Is my arduino busted or is there something bigger at play here? Could I somehow ground the arduino better? It is extremely difficult to test anything at all while this is happening.
Using a leonardo board.
EDIT: putting in a resistor does not change behavior
That's perfectly correct. The way You declared pin 7 it acts as a radio antenna.
Any ideas on how I could fix this? I can't even use the arduino with a protoboard like this
Connect something useful to pin 7, like a sensor, a resistor to Vcc or GND.
For example:
pinMode(7, INPUT_PULLUP); //activate internal pullup resistor
What are you "testing"?
How do You intend to use pin 7? What will be connected to it?
In place of chasing the back side of the problem post an annotated schematic. You might post your code as well.
Unfortunately, this information isn't useful, since we can't know where you "put it in".
I fixed it, I was just confused about the pinout of the component I was trying to connect. I understand now it's important to get the ground right.
