Hi All
I am trying to build a digital display for my EV conversion project using a Nextion display. I am running with an Arduino Uno and a generic CAN to serial converter (MCP2515). I cannot get the CAN messages to display any values on the screen.
Here is what I have tested:
- No issue with CAN bus with devices in car, 60 Ohm across H/L term, 500kB/s speed
- Confirmed MCP2515 is functioning - serial port will display correct values (8MHz clock)
- commented out #NexConfig Nextion file, confirmed Serial port
- Use common ground between Nextion and Arduino, use TX (Arduino) - RX (Nextion) Yellow. One power supply/GND
- Nextion display values correctly when I use directly with Arduino using analogue rotary pot input. Have tested another Nextion display, same issue.
#include <mcp_can.h>
#include <SPI.h>
#include "Nextion.h"
#define CS_PIN 10// varies between boards
#define INT_PIN 2 //varies between boards
MCP_CAN CAN0(CS_PIN);
long unsigned int rxId;
unsigned char len = 0;
unsigned char rxBuf[8];
int soc; // battery pack state of charge
//double packCurrent; // pack current, amps
//double packVoltage; // pack voltage, V
//double packPower; //pack power, kW
Serial.begin(9600); // Start serial comunication at baud=9600
// I am going to change the Serial baud to a faster rate.
delay(500); // This delay is just in case the nextion display didn't start yet, to be sure it will receive the following command.
Serial.print("bauds=115200"); // Set new baud rate of nextion to 115200, but it's temporal. Next time nextion is power on,
// it will retore to default baud of 9600.
// To take effect, make sure to reboot the arduino (reseting arduino is not enough).
// If you want to change the default baud, send the command as "bauds=115200", instead of "baud=115200".
// If you change the default baud, everytime the nextion is power ON is going to have that baud rate, and
// would not be necessery to set the baud on the setup anymore.
Serial.write(0xff); // We always have to send this three lines after each command sent to nextion.
Serial.write(0xff);
Serial.write(0xff);
Serial.end(); // End the serial comunication of baud=9600
if (CAN0.begin(MCP_ANY, CAN_500KBPS, MCP_8MHZ) == CAN_OK)
Serial.println("MCP2515 Initialised Successfully!");
Serial.println("MCP2515 Initialising Failed!");
pinMode(INT_PIN, INPUT); // INT input pin
CAN0.init_Mask(0, 0, 0x07FF0000); // Init mask to allow only 0x6B0 (hex) to pass
CAN0.init_Filt(0, 0, 0x06B00000); // Init filter for 0x6B0 (hex)
Serial.println("MCP2515 Library Mask & Filter Example...");
CAN0.setMode(MCP_NORMAL); // Change to normal mode to allow messages to be transmitted
if (!digitalRead(INT_PIN)) // If pin is low, read the receive buffer
CAN0.readMsgBuf(&rxId, &len, rxBuf); // Read data: len = data length, rxBuf = data byte(s)
if (rxId == 0x6B0) { // Check if received ID is 0x6B0
if (len >= 5) { // Ensure there are at least 5 bytes in the message
soc = 0.5 * rxBuf[4]; // Store byte 4 as an integer in 'soc'.
//packCurrent = 0.1* (((rxBuf[0] << 8) | rxBuf[1])); // -500 because we added 500 in Orion CANbus settings
//packVoltage = 0.1 * ((rxBuf[2] << 8) | rxBuf[3]);
//packPower = 0.001 * packVoltage * packCurrent;
Serial.print("soc.val=");
Serial.print(soc);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.print("ID: ");
Serial.print(rxId, HEX);
Serial.print(" Data: ");
for (int i = 0; i < len; i++) // Print each byte of the data
if (rxBuf[i] < 0x10) // If data byte is less than 0x10, add a leading zero
Serial.print("0");
Serial.print(rxBuf[i], HEX);
Serial.print(" ");
Serial.print(" SOC: ");
Serial.print(soc);
Serial.print(" packCurrent: ");
Serial.print(packCurrent);
Serial.print(" Voltage: ");
Serial.print(packVoltage);
Serial.print(" packPowerkW: ");
Serial.println(packPower);
The value I am attempting to display is state of charge (soc) - in serial monitor the HEX values are converted and are displaying the correct scaled value (82%) but nothing comes through to the display.
Any ideas what I should try next?
