here is a video -
Try to double click directly on the text: Arduino follow me robot.
still not works
Has this ever worked ?
Where did you get this file? Can you send me a link so I can try it.
i dont know i am new to arduino just started using it and when i open it it does not so for me it never worked
file is in the description @blakeblake11
Have you by any chance got the appalling Windows option turned on that hides file extensions ? If so then that may not actually be an .ino file at all and could be named something.ino.wibble for all you know but Windows will display it as something.ino
What is its name shown as if you right click on it and select Properties ?
I can open it here is the code:
//Arduino Human Following Robot
// Created By DIY Builder
// You have to Install the AFMotor and NewPing library Before Uploading the sketch//
// To install the libraries ( first download the AF Motor driver, NewPing and Servo Library zip file //
// then Go to Skecth >> Include Library >> Add .Zip Library >> Select The downloaded zip file >> Done) //
// Contact me on instagram for any question(Insta Id : DIY.Builder)
#include<NewPing.h>
#include<Servo.h>
#include<AFMotor.h>
#define RIGHT A2
#define LEFT A3
#define TRIGGER_PIN A1
#define ECHO_PIN A0
#define MAX_DISTANCE 100
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
AF_DCMotor Motor1(1,MOTOR12_1KHZ);
AF_DCMotor Motor2(2,MOTOR12_1KHZ);
AF_DCMotor Motor3(3,MOTOR34_1KHZ);
AF_DCMotor Motor4(4,MOTOR34_1KHZ);
Servo myservo;
int pos =0;
myservo.attach(10);
for(pos = 90; pos <= 180; pos += 1){
myservo.write(pos);
delay(15);
} for(pos = 180; pos >= 0; pos-= 1) {
myservo.write(pos);
delay(15);
}for(pos = 0; pos<=90; pos += 1) {
myservo.write(pos);
delay(15);
pinMode(RIGHT, INPUT);
pinMode(LEFT, INPUT);
delay(50);
unsigned int distance = sonar.ping_cm();
Serial.print("distance");
Serial.println(distance);
int Right_Value = digitalRead(RIGHT);
int Left_Value = digitalRead(LEFT);
Serial.print("RIGHT");
Serial.println(Right_Value);
Serial.print("LEFT");
Serial.println(Left_Value);
if((Right_Value==1) && (distance>=10 && distance<=30)&&(Left_Value==1)){
Motor1.setSpeed(120);
Motor1.run(FORWARD);
Motor2.setSpeed(120);
Motor2.run(FORWARD);
Motor3.setSpeed(120);
Motor3.run(FORWARD);
Motor4.setSpeed(120);
Motor4.run(FORWARD);
}else if((Right_Value==0) && (Left_Value==1)) {
Motor1.setSpeed(200);
Motor2.setSpeed(200);
Motor3.setSpeed(100);
Motor3.run(BACKWARD);
Motor4.setSpeed(100);
Motor4.run(BACKWARD);
}else if((Right_Value==1)&&(Left_Value==0)) {
Motor1.setSpeed(100);
Motor1.run(BACKWARD);
Motor2.setSpeed(100);
Motor2.run(BACKWARD);
Motor3.setSpeed(200);
Motor4.setSpeed(200);
}else if((Right_Value==1)&&(Left_Value==1)) {
Motor1.setSpeed(0);
Motor1.run(RELEASE);
Motor2.setSpeed(0);
Motor2.run(RELEASE);
Motor3.setSpeed(0);
Motor3.run(RELEASE);
Motor4.setSpeed(0);
Motor4.run(RELEASE);
}else if(distance > 1 && distance < 10) {
Motor1.setSpeed(0);
Motor2.setSpeed(0);
Motor3.setSpeed(0);
Motor4.setSpeed(0);
i know what is the code i already tried opening it with visual code but i wanna know why arduino can open it
it is .ino only
Try uninstalling and re-installing Arduino. The app may be corrupt.
ok will try
once you install the file don't click shop in folder, just click on it in the bottom left hand corner.
well i know this much
are you getting any erorr messages?
reinstalling worked thanks everyone for help
@ak_tech You are very welcome. If you need any other help with your boards and/or software please ask me by PM or mentioning me in your post, so I could help you again if you need help.
